Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
Д713
Цитата(kyzmi4 @ 6.10.2010, 17:15) *
Скажите,существует ли какая-нибудь более дешовая замена 150EBU02 (кроме баяна КД213) ???
А то уж очень они бьют "по карману".
нет.
kyzmi4
Д713,
нет.
А жаль!
Ну и напоследок вопросик:
Какая минимальная емкость накопительных кондеров при 160Амперах????
Д713
Цитата(kyzmi4 @ 6.10.2010, 17:23) *
Д713,
А жаль!
4х470.
kyzmi4
Д713,
4х470.
Столько и поставлю!
KLIM
ЗЫ - нету их вообще... а те что есть - цены просто грабёж...
Д713
пора подумать о герц эдак о 200..
вдуч вон квазирезонансный живет на 2 кГц на 4-х строчниках и варит не хуже любого "косого"..
без всяких там EBU и EPCOS-ов.
sarmat
На днях заказал в Платане 60EPU02 по 43 р. в корпусе ТО-247 (60А, 200В, 35нс). Выслали счет, оплатил и жду. По три штуки взамен 150ЕВU, даже лучше. Для сотки и по два пойдут. Что-то Коля исчез (был болен соткой).)))))))
Никто не переделывал печатку от Спарк (плата управления) под SMD?
skipp
И сколько за штуку(60EBU) - ?
sarmat
Мне счет выслали по 43 рубля без НДС....сейчас смотрел на их сайте- от 1 штуки 51 рубля
http://www.platan.ru/cgi-bin/qwery_i.pl?code=60EPU
KLIM
АААааа - всё и EPU02 хана... аминь!
Я как понял -чего тут не выложи - всё пропадает с прилавков, прям место заколдованное. Нужно ассортимент конкурентов сюда отписать... пусть помучаются!
По поводу 2997 - я их до 100кГц разгонял, греюццо но живут... зачэм так сразу 200Гэц???
skipp
Я 80EBU покупал по 128 руб. правда на 400 вольт.В электонщик.ру.
Д713
дешевая комплектация.
могучие ключи,диоды обыкновенные,железо 2412 вполне подойдет..
ведь "косари" по большому счету не варят,скорее делают вид..
игорь315
добрый вечер уважаемые,подскажите подойдет ли такой чудо осцилограф для наших целий http://www.leoton.ua/oscill-usb.php
KLIM
Уши жалко... сильно это.
ЗЫ - у многих даже фирм, не то что любителей, и мосты не варят а делают вид... icon_wink.gif
Для бармалейника или резера хватит, что либо серьёзнет - НЭТ, дарагой игрушко...
игорь315
у нас на рынке за с1-112 800гр просят, какую игрушку лутчше брать?
Д713
так это с непривычки..
ostap
Ну если за БУ 800 грн. Чтото типо етого наверное лучше будет ?
http://electronlab.com.ua/pi/cPath/895_910...ducts_id/130931
http://electronlab.com.ua/pi/cPath/895_910...ducts_id/130930
http://masteram.com.ua/ru/GoodWill-Instek-...scilloscope.php
шоб игрушка )))) (кстате ниче так хорошо работает)
http://www.jyetech.com/Products/LcdScope/eDSO062K.php
http://www.jyetech.com/Products/LcdScope/IMGP8858.jpg
Vduch
Добрый день!
Не подскажите, кто-нибудь пробовал собирать бармалейник вообще без блока питания, используя для питания шим контроллера выпрямленные импульсы с выхода силового транса?
Сам сварочник при этом оказывается как бы и блоком питания самому себе.
Я в свое время попробовал сделать подобное, но аппарат хорошо работал только на холостом ходу.
При сварке вылетали стабилизаторы напряжения. Потом на время эту идею "положил" в "долгий ящик"
Может у кого-то получилось?
толян
тот же кайзер , куча типа итальянцев и китайцев . питание от самой себя - слежение за питанием контроллера , и отключка при к.з полностью и с последующим включением как на старте. имеет право быть , но неудобно , проще доппитатель.
игорь315
подарили мне два нерабочих прибора н313 и н3015 стоит их рнмонтировать?
kyzmi4
Имеется феррит Ш7Х7,вот только на каркасе нету ножек.А вертикальный каркас с ножками не найти,безвыводные одни попадаются.Вопрос:
Бывают каркасы ЭПКОС например,в которые всунется наш Ш7х7.Но чтоб с ножками и вертикальный был???
С безвыводными делал,но не понравилось,все болтается.Пришлось эпоксидкой все залить.Да и если бумажки не подклеишь,где какой провод,то через пару дней хрен разберешься!!!
игорь315
каркас от Е30далжон подойти
Lemm
в Е25 тоже нормально входит - в каркасе 10 ног .
игорь315
в Е25 входит сердечник сильно гуляет ,толька-что попробывал
толян
киевская конторка - тератрон называется. любые ферриты. я беру 138 сердечники , соответствует N87.
на 200 амперный косой - кольцо 65-38-25 , цена - чуть больше 5 баксов. правда беру упаковками .
kyzmi4
игорь315,
Lemm,
Спасибо,что откликнулись.Будет возможность,попробую купить и тот и другой!
yjriy
Ежели оторван сетевой штепсюль или отломана ручка для переноски, то стоит и отремонтировать- в остальных случаях наверно не стоит. Знали наверное что дарили icon_biggrin.gif icon_biggrin.gif
olegators68
Здесь подымался вопрос о дросселях,
Почему не делать на сердечниках от ЭМ пускателей, вроде самое оно - наглухо склееные две Ш-образные железки + зазор легко настраивать?
KLIM
А почему вы решили что никто не делает? Вот вы додумались icon_wink.gif и многие тоже додумались.
толян
клим . так тебе книжка нужна?
guliver83
Привет!
Я хочу построить машину 300A.
Может кто поможет мне?
Схема должна
Спасибо
yjriy
а в какую розетку штепсюль будете всовывать? Ну нада мне знать чтобы тебе схему правильную, надежную, несложную и дешевую выложить на 300- 390 Ампер mage.gif
yura_
Я думаю с 220V точно не выдернишь больше 250А(какая бы сеть небыла) проверено опытным путем, если кабель не со столба icon_biggrin.gif
Даже при длительной работе на токе 200А розетка и вилка расплавятся! Кабель сечением 2,5 мм становиться горячим.
На 300А однозначно 3 фазы engine.gif ранее об этом писал.
guliver83
220А машины SEMA?
Я сделал эту машину
http://www.hobbielektronika.hu/apro/images...70980923e38.jpg
gyrator
Цитата(guliver83 @ 10.10.2010, 21:19) *
Я сделал эту машину
Тохда в чём праблема? Ваяйте вторую машинку и фключайте обе параллельно. Получите в выхлопе читыристасорок анперей. icon_biggrin.gif
yjriy
Ведь сказано в запросе:
Надо придерживаться рАмок заказу- будем челу помогать наверна, тем более у него наверное нету лектродов шестерки, а арматура вправленная в держак здОрово иску бросает без обмазки и тапочки может пропалить от 400 Анпер upal.gif
Д713
Привет!
на аргоне или углекислоте это реально с одного штепселя 220 вольт.
guliver83
Привет!
Может кто-то посылать электрические схемы?
Что я сделал в машине 120A - 150A макс.
electrovoz
Так иностранец это. Welding machine перевел гуглом, и остальной такст явно машинного происхождения.
Сайт-то заканчивается на .hu, это венгр.
You better write in english, without machine translation.
guliver83
Да, я Венгерский (Закарпатсьа ОБЛ Береговский район)
electrovoz
Тоді краще на українській, яка вже більш рідна. Так як є читати неможливо.
В західній Україні російська мова - іноземна, і не вивчається. Люди 83 р.н. в основному не знають.
Д713
для выпаса гусей російська мова просто вредна-доказано научно,
ведущими украинскими нии околовсяческих наук..
САНЕК
Парни,тормозим.
По теме.
kyzmi4
Мужики,кто-нибудь переделывал бармалея под ПА ???
ПА в хозяйстве не повредит.
molotok26
Заказал в Платане IRGB20B60PD1.Получил ответ:
"нет возможности поставить в ближайшее время "
сваркостроители все раскупили....
И еще я спрашивал на форуме о доработке Colt в пускозарядное
устройство.Подскажите кто-что знает.Особая просьба к Golub
он вроде много практиковался со сварочниками по схеме Colt
Заранее всем спасибо
Alex.N
Всем доброго времени суток.Собрал Бармалея,варит отлично,ток ограничил на130А. Вопрос:как включить по 2 транзистора в плечо,какой использовать ферит. Бросте схемку или ткните носом,пожалуйста.
kyzmi4
Alex.N,
На второй транзистор подводим резистор и стабилитрон.
А на чем транс мотал???
a-nry
Цитата(kyzmi4 @ 18.10.2010, 17:33) *
Alex.N,
Я ничего не добовлял, работает нормально.
kyzmi4
STASKIN
Очередной глупый вопросец у меня образовался,сильно не пинайте-но всетаки спрошу. На схеме Бармалея,да и на схемах последователей,в узелке ограничения тока указан стабилитрончик 9V? Насколько критичен и чем он там занимается? Говорят нет такого,только 9,1V. Спасибки что непослали,или послали куданибудь за стабилитрончиком.
