Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
slavyann
Цитата(Павел(Sp) @ 9.12.2013, 18:37) *
посоветовали не заниматься фигней
правильно посоветовали, если уж совсем нечем регулировать, то есть простой способ - берете лампочку ватт 100, включаете через неё одну, потом к ней параллельно еще одну и т.д. набираете штук до 5 ( надеюсь у вас там лампочки накаливания не извели еще -))
Павел(Sp)
icon_mrgreen.gif говорила мне мама.... учись хорошо.лампочки не извели, китай переходит на енергосберегайки,так что тут простых лампочек, шо на гуталиновой фабрике гуталину-завались, даже есть галогенки еще и в простую колбу воткнутые,шоб пальцами на хапать...
А 5 лампочек по 100ватт по цене тут почти как латр дома..Но идея не плохая, вчерась видел похожее ,только на основе електроплитки,.. спираль и крокодилами цепляешся и напругу выбираешь..
DJPashA
Мучаю сижу плату с 3845 (только 3845 и обвязка_ делать буду на оптике(др на отдельной плате)), возникла проблема - не регулируется скважность. Проверял 1хххххххххх раз разводку пайку и всё вообще - ну чётко ж всё блин, но заполнение по максимуму ти всё тут. Позже выпаял микру, поставил панельку - и того в эксперименте участвовало - эта 45-ка, ещё одна (не паяная, но куплена одновременно с той) и 3843.Короч результат во всех случаях один - сигнал нормальный, частота регулируется чётко, помех никаких вроде нет, но длительность по макс-му и не регулируется во всех случаях (с той конечно разницей что у 45-х она стоит в районе 45% а у 43-ей оно почти 100%(паузы просто как иголки)). 1-я нога на массу останавливает шим(т.е. эт работает), на 3-ю ногу 1.5В и результат тот же, вобщем только длительность никак. По всему вроде микры нормальные, но... Присоветуйте что бы где ковырнуть.
Ни чего не греетя и вообще ни каких аномалий.
На фотках дл=20мкс, 10мкс(на всяк) и то же с лампой 12В 3Вт на выходе.
oleg1ma
Можно в голове поковырять, а еще лучше почитать ветку.Длительность менятся не будет, пока на третью ногу не начнет приходить сигнал ОС с ТТ.На счет лампы не понял, Вы ее куда прицепили??
DJPashA
лампочка параллельно выходу. Так можно ли как нибудь убедиться в работоспособности блока без сигнала ос.
Navstar
DJPashA, Я тоже через это проходил. В принципе никак, можно лишь проверить реагирует при подачи напряжения 5-9 В на 3 ноге. Остальное только при подключенном тт
KT117
Вместо ТТ подключи батарейку 1,5В и сможешь проверить изменение длительности. Или снова перечитать про настройку Бармалея (выделенное место)
oleg1ma
Можно.
DJPashA
Олег, спасибо огромное. Ну и всё - всё работает. Немного другие номиналы получились, но всё "крутится" icon_smile.gif. А с приведённым текстом я конечно знаком, да и "выделенное место " "врезалось в память", но почему-то у меня так не захотело работать. Сейчас ясно - блок трудоспособен.
SHA-SEREGA
Подскажите плиз как поднять амплитуду выходного сигнала с 6-ой ноги uc 3845, а то у меня 5 вольт получается. Два дня искал по форуму не нашел
nikon
Думаю не найдёте никогда, я так думаю амплитуда зависит только от питающего напряжения, и смотреть нужно осциллографом а не мультиком. И вообще никогда не заморачиваю себе этим голову, сигнал либо есть либо нет, смотрите заполнение. Дальнейший сигнал смотрю на затворах ключей.
ingener99
Мультиметр покажет половину амплитудного, если на дисплее 5В - то амплитуда 10-11В.
Можно подключить конденсатор через диод, тогда на нем будет действительно ампллитудное
DJPashA
Когда я на своём бп кручу ручку, напр на выходе UC, по осц-фу, почти в точности соот-ует показаниям вольтметра на бп. Да и все они - 3825 tl494, на вых - что на входе.
SHA-SEREGA
меряю осцилом, питание 14.3в , на выходе тр2 сигнал амплитудой всего 10в, подключаю драйвера, резистор что на 200 Ом через пару минут горячий палец не терпит
nikon
Проверьте фазировку обмотки размагничивания и направление диода на ней.
DJPashA
А прям на выходе 3845 сколько, может тгр чего.
SHA-SEREGA
с напругой разобрался, щуп глючил. вот осцилки, какой диагноз? первые на резисторе 200 Ом которфй греется Нажмите для просмотра прикрепленного файлаНажмите для просмотра прикрепленного файла а эти на кс213Нажмите для просмотра прикрепленного файлаНажмите для просмотра прикрепленного файла
KT117
На выходы драйверов навесь конденсаторы 4n7, проверь диод. уменьши заполнение.
rcmk
Когда-то давно загорелся резонансником негуляева, начал собирать детали, потом закрутили семейные проблеммы и все забылось.
Сейчас решил вернутся к теме сварочников, но взвесив все решил остановится на косом.
Дома осталась часть деталюх купленных для резонансника - 1 комплект E65 (2 половинки) и 4 G4PCF50UD .
Насколько я понял на таких транзисторах я выше 30 кГц не запрыгну.
Хватит ли одного коплекта Е65 на такой частоте?
В принципе я на 165 А не замахиваюсь, 120 думаю хватило-б с головой.
Или таки надо 2 комплекта?
SHA-SEREGA
заполнение сделал 0.47, резюк греется как утюг, может помощнее поставить,
KT117, а кондеры 4н7 на выход драйвера это паралельно кс213? и какой диод? если на размагничивающей обмотке так я его уже менял
nikon
Про диод вы поняли правильно, а как на счёт фазировки обмотки, резисторы греются когда выполняют роль размагничивающих.
SHA-SEREGA
обмотки проверял, на драйверах сидят ключики 80n60, попробую транс на кольце сделать думаю фериты ш 7*7 отечественные не особо хорошие
SHA-SEREGA
намотал новый транс на кольце, сигналы не изменились резюк горячий, может он и должен греться?
померял температуру примерно 92 градуса греется, кто скажет почему?
ММихаил
Здраствуите. Олег подскажи по трансу бп в аппарате бэби . Меня интересует каркасик трансика которыи на плате управления. В магазине у всех каркасов тоисть гориз и вертик выводы идут по одному ряду с каждои стороны а на плате управления каркасик с выводами в два ряда с однои стороны. Как он называется и где его можно купить или заказать.
tranzistor3102
про какой резистор идет речь?который стоит после транса 200 ом он и должен греться конечно не до красна но градусов 70-90 рабочая температура. какой мошности установлен резистор? если не дымиться резистор то все в норме а так поставь 2 резистора 2 w в паралель. icon_biggrin.gif
DANTIST
11.12.13 г 14ч 15'16"
SHA-SEREGA
tranzistor3102, ясно, спасибо за подсказку, попробую поставить два
DANTIST
Цитата(tranzistor3102 @ 11.12.2013, 12:46) *
...он и должен греться конечно не до красна но градусов 70-90 рабочая температура. какой мошности установлен резистор? если не дымиться резистор то все в норме а так поставь 2 резистора 2 w в паралель. icon_biggrin.gif
У меня тоже 2-х Вт греются. Пальцем не удержишь. Если будет стоять в обдуве, нормально. Не перегорят. А так, со временем, краска темнеет.
Или сделай узел ТГР по Бармалею. Я в крайних аппаратах ставил ТГР с дополнительной размагничивающей обмоткой. Там ничего особо не греется.
Народу, видимо, стало лень мотать еще одну обмотку, вот и придумали резистор. Я мотаю на кольце сразу 4 провода МГТФ-0,12 (0,14). Никаких проблем.
sergey777.68
Уважаемый тов Dantist не могли бы вы выложить фото вашей спарки (интересна компоновка силы) заранее спасибо. icon_rolleyes.gif
oleg1ma
Нужно заполнить профиль, чтобы хоть знать с какой Вы планеты, что-бы посоветовать, я беру у Артема Терейковского, тут. См файл на 6 стр. Рисунок 3.
DJPashA
Народ, просветите пожалуйста_ диоды HFA25TB60. Ну т.е. они как бы 2-хногие быть должны (как на картинке на голубом фоне). А у меня в закромах обнаружился вот такой экземпляр в нек-ом кол-ве. Диод звонится только между средней и правой ногой. Можно ль такие ставить и долго он с ними проработает?
SHA-SEREGA
DANTIST, так я и делаю по бармалею, последний тоже на кольце в 4 провода мгтф, а резюк который на драйвере стоит 200 Ом
Wasiliy61
Не ребята, если ТГР с размагничивающей обматкой, т.е. четырёх обмоточный, то хватает одного 2ух вт.
oleg1ma
Тут Скачай файл прикрепленный.
А название у твоего экземпляра есть, и еще очень помогает даташит на комплектующие. icon_biggrin.gif
Wasiliy61
Это похоже HFA25TB60, если они -то можно смело ставить.
ingener99
Вроде в исходной схеме Бармалея есть и размагничивающая обмотка ТГР, и резистор 200 Ом, шунтирующий вторичку.
sergey777.68
Олег спасибо.Думал что одно платный.
DJPashA
Да конечно, я ж так и написал "диоды HFA25TB60"(на фотке в принципе читаемо если увеличить) . Но они ж двуногие должны быть вроде б,. По даташиту уж точно, а тут обычный(3-зхногий) ТО-220. У меня их 8 штук - звонятся все одинаково. Получается чё - у косоглазых вдруг двуногие заготовки закончились и они - да лан чё там, 3-хногие давай, пойдут нах... icon_smile.gif не ну т.е. не паливо ли какое. Обычно у трёхногих 2 диода катодами к середине - тут только один - справа (слева ни чё не звонится) - он точно 25А или может 17.5 а второй диод воткнуть забыли? Вот оно и беспокоит.
tranzistor3102
но если человек переживает что у него сильно греется резистор надо же ему выходить как-то из положения может у него резистор установлен не соответствуюшей мошности указанной в схеме
ММихаил
Спасибо за ответ. Профиль заполню.
nikon
И правильно беспокоит, всё что не входит в рамки шиита левак.
А по мне так лучше разобраться почему он греется, у меня на бармалее сильно не грелся.
tranzistor3102
"сильно греется" у всех понятие разное .может у него напряжение питания завышано вот греется больше чем положено
igorka
Цитата(oleg1ma @ 10.12.2013, 20:17) *
Для наладки сварочников мне лично подходит, а Вам для чего?
Да так , шоб було icon_biggrin.gif Типа большой экран , дань моде... icon_biggrin.gif
Смешоно , смешно.Осциллограф у меня Ф4372 . на роботе С1-112 , С1-68.Вообщем так.
@Alex@
Олег, привет. Вопрос по малышу: собрал управу, в PIC залил 120.HEX, всё работает, но PIC выдаёт ШИМ 16кГц(напруга на 15 ноге TL меняется от скважности) нормально ли это или я где-то с фьюзами накосячил (не должно-ли быть 75кГц ШИМ) и после смены уставки ЗАПС загорается чуть-ли не через минуту?
Serega30
Если уж затронули эту тему...Если по схеме Бармалея то у меня на выходе ТГР: 200 Ом. 1 Вт, греются, но работают, не чернеют(китайские серые). Все пока гуд. Форма сигнала на выходе (после драйверов) как по инструкции. Проблемм с формой сигнала никаких не наблюдал.
oleg1ma
При прошивке фьюзы не трогать, стоят заводские, было бы меньше вопросов если бы читали ветку, по второму тут
@Alex@
Спасибо. Ветку читаю, но этот момент упустил а посмотрел вот сюда, а там 75кГц icon_eek.gif
slavyann
и шо с того ? у меня тож много чего на роботе ; причем здесь осциллограф ? если вместо лампочки, то мне тож смешно
SHA-SEREGA
у меня стоят на 2 вата китайские серые, греются но не чернеют, напруга на них 18.3в, на на затворах ключей 12,8в .
Вот осцилка на ключах без 300и
присутствуют какието выбросы , грешу на прибор, нормального нет меряю хамалеоном.
Мож они и должны в диапазоне 90 градусов работать, только вот как-то неуютно
Serega30
Таких выбросов в принципе быть не должно! Найдите нормального осла.
