Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
STASKIN
Цитата(UVM @ 10.1.2012, 10:47) *
Это тоже не та осцилограмма, на ТТ должна быть пила и скос примерно от середины переднего фронта импульса вверх. В первой ветке бармалея осцила точно была, ищите.
Сдесь помоему для начала хватит.Нажмите для просмотра прикрепленного файла
TSW
Выход тт на холостом ходу
RUS5610
Блин не ту осцылу кинул.Напиши мыло скину все бармалеевские.
lera
Это осцилограмма с калькуля Лысого?
TSW
да!!!
petr0757
Цитата(электросталкер @ 4.1.2012, 21:01) *
Уважаемый,а какие переделки были в комповом БП?Если можно-поподробнее,сам хочу поставить такой.Только АТ(не АТХ)
C АТ проще чем с АТХ( в последних моделях и спользуется мониторинг выходных напряжений).
Просто изменением делителя с +12в на 1 ногу ТL494. выставляеш +14в, или сколько хочеш.
UVM
Хватит, по факту можно увидеть пилу и с более крутой верхней полкой это нормально, у меня как правило фронты вертикальные а верхняя полка градусов на 15-20 наклонена, жаль эту осцилу ни разу не фоткал.
vovaan
собрал Я калькулятора но такие осциллограм не вижу.Прямоугольные импульсы получаются или срезается левая сторона прямоугольника.
Basill
Так всё-таки: речь об осцилограмме калькулятора Лысого или на выходе трансформатора тока?
Если "калькулятор" - то на холостом ходу прямоугольника быть не должно. Это означает либо мизерную индуктивность (дерьмовый феррит или КЗ витка в первичке/вторичке) либо абсолютно не те частоты и длительности импульсов для данного транса (да и бахнуть может сам "калькулятор").
Мою осциллу калькулятора можно увидеть ЗДЕСЬ
vovaan
А где можно почитать о трансформаторе Е65 на одном комплекте ?
STASKIN
В даташите! icon_biggrin.gif Вопросы задавайте конкретнее!
vovaan
Я имел ввиду сколько витков нужно намотать на феррит Е65 один комплект ?
STASKIN
Для чего? Конкретнее задавайте вопросы-больше шансов получить ответы! Что с Вас вытягивать приходится все!? Больше информации давайте!!! :!:
Народная мудрость-не хотите слушать глупые ответы-не задавайте глупых вопросов!
vovaan
сварочник Бармалея 100А F=35кГц силовой транс E65
zario
перв. 32вит. втор.10вит. зазор 005мм на каждом керне.
KSV
Посмотри файл
vovaan
У меня в первичке 32 вит. двумя проводами D=1.5 мм. Вторичка шинка 2.5х6мм. восемь витков.Двойкой варит не устойчиво ,залипает. При четвёрке тихо умирают транзисторы.Поэтому Я тут и узнавал про калькулятор ,правда пока не разобрался . Завтра куплю новые транзисторы, проверю калькулятор на самом сварочнике.
ostap
Для фирменных сердечников Epcos #87
http://www.electrik.org/forum/index.php?au...load&id=360
vovaan
В два провода по 1.5мм это немало по первичке? Как-то странно тихо умирает ,не бахает.
TSW
vovaan Дата 13.1.2012, 23:38 В два провода по 1.5мм это немало по первичке? Как-то странно тихо умирает ,не бахает
У бармалея в сотке сечение первички 26х0.3=1.83см^2 и живет, У вас 2 по 1.5мм=4.22мм^2 впринципе в этом криминала нет, сечение влияет только на пв и не более (вразумных пределах конечно!) такчто ищите глюк в монтаже или в отводе тепла от силовых транзисторов, проверьте термодатчик!!!да чуть не забыл может у вас дежурка от просадки останавливается!?
cot
2 по 1,5=3,53 считайте правильно! что впринципе тоже не мало!
UVM
Ну если двойка залипает, куда с четвёркой то лезть?!
Да и вообще до электрода на баласте проверялось, какие были результаты, осцилограммы?
zario
видимо у тебя со снабберами проблемы, проверь цепочку
TSW
Извиняйте не на тот калькулятор глянул. это я для себя считал на косой 120 андрея_G 4,22;
A пи э-р квадрат конечно-же еще никто не отменял 2 по 1,5= 1.5/2=0.75*0.75*3.14=1.766*2=3.53СМ^2!!!
ГонZа
Приветствую всех на форуме.Начал делать Бармалея 165.Намотал силовой транс на 6 ТВСах(Ш 20*28 -нет)первичка 4мм2,вторичка 14мм2.Вопрос знатокам:какая индуктивность первички должна быть?С уважением Гонза
eger
я не знаток но отвечу так как для пробы сделал транс на твс при 15 витках получилось 1400
urdint
За 2 года сделал 3 сварочника на 6 ТВСах 18-первичка, 6 -вторичка с зазором на каждом керне бумага от кассового аппарата. с измерением индуктивности не заморачивался. все сварочники
без проблем работают до сих пор.
электросталкер
А частота какая?Я мудрю то же но ключи у меня 50u.А результаты какие?Ключи спарки или по одному?Феррит какой?Сколько диодов ?Информация из практики ,она то очень ценная наверно не только для меня!
ГонZа
Приветствую всех на форуме.Большое спасибо всем кто отозвался на моё сообщение.Сегодня запускал генератор на UC3845 и по выходу на 6ноге оссцылом увидел пилу(я почему то думал там прямоугольники).Вопрос знатокам,что все таки на 6 ноге должно быть?С уважением Гонза.
UVM
Меандр должен быть на выходе, правильно думал!
ГонZа
Приветствую всех на форуме.Вчера,как я уже писал что запустил генератор,сегодня подключил полевик и ТГР.Микросхема,после подключения полевика вышла из строя(с 6 ой ножки пропали импульсы).После отключения полевика и ТГР импульсы не появились.Поставил другую UC3845,не подключая полевик и ТГР,импульсы идут(но идёт пила).Проверил всю плату на наличие косяков-не обнаружил.Жду помощи знатоков!С уважением Гонза.
кабельщик
Такого не может быть, между ними есть резистор 22 Ом. Он не даст микросхеме помереть ни при каком раскладе полевика.
идёт пила
Такого тоже не может быть, я не знаю, как заставить 3845 дать на выходе пилу.
Ваш осциллограф вообще может показать прямоугольники с такой частотой? Проверьте на каком-нить источнике импульсов (например, на импульсном источнике питания)...
ГонZа
Вечер добрый.Осцил у меня древний С1-68.Вычитал,что стартовое напряжение питания должно быть 15 вольт,а яеё(UC3845)запускал от 12 вольт.Может быть проблема в этом?С уважением Гонза.
urdint
отвечаю: феррит брал 6 комплектов строчников от телевизоров 3УСЦТ. частоту проще выставить так: в разрыв провода +310В включаешь эл. лампочку на 100 ВТ и изменением частоты добиваешься еле заметного свечения нити накала. При витках транса 18/6 у меня получилось 33-35 КГЦ. все детали как в схеме, ключи по- одному, диоды 150ебу02 а лучше 04 тоже по-одному. все это неоднократно было описано ранее. Успехов. если есть еще вопросы задавай
полазь осциллографом по питанию, может помехи из-за монтажа, навесь по питанию прямо на ноги UC3845 и выводы ТГР кондеров 0,1 мкф
электросталкер
[quote name='urdint' date='18.1.2012, 21:24' post='217054']
Как мотал транс?Чем пропитывал?
urdint
[/quote]
дрелью свивал пучок тонких проводов, для надежности всерху натягивал чулок от веревки. Мотал без каркаса, перед этим феррит обматывал малярным бумажным скотчем, им же изолировал и между обмотками. готовый транс несколько раз пропитывал лаком ПФ- (какой номер не помню)
Alex.N
Была такая проблема даже от 14в не хотела работать.UC была производства Индия или Индокитай,поставил другую всё работает
wkaktuz
Парни, кто нибудь сталкивался с аппаратом Диолд АСИ 160-200? Интересует отдельное подключение питания управы, буду очень признателен.
and_w
Доброго всем времени суток! Решил спросить у гуру сего дела:
решил собрать бармалейника 5-165.... Наклевываются некоторые вопросы:
1. По дросселю- есть 2 феррита от строчников , по схеме нужно мотать лентой 0,5х12... Т.е. получается сечение 6 мм квадратных. Проблема состоит в самой ленте, в смысле в проблеме ее достать.. Могу ли я это намотать проводом в 6 квадратов и более или набрать полосу из продов каждый по 0,5-0,6 мм до ширины окна ?????
2. Тоже по силовому трасформатору- по схеме провод 2мм, на сколько я понимаю, я могу взять 2х1,2 и намотать первичку??? Или я может что-то недопонимаю.........
3. В схеме не указано никаких зазоров в магнитопроводах всех моточних элементов- это так, либо надо их делать??
4. Есть такой диод BYV26C, на сколько я знаю его иногда можно встретить в БП компьютера, а чем его можно заменить? Пойдет ли , к примеру, КД226? Или там какие-то есть требования?
Сорри если спрашиваю глупости, просто с силовой электроникой как-то не сталкивался...
Спасибо!
Basill
См. фрагмент схемы 165-ки - подчёркнуто красным. Про ленту из тонких проводов (взамен сплошной ленты) - там же.
oleg1ma
Спасибо!
1. Где подчерпнули такие данные по дросселю, из какой схемы, ниже схема бармалея 5-165А.2.Провод диаметром 2мм имеет сечение 3.14мм2, а провод диаметром 1.2мм имеет сечение 1.13мм2, если два то всего 2.26мм2.3.Смотрите схему.4.Кд226 непойдет, заменяется на UF4007, SF18,HER108.
ГонZа
Приветствую всех на форуме.Вопрос знатокам:сильно ли греется полевик IRF540 на ТГР,можно ли запустить только одну UC3845 без 555(которые стоят на включение реле и на включение кулеров?Генератор запускал от обычного стабилизированного БП на трансике,и от 12вольтового аккумулятора.Сегодня подключал к оссцилу генератор прямоугольных импульсов и обнаружил,что выше 2кHZ он рисует пилу,а не прямоугольник!Подскажите как выбрать в магазине нормальную UC3845 и чем отличаются UC3842.3843.3844 от3845?С уважением Гонза.
игорь315
если не ошибаюсь отличается 3844 напряжением питания а 3842-43 кзап
oleg1ma
Ну и где в твоей схеме ты такое вычитал, ну и раз знаком с радиомаркетом зачем задавать вопросы про BYV26C закажи и вышлют.Дроссель можно намотать чем угодно, лиш-бы сечение было подходящее, а также почитать не мешает форум, глядиш и вопросов поубавится.
HEMELL
[quote name='ГонZа' date='19.1.2012, 20:02' post='217248']
540ой. должен быть слегка тёплый.Если хотите правельно и без косяков запустить 3845 - найдите схему Негуляевского бармалейника, в котором БУ вообще максимально простой, без таймеров (без 555) подключайте себе на здоровье и будет вам частье.
И вообще, думаю, что не надо делать скоропоспешные выводы по поводу 3845. Соберите полную схему этого узла вместе с ТГРом, выставте частоту 30кгц., а уж потом будите посмотреть.
and_w
Спасибо что ответили! Схему, по которой собираюсь делать приаттачил. Если честно, то меня больше волнует дроссель, т.к. медной полосы у нас даже на радиорынке нет. Есть только толстая...... Так вот я подумал, мож попробовать пучком свитых проводов??????
STASKIN
Цитата(and_w @ 19.1.2012, 23:14) *
Спасибо, что откликнулись... Предвидел я вопрос про схему. Схему прикрепил.
Могу посоветовать начать с схемы посвежее,будет проще с помощью и с комплектующими. Либо другой вариант-почитать еще немножко форум,тут немерено информации! icon_biggrin.gif
and_w
Сорри, там 0,5х26.... А радиомаркет- это просто базар так называется... И честно, облазил на днях весь- и не нашел.... Кризис. За ответ СПАСИБО! icon_smile.gif
cot
Я на все сварочники мотаю дроссель жилой, от обычного кабеля к примеру ВВГ 5*10, снимаеш изоляцию, мотаеш свою (винил расплавится),удачи. http://s018.radikal.ru/i521/1201/0a/df2aba4b41c0.jpg
кабельщик
Выбирать не надо, они все нормальные. Через мой паяльник их прошло полтыщи, не было ни одной нерабочей.
Вам нужна 3845. Чем она отличается от остальных, написано на первой стр. даташита. Старайтесь прочесть сами, тогда лучше запоминается... Там цифры, перевод практически не нужен.
