Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
шумный
Всем сваркостроителям привет и с наступающим. Наконец то вернулся с командировки, читаю форум, много страниц накопилось за 1,5 месяца
серж2105
Сколько не перематую ТГР ,нижняя полка горизонтальная- совсем не горизонтальная на 200-омах.С драйвера покрасивей выходит,выравнивается изгиб меньше проявляется, что то ещё остаётся но чу чуть.Прямая имеет загиб по середине(вернее до середины идёт ровно потом немного переламывается в верх.Это если смотреть на 200 ом сопр. Или не стоить с этим заморачиваться? на затворах то впринципе как норма. Сфоткать нечем.Как только не мотал и на кольце ( ломал и склеивал )и на ш-обр. результат почти один и тот же. Идеального прямоугола не получается.Можетат я не так что то делаю?Или это нормально? icon_sad.gif
Summon
Цитата(RUS5610 @ 27.12.2010, 21:42) *
Без диодов и дросселя можно проверить правильность фазировки тт и проверить работу регулятора тока.
Тт ставил по схеме 165 бармалея, если в ней ошибки нет то Тт стоит правильно. Смотрю на кольцо, начало обмотки идет внутрь кольца, этой же стороной надеваю на провод выходящий с платы на транс.
HEMELL
Кольцо К20х11х6 разламываю, склеиваю, одновременно мотаю три обмотки по 35 вит., паралельно вых. обмоткам никаких резисторов не ставлю. Паралельно первичной обмотке - диод IN4148 + cтаб. 18 вольт последовательно. Дрова - кольтовские, паралельно первому диоду подключаю резистор 130 ом. Никаких эксцесов никогда небыло, начинало работать с первого раза.
Частота - 50кгц.
К. зап. 0,44.
RUS5610
Если будет писк при кз и работе значит концы тт неправельно.Сильно не парься,у меня самый первый сварочник несколько лет с перепутанными концами работал.При прохождении Т.О перепаял концы. Ключи стоят IRG4PH50U-150 ампер держит запросто.
RUS5610
по 80 баксов из китая http://sonscn.en.alibaba.com/product/23199...ss_arc200_.html
Д713
Цитата(RUS5610 @ 28.12.2010, 21:15) *
вот и приехали..
когда узкоглазые хлопцы перекроют экспорт редкоземелья-некисло будет вдвойне.
мало того,шо шьют флаги для USA с пометкой made in china,так еще добрались и до святого-
http://www.nr2.ru/kiev/314888.html
Lemm
Цитата(Д713 @ 28.12.2010, 23:36) *
вот и приехали..
имхо , сей с позволения вэлдинг машын не конкурент даже самодельным . а народ потихоньку наедается дешевыми чиновскими пирожками . был в руках аналог - телвин 164 , плата точь -в точь . так кулер не спасает его , а "ходовые" испытания показали мерзкую работу на чуть просаженной сети . вот если спецом будут демпинговать по цене составляющих , это да .
Д713
нет слов..
petr0757
Все таки грамотно сделанный Бармалей вещь нужная, отработал три года беэ проблем. Не рекомендуют питать его от дизеле генератора, но безвыходная ситуация, премия всей организации за не освоение средств. 4 квт дизель генератор день отработал на аппарат, так что если очень хочется, то можно.
allhimik
Варил своим Бармалеем от бензогенератора 4.2 квт, варит без проблем, и вобще не подводил летом в жару на солнцепёке и зимой в -15, сварочный супер, доволен им не то что как слон, а как стадо слонов icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif
RUS5610
Тоже варили от бензогенератора,проблем нет работает нормально.
Народ! немного не в тему: есть у кого схема авто-зарядного устройства желательно импульсного.220в-18в с током до 5ампер(схема самой зарядки будет на тирике). Только без всяких проциков и мк. icon_smile.gif Зима -батарейка заряжать надо icon_smile.gif Хочу поселить зарядник под капотом.
allhimik
Посмотри в журнале Радио2002 №11, я когда то начинал собирать, но из за отсутствия микросхемы так и не доделал.
RUS5610
Спасибо посмотрю.
ostap
На етом форуме "кто-то" выкладывал ----- electrovoz -----
Lemm
этот девайс работает в количестве 8 шт . есть печатка ЛУТ . первый файл - монтажка - сменить расширение на rar - разархивировать - пикад вьювером смотреть. (че-то обычным путем не грузится) . деталюшки радиаторы и транс тянуты из 3усцт - МП3-3 . на плате добавлен RC фильтр для кулера 60*60*25 0,1а (на схеме нет) . при затруднениях с нихромом по токоизмерителю R6 можно набаянить смд резисторов по 0,15 - 0,1 ома штук 10 .
ЗЫ параллельно VD2 ставлю 33кОм*2Вт*4 шт + 0,1 мкф*400вольт , а то супрессору самому там несладко . все это этажеркой на 2 медных стойках из проволоки .
petr0757
У меня было огромное количество БП АТ с системных блоков. Все переделал на зарядные. Элементарно, напряжение отпускаеш до 18в, а ток выставляеш компаратором и на 4 ногу TL494. Как раз при 18в легко берется 5а.
electrovoz
Цитата(ostap @ 29.12.2010, 21:35) *
На етом форуме ктото выкладывал
Этот кто-то - я, первая схема никуда не годится, по второй уже сделано десятки. Только рекомендую прокладку не 0,36 мм, а 0,6, ну и резистор не 0,47 Ом, а 0,36 - 0,43.
А еще у меня есть схема с процом, дисплеем на 1 строчку, и 15 А. Влазит в корпус АТХ, регулирует ток, показывает ток и напряжение.
kyzmi4
electrovoz,
А печаткой не поделитесь???Что-то я тоже заинтересовался этой схемой.
allhimik
А двухстрочный дисплей к ней можно приладить, валяются 6 шт. без дела.
RUS5610
То что Остап выложил вторая схема? Ну если можно и печатку выложите. Получается по схеме просто стабилизированное напряжение на выходе? Ток чем рулить?
Петр поделись схемкой.
Лопух
RUS5610, для зарядки автомобильного аккумулятора можно вообще не заморачиваться регулировками тока и напряжения. Есть такая фишка, как зарядка при постоянном напряжении. Подробнее здесь http://akb174.ru/poleznye-stati/metody-zar...-akkumulyatora/ . Тут уже ЕМНИП Камелот выкладывал схему дежурки на UC3842, что, собственно, есть схема БП роутера d-link http://blog.amigas.ru/?p=263 Считаем в ПИ эксперт либо в проге випер для 16 вольт 5А и собираем либо вышеприведенное, либо на ТОР. В минусовую цепь ставим мощный резистор 0,1 ом и получаем зарядку при полупостоянном напряжении. Смысл в том, что при подключении к разряженному аккумулятору этот резистор ограничивает начальный зарядный ток и на нем падает некоторое напряжение (зависит от разряженности аккумулятора). По мере зарядки внутреннее сопротивление батареи увеличивается, в результате ток падает, а напряжение зарядки растет. Получается как бы автоматическая регулировка. Проверено неоднократно.
Вот один из вариантов http://qrx.narod.ru/arhn/viper.htm
petr0757
Схема последняя доработана для универсального БП от 3 до 18 вольт, ток зашиты дискретный, для зарядного половину можно выкинуть. Доработка БП АТ сводится всего в том что резистор на 1 ноге TL494 меняется на переменый, а дальше по схеме.
lera
Друзья. всех с наступающим НОВЫМ ГОДОМ. успехов в нашем увлеченье и здоровья. счастья.
RUS5610
Спасибо за информацию! Всех участников этого форума поздравляю с наступающим Новым Годом! Желаю всем крепкого здоровья и счастья! ( чтобы сварочники плодились как кролики icon_smile.gif )
Иванн
Маленький вопрос. Мотаю силовой транс, стал вопрос на счет датчика. Думаю ставить ли диод Д9, между первичкой и вторичкой, но он там не очень хорошо вмещается. Может он там и не нужен, так как сечение будет 6мм2/20мм2, сердечник – Е70, частота – 35кГц. Ток хочу до 160А. Возможен ли перегрев обмоток?
Д713
там датчик не нужен.
RUS5610
Иванн какой датчик???? Новый Год на носу! Поставь транс под обдув и пропитай его лаком.И будет тебе счастье!
С таким сечением перегрева не будет.Я лично всегда считаю 10ампер на 1 мм2.У китайцев и того меньше.
Ну теперь всех с Новым Годом!
Лопух
Всем желаю счастливого Нового Года. Удачи, здоровья и достатка в наступающем году.
Иванн
Поздравляю всех с Новым Годом!!!
Подскажите пожалуйста, какая минимальная частота для транса: Е70, витков - 18/6.
Так как ключи у меня 50U, выставил 30кГц. При этом, на 220В, без зазора, проявляется маленький загиб, и ток намагн. 3А (на ХХ транс. разогрелся за 5 мин до 40 град.С). С зазором резко растет Інамагн. Как я понимаю на этой частоте лучше я ничего не сделаю?
tnttnttnt
Ребята всех с новым годом!!! Помогите кто если может собрал схему бармалейки на 165А все по схеме проблемы которые возникали все вроде под силу были решить а теперь тупик не знаю что делать осцилограмма колектор эмитер оба ключа одинаковые Нажмите для просмотра прикрепленного файла 10в\клетка питание силы 25в частота 30-31кГц единственный косяк силовой транс намотан на ш20х28 2500нмс1 намоточные данные взял из негуляева он писал что этот сердечник полный аналог эпкоса е65 н87 я сделал по его даным 19витков 2,24 первичка вторичка 6+6 в два провода по 2,24 общее 16кв примерно так вот из за этого это или нет. Сегодня по пробывал по лысому первый раз не все понял в этой методике но вроде как на 115в силы поползла игла вверх оставил на несколько минут сердечник нагрелся до 50 градусов примерно.Нажмите для просмотра прикрепленного файла затвор-эмитер тоже одинаковые оба 10в клетка 10мик\сек. Ребята вообщем напишите кто что думает только не отправляйте форум читать с первой части два месяца читаю уже,заранее всем спасибо!
lera
tnttnttnt. ты сперва определись -что хочешь собрать Негуляева или Бармалея. У Бармалея все правильно.
Lemm
бармалей -прямоход , и транс по другому мотается . у негуляева - мост . мотай по бармалею , и там вобще должно быть 2 сердечника . а ш20*28 - далеко не аналог Е65 . материал паршивенький .
aleksandr64
У Негуляева во второй книге и косой есть.
RUS5610
Ты по што Ш20/28 ругаешь? Нормальный сердечник и нормально работает.Только греется немного.Народ за зря пугаешь! icon_biggrin.gif
Lemm
да , чего-то проглядел . но все равно - в оригинале Бармалея 2 сердечника 20*28 и один даже эпкос их не заменит . а транс у aleksandr64 явно в насышение лезет .
частоту может чел не хочет задирать . а так - если ниче другого нет , то можно конечно , но их параметры от штуки к штуке изменчивы как погода .
RUS5610
tnttnttnt по первой осциле размагничевания не видно.попробуй зазорчик поставить.Запитай силу от 220 и в разрыв ключи конденцаторы поставь лампу 60-100ват.Проверь щупы осцилоскопные .
Summon
Чет мне осциллограммы твои не очень нравятся. Я не профи можно сказать третий раз осциллографом пользуюсь но у меня такие картинки при 5мкс. Частота точно та что надо?
tnttnttnt
Да я намотал по бармалею катушка лежит сердечников нет ни где один этот комплект попался я решил резкнуть,а материал из второй книги негуляева прямоход!! Зазор 0,1 стоит транзюки еще у меня UD а не U.
Была такая мысль в литературе тоже вычетал что такая картинка при 5 м\сек должна быть но персчитал частоту и подумал что опечатка.
Вот литература откуда че бралНажмите для просмотра прикрепленного файла
Lemm
в той схеме трансформатор тока надо прямо с вывода силового транса брать , а не за размагничивающим диодом . давненько обсуждалось . хотя в данном случае сейчас не важно .
tnttnttnt
Кстати схему я эту собирал Нажмите для просмотра прикрепленного файла
Мужчины частота 30кГц картинка 10в клетка 10 м\сек Нажмите для просмотра прикрепленного файла а не при 5м\сек такая должна быть???Умы инвертостроители подключитесь пожалуйста!!!
Summon
Цитата(tnttnttnt @ 4.1.2011, 22:44) *
Мужчины частота 30кГц картинка 10в клетка 10 м\сек а не при 5м\сек такая должна быть???Умы инвертостроители подключитесь пожалуйста!!!
Извини видать с просоня в глазах двоилось. Пришел с работы, пару часиков поспал, открываю глаза а тут твоя осциллограмма. icon_smile.gif Сейчас вроде уже проснулся, у меня импульс и пауза шире при 5мкс так что при 10мкс у меня такая же картинка получится. icon_smile.gif Для успокоения сможешь глянуть здесь мои осциллограммы
tnttnttnt
Теперь можно со спокойной душой спать лечь спасибо что обратили внимание на мою беду.
sarmat
У осциллы (затвор-эммитер) заполнение странное...или щупы перевернуты. Показал бы осциллу после выхода УСки.
осцилограммы для косого примерно такие:
tnttnttnt
Вечер добрый всем! Вчера на хватав советов сегодня пол дня эксперементировал и к чему пришел?! Негуляевский транс из одного комплекта сердечников по калькулятору лысого перенасыщаться начал при 150в силы в следствии чего я решил поступить следующим образом в заранее намотаную катушку бармалея я вставил этот комплект ш20х28 НМС1 зазор 0,1 по калькулю лысого поднял напругу до 220в силы перенасыщения нет вобщем малориком держится. Собрал в схему все поднял напругу до 220в без нагрузки все вроде как нормально не че не трещит не дымит покрутил регулятор тока тоже все ок потребляемый из сети 0,4А все осцилограммы без нагрузки на выходе напруга 220вНажмите для просмотра прикрепленного файла
Цитата(tnttnttnt @ 5.1.2011, 17:48) *
Вечер добрый всем! Вчера на хватав советов сегодня пол дня эксперементировал и к чему пришел?! Негуляевский транс из одного комплекта сердечников по калькулятору лысого перенасыщаться начал при 150в силы в следствии чего я решил поступить следующим образом в заранее намотаную катушку бармалея я вставил этот комплект ш20х28 НМС1 зазор 0,1 по калькулю лысого поднял напругу до 220в силы перенасыщения нет вобщем малориком держится. Собрал в схему все поднял напругу до 220в без нагрузки все вроде как нормально не че не трещит не дымит покрутил регулятор тока тоже все ок потребляемый из сети 0,4А напруга на держак 58в все осцилограммы без нагрузки на выходе напруга 220в 10в клетка 10мск одна осцилограмма 20мкс Нажмите для просмотра прикрепленного файла
Нажмите для просмотра прикрепленного файлаНажмите для просмотра прикрепленного файла[attachment=
11181:05012011009.jpg]
Следующий этап под нагрузкой беру реостат примерно 1Ом выход на него питаю управление начинаю подовать силу регулятор тока максимум дохожу до 70-80в возникает свист питаниие отрубается как я понял срабатывает защита по току????? убавляю регулятором тока задание все приходит в свое русло повыщаю напругу латором опять свист короче задание на минимум поднял напр до 130в выбило 6 амперный автомат зафиксировал потребление 13А из сети кто знает это нормально или нет почему защита срабатывает??? Времени уже не было завтра автомат пятнашечку поставлю попробую.В процессе всей этой возни ферит разогрелся до 50градусов.
Щупы проверить не знаю как померял емкость 100пФ поменял полярность 80пФ.
вчера в чип дип заказал е65 N87 две пары сегодня счет прислали с риквезитами все это удовольствие на 1000 русских рублей может кто заказывал не давно где или знает это дешево или дорого???
HEMELL
[quote name='tnttnttnt' date='5.1.2011, 18:22' post='164246']
Хоть какой нибудь знак припинания, хоть какую б нибудь запятую поставили бы, ведь нельзя же ничего понять.
lera
tnttnttnt. сделай осцилки в полный рост и импульс пошире. может что и увидим.
Summon
А ассоциаций нет никаких? 6А автомат, 13А кушает нагрузка, выбило?
tnttnttnt
Срабатывает обратная связь по току со свистом!! Почему выбивает автомат всем понятно.
завтра сделаю покажу
Summon
Свист обычно означает что не правильно установлен ТТ.
Если так глумиться над автоматом то не факт что не он вам свистел что мол хорош.
С таким описанием думаю мало кому что то понятно если вообще понимающий найдется.
