Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
sergey777.68
beer.gif С первенцем вас.Вас начинает затягивать?.
Серёгин
Wasiliy61
Спасибо большое, меня всегда тянуло что-то изладить, одно время почти завязал с паяльником, стал плоховато видеть вблизи, но меня всё равно тянет.
Цитата(Серёгин @ 10.4.2013, 20:33) *
Подскажите пожалуста, должно ли так быть, в одном положении ТТ дуга как свистит и кажется в аппарате что то попискивает,дага тянется. В другом положении ТТ дуга мягкая горит хорошо, но мне кажется току бы чуть-чуть добавить.
Wasiliy61
Цитата(sergey777.68 @ 10.4.2013, 21:15) *
В другом положении ТТ если можно фото положения т.т(возможно ловит помеху).
Нажмите для просмотра прикрепленного файлаТо что меж двух радиаторов, в чёрном пласмассовом корпус, красенький- это он. Я имел в виду положение-это фазировка.
Серёгин
Фазировка ТТ .Первый способ проще .Я всегда помечаю начало обмотки .
Wasiliy61
Спасибо, завтра посмотрю. Мне кажется при неправильной фазировке он всё равно свистеть не должен.
Серёгин
Вот при неправильной он и свистит .
Wasiliy61
А напряжение на 1ой ноге 3845 тоже сказывается на выходной ток, если да, то сколько должно быть для 150 ампер.
Wasiliy61
Цитата(sergey777.68 @ 10.4.2013, 22:46) *
примерно 0а-1.4в
50а-1.8в
100а-2.2в
160а-2.73в
Ого, а я считал что должно быть 4 с лишним вольта,дак почему то считают 5 вольт. У меня точно вольта 4 есть.
KT117
icon_biggrin.gif обычно так и происходит-ключи Бахнут и не свистит.
Wasiliy61
Цитата(sergey777.68 @ 10.4.2013, 23:13) *
формула позволяет правильно подобрать резистор т.т с выставленным напряжением на 1ноге 3845 согласно току.
Дак почему у меня тогда там так много, аж 4вольта,я и так уже убавлял, т.е. поменял резистор 33к на 39к.
KT117' Добрый вечер, как Вы то думаете, должен или нет свистеть при неправельной фазировке.
Wasiliy61
Цитата(sergey777.68 @ 10.4.2013, 23:44) *
Проверь номиналы (доп резисторов на +5в и0 ) на регуляторе тока.
Номиналы во круг рег. тока все по схеме, кроме того что на средней ножке рег.тока -39к. Питается управа от 15в.
Wasiliy61
Цитата(sergey777.68 @ 11.4.2013, 0:03) *
схем много с ошибками! резистор 39к оставьте в покое. надо увеличить доп резистор на регуляторе в землю.
Спасибо. Хорошо я попробую. А что Вы скажите за микросхему UC3852, мне сегодня предложили, говорят что она меньше возбуждается, меньше чем 3845.
KT117
Возможен свист, шум в силовом трансе, при полной мощности и кз играет Мендельсон icon_smile.gif. Если экспериментируете-то на самой малой мощности. На ветке про работу ТТ с неправильной фазировкой много написано, особенно в первых про Бармалейник. Есть разбор работы ТТ и у Юрия в его ветке про ММА
Смотрите обвязку переменника, с 8 ноги УС на него приходит опорное напряжение
И посмотрите, как к своей УС прикрутить компенсацию пилы, если еще нету. Очень хорошая вещь. Схемку смотрите ММА от Юрия.
Wasiliy61
Да похоже что поёт транс, только от чего.
KT117
Думаю, ответ про шум в трансе кроется здесь. Ток можно так же настраивать подбирая нагрузочный резистор в цепи ТТ и витки самого ТТ. Перечитайте настройку бармалейника от Пупкина, там все это есть.
Wasiliy61
Благодарю, Пупкин в какой-то папке есть -посмотрю.
RUS5610
На счет фазировки: если свистит дуга-неправельная фазировка. От неправельной фазировки ключи не дохнут.
ingener99
помимо фазировки ТТ, еще проверить бы фазировку силового транса
oleg1ma
И Вам не мешало-бы проверить, или научится правильно их снимать, раз выкладываете такие кривые оцилки в сооб №15855.
ingener99
Ошибки в полярности осциллографа или подключения к +/- аппарата нет, если об этом речь. Дополнительно проверено на обычной батарейке.
Если эти осциллограммы чем-то отличаются от ваших - называть их кривыми преждевременно.
Или у вас они прямые как линейка
nikon
На вашей осциллограмме транс не успевает размагнитится, поэтому я и спрашивал как себя чувствуют ключи. Оно и не удивительно раз кольцо без зазора
ingener99
Отсутствие вертикального участка на заднем фронте?
Если это говорит о неразмагничеваемости транса, то должны были быть последствия?
Но пока ничего плохого не наблюдается - на ХХ транс чуть теплый, потребление - через лампочку 25Вт едва накаляется. Никаких звуков нет. Частота опускалась с 90 до 60кГц для проверки запаса - без последствий. Ключи не самые мощные. Спалено пол-пачки тройки и штук 15 четверки....
nikon
Последствия должны были быть, и похоже отсутствие их удивительно не только для меня. Если все же аппарат как вы говорите работает то на грани
Wasiliy61
Доброй ночи друзья. Вот у меня заморочка интересная, при правильной фазировке Тт свистит дуга, и силовой транс, а при не правильной ничего не свистит, что за ерунда не могу понять.
zario
попробуйте одеть феритовый колечку на провод от ТТ. Должно устаканится
Wasiliy61
А что это может дать или уже проверенно?
Цитата(Серёгин @ 12.4.2013, 1:09) *
Если пишут , значит помогает .У меня не было такого ,и я не путал фазировку .
Сегодня я точно определил фазировку, при помощи 9вольт. Оказывается, при нормальной он свистит.
Да и напряжение на первой ноге 45 кажется завышенно, на максимуме 4вольта, на минимуме 2вольта.
Меняю обвязку переменного резистора, смещается диапазон писка на переменнике.
zario
Проверенно. А что спрашиваете если сомневаетесь на ответы
Jorg63
между первой и второй ногой стоит RC цепочка,поиграйтейтесь с ней,свист должен пропасть.
Wasiliy61
Да, конденсатор я менял с 0,1 на 0,15 без изменений, а резистор пока не пробовал, я уж думаю либо микросхема касячная.
Jorg63
слишком большая емкость,может она на корпус стоит? между 1и 2 ногой емкость небольшая
Wasiliy61
Да номиналы согласпо схеме, ведь 150n-это 0,15 если я не путаю.
Jorg63
а с 1 ноги на корпус нет кандюка?
Wasiliy61
Да, с 1ой ноги он и стоит на массу 0,15.
Jorg63
а между первой и второй ногой есть кандюк?
DANTIST
Ну так и оставь в такой фазировке, когда не свистит. Чё париться? Аппарат же работает. icon_biggrin.gif
Wasiliy61
Да стоит, был тоже 0,1 поставил тоже 0,15-свистит.
Jorg63
по восьмой ноге опроного питания кандюк стоит?,там керамика должна быть. если все стоит то пробовать микру поменять если свист напрягает
Wasiliy61
А при такой фазировке Тт кажется тока маловато, малость бы добавить.
На 8ой ноге стоит кондюк 0,1. А варить плохо дуга как-бы тянется,а при неправильной фазировке, дуга мягкая,только току бы чуть добавить.
Jorg63
если на неправильной фазировке варит нормально,как вы считаете, то в цепи резака установки тока подкоректирйте резисторы делителя до нужного вам тока
zato4nik
Свистит при неправильной фазировке. У меня так было, когда устранил тоже показалось ,что току стало меньше. Пространственное положение ТТ может зависеть на какой из выводов первички он одет . Если на верхний (по схеме ) вывод СТ , то начало вторички ТТ(провод обмотки входящий с той-же стороны внутрь кольца) будет со стороны верхнего ключа , если на нижний вывод СТ то начало будет со стороны СТ. Чего написал сам не понял icon_biggrin.gif
Wasiliy61
Я думал об этом, но хотелось что-бы было всё как положенно. Вы не знакомы с микрухой UC3852,говорят что она менее склонна к возбуждениям. Вчера знакомый предложил.
Jorg63
это ва-ще другая микра!И для других целей
Wasiliy61
Да.я посмотрел, это какой то коректор мощности.
DANTIST
Ну уменьши немного нагрузочный резистор ТТ. Больше резистор - раньше наступает ограничение. Что у тебя хоть за схема? А то уже третью страницу идет базар за свист.
nikon
По моему Вася сам запутался и окружающих пытается запутать, все указывает на то что ТТ подключен не правильно но ловля блох все же продолжается.
Wasiliy61
Не я не запутался. Может быть из за того что Тт намотан на распылённом железе.
nikon
А кто же вам рекомендовал распыленку? Но даже если так вы сами пишите что при переключении концов ТТ дуга становится мягкой и не свистит и то что при этом ток сбавляется тоже закономерно, что вы еще хотите от аппарата ?
Wasiliy61
Так значит дело не в распылёнке. Да он был заводской намотки на нём просто было много витков, я перемотал и сделал 100витков.
Серёгин
Найдите нормальное ферритовое кольцо и намотайте нормальный ТТ .
