Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
Dimon4ig
А сама надпись правильно отбражается, ато она какаето нечитаемая получается, если не знать что это остановка по перегреву.
Проверил все, везде нормально, я даже пробовал амперметр вместо датчика подключать, там ток 7мА протекает, былбы обрыв-токаб не было. может что с прошивкой не то?
oleg1ma
Цитата(isirx @ 27.1.2013, 0:53) *
Уважаемый Олег , Вы принтером печатаете на глянцевой (мелованой) бумаге из журналов ,
или на основе от бумажной самоклейки ?
как переносите на обезжиренный стеклотекстолит ? Утюгом или в ламинаторе ?
Бумага глянцевая 80г/м2 для сруйников.Ничего не обезжириваю, поступаю так:беру два небольших кусочка мелкой наждачной бумаги и одной рукой через наждачку прижимаю плату, а другим кусочком зачищаю всю плату, равномерно без пропусков.Самое главное не залапывать плату руками.Потом аккуратно беру платку за края и вытираю с нее медную пыль, накладываю лайку и с каждой стороны укрепляю полосочками малярного скотча.Катаю утюгом, довольно долго, минут 10-15(утюжок слабенький, наш всего 750ватт), пока бумага слегка пожелтеет.Сразу же кидаю после утюга в горячую воду, которую ранее поставил возле себя.А со всевозможным обезжириванием, толи это спирт или растворитель или гала, у меня не пошел, результат раз через раз, как говорят.
Надпись должна быть, как на фото, а у тебя еще два лишних сегмента горят.Скорее всего где-то еще есть сопля, хорошо вымой плату растворителем и проверь на наличие косяков.Проверь, как меняется напряжение на 10ноге пика когда коротиш датчик, скорее всего у тебя короткое между 10 и 11выводом, проверь.
Dimon4ig
короткого между 10 и 11 нету, при замкнутых датчиках напряжение на 10 ноге 2,23В при разомкнутом 2,73В.
oleg1ma
Замкни 10вывод на минус, что изменится?
Dimon4ig
замыкаю, защита отключается, но все еще подсвечиваютя лишние сегменты( другие), вот фото:
получается сопротивления в 300 ом много для этой цели. и еще на кнопки не реагирует,когда в " рабочем" режиме. долженли он на этом этапе реагировать?
oleg1ma
Вынь процик и включи без него.Где-то ляп, мне плоховато видно от сюда icon_biggrin.gif С делай фотки со стороны печати
Dimon4ig
вот фото:
http://s019.radikal.ru/i602/1301/fd/c841868c4e9a.jpg
чтоб лучше видно было-сфотал только область проца и индикации. при извлечоном проце на индекаторе не каких признаков жизни.
на этом этапе на кнопки оеагировать долженже?!
oleg1ma
Нечего фактически не видно, вот фотки с нормальным разрешением, смотри и сравнивай. Платку индикаторов тоже проверь хорошенько, тр-ры прозвони, а в последнюю очередь если ничего не найдеш, сотреш процик и зашьеш поновой прошивку.
Dimon4ig
процик пробовал перепрошивать уже, пробовал разные прошивки, никакого эфекта. буду искать на плате тогда. подскажите как Вы уменьшаете и куда заливаете фотки.
oleg1ma
Выкладывай на сторонний ресурс,( например тут) и копируй ссылу прямо в сообщение.
KT117
Dimon4ig , у меня один вопрос по плате-Не страшно +300В пускать рядом с низковольтной частью через остаток контура платы? icon_biggrin.gif
смотрите цепи с 10 ноги процессора на индикатор, где то залип
Dimon4ig
спасибо.
вот: http://ifotki.info/12/771f8adb1b09ae8512ea...902299.jpg.html
oleg1ma
KT117 еще просил меня ветку открыть, мне одного Димона .. за глаза icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif.На сегодня все.
KT117
проблема с сегментом D в последнем знакоместе. А так процессор честно пытается отработать , запуск идет штатно, сначала 8888, потом 20А (здесь видна засветка сегмента D, вместо А светится 8 ), и потом видя наличие напряжение на 10 ноге переходит в Er C
Ставьте перемычку в разьем Термо и смотрите наличие лог 0 на 10 ноге пика. проверьте номинал резистора на подтяжку к +, ну и на плате индикатора посмотреть ляпы
Dimon4ig
Кт117, там проблема не только с D сигментом последнего индекатора, также еще подсвечивается тотже сигмент на первом индекаторе, а при другой надписи совершено другие два лишних подсвечиваются, я уверен что былаб еще какая нибуть надпись, и на ней бы 2 лишних подсвечивались. тут проблема в том что используется динамическая индекация,невозможно отследить откуда косяк идет. и еще помимо всего кнопки не работают. Напомните пожалуйста напряжения логических уровней, ато давно с ними не сталкивался, на сколько помню лог"0" до 1 В а лог"1" от 3? это правильно? Кт117 по поводу низковольтной части и 300 в, я пользуюсь уже до меня разведеной схемой, у людей работет... Поставлю там в розрыв предохоонитель.
Олег и Кт117 спасибо за советы,буду все проверять.
KT117
http://clip2net.com/s/2LaJI
вообще то я говорил про остаток линии контура платы, который у вас соединен с +300в
Dimon4ig
аа,извините, сразу не понял. А что скажете по напряжению лог "1" и "0"?
Vs55
Dimon4ig, логический "0" это до 0,4 в, лог "1" - не менее 2,4 в
Dimon4ig
vs55 спасибо. кажется нашол я косяк, транзистор в цепи индикации 4 символа подозрительно себя ведет,то звонится, то нет, в общем выпаял я его, без него включаю- работает датчики,регулировка тока кнопками ну и все остальное, только вот естествено четвертый элемент индекатора не работает и некоторые сигменты других букв. вот так и доверей новым деталюхам. теперь не в жизнь нечо не буду впаивать без проверки( то что без впайки проверить можно). жалко нет в наличии такогоже транзистора, его кт315 можно заменить?
KT117
Заменить можно, а так же на С945, КТ3102
Dimon4ig
нашол в закромах транзистор,поставил-все четко работает.
пойду в закромах денег поишу и в космодром за ключиками)
KT117
icon_smile.gif Красота. Если 3120 установлены-можно проверить сигнал на выходе, на стабилитронах. Дальше-по инструкции
Vs55
Dimon4ig, поздравляю с победой. Там спокойно можно ставить КТ315. будут жить вечно.
oleg1ma
Свершилось, наверное будет неплохой день.
Dimon4ig
Спасибо всем за помошь, буду дальше собирать и бодатся с ним)
Олег, ну в даном случае не мой косяк был, а фирмы производителя транзисторов icon_biggrin.gif
oleg1ma
Твой, детали нужно проверять перед установкой.
ММихаил
Здраствуите. Скажите пожалуста а есть разница какая нибудь в сердечниках e20 и ef20 кроме как установочных горизонтальных и вертикальных по каркасам их. Михаил.
KT117
Разница только в каркасах.
ММихаил
Спасибо за ответ Михаил.
Dimon4ig
проконсультируйте пожалуйста по поводу трансформатора, пилить на 2/3 с одной стороны,или с двух? что потом с проптлом делать? залить лаком или эпоксидкой,или просто оставить? индуктивность должна быть 8,3мГн? витки как на схеме делать: 33 на 11?
Буду очень благодарен за ответы.
oleg1ma
Пилить с одной стороны, в пропил я заталкиваю толстые нитки и заливаю суперклеем.Как высохнет, лишнее обрезаю ножиком, потом порез обматываю двумя слоями малярного скотча шириной 10мм.Индуктивность уж какая выйдет, материал разный.Витки мотай 33/11.
Dimon4ig
Олег, спасибо.
oleg1ma
Тр-тор приложи к плате, маркером отметь где начала обмоток, потом мотай.
Dimon4ig
смотрел осцилки на управе вот на 10ой ноге 494, при замкнутом термодатчике
вот при разомкнутом:
как Вы кт117 и говорили,нужно резистор р10 подобрать.
вот на входе на стабилетронах:
частота 44,44444кГц заполнение 42,22222%
вот только меня смущает то что на стабилетронах 25 вольт,хотя они на 16.
Олег, извените за тупость,но немного не понял на щет отмечания маокером начала обмотки. всмысле на кольце сделать отметку где начало,или что?
KT117
Да, R10 нужно подбирать, никаких иголок быть не должно-ШИМ должен быть заглушен. Мне не очень понятны ступеньки на верхушках меандра-у меня небольшая иголка и ровная вершина.
По трансу-Олег предложил наметить начала и концы обмоток на сердечнике, что бы потом сразу в отверстия платы попали. Ну, и фазировку соблюсти-внимательно смотреть по плате icon_smile.gif
Dimon4ig
резистор уменьшил до 710 Ом, и шим заглох. ступенька на выходе я думаю это погрешность моего ослика, он у меня и на бормалее подобное показывал, меня смущает то что там 24 в а не 16, или это из-за того что нагрузки нету?
а пропил в 2/3 делать по высоте сердечника (25мм), или по ширине (12,5мм) на всю высоту?
KT117
Что то странно ваш ослик избирательно показывает погрешность-на ТЛке нет ступеньки . Нагрузка там есть-резистор 1,8 кОм. В отрицательном смещении драйверов стабилитроны на 10Вольт? И почитайте про настройку внимательно-сигнал должен быть размахом 23-25 вольт
По трансу-читайте посты Олега в этой ветке начиная отсюда http://www.electrik.org/forum/index.php?sh...44&st=11439
Dimon4ig
я когда бармалея собирал то на 3845 тоже ступеньки не было, была не большая иголка,а на стабилетроне была. А если это щитать как неполадку, то куда копать? тут и копать вроде как некуда,всего одна микросхема на каждый драйвер...
KT117
И на обоих выходах такая ступенька? Попробуйте нагрузить выходы емкостью на 6н8 или 10н и посмотреть сигнал. Может быть стабилитроны так режут верхушку?
Dimon4ig
Плату пролачил, пусть слегка подсохнет и попробую кондер подключить.
А пока она сохнет намотал первичку трансформатора, мотал двойным проводом по 1,77мм.кв каждый, в обшей сложности получилось 3,53мм.кв. Индуктивность обмотки получилась 6,7мГн, сойдет?
oleg1ma
Сойдет.
ingener99
Цитата(Dimon4ig @ 27.1.2013, 22:55) *
ПИндуктивность обмотки получилась 6,7мГн, сойдет?
это 33 витка на кольце без разреза?
Dimon4ig
ingener99 33 витка с разрезом.
Вот фото без вторички:
Кт117 такой сигнал на обоих драйверах.
поставил конденсатор 10н на выход получил:
ступенкя превратилась в плавный изгиб.
тут вот заметил что кренка на 5 вольт достаточно горяченькая, на нее в наших целях нужно радиатор цеплять?
KT117
Радиатор не нужен, если конструктив как у Олега- то очень хорошо обдувается.
Осчилки вроде приходят в норму. Стабилитроны на выходе управы на 18V ?
Dimon4ig
нее, стабилетроны на 16в, на 18 не было. стоят 1n4745А. а нужно обязательно на 18? я просто подумал что можно как в бармалее от 13 до 18.
Олег, какой у Вас вентилятор по размерам и производительности стоит?
oleg1ma
В такую конструкцию ставлю FD12038H220
Dimon4ig
пробовал подключить входную часть и управу через латр, нормальный запуск получается при сетевом напряжении не ниже 150в.
Олег, спасибо за инфу, в том магазине очень даже демократичная цена получается. вотбы найти в харькове за эти деньги. А Вы радиаторы покупаете? если да,то можно пожалуйста ссылку на те которые покупаете.
oleg1ma
Что-то многовато, вот посмотри почти всегда у меня так.Видиво
Dimon4ig
да,от 65 работает получается, у меня при низком напряжении отрубается и включается по новой,и так по кругу. но у Вас там релюха вроде не подключена? может она так влияет?! чтото получается в аппарате не продуман следущий момент: когда после работы сварчником его выключаеш от сети,то управление работает пока не разрядятся электролиты. чтоб этого не было придется в разрав между входом и управой кнопку лепить.
oleg1ma
icon_biggrin.gif Лепи Димон лепи, тебе видимо она нужна, мне нет.
