Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
Д713
Да и баллон с аргоном как-то не очень эстетичен в коровнике или на огороде.
да уж,с флягой сивухи -ни в какое сравнение,просто портить обстановку... icon_biggrin.gif
витя
golub. Спасибо.
svarnoy12
Д713, тема аргоновой сварки мне очень интересна,я сделал себе бармалееподобный аргонник с осцилятором.Реализована также продувка газом после сварки(можно также реализовать режим пульс) но как организовать плавный спад тока без проца - может поможете?
Д713
..но как организовать плавный спад тока без проца - может поможете?
очень просто-отводите дугу в сторону и усё.
ловкость рук и никакого геморройного "проца".
дырочка в кратере заваривается за 1 секунду стандартным образом.
svarnoy12
Этим способом пользуюсь уже давно,(если с присадкой то в конце шва можно ускорить ее подачу с одновременным уводом дуги).А вот на фирменном аппарате где есть функция заварки кратера все намного проще-при большом количестве коротких швов (которые потом полируют) здорово сокращает расход времени и нервных клеток.
Д713
Цитата(svarnoy12 @ 21.7.2010, 18:13) *
Этим способом пользуюсь уже давно(если с присадкой то в конце шва можно ускорить ее подачу с одновременным уводом дуги), но на тонкой нерже(скажем 0.5 мм)способ не работает.
какой ток минимальный?
для 0,5 мм более 15 А не надо.
реализовать снижение тока при отрыве дуги видимо можно отслеживая напряжение на дуге,но меня это пока не интересовало.
svarnoy12
От 10А с вариациями.Может еще кто подкинет идейку?
Д713
что должно являться сигналом для снижения тока?
RUS5610
Немного фотосов швов,тренировался немного
svarnoy12
Д713 сигналом будет отпускание кнопки на горелке(при отпускании кнопки реле коротит 1ю ногу уськи на землю-это сейчас так).
Д713
Цитата(svarnoy12 @ 21.7.2010, 18:48) *
Д713 сигналом будет отпускание кнопки на горелке.
какое процентное снижение тока оптимально?
svarnoy12
Примерно половина от установленного до 10сек(в зависимости от толщины деталей),потом резкое выключение.
Д713
пошел думать.
sorry
Если можно пару вопросов: 1. Какой марки электрод? У шва цвет синеватый. 2. Как я понял это труба и шов просто на неё положен? Или трещину заваривали? Считаю швы которые ни чего не соединяют баловством и выполнить такие намного проще нежели сварить трубу в стык например.
RUS5610
1,Даже не помню марки электрода. 2,Это труба угадал,заваривал трещину 3,Я так балуюсь и шалю и в стык так же варю.Надо же руку набивать на таком баловстве!
Сварочник голый Бармалей .
САНЕК
Цитата(Д713 @ 21.7.2010, 21:04) *
пошел думать.
А проциком не проще????????
Я уже предлогал ёмкость,не хотят.
DGEC
По поводу процика - вроде всё понятно - но как шить - чем - не догоняю хоть убей - никогда с прошивкой не приходилось работать. Ветки где бы серьёзно меня тугодума с процами общаться научили - не нахожу - чтоб от А до Я. И у многих или некоторых я думаю те же заморочки!
Д713
как раз как и чем шить не вопрос,вопрос-что шить,и насколько это необходимо?
DGEC
Вот видите - у каждого свои вопросы
Д713
ситуация довольно простая-либо сами пишите программу с глубоким пониманием процесса,либо становитесь заложником "писарей" со своим пониманием.
шоб писать самому нужно отсидеть пару сотен часов за этим делом,причем без гарантии результата.
САНЕК
Начинающие не представляют всех схожностей,или всей простоты,данного проекта.А по теме,согласен,будет заложником.
DGEC
Это мне понятно, но нужно с чего- то начинать Сам программатор собрать, программу(желательно на русском - если существует) а потом уж 200-700 часов за написанием после нескольких проб чужих программ А сколько ищу - всего этого добра великое множество и с чего начать - не пойму
Но это всё отвлечённая лирика не в тему!!!
svarnoy12
Д713,можно без процика сделать правда ступеньчато,блин хотел с-плановскую схемку вставить- почемуто нельзя?
САНЕК
Ты её запихай в ZIP.
Д713
Цитата(svarnoy12 @ 22.7.2010, 9:27) *
Санек,Д713 гляньте.Вот что получилось-в делитель добавляем резистор который даст нам ток спада,обрывом земли делителя отключаем шим через заданное время.Если что не так поправьте.
вроде все понятно.
у меня есть регулируемый 1-4 сек пост-газ,реализованный как раз на реле с таймером 555,можно его задействовать,расширив диапазон до 10 сек.
сброс тока видимо лучше сделать регулируемым.
svarnoy12
Согласен добавочный резистор может стать реостатом,а реле на полевике у меня работает в таком виде как нарисовано для обдува шва газом после сварки(задержка до15сек. подбирается резистором паралельно электролиту,вместо оптрона-реле с блокировочным диодом).А так спасибо за участие,может еще чего полезного вместе придумаем.
Серёга Я
Доброго
всем дня. Мой вопрос о правильной намотке Тр-2 по схеме Бармалея завис
в воздухе. Подскажите, пожалуйста, как все же его правильно намотать ?
allhimik
[quote name='Серёга Подскажите, пожалуйста, как все же его правильно намотать ?
[/quote]
Сначала мотаешь в два провода обмотки I и IV, затем II и III, те что идут на драйверы, ну и не забываем о хорошей изоляции между обмотками.
Lemm
", Бармалей мотал в 2 параллельно первичку и размагничивающую обмотки чтобы приблизить их ближе к сердечнику и уменьшить рассеивание , и возможно - повысить эффективность работы размагничивающей обмотки , а уж потом по очереди обмотки питания драйверов . " - это на скорую руку выдрал из архива 2005 г. а все остальное вроде есть на схеме . а вообще можно мотать и на Ш7х7 (больше места) , лично я мотаю на ЕЕ25 - они и на ТОР224 в БП идут и на ТГР .
RUS5610
Если есть колечко то мотай в 4 шнурка одновременно.
Серёга Я
Благодарю всех ответивших на мой вопрос. Буду мотать в два провода 1и4 обмотки,а затем 2и 3 раздельными обмотками.
Lemm
Да , но и они (2и3) должны охватывать весь сердечник равномерно , если это кольцо .
Алекс_Н
Доброго времени суток. Есть деталки: G4PC50UD 4 шт., 150EBU04 4шт., HCPL3120 4шт., феррит 3 компл. Ш20х28, БУ на 3846(двухтакт, но пойдет и на однотакт). А, ещё где-то валяется строчник от монитора ымпортного, пойдёт на дроссель?
1. Получится ли из этого сверкальник на 160-170 ампер?
2. Где взять схему бармалейника на такой ток? И с оптодрайверами? у меня есть схема на 100А в корпусе АТ. или делать по ней, тогда на мой взгляд там надо всё равно некоторые детальки помощнее.
ЗЫ. Скачал первые 3 ветки, читаю...
yjriy
Таакс, с резонансником покончено, ну тогда собирай
http://www.electrik.org/forum/index.php?showtopic=13202
Там паравоз всем его разжевал до состояния сборки на скорость как калашА, за 40 сек.
Или Дантист на дровах схэ выставлял, но сам делает на ТГР
Алекс_Н
http://www.electrik.org/forum/index.php?showtopic=13202...
Не покончено. Пока что. Я думаю. У меня там проблемы с ТТ, а ты на личку не отвечаешь... (на ликбезе в последней странице написал, недели полторы никто не отвечает...)
RUN1
Парни а вот эту схемулину можно под косого подстроить и проц как то прошить из ходя из схемы а то я в процах балбес совсем))) и чет не пойму как тут за током следятНажмите для просмотра прикрепленного файла есть еще схема резонансника на таком же процике но тоже блин без прошивки
STASKIN
Санек! А ты вот возьми и создай тему по програмированию и написанию програмулек,и самое главное по пониманию процесса програмного управления ! Ты я знаю сам потихоньку изучаеш,а тут глядиш и людишки подтянутся-сами научатся и другим подскажут!
Лопух
Цитата(gyrator @ 25.7.2010, 17:13) *
... для умеющего варЫть-оне не нужны, а не умеющему варЫть-и примочки не помогут.
Абсолютно верно. Ранее утверждал то же самое.
САНЕК
Всё таки создал тему по оцифровке,теперь постим суда http://www.electrik.org/forum/index.php?showtopic=19865
svarnoy12
Gyrator,я понимаю что мой вопрос здесь не очень актуален,но может подскажеш как заставить бармалейник плавно (до 10сек) снижать ток в конце сварки,а то уменя как-то через коленку получается а с проциком не хочется связываться?
Алекс_Н
Это как, в конце смены или в конце электрода, или ещё в каком-нить конце? Как дать зелёный свисток бармалейнику, чтобы начал уменьшать? Откуда он узнает, что через N секунд конец сварки?
Народ, где всё-таки искать схему с оптикой?. Проверенно рабочую.
yjriy
В ПА это нужно, вот те СХЭ дантистом нарисованная с управой по среднему, Голубом предложенная
С твоих железяк от резонанника в аккурат полтора Дантиста выйдет, а то и два почти
svarnoy12
Алекс Н схема интересует для аргонника,сигналом для плавного спада тока служит отпускание кнопки на горелке.Сейчас кнопка управляет реле,которое коротит 1ю ногу уцешки на землю своими нормально замкнутыми контактами.
svarnoy12
Спасибо, будем пробовать.
DANTIST
Извиняюсь, конечно, что отвлекаю народ от решения такой могучей проблемы, как стопорение сварочника в конце работы. Похоже - это выльется в докторскую диссертацию.
У меня вопрос проще. Скажите, пожалуйста, кто как делает отверстия в плате под плоские выводы? Типа под мост выпрямительный.
САНЕК
Я сверлю отверстия,потом в микродрель стомат фрезу,и всё нормально.У стоматологов там выбор фрез большой.
DANTIST
Цилиндрическим бором, вы же -"дантист"
Хвостовик варварски укорочен пассатижами.
[/quote]
Gyrator, у тебя хорошие пассатижи. Или хреновые хвостовики... Я хвостовики отрезаю болгаркой.
К стоматологии я не имею практически ни какого отношения. И слава Богу. Но боры использую часто. Все приличное, что было, поломалось. Видимо, нужно приобретать какой-нибудь приличный инструмент. А-то в моем цанговом зажиме на движке пока отцентруешь бор... Из-за биений они и ломаются.
Но тот бор, что на твоей фотке, врятли сломаешь. Если сравнить с хвостовиком - мм 2...2,5 будет. И что ж за диру им можно пробурить? Нужно хотя бы 1...1,2 мм диаметром. А таких че-то не могу найти. Можно сломанным сверлом. Пробовал - не очень производительно и удобно. На выходных купил какой-то бор с якобы алмазной крошкой. Худой. Сегодня попробую.
ACER
Подскажите как определить проницаемость феррита от сопротевления?
Maxim_Z
Главное-никакой оптики для гальваники,
Дада, за это стОит бороться (смайлик с большим пальцем). МСМ, оптика тут, от сварочной цепи -> втуда - для слабакоф и долб...icon_mrgreen.gif.
Недавно мучал по мотивам известного "т-ра напряжения постоянного тока"
Ну, го... э-ээ, не очень, на переходных режимах, пульсациях, шуме.
Надо попробовать из А.С. №1695465 . Спасибо, gyrator.
AlexNik
А чем данный СХЭ отличается ? Тыцните где обсасывается этот СХЭ.
