Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
ozzy
В общем, камрады, поздравляйте с пополнением в ряды "паяльников". Испытания прошел успешно, никто не свистит не шуршит, максимальный ток сварки 150-155 Ампер, плата слегка переделана под свои комплектующие. Самые горячие выходные диоды.
Но есть пара вопросов:
* на холостом ходу силовой транс должен грется ? (у меня 35-45 С* и в работе мне кажется что он менше греется icon_smile.gif )
* Дантист ждем от Вас схемы с регулировкой хотстарта
* ..э .. забыл ... вспомню спрошу.
Всех благодарю за представленние материалы и оказанные консультации.
P.S. В плату еще не впаян предохранитель 10*38 CHT 10 типа такого предохранителя
golub
Цитата(SERGUN @ 1.5.2010, 19:17) *
ребята, доброго дня или вечера, помогите по Бармалею 160, пропал ток, варил раньше нормально, заявленый ток, теперь только электрод 2 мм. не больше регулятор тока на максимум все равно. Помогите, что к чему!?
а что делается на банках в момент тыканья електродом?
SERGUN
Golub, добрый день, я не знаю что делается в банках, инвертор далеко находится а что должно быть, я думаю пропал ток из-за того, что есть кз витков в силовом трансе может быть такое?
golub
при короткозамкнутых витках на силовом, думаю, играла бы грустная музыка.
Коля
Добавлен список компонентов
http://myfolder.ru/17543951
SERGUN
Golub, прошу поделится вашими предположениями, по моей проблеме с падением тока в дуге. Заранее спасибо вы из самого Харькова?
DANTIST
[quote name='ozzy' date='1.5.2010, 20:45' post='133057']
OZZY, прими мои поздравления!
Слушай, а не слабовата конструкция на шпильках? Я так понимаю - это М4? Или М5? Я свой собирал на стойках 7 мм.
Конечно должен греться. Как говорил один великий сваркостроитель: - что не греется - все лишнее.
Я думаю, ты же не идеальный транс намотал. И у него есть индуктивность рассеивания. А это вредно. Поэтому народ и изголяется, чтобы ее уменьшить. Чередование и секционирование обмоток и всяка друга хрень. А еще и перемагничивание сердечника. Так что, 35...45 град - это нормально.
Я тут вчера пару трансов мотнул. Хочу попробовать спарку косого. По китайскому конструктиву. Типа ЦАЙ. А то что-то однообразие поднадоело.
Здесь фотки с крайнего аппарата. И фотки трансов для спарки "косого".
Многие уже посмотрели. Здесь те же фотки только в архивах.
Коля
А почему у сотки дуга свистит?
ozzy
М4, держится нормально , но расшатывается. Я намерен укрепить путем надевания метал. трубок на шпильки.
САНЕК
DANTIST
Ты,упаковал бы это дело в архивчик,и прицепить на сайт.
Сам видел,как народ изголяется.
kyzmi4
Мужики,у меня вопрос:
Если я достану один комплект Е80 N87 и захочу сделать сварочник,то:
1)Можно ли работать на 33кГц???
2)Сколько тока сниму при такой частоте???
3)Сколько витков мотать???
4)Кто-нибудь делал???
Хочу в следующем аппарате применить что-нибудь поменьше и чтоб полегче достать можно было(в отличии от строчников).
petr0757
Все зависит от ключей, габаритная мощность Е80 позволяет об остальном не беспокоится.
SERGUN
Товарищи, помогите: упал ток в Бармалее 165, на максимуме регулятора можно работать только электродом 2 мм, раньше было нормально. Прошу поделится у кого есть какие мнения.
sarmat
Прими мои тоже поздравления. А фотки можно было уменьшит раза в три. Себе дешевле и народу удобнее смотреть. Стержень для дросселя откуда выдрань?
petr0757
Golub намекал,высохли банки. Прав на 90%.
kyzmi4
Ключи по два в плечо IXGH24N60CD1.
petr0757
В Gyzmi, всем известном, стоит по 4 таких же, но в два раза слабее по току IXGA10N60. Выше 50кгц, гарантированных от 161 до 183а.
SERGUN
petr0757, Golub - спасибо!
хотя мне мало в это верится, апарату всего 2 года, работали им систематически, банки стоят 470мкФх400В - 5 штук: 2 шт.- фирмы Philips (хотя не факт), а остальные 3 шт- Sawha.
Тут еще писали что полный разряд банок в конце работы губительно для них, надо чтобы оставался заряд на них а у меня дежурка запитана от банок и разряжает их до конца. Может из-за этого случилось такое.
А возможно это связано с изменением частоты или заполнения ШИМ в связи с тем, что частотозадающая емкость на 4 -й ноге TL3845 обычная (китайская - желтый), а не с подобранным ТКЕ???
DANTIST
Если тебе все равно что-то придется доставать, то почему не попробовать достать Е65 или Е70? У них же сечение поболее чем у Е80.
Я как-то делал монстряка на 2-х Е80. И на ПА пробовал ставить. Но ПА пока не пошел.
А чего, собственно, 33 кГц? Из-за дохлых ключей? Можно было б поднять частоту кГц до 50-ти и поставить ЕТD59. У него 3,6 см кв., а у Е80 - 4. Не велика разница. И снял бы своих 120 А.
На первичку у ЕТD59 21 виток, на вторичку - 7.
А вообще считай по формуле: N= U питх10 000х0,48(скважность) / f(Гц)х2хB(примерно 0,2)хS(см.кв). Округляй до ближайшего кратного 3-м. В сторону увеличения.
А как ток упал? Вчера варил без проблем, а сегодня упал? Банки враз усохнуть врят ли могут. Плохо, что аппарат далеко. Что толку гадать?
Коля
Вот я пробовал фотки делать- крупным планом нихрена и не получается. Вот решил попробовать с лупой снять- качество почти идеальное icon_biggrin.gif
sarmat
Коля, если фоткать даже мобильником, то фотки даже уменьшать надо чтобы в размер монитора влезли. Ты чем фоткаешь? Что ты выложил это снимок чего?
Коля
Это РАДИКАЛ уменьшил! Это фото дров сотки.
kyzmi4
Все-равно что,просто Е80 больше по размеру,я на это и купился.
Так че лучше: Е65 или Е70???
lapa
Цитата(sarmat @ 1.5.2010, 8:08) *
Вчера относил Спарк к профессиональному сварщику. Указал на жесткую характеристику
Так и должно быть поскольку статическая характеристика у него как у Бармалейника (Kolt4). Профессионал прав. Я взял Витину модельку упростил её, для ускореня счета и вот результат. Если немного изменить схему (Kolt5) то результат будет иной. Деталями не занимался просто прикидка. 3525 мне неинтересна нет у неё канала поциклового огранмчения, хотя псевдопоцикловка в схеме организована.Пусть автор роет если сочтет нужным.
ozzy
От дроселя поджига люминесцентной лампы насколько помню на 40Вт, а фотки ужаты до 300 кб оригинал по 2 мб
DANTIST
У 80-ки, конечно, окно поболее. Судя по ответам, те ключи, что ты собрался ставить, на 50 кГц будут работать без проблем. Я бы советовал собирать на Е65. Окно в нем не ахти. Но 140...160 А с него снять можно. Для 50 кГц мотаешь 15х5 витков. Первичку квадратов 5...6. Вторичку - 15...16. Поместятся.
Можно и Е70. Смотря что ты хочешь с аппарата получить.
А Е80 уж больно рогозливый. Хоть стоя, хоть лежа. Единственное его достоинство - это большое окно. Так оно у тебя будет наполовину пустое.
120...130 А можно, при желании, и с ETD59 снять. Поднять частоту кГц до 60-ти. Ключи порядочные поставить. Так его ж удобно мотать. Он же круглый.
kyzmi4
Для 50 кГц
А какие трудности меня будут подстерегать на 50кГц???Или все так же просто как и на 33,3кГц???
petr0757
Сдесь многие уже перепрыгнули 50кгц. Соблюдай правила монтажа и намотки, аппаратно все то же.
DANTIST
А что это за магическое число - 33,3? Это типа 100 на троих?
DANTIST
Здесь печатки и схема для ранее выложенных фото.
Если у кого есть желание, можно повторить.
allhimik
Помогите советом, как подобрать шунт для головки, головка 492 Ом , 300 мкА, посчитал на 300А, получилось 0,00049 Ом, а как отмерить такое сопротивление.
OFATUM
Никак не отмерить, только если взять большой отрезок материала ( который предполагаете использовать)и померять микроомметром, а потом разделить этот кусок на ровные части и тем самым высчитать сопротивление мелких кусков. Вообщето сначала берет шунт, а потом подбирают голову, хотя на безрыбье ......
Якшо нету микроометра, найдите статейку в инете по измирению малых сопротивлений.
Vlarcad
[attach
ment=7783:полная_схема.spl]посмотрите пожалуйста схемку! Фото будут позже. icon_cool.gif
ozzy
двумя постами выше схема намного лучше, имхо
sorry
Николай, прими и мой запоздалые поздравления, очень рад что у тебя получилось довести до логического завершения своё детище!
У более знающих хочу узнать. Если сравнивать управление по среднему току и поцикловое какое меньше просаживает сеть? Если конечно кто сравнивал.
petr0757
Меряют професииналы в метрологиии, а для 10% проще так.
И вдогонку мой первый шунт для головки 100мка - 5см.
petr0757
Цитата(vit336 @ 5.5.2010, 13:28) *
У кого-то была проблема с релюхой, и варили через зарядник. На всяк глянь.
Его порвет, если это не ТЭН 3квт.
Александр_М
Поменял резистор с 33ома на 24 ток возрос с 70 до 120 ампер .
В выходные уменьшу до 22 ом
Опробовал варить- варит отлично но есть одно но...
Электрод ЭА395(зеленый) нержавка плохо загораеться пытаеться залипнуть...
Все остальные горят на ура!
Что может быть?
На электроде + на детали -
По теплу после 7 электродов тройки самые теплые ключи 35-40 градусов(медные пластины)
а все остальное холодное.
Все собрано по печати DANTIST одиниз первых однодплат .
sarmat
petr0757, три куска по 10 см четверки. Это электрода куски или медная проволока?
HEMELL
Ну во вообще то при нормальном режиме сварки "ПЛЮС" должен быть на детале, а "МИНУС" на электроде, а на счет залипа - может емкости не хватать прямо на выходе апарата этак микрофарада с три...
petr0757
Електрод 4мм поделил на три части.
Александр_М
А с этого места поподробнее можно?
HEMELL
Это из собственной практики. Когда то варил бак из нержавейки (постоянка, но 50Гц.) жарился до тех пор, пока не нацеплял на выход апарата кандеров (электролитов, емкости общей уже не помню, но большая) только после этого апарат начал варить. Еще помню, что электроды тоже были зелёные.
petr0757
Это для 50гц поможет при малом ХХ, напряжение подымется в 1.41 раза. Допустим при 36в, получим
36вх1.41=50.76в. А в косарике и так 100в.
HEMELL
Может и так, но прицепить кандер и поэкспериментировать думаю особого труда не составит, да и не помню я если чесно сколько на выходе того (50и-герцового) апарата вольт было, нету у меня уже того апарата.
Лопух
Цитата(vit336 @ 5.5.2010, 14:10) *
Ну для начала надо бы озвучить Омы: если например 10 Ом то да, а если зарядник 50 ом, да к тому же ПЭВ icon_smile.gif.
У меня стоял на одном аппарате ПЭВ 20 вт 51 ом. Глюкануло реле. Через пару секунд попыток зажечь дугу резюк раскалился до красна. Зажечь дугу при этом нереально, так, мелкие искорки
кабельщик
макс.сварочный ток на выходе 30-50А, при высекании этого свар.тока рассеиваемая мощь на резюке около 1кВт, время жизни резюка 0,5-3сек в зависимости от его габаритных и конструктивных свойств...
макс.сварочный ток на выходе 7-10А, при высекании этого свар.тока рассеиваемая мощь на резюке около 300Вт, время жизни резюка - канечно чуть больше icon_biggrin.gif
В общем,
Причем как тузик грелку.
Wiew
без существенной разницы.
Александр_М, варил зелеными нерж. на електроде "плюс", зажигаются и горят не хуже АНО но только по нержавейке, на чернухе липнут
ozzy
кто то обещал показать схему регулирования Хотстарта icon_rolleyes.gif radost.gif
игорь315
добрый вечер уважаемые! пытаюсь сложить апаратец ( DANTISTA sparka) вместе с закупкай компонентов начали появлятся вопросы,помогите пожалуйста!
1-ненащел у нас в днепропетровске сердечник (EPCOSе65N87)нащел вот ето-Сердечник CF138-EE6527
Ш-образный MnZn сердечник без зазора. Размер 66,5x32,5x27,4мм.
Магнитная проницаемость = 2100. Индукция насыщения = 480/380mT.
Индуктивность на виток AL = 8100nH.
Производитель: Cosmofer
Цена (грн): от 1 шт: 28.67 от 10 шт: 27.61 от 20 шт: 26.54
и вот ето-Сердечник E65/32/27 N27
Производитель: EPCOS
Цена (грн): от 1 шт: 30.94 от 10 шт: 29.39 от 20 шт: 27.84
подскажите можно ли их брать?и чем отличается N27 N87 N97
2-можно в сетевом фильтре баянить кандюки из комповых питалок330*200!
