Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
KSV
Цитата(Wasiliy61 @ 28.1.2014, 10:07) *
А почему перегрев-то, из всех моих аппаратов пока не замечал перегрев, или это вы за малыша говорите, то.... я его не собирал.
Малыша я тоже не собирал а перегрев радиатора диодами и транзисторами, фото на 1000стр.
владимирон
подскажите частота 50кгц коофициент заполнения получился ровно 0,4 это нормально
KT117
Я бы сказал, частота 45кГц. Заполнение нормально, потом сможешь увеличить
Ключи какие?
Velgosh
ребята а 40в на выходе ето не маловато? и еще если ТТ не сфазирован можно дугу запалить или нет?
slavyann
вот заодно и ТТ проверишь, если неправильно сфазирован, то будет писк
AS65
Рискованное дело ,сфазируй сначало,потом уж дуга.40 маловато но может так прибор меряет,
Ктр. какой?
Wasiliy61
Может мала площадь радиатора, для совместного проживания ключей и диодов, или тонкая подошва у радиатора
Ктр. какой?
Да ни чего страшного не будет, я на одном аппарате пробывал и так и так, при неправильной фаз--ке что-то пищит,подсвистывает, и меньше тока-чем при правильной. Вот 40вольт маловато, может прибор врёт.
Velgosh
Цитата(AS65 @ 28.1.2014, 15:01) *
Ктр. какой?
непонял?
oleg1ma
Что-бы понимать, нужно немного почитывать форум.Ктр- это соотношение витков первички и вторички.Если к ипримеру 18витков первички. а вторички 6. Ктр-ции = 3.
Velgosh
ааа, у меня как раз так и есть 3
Wasiliy61
Дак почему-то тогда на выходе маловато, у тебя сила полная поданна.
ММихаил
Олег а покажи пожалуста платы последнего аппарата.
Velgosh
в силе пока только один електролит 470мкф/400в запаян вместо трех
slavyann
это на скорость не влияет, вопрос в другом : аппарат запитываешь от 220 В ??
Velgosh
да, через лампу 100вт, в сети где то 215-218в
KSV
Для проверки и одного достаточно, а то, что 40в на выходе, то китайские мультики если не чистая постоянка показывают погоду. Я пробовал на выходе одновременно замерять флюком и мастэч и разница была около 20 вольт и мастэч в добавок пищал. Да и заполнение у Вас какое ?
Velgosh
еще нету осциллографа
AS65
А лампа как себя чувствует,сколько на ней падает напряжение,
или хотя бы светится или нет на хх.
Velgosh
чуть накаливаетса, даже еле видна
Wasiliy61
Ну так это нормально.
KSV
Значит, чтото работает, жаль импульсы не чем посмотреть. Я первый сварочник запускал без баласта и настройки на ток, контролировал по входному току и варить сразу пытался. IRF740 скупил во всех соседних областях, ни чего так и не вышло, но приборов было достаточно всяких. Вы не торопитесь, бахнуть успеете.
Velgosh
советуете ждать пятницы (ослик приедит) или сейчас зажигать дугу?
oleg1ma
Советую найти какой-нибудь баласт для начала и проверить на нем, регулируется-ли ток, какое напряжение на нем и т.д.
Velgosh
а что может послужить баластом
oleg1ma
На этот вопрос уже отвечали много, много раз, я вам уже писал, нужно не задавать вопросы, а сесть и немного почитать, может в голове, что и отложится, заодно и много полезного узнаете, достаточно прочитать 1часть бармалея.
AS65
Всё что угодно имеющее сопротивление 1 Ом с возможностью его уменьшить до 0
способное рассеять пару киловат нерасплавившись быстрей чем сможешь померять icon_biggrin.gif .
А если серьёзно почитай всё есть в теме.
KT117
Цитата(Velgosh @ 28.1.2014, 0:42) *
Все таки нашол косяк, вместо резисторов 4,7Ом, те что возле драйверов и силовых, поставил 1,3к (так что надо после магазина все проверять), уже заменил, включил через лампу 100вт, лампа еле - еле накалилась, на выходе - 40в, что скажете - зажигать дугу или все таки дождатса ослика и перепроверить??
Если меряете напряжение на выходе при подключенной лампе-то там и будет примерно 40В. Если лампу уберете-поднимется до 52-55В. Так что вроде все нормально у вас.
Velgosh
спасиба, так и есть, без лампы стало 57в, я нестал ждать осциллографа и зажок дугу, чудо свершилось варит на ура!!!!!!!!!!!!
Wasiliy61
Velgosh
Цитата(Wasiliy61 @ 28.1.2014, 21:49) *
всем огромное спасиба, без Вас всех я бы несправилса то точно, на выходных начну делать еще один для знакомого но уже с осликом
всем удачи
Wasiliy61
Снял осцилки, вроди нормальные
Нажмите для просмотра прикрепленного файла К-Э нижнего при полной силе.
Нажмите для просмотра прикрепленного файла К-Э верхнего при полной силе.
Нажмите для просмотра прикрепленного файла На обратном диоде.
Только что то не понравилось- за 10-15 мин без награзки транс нагрелся градусов до 40. Померить индуктивность нечем, пробовал через лампочку 100вт- накала нет, при 60вт лампочке есть.
Павел(Sp)
Василий, я долго пользовался этим набором,пока не купил китайское мерило, имея конденсатор с известной емкостью более мене стабильных можно вполне доверять данному девайсу,я его проверял и сравнивал с китайским мерилом,погрешность минимальная.
Одним словом дешево и сердито.Набор внизу.
http://yadi.sk/d/K-Nk6kLJGxd7N
KSV
Может кто подскажет марку ХОРОШЕГО вентилятора 120мм на 12 или 220 вольт.
Wasiliy61
В одном стоит какой то на 220в, в остальных ставил вот такие.Нажмите для просмотра прикрепленного файла Запитываю от 15 в. Правда я не делал всё на одном радиаторе, и вроди как не жидкие ставил, может по этому нет перегрева. Примерно вот такие Нажмите для просмотра прикрепленного файла на ключи.
и вот такие на диоды.Нажмите для просмотра прикрепленного файлаНажмите для просмотра прикрепленного файла
Такой остался один, может как угоню на диоды.
aog1996
Цитата(Wasiliy61 @ 29.1.2014, 0:01) *
... Померить индуктивность нечем..
И звуковая карта не работает?
Wasiliy61
Да я чёт не заморачивался со звуковухой, сейчас обратил внимание-греются не обмотки,а феррит.
KSV
Цитата(Wasiliy61 @ 29.1.2014, 6:10) *
В одном стоит какой то на 220в, в остальных ставил вот такие Запитываю от 15 в. Правда я не делал всё на одном радиаторе, и вроди как не жидкие ставил, может по этому нет перегрева. Примерно вот такие на ключи.
и вот такие на диодыТакой остался один, может как угоню на диоды.
У меня была дохлая сварка solution и я решил в этот корпус вделать свой сварочник на родном радиаторе и с родным вентилятором.Нажмите для просмотра прикрепленного файла
ПН получилась маловата 3 тройки до перегрева. Я обычно делаю в свои корпуса свою компановку Нажмите для просмотра прикрепленного файла
В таком последнем варианте получилось 11 троек до перекрева.
KT117
По моему мнению, радиатор плохо охлаждается, основной поток воздуха от вентилятора проходит по другой стороне платы, и вентиляционные отверстия в корпусе расположены не со стороны радиатора
KSV
Внутри сделана типа шторки для направления потока.Нажмите для просмотра прикрепленного файла
Получается половина вентилятора дует на радиатор. На вид честно говоря
радиатор маловат подо всё.
KT117
Маловат? Какие ж у него размеры? в длину вроде 20см будет и по ширине 10см
Попробуй радиатор не с торца обдувать а со стороны ребер
Velgosh
Вентилятор для корпусу Zalman ZM-SF3 120*120*26.4мм, ELQ, 900-1500RPM, 18-23dB
Вентилятор для корпусу Zalman ZM-F3 120*120*25мм, ковзання, 900-1800RPM, 20-34dB
Вентилятор для корпусу SCYTHE Slip Stream Slim (SY1212SL12M) 120*120*12мм, 3+4pin, 1600RPM
KSV
Радиатор 19 на 10 см ,высота рёбер чють больше 2 см. Со стороны рёбер будет лучше без сомнений ,
да только места по ширине в корпусе нет, а рамодить сбоку на корпусе-это получится ерунда.
Хотел вентилятор от ФУБОГ пристроить а он на 24в. Закажу вентилятор
на 2850об. 220вольт ,потом продолжу эксперемент.
У меня стоит похожий 120-120-25 ,марки нет, отклеилась. Спасибо.
tranzistor3102
Василий здраствуй у меня тоже нагревается силовой транс(феррит) без нагрузки может даже больше 40 градусов.все тепло лишнее сдуеться хорошим вентилятором icon_biggrin.gif icon_biggrin.gif
шумный
KSV!
С моей колокольни поток воздуха от вентилятора проходит по ребрам радиатора и ударяется в переднюю панель.
Вопрос: куда ему деваться дальше? По моему представлению после удара в переднюю панель воздух пытается уйти обратно,
создавая противодавление для вентилятора и часть заполняет пространство между прокладкой на радиаторе и крышкой корпуса.
Надеюсь понятно что написал. Проверить гипотезу можно если варить без крышки, воздух будет уходить после удара о переднюю панель вне пределы корпуса. Если ПН увеличится, то возможный вариант сделать вентиляционные отверстия на крышке.
Vs55
Вот парочка от SUNON 120х120х25
MEC0251V1-A99 Подшипник Vapo (магнитная подвеска) 12V 183,94m3|h
EEC0251B1-A99 Подшипник шариковый
Есть и на 220В, но у них воздушный поток пониже будет.
Если место позволяет поставить 120х120х38, то есть зверь на 320 кубов в час PMD1212PMB1A, но цена почти 25 зеленых.
KSV
Цитата(шумный @ 29.1.2014, 11:31) *
KSV!
Без крышки и чёрной пластмаски на радиаторе нагревается еще быстрее,
заметил ещё при проверке на балласте. На передней панели есть отверстия и внизу корпуса и на крышке сбоку, воздух выходит.
Я нашёл описание на сварочник SOLUTION 3100(корпус и радиатор от него) Номинальный сварочный ток,
А (при ПВ %) 15% (120) / 60% (70) а гдето было не 15% а 7%. Радиатор хоть и большой, а рёбра редкие и площадь не большая.
Завтра обещали пару вентиляторов с промышленной аппаратуры принести, буду пробовать. Если не получится продам так или себе
оставлю, мне трубу 1400 не варить.
Wasiliy61
Возможно, но меня смущает что предыдущие трансы не грелись. Хотя это всё дело пока без винтилятора.Вроди как получается в насыщение входит, пока ни чего не смотрел, включал через лампочку 100вт- накала нет. Транс Е65 50кгц 15х5 витков.Нажмите для просмотра прикрепленного файла вот расчёт- вроди всё верно, если что -то придётся частоту чуть добавить.
KSV
Вы посмотрите по калькулятору лысого чего творится. Я делал на ETD-59 EPCOS и ЛЕПКОС с одинаковой
проницаемостью и витками, последний и грелся больше и индуктивность другую нужно было делать.
Serega30
Здраствуйте! Практический вопрос: верхнюю крышку лучше делать с напуском на переднюю панель или без? Как лучше в плане переноски/транспортировки/пользования?
Evergreen
Цитата(KSV @ 29.1.2014, 9:50) *
Serega30
с напуском чем хорошо?!-ведь если вдруг какая небольшая железяка упадет сверху на твой работающий аппарат , то шансов удариться о ручку регулировки значительно меньше со всеми последствиями от такого
