Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
санекнс
Да при регулировке транс пищит, а транзисторы вылетали когда доводил латром до 230в, первый раз поставил по три в плече, пробило 2транз и диод, потом по одному в плече,
пробовал переворачивать ттр менять местами начало конец ттр, менял микру
может дело в ттр, кольцо 28-16-9. прониц 2000нм
oleg1ma
А может нужно оцилки показать?
AS65
icon_biggrin.gif Извиняюсь неправ.
санекнс
Вот фото, уже всю голову изломал
DANTIST
А может дело в ключах? Чё-то как-то подозрительно они вылетают.
Зачем переворачивать ТТ, если узел работает?
Ключи за собой тянут и драйвера. Там все живое было после первого баха?
Почитай все же первую страницу 1-й части и сделай так, как там рекомендуют.
И пора, конечно, что-то показать из осциллов.
А импульсы ты смотришь на затворах ключей или на выходе 3845. Амплитуда импульсов на затворах не уменьшается перед бахом?
Санекнс, что я не пойму, так какая же у тебя частота? 50 или 40? Что за магические кГц показывает твой чудодейственный осциллограф?
Если 40, так у меня даже без Зуева-Гумилева на первичку получается как минимум 10 витков. А лучше 12.
Может быть твой транс тупо впадает в насыщение.
Мотнул бы 9 витков первички и не парился с 2,5 витками. Кстати, а как ты намотал 2,5 витка?
И ключи бы не горели...
санекнс
импульс мерил на ключе, ключи 6шт 50u и два 4063d, 50u тихо умирали а 4063д рванули с осколками на хх без кз. остались 4шт 4063д. сейчас сделал навес подстроечник как на 1стр бармалея ширина регулируется сечас разбираюсь выставляю мин мах подстроечниками вокруг регулятора тока.
А какие осциллы выложить? чтобы разобраться легче было
Частота была 50кгц осциллы фотал на 38кгц, пробую ,
А по прибору пит 12в насыщение начинается с 350мкс/25=14мкс у меня ширина 10мкс,
при пробитии ключа импульс не уменьшался
для сложенных Е70 9и3 на 40кгц пойдет? попробую перемотаю транс
А зазор в сердечнике какой
Сейчас пытался регулировать с обвеской как у бармалея настройка начинаешь прибавлять задатчик тока и ипульс дрожит не стабильный в какой-то момент
DANTIST
Цитата(санекнс @ 11.4.2014, 12:07) *
...а 4063д рванули с осколками на хх без кз. остались 4шт 4063д.
Похоже на транс
Питание 12 В. Что это? Импульс на затворе должен быть не меньше 14-15 В. Т.е. питание должно быть в районе 16 В.
для сложенных Е70 9и3 на 40кгц пойдет? попробую перемотаю транс. А зазор в сердечнике какой
А зачем такой могучий транс? Что ты хочешь с него снять? Для однофазной сеть 140-160 А в дуге - в самый раз. А ты хочешь получить 250?
Для 2-х Е70 и 40кГц 9х3 - это впритык. Практически без запаса. Самая большая скважность на ХХ. И ХХ для него самое тяжелое в плане насыщения. И максимальное питание и скважность.
Я бы мотнул 12х4. Но это для ровного счета.
Кстати, а ты ставил лампу в +300 В? Как она ведет себя на ХХ?
Здесь тоже может быть все, что угодно. Он хреновой компановки до плохо разведенной печати. Наводки и т.д. Попробуй управу отнести от силовых узлов. Если возможно. У меня как-то транс пел, когда управа была над силовым трансом. Потом проложил кусок стеклотекстолита фольгированного и все успокоилось.
санекнс
Питание 12в прибора гумерова 300/12=25 350мкс/25=14
Лампочка горит чуть жултым
Wasiliy61
Да, санекнс- с ферритом ты явно переборщил. С одного комплекта Е70 можно взять под 200а, если не больше.
DANTIST
Это практически белым!? icon_biggrin.gif Как солнце!?
санекнс
Четыре года назад сделал 2 резонансника по негуляеву оба до сих пор работают радиодетали покупал с запасом, остались два комплекта е70 в чип и дип заказывал, вот что-то загорелся сделать бармалея, хочеться что бы было мощи с запасом. хотя резонансники мостовые работают и дались меньшими потерями, один правда буквально сразу в работе пробило выходные диоды, он был с удвоителем, снял удвоитель заменил диоды и все в норме,
пол часа назад буквально настраивал управу по инструкции бармалея подстроечниками по бокам задатчика задатчик 2,2ком получилось что за половину поворота производит полное сужение и расширение импульса, поставил 1ком отрегулировал чтобы полный оборот задатчика полностью сужал и раширял импульс и все равно когда импульс не много не до конца расширен присутствует дрожание, может дело в самой микросхеме я же как то писал на форуме и фото выкладывал микр оказались перемаркеры
slavyann
Санек, а R1 у тебя какой стоит ? переменник ?
санекнс
СП-3 которым устанавливается сварочный ток
vya4es
На двух е70 9 на 3 делали здесь. http://cxem.net/house/1-188.php Там частота 50 кГц.
slavyann
сварочный ток - это R3, а R1 похоже заполнение, и он у тебя переменный ? icon_eek.gif
санекнс
да боковые оба переменные сп-5 подстроечные
SERGIO84
Какой готовый трансформатор можно поставить в блок питания?
Wasiliy61
Лучше импульсный блок питания, если чисто для Бармалея - то 15вольт на выходе, где-то так.
DANTIST
POL12017, если для Бармалея. А если в общем, то почитай вот это?
Serega30
Здравствуйте! Весело у вас тут...Извините за OFF, теперь по теме-вопрос остался: на вых. диодах у меня стоят снаберы 0,01 и 28R/5W. Могу заменить на ''Бармалеевские''. 1)Стоит ли заменять их или можно оставить? 2)Они выполняют только защитную ф-цию для вых. диодов(150ЕВU04) или влияют еще на что-то? P.S.читать форум, п-та, не посылайте. Спасибо.
oleg1ma
Спасибо, что развеселил icon_biggrin.gif Снаберы защишают диоды от пробоя при всевозможных всплесках напряжения на них, можеш стать осликом на них и посмотреть, что творится со снабберами и без.Какие диоды применил?
Serega30
150EBU04
oleg1ma
Больше не думай про свою снаберную цепь.
санекнс
Привет всем подскажите на какой частоте могут работать транзисторы gp4068d, кто нибудь использовал в в косом мосте
sergey777.68
Отлично.В новых Ресантах стоят по фирме(60кгц)
санекнс
А КАКАЯ ПРЕДЕЛЬНАЯ РАБОЧАЯ ЧАСТОТА У НИХ
Serega30
Тогда про макс.раб. ток и температуру можно забыть...
санекнс
а на кокой частоте рекомендуется для них работа
tranzistor3102
ну и вопросы пошли icon_biggrin.gif все зависит от твоих комплектуюших которые будите использовать icon_biggrin.gif
санекнс
я извиняюсь за такие вопросы просто столько уже транзисторов взорвал, сейчас переделываю управу на ус3825 и перематываю транс на косой мост, кто нибудь делал, есть какие то тонкости
Jorg63
Если бы все по уму делал и комплектация подобающая была и не косячил ,никаких бы бухов и взрывов не было бы.В силовой электронике,как только начинается мала-мальская самодеятельность -жди проблем.От того что будешь переделывать управы или еще чего там выделывать,ситуация не поменяется с твоими подходами
санекнс
на управе ус3845 при регулировке длительности ширина как бы дрожала, менялась даже без подключения силы на 6 ноге, регулировалась с обвязкой для настройки, делал все один в один по схеме без самодеятельности
Jorg63
как не крути, но что то в десятке деталей управы умудрился что то удудить.Чудес не бывает,шаловливые ручки-ДА icon_biggrin.gif
И еще! Прими за правило-если взялся что то делать,доведи до конца.разберись с управой на 3845.А шараханье из стороны в сторону результата не даст
AS65
санекнс
Если пытался регулировать длительность без силы,
то это зря,будет срыв при определённых номиналах резисторов
и тд. и тп. но нормально регулироваться будет только с ОС по току,
или доп примочки для настройки городить,не требовалось не делал.
Короче на голой управе длительность импульса
при любом положении задатчика менятся не будет.
санекнс
Я ставил доп. примочку импульс регулировался но возле максимального значения срывался а от нуля до середины регулировался нормально
А подскажите в каком диапазоне должно регулироваться напряжение на 1 ноге ус3845 для регулировки сварочного тока?
golub
даже если не очень внимательно глянуть в датасшиит, можно видеть, что 1 нога 3845- это выход усилителя ошибки, притом довольно медленный. Ну и Х с ним. По сему значение на нём напряжения никакой инфы не несёт. Смотрите косую разводку земли в управе, и пару фото конструктива не помешали БЫ.
Wasiliy61
А что ты так обиделся на UC3845, если косяков не наделаешь, и правельная разводка печати, то управа на ней тоже хорошо работает.
санекнс
конструктив покажу позже все разобрал переделываю две управы на ус3845 и ус3824
Jorg63
санекнс
согласен но хочу посмотреть с ус3825 а ус3845 переделываю печатку, скорее всего в ней косяк, а еще когда пытался настроить перед взрывом ключей наблюдал на осцилле на затворе выбросы иглы до 50в на мах заполнении как говорил сбивался сигнал но когда осцил ставил прям на ноги все дыло нормально игл не было это на сопрот 1ом и напр200в с латра, на некоторых погибших ключах был пробит и затвор с стабилитронами.
Jorg63
санекнс!
Я запускаю инвертор на полной силе на холостой ход с таким технологическим блоком питания.сделан банально на макетке.На резаке позиция R2 измеряеться напряжение и по закону ома рассчитывается потребление тока.нормальное потребление не более 150 миллиампер.при наличии косяков очень малый шанс спалить ключики.быстрее сгорит предохранитель а через резакR2 будет ограничен ток ниже критического. резистор можно ставить до 15 ом.
tranzistor3102
Цитата(Jorg63 @ 15.4.2014, 17:39) *
санекнс!
Jorg63 здраствуй. зачем санекнс запускать инвертор на полной силе через всякие блоки?мое личное мнение ему надо сначала запустить силу на низком напряжении (трансформатор 50 гц 50V-60V) посмотреть осцилограммы в соответствуюших контрольных точках.если все в норме можно и наполную силу но через лампочку включать.я практически все инверторы самодельные и попавшие в ремонт таким способом проверяю пока все живы при проверке.а так можно еше ведро деталей нажечь хоть какие транзисторы не установи и к заветной цели не придти icon_biggrin.gif
Jorg63
Малую силу никто не отменяет.стартовый запуск по любому должен на малой силе. лампочка это хорошо,но с лампочкой замерить реально сигнал ка К-Э наврятли получиться,да и насыщение если есть таковое, лампочка скроет.Лампочка выполняет роль только защиты в случае косяков возможных при запуске,хотя этого и достаточно в принципе..
satinstaller
Этот БЛОК = включить резак в разрыв 300 вольт в собранном аппарате.
ingener99
Лучше включить лампочку по переменке 220, но вместо электролитов временно подкинуть кондерчик 4-7 мкФ. Таким образом не снижается амплитуда на силе, т.е. можно быть уверенным в плане проверки насыщения. Но, в любом случае, лучше сначала подавать сигналы полного заполнения на ключи, а потом уже 220 - таким образом даже при всем желании ключи сжечь невозможно
Jorg63
на лампе значительно больше падает напряжения чем на резисторе. и как раз эти вольт 20 падения на лампочке могут скрыть насыщение
tranzistor3102
какой мошности должен быть этот резистор?
а что вы пристали к этому насышению?если трасформатор намотан правельно и материал сердечника из нормального материала то вероятность попасто в насышение мала icon_biggrin.gif
lera
Может лучше с ЛЫСЫМ посоветоваться. Ребята уже 1055 страница. и опять лапочка.
KT117
Да, позвоните на бесплатный номер 8-800-200-40-40 и задайте свой вопрос.
RadioГубитель
А после получите приз!!! Проверено, инфа 146%
