Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
Camelot
Dedan
это не попытка а вполне рабочая реализация, я делал такой только добавил резисторы и стабилитроны в затворы, работает на ура, но то двухтактник, мне нужен косой потому что на порядок проще рулить зарядным током...
если пошла малина про водянное охлаждение то рекомендую посмотреть в сторону тепловых трубок, насос не нужен и можно аккуратненько свести все тепло в одно место, только как писали выше греются не только моточные и полупровода...
RUS5610
Я их имел в виду
Kardinalli
Basill, спасибо, интересно.
Но резко усложнен драйвер. IXFN48N50 имеет почти те же токовые параметры что и применяемый автором IGBT, но гораздо меньшую емкость чем 6 штук IRFP460. Это если только девать некуда детали, есть резон такой вариант делать, иначе он проигрывает (для меня) перед авторским однозначно, в смысле доставания комплектующих. Мдя, бум думать...
supryur
Цитата(electrovoz @ 25.11.2009, 19:23) *
Ток сбрасывается до установленного R52 значения, не рекомендую ниже 50 А.
Ваш антистик работает отлично , вместо придлагаемых BSS138N поставил транзисторную зборку IRF7313, немножко пришлось подобрать номинали диталюшек на затвореVT12 ток виставил при срабатывании 70-60А, просто интерестно в буржуйских аппаратх каков там ток при срабативании антистика.....
Д713
Цитата(eger @ 25.11.2009, 19:09) *
нужно что то типа насоса для аквариумных фильтров они там полностью в воде вот только слабые наверно для масла
прежде чем затевать дискуссию подобного плана,надо хотя бы предварительно шо-нить прикинуть к носу,например систему контроля за давлением в системе,без которой все может мгновенно "пукнуть".
maxx
Цитата(RUS5610 @ 25.11.2009, 17:29) *
Мужики кто ствил кондеры К 73-17 цилиндрические? Как они в работе?
Встречал их в устройствах как снаберные.
На счёт жидкостного охлаждения-зачем? У кого что перегрелось?
Д713
это шоб развеселить публику.
для примеру-некоторые корабельные передатчики имеют охлаждение забортной водой,но это ж при наличии окияна!
eger
это просто как вариянт самодельным инвертором работать мне не приходилось а вот гусь и еще какой то мастер очень быстро по нагреву отключались я после этого если надо много работать и быстро беру транс он терпит хотя тоже не холодный icon_smile.gif инвертором нужно работать возле окияна icon_smile.gif
САНЕК
Цитата(Лопух @ 25.11.2009, 8:46) *
Приготовить кого- сопрессор ? icon_biggrin.gif А если серьезно, исхожу из личного опыта: из 6 отремонтированных БП и ЗУ (заводских) лишь в одном сгорел ТОР, в остальных были пробиты сопрессоры. В одном к тому же потекла емкость.
Будут фотосы
maxx
Я этой весной уже рассказывал, на даче порвало зимой м-у дачами 120 мм, не только у меня, ездили ремонтники на легковушке с прицепом-на которой сварочный транс. Так вот именно на моей даче он задымился, в итоге варили бармалейником, и восхищались icon_biggrin.gif приятно грело душу icon_biggrin.gif
Д713
..а вот гусь и еще какой то мастер очень быстро по нагреву отключались..
согласен.
для наглядности пример не самого "отстойного" "гуся"-
это некто awelco.
совместный радиатор выглядит достаточно скромно (по габариту).
eger
да понятно все аппаратов много и все разные варить инвертором гораздо приятней просто хороший или дорого или делай сам если есть голова и руки
Д713
..да понятно все аппаратов много и все разные..
жидкостное охлаждение уже не актуально,ага?
OlegarX-RUS,шо там с моей дверью?
Camelot
господа, есть идея создать косого на 380, тоесть на 540 постоянки отсуда вопрос как организовать дежурку, я бы наверное сделал флай аля косой с двумя ключами, только вот не могу решить проблему управления верхним транзюком, заполнение то может быть далеко за 50%, тгр вроде как уже не канает... какие будут идеи? люблю блин с дежурками возитсо больше чем сами сварочники icon_smile.gif
Д713
организовать в первом приближении просто-маленький транс 380-220,и так далее,это про "флай-дежурку".
а вот "далеко за писят"-непонятно.
и потом,подход к 380в может быть и таким-нет 0 провода-нет и пестни.
Camelot
нее, не канает нужно чтобы пестня была именно без нуля, просто-трансы на дух не переношу после первого собраноого ибп, и давно размотал их все на цветмет и проволоку, далеко за писят это опять же про флай - дежурку, он же флай значит заполнение теоретически может быть аж до 100% в реале до 98% а совсем в реале применительно к дежурке явно может быть выше 50 процентов...
maxx
А диодный мост 3 на входе- 2 на выходе, или чего-то я не понимаю?
Ewgeniy_RZ6LYE
господа, есть идея создать косого на 380, тоесть на 540 постоянки отсуда вопрос как организовать дежурку...
ап-нот от Он-семикондуктор AN4213/D Нажмите для просмотра прикрепленного файла, БП вход 90-600В, выход 12В, собран 3845+3N120, полный расчет + макет платы.
Camelot
3n120 очевидно на 1200В ? у меня есть только транзюки 2N60 из комповых дежурок, было бы у меня ведро с 1200 вольтовыми полевиками я бы и не стал задавать вопросов, всё упираетсо только в изоляцию...
Д713
нее, не канает..
либо отпочковаться от последовательно-включенных банок на входе.
RUN1
Цитата(Slava79 @ 25.11.2009, 16:05) *
Ув. RUN1 может у вас есть полная схема из Сообщения #5027, интересует именно она, точнее дорожка идущая в низ от 6й ноги UC3845. Спрашивал у Wiew`а, он не понял, что именно хочу узнать. На схеме указанно стрелкой, что именно интересует.
Спасибо.
Продолжение - к источнику питания 13,5 В
Ресурс 10 минут
Цитата(Д713 @ 25.11.2009, 19:29) *
эт-точно.
electrovoz
В моем ПА именно 380-220 транс, и как раз потому, что ноль заводить нельзя, а иметь на плате БП импульсы под 1000 В не нужно. Это если практически нужен результат, а если процесс - то питальник можно усложнять как угодно. Вообще ИМХО самый правильный вариант - это транс ОСМ 380-24, из него 30-40 в постоянного напряжения превращается LM2576 во все что надо, и без боязни просадок сети, и без высоковольтных деталей на плате вобще. Буду еще что-нибудь трехфазное делать - обязательно так и сделаю, просто и надежно.
Camelot
важен именно процесс творения, всё остальное вторично бо сварочники меня не кормят.
yura_
Всем привет! Очень интересует Кто нибудь собирал сдвоенную схему силовой части с двумя трансами Ш20х28?
Собрал на 2хШ20х28 на балласте 0.2 Ома 160А после пяти минут температура обмотки транса более 100 градусов,феррит холодный,после 7 минут греется феррит. Хочу увеличить мощность и охлождение двух трансов, думаю не будут греться. Если у кого есть схемка, поделитесь пожалуйста.
Вот наше творение, пока безобразно,но работает.
KLIM
RUN 1
Вопросик всплыл. Завел таки я регулировку по среднему... в новом аппарате. В принципе все ОК, и варит мягенько, и брызг немного, точнее как у меня и было, так и осталось но дуга устойчивей, особенно на малых токах. Дело в интересном моменте - сильный щелчёк при касании электродом и его прилипание. Голая поцикловка с небольшой компенсацией меньше подлипает. На больших токах все нормально, на токах же 30-80А подлипание (это основной диаппазон для 3-ки). Как у тебя с этим фокусом? Я уже аркфорс думаю встраивать... Напоню - схема что Ты собирал, чуть изменена, но по существу всё еще та же.
Wiew
Вы часом ничего не путаете?
мда... без аркфорса и у меня липло, поставил аркфорс все с полтыка пошло.
KLIM
В смысле путать? для тройки 130А практический максимум, в основном варят до 100А (если аппарат хороший и честный). Или я не об этом? Поставлю завтра аркфорс, отпишусь.
Wiew
не ну 80а -согласен, но меньше эт уже извращенство ИМХО
KLIM
RUN1
Цитата(KLIM @ 26.11.2009, 22:53) *
RUN 1
KLIM поздравляю! Дуга действительно очень устойчивая на малых токах да и вобще а щелчек при поджиге действительно не хилый какбудто кондер на выходе весит а подлипания не замечал мне прям понравилась метал лить каплями на малых токах чуть прикаснулся и тянеш дугу как хочешь и это при КТР 3,33
gorbun75
Меня тоже ,как оказалось . Много недорогих укр-ских инверторов на рынке . А вот ремонт
,наверное , нам поможет . Не каждый перейдет с тыканья в клавиатуру и передергиванья плат
на силовую технику .
DANTIST
Yura, я сам не делал. Все собирался, да как-то руки не дошли. Сейчас пока некогда. Хотел попробывать вот эту схему.
golub
Не знаю с каких соображений електровоз зациклился на 50 А, у буржуев- 15-20 А.
KLIM
И Тебе спасибо и WIEW - тоже спасибо. Поставил форсаж при снижении сварочного, сильно резко идет, прийдется затуплять чуствительность, но нержа на 50-60А электрод тройка мажется как пластилин, тройка УОНИ немного побрызгивает но на 60А идет уверенно... наигралось только что пол цеха, у всех слюни icon_smile.gif
Доработаю - расскажу.
golub
Дык уже рассказано. Легулировать нада. Если такой диапазон применяемости подразумевается (для дачников). И в оконцовке разобраться, что АС только глушит при обнаружении КЗ, а АФ не даёт этого сделать чуть раньше подбрасывая ток. И вот как раз величину этого подброса надо регулить, для разных металлов.
Цитата(gyrator @ 22.11.2009, 19:46) *
"- Чё дают-то? - Мопассана - А это лучше кримплена или хуже? - Не знаю, не пил..."(С) icon_biggrin.gif
"Ва хмелю слегка, лесом правил я ..."(с)
Wiew
угу
Д713
с такой динамикой роста аппетита поставщиков китайской комплектухи и эта статья под большим вопросом.
САНЕК
Народ,случайно шита на русском на UC3845 не завалялось?
Оч нужно.
gyrator
Цитата(САНЕК @ 27.11.2009, 20:05) *
Оч нужно.
Ось http://slil.ru/28263270 тоби справочник на русском icon_biggrin.gif .
maxx
Спасибо!
kyzmi4
Привет специалисты самодельщики!!! icon_biggrin.gif Помогите с выбором транзисторов в бармалейник.
Вот присмотрел такой транзюк:
IXER60N120
Корпус ISOPLUS264
Uкэ макс, В: 1200;
igbt Ik max, А: 95;
Uкэ нас, В: 2,1;
tнар/tсп, нс: 50/30
Цена (руб.) 66.77
Пойдет он в бармалейник????Или искать IRG4PC60U.Конечно меня смущает корпус ISOPLUS264,но думаю можно пережить,он ведь дешевле в два раза.
Даташит прилагается icon_biggrin.gif : http://www.chipfind.ru/datasheet/pdf/ixys/ixer60n120.pdf
KLIM
IXER60N120
30кГц максимум, а то и меньше, хотя для себя - 25кГц я думаю потянет с нормальными снабберами. Думайте сами... В принципе очень неплохи но аккуратно с ними, туповатые. Лучше по два, а еще лучше - в фиксатый их. Есть тут темка и идеи есть.
kyzmi4
KLIM, а Вы такие не ставили????А какие транзюки используете???
RUS5610
И по одному потянут нормально эти ключи. Плюс ко всему к этим ключам хороший охладитель и не каких прокладок!
Wiew
Цитата(RUS5610 @ 27.11.2009, 21:03) *
И по одному потянут
Вы пробовали?
RUS5610
Я нет. Судя по даташиту хорошие характеристики
Dedan
IXER60N120
Пытался заказать в Питере в Мегаэлектронике для фиксатого. Сказали от 30 шт и ждать минимум 2 недели.
UVM
Заказик сегодня поступил на контактную сварку, вот и ума не прилажу как сделать чтобы бодика на торе не мотать.
Требуется вобщем источник тока в 1500-2500А чтобы болты М6 шляпкой к листу 2ке прилеплять
вся механика с пневматической установкой уже имеется, остался только источник тока.
На прикид видно что даже 1 виток вторички некуда вставлять (нелезет), может на кольцах прбовать или еще чего, кто нибудь пробовал?
maxx
Время прижима-одна из проблем, прижим немного разный с пневматикой, поэтому регулируют время сварки и силу тока. Ну и прижим тоже надо бы регулировать.
UVM
Да с прижимом порядок будет, регулируется как хочешь техника буржуйская прфессиональная.
Вопрос с источником тока, как его сделать на основе косого?
Пока в воображении рисуется огромный транс из 8-10 комплектов ТВС, частота килогерца 2-3 иначе витков не набрать и..
