Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
oleg1ma
Цитата(Navstar @ 24.2.2013, 19:14) *
Годится ли такая топология для блока питания на тор 244?
Хуже не придумать, оптотрон должен стоять как можно ближе к топу, и удобнее тр-тор поставить вертикально.
Navstar
Так лучше?
oleg1ma
Лучше, но нет контактов для подвода 300в, и топ и диоды нужно перевернуть
Navstar
Как-то так! Спасибо!
oleg1ma, Олег? А по какой схеме вы собирали полуавтомат?
oleg1ma
По этой схемке.
ВиталикД
Существуют некоторые требования к расстоянию между дорожками гальванически развязанных частей.
DANTIST
Похоже, праздник прошел на высоком идейно-политическом уровне. Жизнь на ветке замерла. За два дня какой-то десяток сообщений. В лучшие времена за день исписывали по паре страниц.
yrih
NAVSTAR Подскажи пожалуйста по какой схеме этот БП
VladBear
Здравствуйте. Предлагаю для обсуждения простую схему контроля напряжения питания цепей управления в классическом "Бармалее". Нужно подключить к 4-й ноге таймера на (+Uп) стабилитрон на (1-2)В меньше Uп и резистор несколько КОм - на (- Uп). Идея взята с Радио №10. 2006г. стр. 45.
Navstar
yrih, Блок питания на тор 224 от бармалейника
Я ее чучуть ужал из-за дефицита текстолита
Вот тебе лау файл!
только я буду мотать не на ш а на колечке
tranzistor3102
Цитата(VladBear @ 26.2.2013, 17:21) *
Здравствуйте. Предлагаю для обсуждения простую схему контроля напряжения питания цепей управления в классическом "Бармалее". Нужно подключить к 4-й ноге таймера на (+Uп) стабилитрон на (1-2)В меньше Uп и резистор несколько КОм - на (- Uп). Идея взята с Радио №10. 2008г. стр. 45.
VladBear здраствуйте а схемой можете поделиться?
VladBear
Tranzistor3102.Я с компьютером на Вы и не могу отправить схему.В ссылке год 2006.
yrih
NAVSTAR A нет ли под рукой самой схемы
Navstar
не спешите собирать блок питания схема бп которую начертил я в спринте еще не проверенна. На днях будут результаты
aog1996
Navstar, Вы не планируете в БП ограничивать ток заряда ближнего к сети электролита?
and_w
Сорри что вмешиваюсь, а зачем его ограничивать? При пуске происходит общее ограничение резистором, затем слышим через 2 секунды клацание реле и банки заряжаются по полной..... Все просто и работает на 5 балов... Если вопрос про дежурку- там вобще нет смысла ограничилки, а запитать лучше от общих банок + поставить диод какой-нить типа HER157 или просто 1N4007. Да и в оригинале для дежурки ограничителем NTC служит..
Navstar
aog1996, Не планирую, если при первом пуске будет феерверк со всеми спецэфектами тогда поставлю 5-10 Ом между мостом и электролитом
sergey777.68
Зачем столько мс.достаточно одной 555 с термо датчиком отлично работает.
zentr
Здравствуйте! Вот готовая рабочая плата http://www.electrik.org/forum/style_images.../attach_add.png Удачи!!!
Antikiller
Цитата(oleg1ma @ 15.2.2013, 21:18) *
Блокировочные конденсаторы стоят по цепи 300вольт?Как то ради интереса отпаял один около ключей и лампа вспышнула почти в полный накал, хотя на ней до этого падало вольт 10 всего.
какраз этот и забыл поставить. поставил его , лампа потухла. поставил предохранитель 4а вместо нее, подключил лампу по переменке, запустил все работает и не светится. выключил, включил и бах! предохрон сгорел и ключи тоже. почему с первого раза все запустилось? где че копать?
можно ли поставить ключи IRG4PC40U или IRG4PC50U ?
oleg1ma
Поставте, раз нет других но работать будут на пределе, почему бахнуло незнаю, про оцил уже писал.Пока не увидите какие на самом деле у вас сигналы, бахать можно сколько угодно.
yrih
Почему-то готовая печатная плата не открывается. Можно в другом формате
Navstar
под ней ссылка на РСВ.лау
isirx
Уважаемый oleg1ma!
Я наконец-то , нашел все детали и
собрал свою плату , Вашего "дешевого сверкальника"
Включал сначала через лампу накаливания (силу)
Потом у же собрал все напрямую , прицепил к выходу
нагрузку лампу 500вт , на выходе получилось 55 вольт.
Но вот даже при такой минимальной нагрузке транзисторы
(оба радиатора) при длительном включении , пока снимал осцилограммы
нагрелись, где то до 45-50 гадусов, и осцилограмма на одном из транзисторов,
котрый идет эмитором (простите знаю что он полевой, но у Вас в схеме изображен
как биполярный , поэтому и буду так называть выводы)на тр-тор , а коллектором на +300v
имеет вот такую страную форму, между эмитором и колектором
и вот такое на базе у него же
а вот на транзисторе , что идет колектором на тр-тор , а эмитором на -300V
вот на его базе
и еще мне , не совсем понятно как работает регулировка по току ,
напряжение на 15 ноге ШИМ у меня меняется с 0.28 до 3.87 вольта ,
с откинутыми проводами от шунта,
но на выходной сигнал с МС это никак не влияет,
есть ли где нибуть описание настройки подобной схемы?
(с шунтом , а не токовым трансформатором)
Шунт вы пилили или все делается подбором *R1 ?
з.ы. Забыл написалть , для пробы впаяны те транзисторы что вы мне разрешили применить для пробного включения
(сказали 30А выдать могут по выходу) они МОСФЕТ
и еще..... у меня реле включается с задержкой 2-3сек , так и должно быть?
oleg1ma
Цитата(isirx @ 28.2.2013, 21:26) *
Уважаемый oleg1ma!
Как Вы снимали оцилы с верхнего ключа?Земляной щуп на эмитере, а сигнальный на базе(колекторе) -так?Реле работает правильно.Регулировка тока начнет работать только с реальной нагрузкой, а пока вы ничего и не увидите.Еще вопрос, без подачи на силу 300в, сигналы такие-же?Шунт пилить ненужно.
KT117
isirx , на верхнем ключе обычно всегда такая помеха-виноват осцил. На нижнем вроде все нормально, но снимите осцилки без нагрузки на выходе, на ХХ. Еще покажите осцилки на выходе аппарата, перед дросселем. Реле так и должно срабатывать, с задержкой на зарядку силовых конденсаторов. Время регулирeтся емкостью конденсатора С13 и резистора R13
Если шунт вырезан из нержавейки размерами 27х19х1 мм то подборка тока сводится к подборке сопротивления R1 (который на 15 ноге ЩИМ), но это при желании иметь соответствие цифр на индикаторе реальному току (а можно просто померять ток на выходе и нанести метки на индикатор) . (На схеме даны напряжения на подвижном контакте переменного резистора R2-от них и отталкивайтесь)
Регулировка по току работает только под нагрузкой, на ХХ это не увидеть, нужно вешать балласт на выход, тогда увидите как длительность импульсов будет меняться
icon_smile.gif Пока писал-Олег уже ответил.
isirx
Большое Спасибо за ответы!
Земляной щуп осцилографа я все время подавал на Эмитор , сигнальный на Колектор или на Базу ,
и на верхнем , и на нижнем транзисторе . Без подачи 300V на силу , осцилограммы не снимал , совсем без
нагрузки , на выходе не снимал тоже , пред дроселем с нарузкой тоже нет. Послезавтра сниму и
выложу . А то что транзисторы такие теплые на такую небольшую нагрузку нормально?
Еще у меня частота рабочая чуток завышена получилась 42.3кГц...
oleg1ma
Это без обдува?
Это много и соответствует току порядка 200а, увеличте R3*так что-бы на среднем движке максимально было около 2.4вольта.
KT117
Лучше перемотать, из двух сделать один, но вначале проверить из какого материала сделаны сердечники.
sergey777.68
спасибо буду думать. феррит с fubag 160.
oleg1ma
Цитата(sergey777.68 @ 2.3.2013, 21:26) *
Нужен совет как правильно соединить два готовых транса на Е-55 1-12вит 2-4витка.для работы в косом на 40кгц. Или перемотать?.
Если место позволяет, соединяй так,хочеш компактнее перемотай, это у меня лабораторные.
sergey777.68
я так думал но боюсь неравномерного размагничивания.
isirx
Всем Добрый Вечер !
Вот сделал осфилограммы что ,
Вы просили :
Это с отключеным напряжением +300v
Эмитор - база , на обоих транзисторах полная идентичность
А это с выхода , без нагрузки , как Вы назвали ХХ
А потом я совершил , фатальную ошибку , прицепил к выходу нихромовую спираль
и начал плавно уменьшать , сопративление .... где то до 25А....
Невыдержала проволочка, которую я впаял в место разрыва напряжения 300v в силу
Сгорели оба транзистора , как я позже понял их пропалило противоэдс , в момент
сгорания проволочки , звонятся во все стороны......
А пока вопрос , регулировку тока можно настраивать как в Бармалеевском варианте?
подавая на силу , +10 до +50 V(10ампер) и смотреть на схлопывание импульса, при закороченом выходе?
И еще непонятно , что именно мерять настраивая шунт резистором R1 ?
У меня есть транзисторы IRFP150 они на 100V , пока жду те транзисторы ,
можно на этих настроить , регулировку тока на Низком напряжении силы?
И как это сделать поподробнее ?
А да ... сопративление R3 поменял , на среднем выводе теперь максимум 2.38V, минимум 0.19v
И насчет ниржавейки из которой я шунт сделал, у меня сомниение закралось,
она то нержавейка, но вот на магнит чуток реагирует , правда самую малость...
может все таки не годится ? как проверить?
oleg1ma
Можно попробывать и при низком напряжении силы , но тогда уже проще коротить клемы, да и источник нужно хороший например аккумулятор.А дроссель у Вас стоит?Я дешевый настраивал по простому, если сигналы впорядке, задатчик на минимум, замыкаю выход баластом 0.15Ом и смотрю, какой ток по контрольному амперметру.Если проводочки ОС непопутали, то на амперметре может быть 10-20а.При коротком клемами - так-же.Постепенно увеличиваю ток задатчиком и проверяю ток по амперметру,макс нужный ток устанавливаю подбором R3.Нержавейка бывает разной пищевой и технической, одна магнитится, другая нет, не очень важно для этого девайса.
DANTIST
Цитата(isirx @ 2.3.2013, 22:05) *
Всем Добрый Вечер !
Вот сделал осфилограммы что ,...
isirx, неужели так трудно сделать нормальные фотки? Чем ты фотографируешь? Вторая фотка - это на выходных клеммах твоего аппарата? Если там 50В/дел, то амплитуда не плохая. А вот импульс неправильный. Или ты щуп неправильно поставил. Или что-то не то с трансом и выпрямителем. На выходе импульс должен быть в противофазе с ключом нижним.
Я тут как-то недавно показывал методу настройки Бармалеев для одного аматора. Человек специально методу составил, чтобы меньше вопросов было у любителей. С иллюстрациями, схемами и т.д. Но я смотрю нихрена никто, ничего не читает! Открыл крайнюю страницу и пишет вопрос что ему нужно...
Блин, нужно эту методу как-то разместить на странице перечня тем.
Посмотри, тут несколько осциллов с Бармалея. Что-то похожее у тебя должно быть. И убери все эти свои проволочки. Если лампа не засветилась в полный накал и осциллы правильные, включай напрямую, предварительно проверив, конечно, фазировку ТТ. Хотя и с неправильной не сгорит, при не очень больших токах. Мой самый первый варил с неправильно сфазированным ТТ. И ни че. Не сгорел. Свистел как-то странно. Но мы подумали, что так и должно быть.
Почитай эту инструкцию. И, думаю, у тебя больше не будет никаких вопросов. Будешь других учить.
oleg1ma
Созрела мысля icon_biggrin.gif , сделать управу Юрия на платке односторонней, небольшой, вместе с дежуркой на TNY и ТГР вместе с драйверами и ОС по току для 3845 брать с вых шунта, предварительно усилив операционником, ну чтобы одной крутелочкой выставлять мак.ток а не подбирать витки ТТ и нагрузочные резюки. Уменьшится кучка проводов,аппарат будет всего на 2х платках, кто что скажет по этому поводу??
ingener99
Цитата(DANTIST @ 3.3.2013, 2:41) *
... проверив, конечно, фазировку ТТ. Хотя и с неправильной не сгорит, при не очень больших токах. Мой самый первый варил с неправильно сфазированным ТТ.
По идее, никакой фазировки у ТТ быть не могёт, он же к диодному мостику цепляется, и по-любому полярность импульсов будет в плюс. Другое дело - фазировка силового транса, тут попутать опасно, синдромы - очень сильный нагрев ключей даже при токах 40-50А, если посмотреть осциллом на резисторе ТТ - острые пики амплитудой более 20В. Хотя при верной фазировке импульсы не более 10В и плавные. Пример на фото.
Имхо запуск силовой части надо начинать, подключив осцилл именно к нагрузочному резистору ТТ.
Из личного опыта проверить фазировку проще всего так - подключается на силовой выход кондесатор несколько мкФ и смотрится напряжение (может быть больше 100В), затем меняется фазировка первички силового транса и снова смотрим напряжение. В случае правильной фазировки напряжение на выходном конденсаторе будет заметно выше.
oleg1ma
ingener99,DANTIST в той схеме что делает isirx нет никакого ТТ.
p210
Где Вы в однотактной схеме (напомню, ветка про "косого" имени тов. Бармалея) мостики узрели? icon_eek.gif
klementiu
oleg1ma всё это уже было. Была разработка на двух платах. Одна маленькая управа,на ней антистик .драйверы . Но на ней не было дежурки. На большой была сила ,дежурка, тт, всё остальное. Вот ссылка. Минимум проводов, регулировалось всё одной крутилкой.
http://www.electrik.org/forum/index.php?sh...st&p=257231
ingener99
имхо это зря, никакой защиты (отрицательной ОС) у ключей получается что нет...Если ОС идет только по шунту вторички, то все равно не лишне бы добавить ТТ по первичке и сигнал от него завести на тот же вход, что и от шунта (развязать диодами).
Найдете в схеме Бармалея ТТ, вот он и подключен напрямую к мостику
oleg1ma
Вы читать умеете?Я пишу за управу на атмеге 8 от Юрия.
Dedan
1. Чтобы платка не занимала полморды, лучше тогда индикаторы ставить вертикально. Получается две платки уголком. (По мне так самый удобный вариант, на все случаи жизни). Правда и тут есть нюансы. Драйверы от ключей относить, как-то не очень.. Разве что основную плату так скомпоновать, чтобы до ключей был минимум..
2. Если шунт стандартный 150-200А, так он тоже габаритный. Если самопальный, тогда чем он будет лучше набора резисторов? Крутилкой? Трудно сказать. ТТ вроде штука надежная..
ЗЫ.
DANTIST да я давно уже долблю.
Хорошо бы все по темам раскидывать. Спрашивает человек, посылаем его в...нужную тему. Там все сконцентривано и не надо перелопачивать не по одной сотне страниц по десятому кругу.
Специально ведь наоткрывал и по моткам и радиаторам и питателям..
80% воды туда сольется..
ingener99
Цитата(nikon @ 3.3.2013, 23:25) *
по вашему один диод уже мостик?Он пропускает всего один импульс а не два полупериода, поэтому фазировка важна. Столько лет перетирают бармалея и опять к этому возвращаемся.
Все ясно icon_confused.gif Просто всегда использую полный мостик в ТТ, и это уже так вошло в привычку, что по умолчанию подразумевается во всех аппаратах)
Wasiliy61
Привет всем сваркостроителям. Я с уважением отношусь к Вашим творениям. Почитал форум и решил тоже собрать Бармалея. Собрал шим на UC3845,настроил-осциллограммы совподают. Подскажите пожалуйста.можно-ли в драйвера поставить мосфеты на 500-600вольт 3,3-3.5а.Еще есть 100вольтовые но толи на 60 или 80 ампер.Подскажите пожалуста,за раннее благодарен
and_w
Можно, к примеру если нет irfd120 то можно ставить irfd123, irf 520, irf540, irf740.
Wasiliy61
Всем спасибо за ответ,ставить больше всё равно нечего.До города 100км,когда попаду незнаю. В общем я планировал 160а,ключи дома валялись IXGH40N60B2D1.Можно ли в RCD ставить резисторы 51ом 7,5 вата в зелёной глазури. спасибо.
ГонZZа
Вечер добрый.Wasiliy61,в трёх аппаратах трудятся(довольно давно) в драйверах полевики 2N7000(0,4а 60вольт) и стоят копейки 3,68рубля!Ещё добавлю,на материнках в компах стоят полевики 2N7002(они правда СМД).
Wasiliy61
Всем привет.Я дома нашёл какую-то материнку.там стоят P0403BDG,а они 30вольт а ампер что-то много ампер 60-80, есть ещё дома SPP03N60S5 3.2а 600в.CEP7030L 30в 65а.
p210
Цитата(Wasiliy61 @ 8.3.2013, 5:03) *
Я дома нашёл
Это хорошо, конечно, что нашел... А что спросить то хотели?
