Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
spesso
Цитата(RUS5610 @ 1.6.2010, 11:37) *
Коля я бы рекомендовал собрать одноплат Д713го который Кузьмич выкладывал.
Это тот который в SMD?
golub
Цитата(kyzmi4 @ 1.6.2010, 20:06) *
Коля,сделай корпус покрасивее да продай его нафиг
довольно рискованный совет
STASKIN
Кузьми4 вариант в SMD невыкладывал.
Чем рискованный?
Д713
Чем рискованный?
первый выход на рынок сварочных устройств не должен испортить лицо фирмы.
kyzmi4
Я выкладывал этот
http://s41.radikal.ru/i092/1006/9e/bcadec4eb7fb.jpg
Отличная разводка,нет никаких ляпов,вообщем молодец Автор.
Самое то для начинающего,и ничего не болтается и не нужно соеденять между собой платки.Хотя может место побольше займет,но зато все понятно и детальки подписаны.
Коля
Цитата(Den2 @ 1.6.2010, 18:11) *
Даже тюменские должны иметь какую-то марку
SE 46- довольно распрастранённая вещь.
Цитата(RUN1 @ 1.6.2010, 18:45) *
Колян не парся току маловато для тройки хотяб 120 ампер надо icon_smile.gif в моем АТХСЕ 120 макс ток уонки отлично горят но метал 5мм уже тяжело прогрет 3 отлично проваривает icon_smile.gif
А чтобы добавить ток, нужно уменьшать резюк который 1,5 кОма или 620 Ом?
Цитата(kyzmi4 @ 1.6.2010, 21:06) *
Коля,сделай корпус покрасивее да продай его нафиг icon_biggrin.gif И сделай себе нормальную сварку,чтоб с током проблем небыло,ампер так на 160.Небольшие габариты и вес конечно хорошо,но и про остальные параметры забывать не стоит.160амперным можно и резать и варить.А соткой только прихватывать.
Разводи "одноплат",закупайся строчниками и охладителями(которые побольше) и вперед!Кстати цена не особо сильно отличается,а вот параметры...
Я ни в коем случае ничего не навязываю тебе,почитаешь да и все!И сделаешь как надо тебе,а не мне icon_biggrin.gif
Смысл продавать? Пускай она у меня лежит и пылится! Строчников не надо, у меня есть три комплекта ш 20*28 icon_biggrin.gif
А где вы здесь начинающего увидели? icon_biggrin.gif Я же свой, VIP icon_biggrin.gif
Кстати, 50 электродов двойки пошли как по маслу. Радиаторы теплеют и всё! Для верности сметрел температуру и на ключиках- всё в норме. для двойки ПВ- 100%- радует icon_biggrin.gif Держак и масса уже есть, осталось корпус сотворить и будет красота! Провода от термодатчиков просто торчат невключёнными. Думаю... А нужны ли они? Ответ... Нужны!
kadet
Стыдно не знать такое VIP'у! Для увеличения тока нужно увеличить напряжение на ноге UC.
Коля
На какой ноге? ( если не сектрет). Я ещё про тт вспомнил. по-моему люди с его резюком и мутили. ПОДСКАЖИТЕ номер элемента и номинал! Пожалуйста! Хочется попробовать побыстрее!
kadet
Переменный резистор вместе с соединенными к нему постоянными образует делитель напряжения. Чем больше напряжение - тем больше ток. Значит нужно уменьшить тот резистор, который соединяет переменник с 8-ой ногой!
Цитата, чья не помню:
Расчитывается по формуле:
I(max) = N*Uпор/Rs
где I(max) - максимальное значение тока перед ограничением (амперы)
N - количество витков вторички трансформатора тока
Uпор - порог ограничения компаратора контроллера (вольты)
Rs - внешний резистор обратной связи по току (омы)
Так, как у UC3845 - порог ограничения тока 1 вольт (третья нога) , то для UC3845 Uпор = 1 вольт, поэтому из формулы выбрасываем, что толку на один умножать
Поэтому получаем:
I(max) = N/Rs
Посчитаем маленький Бармалея:
N=50, Rs = 1,5ом
I (max) = 50/1,5=33A
Если сопротивление резистора уменьшить до 1ома, получим ограничение на 50А
I(max) = 50/1 = 50А
Того же тока можно добится и при 100 витках в ТТ, но сопротивление будет:
Rs = N/I(max) = 100витков/ 50A = 2ом
Короче всё просто.
А типоразмер кольца любой больше К16. Ставь К20 2000НМ и будет тебе счастье.
кабельщик
Коля, kadet, потратьте всего ничего времени (полчаса-часы от силы) почитать - как оно работает внутри UC384х.
Просто распечатайте даташит (где-то тут даже был русифицированный) из нескольких стр., разложите и внимательно прочтите...
Если работа операционного усилителя вам знакома, то и с усилителем ошибки UC384х разберетесь.
Надо б заказать на Discovery тематическую серию "How It's Made..."
Иванн
Цитата(kyzmi4 @ 1.6.2010, 23:53) *
Я выкладывал этот
А вы не подскажите, есть лучшего качества? Может с расширением программы оригинала? Зарание спасибо.
Коля
Кабельщик, не говори загадками! Так, если я сейчас тот резюк убавлю до 1,2 кОм, то возрастёт ли максимально заданный ток?
KLIM
Коля - не мураводь.... чем задается ток??? Намекну - не регулируется а задается. Разберешься - сам тогда всё и поймешь. Я ведь не от ехидства не говорю да и Кабельщик тоже не издевается. Мозги тебе тренируем, им тогда легше руки твои беречь станет!
Коля
Клим, блин, ну я прав? Ток задаётся до определённого уровня. Как только с тт идёт сигнал на какую-то ногу уськи. Компаратор сравнивает напруги и выдаёт или 0 или 1 и так на каждом цикле. Задатчик регулирует это напряжение и таким образом сравнивает уровень порога срабатывания уськи. Примерно так я представляю. Блин, ну скажи, сижду жду ответа- охота проверить! Не томите! Мозги потом натренируем!
1) Короче надо сопротивление на 3 ногу уськи 150 ом поменять на 180т ом?
2) Надо шунтирующий резюк тт уменьшить до 1 ома
3) Надо у задатчика резюк 1,5 ком поменять на 1,3 ком
Какой ответ правильный?
golub
А вы у автора поспрошайте. Только не забудьте что у Д713-го всё подписано и думалка у лихих повторяльщиков отключается на тему- что для чего.
Коля
Короче посмотрел по 165 версии- вариант первый отпадает.
Либо два либо три.
Третий вариант? Нужно резюк 1,5 кОм поменять на 1,3 кОм ? Ну, КЛИМ! Говори!
gynik
Цыганка с картами, дорога дальняя (С) (2).
Коля, дык ты сам проверь варианты - времени много не займёт.
Коля
Но думаю, что резюк на тт нужно до 1.3 ома уменьшить. Ведь тогда мплитуда сигнала уменьшится и уська будет регулировать на более высоком токе. Я прав?
И какой номинальчик, если не секрет? 1,3?
Ехали цыгане не догонишь
Пели они песни не поймёшь
И была у них гитара не настроишь
Вообщем ничего не разберёшь
Делали сварные не догонишь
Делали инверторы- не поймёшь
И были у них аппараты не настроишь
Вообщем ничего не разберёшь.
Долой эксперименты! icon_biggrin.gif Мне же нужно за резюком в магазинчик поехать! Или сразу взять номиналов 10?
Поставил два резюка последовательно 0,68 Ом. В результате 1,36 ом. ТРОЙКА ШПАРИТ ОТЛИЧНО! Для металла 2-3 мм- самое оно! Я доволен! Да вот только после электрода радиаторы горячие ( рука спокойно трпит. Думаю ПВ будет где-то 1 электрод тройки- пол минуты отдыхаем.
RUN1
Колян вообще то у тебя с 1,5 должно 100а быть макс тока поставишь 1,3 на 15 ампер подпрыгнешь icon_smile.gif если ктр у тебя 3
gynik
Про ПВ надо сразу думать. Вентилятор попроизводительнее поставить. О производительности косвенно можно судить по току потребления (если это компьютерный кулер), ну или кулер 80-ка на 220в, если корпус то БП АТХ. Ну и ток надо бы померить, чтобы потом знать при повороте ручки регулировки где какой ток будет.
kyzmi4
Забирайте:
http://slil.ru/29255670
Коля,где и по чем брал???
Иванн
Цитата(kyzmi4 @ 2.6.2010, 12:18) *
Забирайте:
Большоее спасибо!
KLIM
Коль, ты мне описал легулировку.... а я говорил о том относительно чего пляшет регулировка.... Способы регулировки мне не интересны в НАШЕМ разговоре. По сути можно снять абсолютно всю регулировку и оставить датчик тока с его цепью и О чудо - аппарат выдаст те самые 100А.... но которые ты его настроил...
Думай Коля почему????
Коля
Откуда ктр 3? Если первичка 35 а вторичка 10, то к. тр. 3,5. Всё как в оригинале! Только частота у меня 40 кГц ( напруга у нас 240 вольт, вот и поднял). Не мерил ток, но уже наверно точно больше стало. Тройка горит нормально. Раньше хреново горела. Наверно ампер 100 будет. Потом скажу.
Цитата(kyzmi4 @ 2.6.2010, 13:18) *
Забирайте:
Брал у нас в городе по 120р комплект ( уже точно не помно, но где-то так). Третий комплект сломан и склеен. Сейчас эта фигня у нас стоит 240р комплект. Об этом уже писал. Реально подтверждаю, что цены у шустрых барыг растут пропорционально популярность в интернете. Так они на сайтах подобных этому сидят и смотрят- спрашивают шашку 20*28- опа, а давай-ка я цену в два раза подниму, один хрен купят!
У меня мозг накаляется icon_biggrin.gif Вентилятор мощный нужен icon_biggrin.gif . Клим, конечноя не против бы узнать как это чудо работает, но если я не въёзжаю, то подобные загадки не просто не помогут мне узнать истину, но ещё больше запутают. Уже поставил 1,3 ома- ток повысился. Выходит следующая картина: сигнал с тт ( ну для примера предположим) 1 вольт на 100А при таком напряжении уська ограничивает ток методом уменьшения длительности сигнала. Если мы поставили сопротивление, шунтирующее тт, меньшего номинала, то в этом случае падение напряжения на этом сопротивлении будет больше и скажем при 100 амперах не 1 вольт, а 0,5. В этом случае уське похрену и она никак не реагирует на это и следовательно не ограничивает длительность. При такой длительности охреневает сопротивление сварочной цепи и ток там повышается скажем до 120 ампер, в это время к уське подходит уже сигнал амплитудой 1 вольт и уська обрубает длительность сигнала. Я прав? Если нет, то объясните потолковее!
Кстати, на сотку ставил два предохранителя один на переменке, другой на постоянке по 15А. Так вот, по постоянке предохранитель не выдержал и сгорел. Вывод- для тройки FUSE надо 20 ампер ставить.
kyzmi4
Я по 250р нашол за комплект...
Буду заказывать.
RUN1
[quote name='Коля' date='2.6.2010, 15:09' post='137227']
Да точно Колян я чет запарился тыж сотку клепаешь один в один ,но тогда и подавно 100а должно быть icon_smile.gif ну да ладно поднял хорошо только не переусердствуй icon_smile.gif
Коля
Да уже всё нормально, тройка идёт хорошо, да вот я буду ставить резюк на тт 1,2 ома. Пусть запас небольшой будет при кз во время каплеотрыва ( или как там). А двойка идёт как спичечка. Больной вопрос- это корпус. Хочу это дело в корпус от упса впихнуть. Будем пробовать!
Я остановился на 40 кгц. Больше нету необходимости подниматься.
Буду заказывать.
Заказывай. И знай- дуракам счастье icon_mrgreen.gif (шутка)
kyzmi4
Заказывай. И знай- дуракам счастье (шутка)
Да,дураки в последнее время оборзели,только цены и поднимают.
Коля
Значит везде такие? Я думал что только в нашей провинции. А откуда ты?
kyzmi4
Значит везде такие?
Похоже что да.
А откуда ты?
Из Питера.
Коля
Цитата(kyzmi4 @ 2.6.2010, 17:31) *
Из Питера.
Не может быть! В самом Питере нет шашки 20*28, что его приходится заказывать? Незачто не поверю! С такой прогрессией скоро и в Москве ферритов не будет.
spesso
Из Питера.
В Питере самые крупные в России конторы по торговле Ферритами, круче только в Китае да на Украине.
http://www.rusgates.ru/index.php
http://ferrite.ru/
Den2
[quote name='spesso' date='2.6.2010, 16:46' post='137272']
Да, приятно осознавать что на Украине есть что-то крутое icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif.Да Терейковский очень адекватный, все без обмана!
spesso
А как же, http://www.ferrite.com.ua , Терейковский А.С. очень адекватный товарищ.
Коля
Да только об этом Терейковском постоянно и слышу. Во всех частях бармалейника и не только о нём говорят.
Полные координаты Терейковского:
Артём Терейковский
(8-057) 757-2859
(8-057) 720-5916 факс
8-050-323-37-63
8-067-575-44-40
ICQ: Ferrite (193635454)
www.ferrite.com.ua
Цитата(DGEC @ 2.6.2010, 18:36) *
А я не понял - к чему это сказано. А у тебя Коля не звёздная болезнь?
Да я просто решил по поиску на этом сайте найти "ТЕРЕЙКОВСКИЙ" Дык там страниц- как конь н@срал( или н@ипал). Очень много люди про него вспоминают. И все хорошее про него пишут. Наверно человек действительно по-человечески нормально работает. Вот в одном из сообщений я и нашёл эти данные. Глядишь кому-нибудь и пригодятся. Собственно к чему это я ? Да к тому, чтобы после просмотров этого сообщения цены на ферриты упали. Надеюсь совесть у барыг проснётся icon_biggrin.gif
Ладно народ, хорошь флудить, сейчас Санёк с веником появится...
RUS5610
Я сам когда отдыхал в Евпатории заказывал у него Е70. Ночным экспрессом получил через день.
Коля
Вот я у него на сайте порылся, нашёл пару вариантов замены етд59, с круглым центральным керном, которые больше етд.
http://myfolder.ru/17996258
Что скажете? Думаю, с таких сердечников токи можно снять поболее, и намотка удобная.
Иванн
Если не в лом, посмотрите пожалуйста на осциллы: КЭ нижнего ключа
1 - без зазора
2 - 0,35мм
3 - 0,7мм
Транс 15/5 2Е70, частота 39кГц, при изменении напряжения спад остается таким же.
Думаю оставить 0,35, но не великоват ли спад? Чем грозит?
З.Ы. Только не говорите что многократно обсуждалось. Трудно новичку разобратся в 1000 страницах форума, 50% (если не больше) флуд.
gynik
Судя по картинкам, зазор не нужен
Иванн
А не опасно?
Basill
У меня в первенце точно такой транс (2хE70, 15x5). Частота 31 кГц (можно и меньше, взял с запасом на 250 В сети, нагрев и пр...). Осциллограмма очень похожа на первую. Зазор суммарный 0,1 мм (слюда 0,05 мм по всем кернам). При работе феррит не греется (слабый обдув). При сборке, шашки попарно склеивал боковинами с нивелировкой по стеклу (технологию подробно рассказывал и показывал). Сейчас думаю, это лишнее. Судя по вашей осциллограмме, такой зазор в "монстре" получается автоматически, если не предпринимать специальных мер. Я бы остановился на первом варианте, если уж заходить на "монстра" типа 2хE70, да ещё и 39 кГц (!). Если проверить калькулятором Лысого, я думаю второй и третий варианты отпадут сами собой из-за большого тока намагничивания (недостаточной индуктивности нагничивания).
golub
А зачем на 40 кгц два сердечника? одного с головой хватит.
Иванн
По осциллу смотрел, разницы никакой. Ну я раньше этого не знал и поэтому брал все про запас. Транс уже намотан, так что оставлю так.
Посмотрите еще пожалуйста: на ток намагничивания рис1 (линия плавная только иголки в верху и в низу) - пойдет?
и КЭ при макс. и мин. задатчике - рис2.3 (на выходе 25А и 10А соответственно). Все при зазоре 0,35мм
Basill
Форма пойдёт, а чтобы сказать про величину тока, надо знать сопротивление резистора в калькуляторе и масштаб осциллграммы по вертикали.
Иванн
Сопротивление - 1 Ом, масштаб уже не помню, посмотрю дома. А индуктивность первички разве не нужна (с этим проблема, нечем мерять)?
Лопух
Зачем индуктивность? Это же не flyback. Тут важнее индуктивность рассеяния. Но раз транс уже намотан, тут уже какая получилось. И если уже транс на 2-х Е70, я бы снизил частоту. Полупроводам полегче будет. Впрочем, дело хозяйское.
gynik
А я бы повысил частоту, и провод квадратов 5/25. А то при такой площади транса не эффективно использование сердечника. Одного комплекта в принципе хватает. Но клиент не пишет, что он хочет на выходе, как тут чтото говорить? Только догадки... И неизвестно, какие транзисторы и т.д. и т.п.
Лопух
Цитата(gynik @ 3.6.2010, 13:38) *
А я бы повысил частоту...
С какой целью? Чем выше частота, тем напряжней ключам и выходным диодам.У человека транс уже намотан с запасом и не оптимален даже на 40 кгц.
Иванн
Хочу получить до 140А-160А. Сечение 4,6/16,5. Насчет 2Е70 согласен что много, но транс. уже намотан, а он мне не просто дался. Транзюки полтиники наверное будут с индексом U (какие есть). Частоту буду понижать, где-то до 30кГц. Правильно?
Из даташита на 50U: 40кГц - 22А, 30кГц - 25А
Лопух
Видимо, потому, что переключится 30000 раз в секунду легче, чем, скажем, 50000 раз. Не надо забывать, что у IGBT существенные потери на выключение. При каждом переключении транзистора появляется коммутационный выброс до нескольких киловатт (величина выброса зависит от снаббера). Соответственно, при увеличении частоты увеличивается количество переключений и растет тепло на ключах. У выходных диодов та же картина.
И еще раз обращаю внимание : человек уже намотал транс (2хE70, 15x5).
Вот что писал сам Бармалей:
Цитата(barmaley @ 7.7.2006, 17:51) *
если ты надеешься так снизить нагрев ключей, то ты сильно заблуждаешься или чего-то не заметил icon_biggrin.gif Поднимать частоту ... полный бред, нагрев всего, по сравнению с 30-40кГц, будет жуткий , вылезут и другие проблемы, намотать хороший и правильный транс на высоких частотах не просто, так что, чтоб уменьшить размеры сварочника частоту надо понижать, понижать на столько, на сколько позволяет транс, иногда даже лучше плотность тока в обмотках сильно поднять, чтоб витки на низкую частоту влезли и обдувать сам транс, чем задирать частоту...
