Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
DANTIST
Цитата(Александр_М @ 13.4.2010, 9:01) *
Подскажите в СПАРК диод VD6 который 5819 можно поставить BYV26D?
5819 - это диод с барьером Шотки. BYV26D не пойдет. 4148 тоже не работает. Как-то по не внимательности поставил, потом долго искал в чем же косяк.
sarmat
Позавчера писал, что запустил Спарк. Ток маловато был. Нашел косяк на печатке (писал о несоответсвии потенциалов на выводах 324-го) пайковая перемычка между выводами R23 и R27. Все убрал. При касании электрода ток валится на минимум. С4- 1н. Антистик не дает дуге зажигаться. Не так ли? Кто-то недавно тоже так мучился....кажется что-то с 620 к.
KLIM
Наоборот, при касании электродом ток должен идти на максимум, ограниченным или Защитой по току ключа или до установленного уровня а потом уже если не загорелась дуга 1-2 секунды уходить на минимум. На осцилле это выглядит как резкое увеличение и плавный спуск заполнения до минимума.
Александр_М
Это наверно у меня было....
У меня VD2 &VD3 стояли BYV26D заменил на 4118 и все устаканилось......
RUN1
Цитата(KLIM @ 13.4.2010, 12:30) *
Теперь осталось с таким к-тр проверить на слабой сети и в путь!
sarmat
Помучился и на сегодня оставил. Такая байда, дуга очень слабая, светится как ксенон, капли на металле от электрода, короче просто мажет. Ток примерно 20-30 ампер. Напряжение Х.Х 53 вольта, при сварке падает до 18-20 вольт. Просадки по сети и после конденсаторов не очень заметные. Задатчик тока мало влияет на процесс. На свежую голову еще поковыряю.... Может у кого была такая картина?
DANTIST
Посмотри фазировку сервисной обмотки. Она должна быть в фазе со вторичкой силового транса.
sarmat
Менял местами выводы сервисной обмотки. ТТ тоже, в одном положении свистит. Жалко балласта нет, осциллы можно было смотреть, что там происходит.
DANTIST
Зачем менять местами выводы обмоток? С начала глянуть осциллографом. Если все нормально, зачем менять? Здесь возможны 4 комбинации. Вообще-то не много...
KLIM
А может все таки вторичка силового транса перевернута?
sarmat
Сам тоже склоняюсь к этой мысли. Все собрано на "материнке" от Дантиста, выводы не перепутаешь (ближные к керну выводы как начало обмотки), хотя направление намотки вторички можно по запарке перепутать. На "материнке" расположение ТТ немного изменено от схемы скорее из-за удобства компановки.
Только сейчас проверил фазировки первички, вторички и сервиса. Подал немного силы, все три сфазированы как в схеме.
KLIM
А попробуй кондерчик с транзистора датчика тока на минус поставить 1n (C4 помоеу) Хотя это есть изврат НО для сравнения?
Скорее всего проблема в ляпе с пайкой или не тот номинал... мелочь незаметная icon_smile.gif
RUS5610
RUN1 Мои поздравления дружище!!! Молодец! Значит вольт добавка Клима вещь! Тоже хочу попробовать.
Wiew
это который с ТТ выпрямляет? странно что Вас не работали...
petr0757
Постоянно испытываю проблемы с заделкой наконечников на мощный кабель. Открыл, может всем известный, но не мне способ. В крышке реле, на печке плавлю припой.
Очищаю кончик кабеля (16мм2), окунаю во флюс ( Ф66Н), потом в крышку с расплавленным припоем. Зажимаю обуженный кончик кабеля в наконечник и опять в флюс и крышку с припоем.
DANTIST
Петр, а что ли у тебя нет паяльника ватт на 80...100?
Проверь еще раз внимательно пайку и монтаж. Я как-то перепутал фазировку вторички. Просто так было удобнее развести выводы на выпрямителе. Короче, получился не прямоход, а хрен знает что. Тока нет, хоть убей. Я даже представить не мог, что проблема во вторичке.
Поэтому все может быть.
На днях прикольный случай. Ремонтирую, условно говоря, китайца (по-нашему называется "Искра", на деле какой-то китайский мост тапа "Цай"). 300 В с платы выпрямителя подается на плату ключей запараллеленными в 3 провода шлейфами. 3 провода красных и 3 провода черных. Через разъемы. По необходимости разобрал разъем на плате выпрямителя. Перед сборкой вызвонил на плате выпрямителя + и -. В гнезда "+" разъема вставляю красные провода, в "-" - черные. Включаю через лампу 100 Вт. Лампа горит в полный накал.
Когда разобрался, оказывается на плате ключей черные провода подключены на "+", а красные на "-". Ну как их после этого называть? Или у них любимый цвет - черный. Пришлось и на плате ключей провода переставить.
Так, что надо искать. Где-то косяк.
petr0757
Паяльники есть любые. но не пропаивают. Паял ложа клему на плиту. Новым способом пайка получается идеальной, быстро, в восторге, никому не навязываю.
RUN1
RUS спасибо друг! Вот только как то кишки не совсем аккуратно получаются как парни умудряются по заводскому делать не пойму icon_smile.gif
Александр_М
А вот кто как ставит диоды на размагничивание..
В смысле сильно греються или можно на мелкий радиатор?
С ключами ставить не получаеться...
spesso
Ыыы, менял кондёры беременные, по выпаивал сначала все, поставил новые, включаю, пипец чё началось, фонтаны электролита, взрывы и разлетающиеся в разные стороны стаканы электролитов, почесал репу, посмотрел на обозначение полярности на плате, всё правильно, взял тестер померил и офигел, всё с точностью да на оборот. Так что, с китайскими товарищами надо быть на стороже, как говориться не верь глазам своим. Теперь всё время проверяю.
KLIM
Можно на мелкий радиатор, там от силы 5-6 ватт, если в обдуве - вообще малый радиатор сойдет.
кабельщик
Александр_М, диоды размагничивания греются не шибко сильно... То есть если они расположены в зоне ветра пропеллера, то охладитель им даже лишний будет. Если же они почти не обдуваются, либо вентилятор периодически глушится, то не помешает мелкий охладитель с полспичечной коробки...
Коля
Народ, никто не хочет поделиться со мной печатками сотки? Желательно с монтажной платой. Форум наверно с годами оперативность потерял icon_biggrin.gif
yjriy
Брось ты нахх ту сотку и слепи нормальный аппарт по выложенным и обсосанным схемам:
Д713, Электровоз, Голуб, Дантист-они все выкладывали готовые схемы, платы, описания и т.д
http://www.electrik.org/forum/index.php?showtopic=13202
Та-же сотка, но 170 Ампер-все подробно расжевано
petr0757
Цитата(Коля @ 14.4.2010, 17:32) *
Народ, никто не хочет поделиться со мной печатками сотки? Желательно смотированную и отлаженую, если можно в корпусе
yjriy
Де не, этому челу нужно помочь, у него есть громадное желание и весьма (никакие) малые понятия в электронной силовухе. Но вопрос в том, что кажись он зациклился на этой сотке, а она труднее чем полноправный чеппер в изготовлении ,.Был-бы ты с Украины, Колян, я-б тебе готовые платы и вообще готовый аппарат подогнал бы бесплатно на шАру. Валяется горелый косой под верстаком
Andrey_G
Я так же здоровые концы оконечиваю и лужу, даже самопальный лиц, а это вообще песня, сунул конец во флюс и в тигель, как вспомню что приходилось зачищать чуть ли не каждый проводок.... правда тигель у меня электрический. icon_smile.gif
Вот так делаю, т.е. диоды припаиваю к медной дороге под радиаторами.
Valter
Коля объявился. Улыбнуло. Дружище, не парься, купи готовый дэвайс, благо цены упали. Иначе соберёшь где-то после 3000-го
Коля
Эх, народ. Люди сейчас явно не те, что были раньше! Ладно по поиску в этом форуме найду что-нибудь. Если нет желания помочь, дык не издевайтесь. Желание заниматься электроникой огромнейшее. Те, кто предлагают мне купить аппарат меня вообще не понимаю. Мне кажется, что у вас сложилось впечатление, что я собираю данный аппарат из-за экономии, незнаю как вам, но мне смешно, а вернее грустно. Дело не в деньгах. Если бы мне нужен был аппарат, я бы его купил бы. Подсчитайте сами: Блок питания регулируемый 0-32V 0-5A стоит 3500, паяльник Lukey852d+ 3500, осцилл сага 1500, УПР ( универсальный прибор радиолюбителя) три в одном 2000, с1-101 1000р., амперметр на 500А 500р, тестер 500р, LC-метр 500р, клещи 500Р За 13500р я бы мог взять инвертор+аргоновый рукав, да вот вопрос: НАХ он мне нужен? Я занимаюсь этим чисто для себя. Уже хочу познакомиться с фоторезистом, да только он пока в магазине закончился
Вот таким людям отдельное спасибо, но аппарат-то мне сам не нужен, мне намного важнее процесс его создания, изучения радиоэлектроники. Ладно, чувствую самому надо рыть. Всем удачи!
Wiew
делал аналогично, и диоды специально для этого брал в корпусе D2PAK icon_smile.gif
Д713
..мне намного важнее процесс его создания..
тогда Коля,Вы-процессор!
такое имячко-"процессор" намертво привязалось к моему однокласснику (меж прочим весьма мастеровитому хлопцу),после его заявления,аналогичного Вашему.
но это было давно,лет 20 назад.
gyrator
И это есть гуд, бо исчё Э. Бернштейн сформулировал тезис: "Движение - все, конечная цель - ничто".
Д713
не знаю,кто там чего сформулировал,но без конечной цели даже яйца не закладываются (не в ломбард,конечно icon_biggrin.gif ).
с другой стороны,ежели бытие рассматривать как движение,а небытие как конечную цель (пункт прибытия),то Э.Бернштейн вероятно прав..
ну и gyrator вместе с ним..
gyrator,все хочу спросить Вас,как начинающий художник-есть ли в природе более-менее достоверная модель дуги?
математические соображения на этот счет весьма объемные и увесистые (как докторская по электродинамике,где три листика вытяжки),прямо сказать-не для повседневного использования.
gyrator
Дык, в MC исть "штатная" мудель "арки", кою как-то использовал для муделирования осциллятора. Однако, в сверкальнике не только дуга, но и капание металла с конца электрода или проволотки. Чистая дуга тильке на конце вольфрама в "ТИГре".
Лично меня вполне устраивает и простенькая модель дуженьки с "клацаюшчим" источником унутри, хотя пробовал и вероянт с нелинейной ВАХ. Тонкости работы варылки всё одно не посмотришь, но динамику вполне можно подкорректировать в первом приближении как и режим работы ключиков и сердешника.
gorbun75
Выложите у кого есть ссылки на эти материалы , а то в процессе модернизации компьютера потерялся файл с выборками из форумов .Заранее спасибо .
yjriy А какие у вас есть готовые платы ?Может можно купить по взаимовыгодной цене ?
petr0757
Хочу добавить вророй контур управления по выходному току. в качестве датчика тока плавнирую использовать шунт на 75а ( 75мв ). Они вроде жирненькие, взорваться не должны, а впрочем попробую поварить через шунт, лучшая проверка.
golub
дык, тема вроде не нова.
Gor
Подскажите пожалуйста какие могут быть последствия из-за длинного скола
У кого-то на форуме было такое, но не могу найти где.
electrovoz
Никаких. Это хорошо.
Gor
Спасибо.
Но транзисторы умерли после второго электрода.Теперь думаю почему
petr0757
Так дело не в новизне, завтра поварю через шунт и в путь.
DGEC
Я их давно применяю
RUS5610
Я тоже варю через шунты. Только у меня шунты на 150А.
Wiew
если ток ограничен в разумных пределах, блокировочние кондеры по силе на месте, то стоит проверить качество сьема тепла с ключиков.
golub
Цитата(Gor @ 15.4.2010, 11:18) *
Спасибо.
похоже на угрев.
интузиаст
Ребята вы пишите что варите через шунты а как у вас осушествлена токовая защита ключей.Если мона глянуть схемное решение.Интересует как сделана обратная связь и осуществлена токавая защита.
Igorыч
Спасибо.
У меня тоже получилась такая картинка, сегодня испытывал все нормально (стрельбы небыло), правда вылезли некоторые косяки(схема Бармалея):
1.Когда сварка проходит на токах от мин. и где-то до 100А после завершения все хорошо, но от 100А и до 140А (больше не наваливал) после сварки, примерно через пару секунд, начинает шелестеть вся силовая часть и с постепенным нарастанием, выключаю затем включаю все нормально - я думаю, что транс начинает валиться в насыщение или что-то другое?(транс 2хШ20х28 эпкос №87, 17/6 без зазора, частота 32 кГц, Кзап 0,43)
2.Ничего, если транс немного шелестит на ХХ?
3.При КЗ начиная от 80А подзжуживает дросель - малая индуктивность? (сейчас, точно не помню 16-20 мкГн)
4.Также при сварке свистит силовая часть, а с дугой все отлично.
Подскажите пожалуйста, что нужно поправить?
Andrey_G
Все эти свисты и шуршанчики в основном от кривой "земли", реже от косячных кондеров или еще какой пассивной россыпухи. Это свистят не транс и не дроссель (сами по себе), это модуляции и биения рабочей частоты, что как понятно не чего хорошо в этом нет. При правильной разводке и настройке аппарат практически не слышно в любом режиме. В общем как не раз уже говорилось - ройте "землю" icon_smile.gif.
RUN1
Эт точно кроме вентилятора не чего не должно быть слышно хоть на холостом хоть на дуге хоть на КЗ icon_smile.gif
Gor
Сегодня с утра посмотрел на умершие ключи. Оказались g4 PH 50ud. Похоже в спешке перепутал с PC.Может быть из-за этого рвануло.
Сегодня поменяю на PC50W. Ток был 100-110А все кондёры на месте. Ключи стоят без прокладок на отдельных радиаторах. Радиатор после баха был еле тёплый . По теплу вроде бы как не должно было-бы.
