Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
tnttnttnt
Цитата(fantom-2011 @ 23.4.2011, 14:36) *
Там что вентилятор от ВДУ-1201 стоит раз так засасывает. Поставь на вытяжку.
Сегодня на рынке купил EBU 04 по 185 руб\шт. Продавец клялся что оригинал. Посмотрим. smoke.gif
да не то что бы засасывает просто работал болгаркой как раз в сторону аппарата искры летели.В Ебурге дешевле 230р 150ebu04 не найти.
golub
После года простоя, на волне всенародного подъёма в сваркостроении, в условиях тотального дефицита комплектухи, и к началу сезона слепил уродца. Спецом для слабой сети. Бармалей- аля телвин, слип, антистик, аркфорс (регулируемый), Е70- 16х6(Ктр=2,66), 6х16 мм2, 40 Кгц, иксус50N60x2, 150ebu02x3, дроссель альсифер К75- 10 витков, два моста, 470мкфх4, продув 2-х ступенчатый.
Wiew
каков результат, в сравнении с "обычным"?
ZPS
Цитата(Kardinalli @ 21.4.2011, 0:06) *
Ну хоть спираль! Сегодня пришла партия 5-ти ваттных китайских цементников. Взял один новый, разбил - внутри ОБЫЧНЫЙ, 2-х ваттный резистор! Сволочи, вся партия вот такие подделки...
Проволочные идут до определенного номинала, а затем стоит резистор типа на 2W в купе с керамическим гробиком и заливкой (кои служат радиатором) получаем мощность в 5W. А вообще то насчет ненадежности этих самых керамических резисторов речь идет давно на многих форумах. В связи с этим так же давно перешел на баяны из MF-2 и набираю количество резисторов отталкиваясь от нужной мощности соответственно пересчитывая номинал.
golub
Цитата(oleg1ma @ 23.4.2011, 23:32) *
Очень даже симпатичный уродец, среди тутошних красавцев, с какого приборчика корпус?
честно сказать не знаю, т.к. ни морды ни задницы не было в наличии когда брал. Наверно какой нибудь частотомер или около того.
Пока никакого одно тыкание на балконе на жёсткой сети. Результат реальный будет где-то дней через 10. А так на вскидку- поджиг конечно без базара хоть на мп3 хоть на уони, но дуга длинная подзадрачивает.
схема здесь, если кого интересует, правда как всегда ненумерованная и актив не указан, ну это сделает Дантист, думаю, когда вернётся.
обращаю внимание на сетевой выключатель, который коммутирует только зарядный резистор. Правда понадобится две полных группы, но думаю 4 гривни не вопрос.
molotok26
Еще пара вопросов по AVT:
1.Возможно ли применение кольтовских драйверов
2.Валентин Володин рекомендовал для ТГР одно кольцо К20*10*5
без размагничивающей обмотки(журнал Радио №4 2007г)
Возможно применить это в AVT?
gyrator
Ктр=2,66
golub
нет, это как всегда, когда петух в ж... .
Kardinalli
Кстати, по поводу Ктр. У меня трансформатор получается либо с Ктр = 3.3, либо Ктр=2.66.
Что лучше выбрать?
golub
В оригинале в кольте1300 Ктр=3.2 (16х5). Так что на любителя и для задач.
gyrator
Цитата(golub @ 24.4.2011, 8:40) *
нет
Дык, из показанной схемули, другого, применительно к фразе
, не вытанцовывается. В результате-длинная дуга на нормальной сети. Злой петушок видно в попку клюнул. icon_biggrin.gif
golub
петушки я так думаю, добрыми и не должны быть. Собственно что должно вытанцовываться в приведенной схемуле? Глобальное решение проблемы в виде Вашего суперфиксера с Кз больше 0,5? Дык я не Вы- не потяну, да и задача не ставилась влазить в дебри макетирования с нонешним дефцитом комплектующих. Так сказать- слукавил, пошёл проторенной дорогой. Проблем и так хватает, а чем-то работать надо.
sarmat
В самой схеме драйвера с отрицательным смещением. Применение в качестве ТГР возможно сердечника любой конфигурации. Лишь бы выполнял свои функции. Драйвера тоже можно кольтовские, если предпочитаете их оригинальным. Вся соль в этой схеме не в этом. Автор указывал важные моменты этой схемы. Я повторил два варианта этой схемы. Дуга короткая, что очень удобно. Лично я доволен. На очереди вариант фиксы с применением управы от AVT-200.
gyrator
Ежели, как вы говорите, варылка для вас - рабочий инструмен, то, пмсм, он должон быть один и качественный. А делать самопал на каждый "клюв" петушка-это для работника несколько расточительно, бо за время потраченное на ваяние самопала, гарный работник может заработать на качественный инструмент. Так я думаю. А ежели работнику в кайф тратить время на ваяние инструмента, то, опять же пмсм, имеет смысл обзавестись йенератором накачки или коррехтуром и питать свой любимый инструмент через упомянутую примочку при любом качестве и количестве сетевого напряжения. icon_biggrin.gif
golub
Местами где-то так. Но как и у медали, в каждой работе свои специфичные оборотные стороны. Может вы с высоты вашего редакторского кресла и правы на счёт "любимого" инструмента (2-х киловатная болгарка, киловатная дрель), я не спорю. Но мне там внизу, на месте, как-то кажется что по сараю 130х35 м таскать со своим "любимым" инструментом да километром удлинителей ещё и приблуду, которая позволит из никакой сети взять неограниченное количество качественного электричества, как-то не очень удобно.
А по поводу злого петушка, так так вышло, что пришлось со своим предыдущим "бойцом" расстаться, в силу сложившихся ... и т.д., который, к стати, честно отбомбил два сезона, и обколесил всю восточную украину.
если честно, вы сами пробовали работать таким инструментом, в описанных мной условиях? Если ДА- я пасс.
gyrator
Варылка-не мой основной инструмент. Однако, полагаю, что использование того же корректора при длинных "соплях" удлинителей и гнилой сети, таки эффективнее и универсальнее уменьшения Ктр. Но своего мнения никому не навязываю, а тильке высказываю оное, бо каждый индивид может как он хочет. Тем не менее полагаю, что когда клонирование бармалейников поднадоест, вы таки придёте к упомянутому варианту. icon_biggrin.gif
golub
А я и не отрицаю, вже почти на подходе.
кто ж с этим спорит, только уход к праотцам или ещё в каком направлении немного дороже, и не менее маловажно- эмоциональней обходится.
Putnik
Христос Воскрес, ребята!
tnttnttnt
во истину!
СМК
Разжеванного корректора или генератора накачки для практического воплощения в жизнь я что-то так и не нашел.Была тема по генератору накачки,но как то потихоньку умерла.Разрабатывать свою схему ,к сожалению,не хватает знаний,хотя форум по самодельным сварочникам дал очень много.
Д713
Разрабатывать свою схему ,к сожалению,не хватает знаний..
избыток знаний только усугубит процесс..
"многие знания-многие печали"-придумано не сегодня.
Dr. Санчес
У меня возник вопрос по блокирующим конденсаторам на ключах . Я смотрю многие применяют желтые помехоподавляющие пленочники . Сам такие не ставил , но возникло не лестное мнение о них . Сразу скажу что не претендую на истину в последней инстанции , и поскольку я их не использовал , то мнение о них может быть субъективным .
Замерял емкость таких кондеров ( новых не б/у ) , она в норме , примерно такая же как написано на корпусе . Но выпаивая некоторые конденсаторы из фильтров разных блоков питания , заметил что у многих эта емкость занижена , у некоторых на 20 - 30% , попался даже один MKP на 0.47мкф с емкостью 0.08мкф ! Вот и возникла мысль - может они в силу каких либо причин склонны к деградации ? Возможно что их и прошивают импульсные выбросы , и они самовосстанавливаясь теряют емкость ?
Для блокировок я использую Wima MKP10 от древних (примерно 92г ) намецких частотников , у меня напирмер была целая батарея 0.15мкф * 1000в , так все они при замере давали строго 0.15 - 0.16мкф . Но в случае с Wima , их габариты не очень удобны для компактного монтажа . Хотел применить желтые MKP но с ними возникли такие непонятки .
tnttnttnt
Тоже обращал внимание что емкость далеко не та что указана на корпусе после б\у.
Д713
та то рекламный агент отписался..
дескать wima и никаких гвоздей!
ежели настойчиво впаривать,шо растут рога,то действительно можно первичные признаки обнаружить при желании..
tnttnttnt
Все может быть,но я то точно не испытываю ни какой симпатии к кондерам wima! Просто пишу что наблюдал сам.
Д713
насчет симпатии Вы зря,но цена не располагает..
могу пальцем указать в строчную развертку,где условия работы не менее напряженные,но трудится там далеко не wima и десятилетиями.
sarmat
Что-то у меня лично особого желания не появляется периодически мерить емкости конденсаторов. Верю тому, что на них написано. Если со временем уменьшается емкость, ну и фиг с ним. Себе хуже. Со временем все ухудшается, кроме коньяка. icon_smile.gif
Д713
Цитата(sarmat @ 24.4.2011, 21:33) *
коньяк-стало словом ругательным,и попрошу его не применять. icon_biggrin.gif
Dr. Санчес
У меня тоже нет повода для симпатий к Wima , да и там где я живу проще купить пряники , самовары и ружья ТОЗ чем найти эти кондеры icon_biggrin.gif , просто попались на работе из старых преобразователей . Выбор у меня не велик : К78-2 ставить , но они при соответствующей емкости - монстры по размеру , К73-17 не для таких цепей , wima - которые есть у меня по размеру с пол спичечного коробка , вот хотел попробовать желтые - но если они такие нестабильные , то уж и приходится ставить то что есть .
Д713
да все замечательно с wima,как впрочем и с hitachi,тока карманные ресурсы вносят некую поправку..
OlegarX-RUS
На днях резал тройкой железяку толщиной ~17мм на токе за 200А (~210-220а)
Ну и после реза чуть более 10см стрельнула сила, а именно ключи SGH80N60 оба в казюлю ушли, обратные диоды 30ETH06 один в казюлю другой в обрыв.
Диоды стояли на радиаторах через намокон ещё зацепило один драйвер но это как следствие. Радиаторы на ощупь были еле тёплые после баха!!!
Так вот собственно вопрос: - Что первое диоды или транзисторы??? вроде как если бы точечный перегрев транзисторов то по идее диоды должны были остаться целыми, если наоборот диоды то почему это произошло именно на сварке на большом токе, а не просто на ХХ
OlegarX-RUS
А почему тогда ушли из жизни размагничивающие диоды??? попробуйте найти ответ на данный вопрос
Транзисторов по одному в плече
OFATUM
Если подключить амперматр и пробовать варить тройкой на всю мощность аппарата, то при полной длинне эллектрода 3мм, более 140А выдавить нереально.
Глянуть нужно, что за кондер стоит в задавалке частоты. Есть подозрение, что при нагреве аппарата нагрелся кондер и уплыла частота и тут произошел БАХ. Греть кондер и мерять емкость, это должно быть за правило.
OlegarX-RUS
Это кто вам такую чушь сказал???
Я когда тестировал и настраивал аппарат то всё оно получается единственное заметил, что чем тоньше электрод тем больше задирается напряжение на дуге по отношению меньшего диаметра к большему (пробовал 3,4,5) при равных токах (то есть у тройки самая большая мощность на дуге)
А сам электрод при резе раскалялся до красна и если его тыкать прям в железяку то он гнётся словно пластиковая трубочка.
Кондёр стоит К71-7 Если вы были бы внимательны читали форум то обратили бы внимание, что я первый как раз обратил внимание на частота задающий кондёр! и сфокусировал внимание на ихний ТКЕ
Аппарат за свой век сжёг кило 150 электродов но вот гипериспытания не прощол
Wiew
по-моему перегрев диода, а дальше цепочкой...
OlegarX-RUS
Я тоже больше грешу на диоды, но тогда другой вопрос почему??? в прямоходе ведь ток диодов вроде зависит только от индуктивности рассеивания и ширины импульса и не зависит от тока нагрузки или я ошибаюсь???
Лопух
В одном из даташитов Fairchild Semiconductor на транзистор этой фирмы как-то видел такую беду. Сам транзистор имел ток 90 А, однако в примечании было сказано, что максимальный ток в данном корпусе (ТО247) то ли 60, то ли 70 А и ограничен именно возможностями корпуса по теплопередаче. Не помню, что за транзистор, но попробую поискать. Я к чему, возможно, кристалл просто не успевает сбрасывать тепло на корпус, потому и бахает.
OlegarX-RUS
Согласен!!! ещё раз повторюсь каким тогда макарам убило обратные диоды если ключи отошли первыми в мир иной????
А по поводу размагничивающих диодов я всё время думал, что для них самый сложный режим это ХХ если не так то дайте мне в бровь
Lemm
в ПА№2 не зря ток ограничен на 189А . тут выход за ОБР транзисторов . если глянуть на шит - то там видно из графика , что максимум тока с ключа при 50% 30 кгц - 35А . и это при температуре 100градусов . но если теплосток на радиатор был плохой - то кристалл мог быть близок к такой температуре . если такие токи хочется снимать - то надо баянить ключи или модули ставить .
ЗЫ: а как себя снабберы чувствуют ?
Wiew
Цитата(OlegarX-RUS @ 25.4.2011, 14:24) *
в прямоходе ведь ток диодов не зависит от тока нагрузки или я ошибаюсь???
ошибаетесь.
OlegarX-RUS
Да я согласен с тем что могли ключи от точечного перегрева ёкнуть!!! НО (в третий раз спрошу) Каким тогда макором убило размагничивающие диоды???
Снаберы себя чувствуют хорошо всё целое.
ошибаетесь.
ОБОСНУЙТЕ!
OFATUM
Я вообщето говорил о токе на выходе при резке тройкой, а не мощность дуги, тоесть напряжение которое выше нежелеи при сварке умноженое на ток.
OlegarX-RUS
А я вам про птичек что ли рассказываю???
Ток при резке тройкой был 220А при настройке аппарата, на четвёрке 220А, на пятёрке 220А
Единственное, что на тройке при одинаковом токе было напряжение выше чем на четвёрке,
на четвёрке напряжение выше чем на пятёрке
Поесть на тройке при 220А тока выделялась самая большая мощность!
OFATUM
Значит у когото из нас амперметр особенный. Пусть напишут люди, кто воочию видел показания амперметра при сварке и резке. На счет мощности дуги, согласен, так как при сварке 4-кой предохранитель 30А 220В чувствует себя хорошо, а вот при резке 3-кой плавится.
OlegarX-RUS
Возможно, что мощность самой дуги одинаковая во всех случаях, а напряжение выше не концах за счёт падения напруги на самом электроде от того и самая большая мощность на самом тонком электроде.
При сварке и резке без корректоров ток одинаковый а напряжение разнится
OFATUM
Когда пытался настроить аппарат на 130А ( облегченная версия для 3-ки), при 140А аппарат резал, когда ставил 4-ку аппарат варил и показывал 160А, тут я точным подстроичником и откидал до 130...140 А ( пусть погрешность амперметра 10А).
Закон Ома гласит, что при сопротивление эллектрода 3мм и длинне 35мм его сопротивление= 0,0087ом, сопротивление 10м кабеля 16мм2= 0,01 ома, при таких величинах ток по закону будет очень велик, но это же при КЗ, но тут есть еще один ключевой момент как сопротивление самой сварочной дуги.
lapa
Это только в теории максимальное напряжение на ключах при обратнном ходе равно напряжению на банке. При кривоватом монтаже появляется выброс пропорциональный прямому току и кривости монтажа. Поэтому пробило ключ, а диод был под прямым током. Мощный сквозняк вынес и диод с отгоранием траверсы. Кроме того компоненты все китайские. Могли и другой кристалл сунуть. Ну а вашу аргументацию в дальнейшем споре спишем на боль утраты близкого аппарата.
Лопух
Неправда. Я проверял максимальный ток при резке. Что 3-кой, что 4-й, амперметр показывает одинаковый ток. Он зависит только от задания тока в аппарате. При максимальном токе 180А, во время резке тройка раскаляется докрасна. Что касается последовательности выгорания аппарата, по цвету и размерам черепков судить трудно. Неисповедимы пути господина БАХА. icon_biggrin.gif
толян
физика процесса очень проста. например - первым уходит верхний транзистор, шваркает затворный резистор, соответственно управление работает . но размагничивание транса идёт на один диод. отработка по току работает - пара- тройка циклов , может больше и диода нет. его сжег размагничивающий импульс. вслед за ним соответственно летит и противоположный транзюк .ну а дальше -- у чего ноги первей отгорели. один диод шваркнет стопроцентно , второй по рандому. кто нибудь просто попробуйте в щадящем режиме этот вариант. диод греется аки солнце. проверено на стенде. давно.
Цитата(RUS5610 @ 22.4.2011, 19:07) *
Толян! В AVT какие навороты есть по сравнению с Бармалеем? Качество сварки?
да наворотов суперстрашных нет. просто рабочая лошадка. компенсатор даёт чёткую и непрерывающуюся последовательность импульсов, автоматика управления очень проста и прекрасно работает. К зап делается любой и элементарно , кстати для деревенских потребителей делаю с повышенным напряжением на выходе , а один добавочный транзистор очень просто следит за скважностью и соответственно за длиной дуги в зависимости от входного напряжения. в универсальных аппаратах за этим следит стабилизатор выходного напряжения. в схеме AVT это очень просто. на 3845 этот режим Икающий , а здесь просто ограничение скважности и всё.
Для Сармата - когда будешь делать фиксатый - то просто можешь сделать Кзап несколько больше 50 % , если транзюки поставить высоковольтные.
OlegarX-RUS
физика процесса очень проста. например - первым уходит верхний транзистор, шваркает затворный резистор, соответственно управление работает . но размагничивание транса идёт на один диод. отработка по току работает - пара- тройка циклов , может больше и диода нет. его сжег размагничивающий импульс. вслед за ним соответственно летит и противоположный транзюк .ну а дальше -- у чего ноги первей отгорели. один диод шваркнет стопроцентно , второй по рандому. кто нибудь просто попробуйте в щадящем режиме этот вариант. диод греется аки солнце. проверено на стенде. давно.0
А ведь таки да!!! вы правы!!!
Но всё таки какой режим самый сложный для размагницивающих диодов???
