Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
strannicmd
Д713,
для измерения миллиом нужно что-то более спецовое,а для LC хватает китайской мыльницы,плюс-минус "лапоть" в нашем деле позволительно.
Он меряет ещё и ESR. И потом я его ведь хочу сделать не строго для того чтоб сверкальники ваять... (с этими китайцами скоро это не выгодно будет..), а есть необходимость в таком приборе и для других приложений.. Есть у меня китайский LC - метр, но хрен его знает, что-то не внушает.. Есть и совковый, хороший девайс (был в своё время), но сдох, а тама милион микросхем и электролитов, ну его.., не охота чинить... В общем, при наличии платы..., почему не собрать.. А вот платы такие, да ещё качественно сделать с утюгом.., вряд ли получится.. А вобще..., дело вкуса.. Наверное буду по тихоньку собирать (если плата будет).
golub
Цитата(Д713 @ 17.8.2009, 22:15) *
на внутренности можно глянуть?
Если успею снять выложу, срочно собираюсь на выезд. Собственно, то что внутри уже выкладывалось- ATX@ATX, с управой на 3845 по среднему, аля Telvin, плюс AF, AS, HS и sleep. Нижняя крутилка регулит величину заброса HS и AF, вплоть до отключения оных.
Сергей76 утюгом делал и ничего, работает.
Д713
Наверное буду по тихоньку собирать ..
скажу по секрету-собирать средства измерения-неблагодарное занятие,лучше заработать денег и купить.
дешевле будет.
какой смысл "по тихоньку" собирать Tektronix?
самое дорогое в нашей жизни-это время.
через пару лет наступит заветный момент,когда Слава скажет-"я его собрал!".
а что дальше?
ну перемеряет ESR всех своих кондеров,опять же-для чего??
RUN1
[quote name='golub' date='17.8.2009, 23:18' post='100948']
golub весьма симпатичный пупсик! и в принципе и надписей не надо и так все смотрится и еще-бы вашу управу глянуть на 3845 по среднему если можно конешно icon_smile.gif
С уважением
[quote name='DANTIST' date='17.8.2009, 20:12' post='100925']
Добрый всем вечер!
На 165-й странице я выкладывал печать по схеме Кольта.
С божьей помощью наконец-то удалось получить хорошую плату. Кстати, с третьего раза.
Практически без дефектов. Мужичок один принес с типографии хорошую глянцевую бумагу, тонкую.
Здесь есть фотка платы после ксерокса. Она, правда, чето слегка запузырилась после ксерокса. Думал, пропала. А отпечаток получился класный.
И еще несколько фоток процесса монтажа. Если кому интересно. Дроссель пока не установлен.
Останется испытать. Ключи стоят HGTG30N60A4.
Транс я мотал немного раньше под 60PD1 и частоту 50кГц. Е65 15х5.
Если все будет хорошо, попробую приподнять частоту.
DANTIST молодца ! а аппаратик на 100\120 ампер раcщитываешь?
gorbun75
а что дальше?
И тогда уже вооруженный новым прибором приступит к сборке сварсчника предварительно перечитав форум и еще раз продумав конструкцию.
yjriy
а что дальше?
Вообще-то это простая конструкция не требующая настроек долгими бессоными ночами является весьма простой конструкцией "выходного дня" и собирается за пару дней при наличии комплектухи и в хозяйстве оч. нужная весчь. И мерять ей мелкую СМД-шную рассыпух весьма удобно. А сделать плату даже лутом не вопрос. Ошибок в печати и монтаже нет, обсосался на форуме не хуже бармалейника.
strannicmd
Д713,
какой смысл "по тихоньку" собирать ..
Ну, блин.., Вы и фрукты.. (Шутка..)Чего не скажешь что хочется сделать.., ответ один: а нафига тебе оно надо?!
Ну хочется мне иметь такой приборчик, а покупать Tektronix, денеХ не хватит...
Д713
strannicmd
Д713,
Слава,я ж беззлобно,не обижайся.
Дык я тоже..., что я , не понимаю..?!Здесь все свои.., без шуток и жизнь скучна..
lapa
На Митино Т225-52B стоит 170р мне стало жалко. вот Т250 52B это 12 витков индуктивность на начальном участке порядка 53мкГн конечный ток 200А. Для 225 сердечника загиб начнется раньше.
Levs
Нету в закромах Т250-52В, есть T225-52B и T300-52D (тоже удвоенная высота).
А T225-52B , собственно и преобретались для сдваивания, либо по одному, но в спарках.
А что это за прога такие красивые кривульки рисует ?
олегр
[quote name='DANTIST' date='17.8.2009, 21:12' post='100925']
Добрый всем вечер!
Платы получаются с первого раза, да вот лето обленился совсем
можно вашу плату, на которой всё, в lay icon_biggrin.gif так нехотца разводить по рисунку.
Levs
Так на 165ой странице тот файл (не рисунок) и лежит, загляни туда и скачай.
Кстати, ДАНТИСТ, плата хороша, спору нет, но - я так уразумел, что ТГР у вас вместе с БУ стоит?
И управу на дрова вы будете длиннющими проводами через всю плату от ТГР тянуть ?
Это есть очень не гуд. Лучше перенесите ТГР на маленькой платочке на двух стоечках рядом
с дровами, а провода длинные (витые) лучше к ТГР от БУ тяните, чем от ТГР к драйверам.
Ну и по разводке БП ТОРа есть вопрос - защитного промежутка между первичной и вторичной частями нету,
его пересекают дорожки к оптрону, хотя оптрон можно выше сместить параллельно трансу. И так, по мелочи.
Хотя компоновка неплоха, а об аккуратности я вообще молчу - супер. Но ТГР я бы всё таки перенёс, от греха подальше.
С уважением.
lapa
Не это я даю 30В на дроссель и смотрю как нарастает ток. T300-52D тоже есть могу мотнуть.
RUS5610
Мужики подскажите как файл открыть со схемой Электровоза, а то что то уже подзабыл.
Levs
Я так и подумал, что это чудный осциллограф для компа. Это,видимо, Гумерова-Зуева приспособа?
T300-52D мотните, если вас не затруднит, плизззз.
golub
Я так думаю что ДАНТИСТ не стал изобретать велик, и заглянул в этот первоисточник.
Я тоже в своих последних конструктивах тяну жгутом от вторички до драйверов, драйвера- святое дело, на отдельных платках на ногах ключей.
lapa
Таках не знаю. Вот T300-52D.
gorbun75
Не от вторички до драйверов , а от управления жгутом до первички ТГР . А драйвера вместе с ТГР как можно ближе к ключам . В этом есть смысл , хотя провода с выхода ТГР нагружены на 200 ом ( если драйвера на ключах )то и так неплохо выходит , если провода не слишком длинные .
Цитата(strannicmd @ 18.8.2009, 10:44) *
[b]
Чтобы откалибровать измерительный прибор с определенной точностью нужно иметь другой на порядок более точный . Измерительная техника это не сварочник(при всем уважении),где +- квадратный гектар достаточная точность . Правильно говорит Д713 , сделайте сварочник , продайте ,купите Tektroniх ,а потом вооруженный Tektronixom , пр. опытом , и теоретическим багажом сделаете суперсварочник .
golub
"На входе стоял швейцар, и всех впускал за рубль. Но если ему рубль не давали, то он всёравно впускал"
Ещё один пример, управа на разъёме над оптикой, хорошо видны дорожки от оптики до ключей.
А то что советуете Вы- это вот, китайский бренд, под разными названиями гуляющий по необъятным просторам.
Александр_М
golub Можно ешо пару вопросов по вашей плате? Та которая ATX_TOP?
Два резистора в паралель в самом верху платы получаеться нагрузка ТТ их номинал?
Резистор правее (опорное напряжение 5 вольт) номинал?
Паралельно выходам ТГР номинал резистора На схеме драйверов кольта не нашел.
golub
Нагрузка ТТ 25-27 ом суммарное. По опорным 5 вольт- 51-100 ом. Нагрузки ТГР- по 360-470 ом.
Александр_М
Спасибо
gorbun75
Рад , что мое мнение совпало с китайским потому , что они далеко не дураки , особенно в области производства конфет из г-а в особо крупных размерах .
golub
Да Вы не представляете как я рад, что просвятили меня по поводу китаёзов, и
Которых не пробовал, и нет особого желания.
Camelot
Levs
вы случайо не тот ли Levs - модер с "поялнега" который драйвера у полевиков считал чем то вроде "сотонизма"? удивлён видеть вас в обществе людей в корне с этим не согласными. это ж ваш девиз был н*х драйвера, даёшь по резистору в затвор и вся любовь. очень рекомендую повторить ваши рекомендации в сварочнике, потом отпишитесь о результатах.
Зы.
очевидно вы так тяготеете к резонанснику негуляева именно из-за отсутствия сотонинских драйверов?
на поялниге я не стал с вами спорить, обычно считаю лучшим оставить человека счастливым в его маразме чем зазря портить себе нервы.
если вы действительно с поялнега то скрывать не буду меня совсем не радует ваше появление здесь.
RUN1
ув Golub не могли бы вы глянуть вот на это художество пойдет такая управа по среднему на 3845 или я лишка отрезал?буду очень признателен за помощь!Нажмите для просмотра прикрепленного файла
С уважением
UVM
Камелоту про Левс
Да пусть поучится здесь, а потом на своём сайте умные вещи народу тулять будет. Хотя лучше на мастерах этому учиться, там о таком филосовствуют!
Не в обиду будет сказано сдешним гуру являющимися посетителями мастеров.
golub
С уважением
По третьей ноге не забыть емкостину, 68 Ом по входу ТТ замените на 1 нану, а вместо 56 поставьте для начала 27 ом, и предусмотрите место для дополниельного впараллель.
RUN1
Golub большое вам спасибо!!! И еще можно маленький вопросик вам, R2 по схеме 22к что им подгонять? Еще раз благодарю!
С уважением
golub
Посмотрите здесь http://flyfolder.ru/13622055
Я бы выкинул эти 22 ком, и сделал как в оригинале.
RUN1
Ok! Благодарю!
Levs
Цитата(Camelot @ 20.8.2009, 0:46) *
Levs
Зы.
Камелот, вы чего - с дуба рухнули ? Не знаю я ни вас, ни модеров с пояльнега, ни самого пояльнега. Я так понимаю, вы про сайт "паяльника" имеете ввиду,
так я там даже и не зарегистрирован вроде, но то что ни слова там не никогда не писал, то точно. Несколько раз на мастерах писал, но совсем не ту пургу,
которую вы мне здесь предъявляете. Да и здесь писать не мастак, зареген в 2007, а постов чуть больше ста всего.
А самый первый сварник - косой собрал в 2006 и там уже стояли НСPL3120 с буфером.
Вот ссылки:
в самом конце - http://www.mastercity.ru/vforum/showthread...;highlight=LEVS
продолжение - http://www.mastercity.ru/vforum/showthread...;highlight=LEVS
Как видите, нет там никаких резисторов, вместо драйверов, я ж не дебил, чтобы такое делать и говорить. Да и к теме резонанса я недавно пришол,
раньше в основном косячками баловался, пока не надоело. Да и в резонансники тоже оптику буду ставить, резюки-печки меня не устраивают.
Так что, думаю, лучше вам признаться в том, что вы лоханулись и меня с кем-то спутали,
ну и, видимо, извиниться за беспричинный и тупой наезд. Не хватит смелости здесь, можно и в личку.
Как я уже ответил, ни с какого я не с пояльнега, но если бы и был оттуда, то вы сами понимаете, что мне бы было глубоко фиолетово радует
вас это или нет.
Цитата(UVM @ 20.8.2009, 8:05) *
Камелоту про Левс
Аналогично, что я написал Камелоту. Мужики - вы чё одной травы накурились с Камелотом. Жил себе спокойно, никого не трогал, тут сразу два поца из-за куста облаяли. Не модер я ни на каких форумах, и модером в жизни никогда нигде не буду, у меня и без этой бадяги дел хватает. А за драйвера я всегда был, и где-то
постил, что перепробовал их все и бармалеевы, и мультика, и кольта, а когда попробовал оптику, то на ней и остановился.
Basill
Цитата(Levs @ 20.8.2009, 11:41) *
А самый первый сварник - косой собрал в 2006 и там уже стояли НСPL3120 с буфером...
Давно присматриваюсь к оптике. Не подскажете, какие буферы к оптике использовали? Ниже - пара фрагментов из схем, выложенных в разное время уважаемыми форумчанами:
Нажмите для просмотра прикрепленного файла Нажмите для просмотра прикрепленного файла
Levs
Вот здесь разговаривали - http://www.electrik.org/forum/index.php?sh...amp;#entry98840
Я на двух транзюках делаю, Diso свой вариант на четырёх полевичках показал, КЛИМ тоже на четырёх полевиках,
Гена в последнего косого на модулях, как у меня на двух поставил. До 40кГц хватит. Транзюки буферные можно заменить
на пару BD139/BD140 они поновее будут.
Удачи.
sorry
Может кто подскажет, есть 2 таких кольца размер D44, d28, h20мм Нажмите для просмотра прикрепленного файла
Возможно ли использовать для дросселя если сложить две шт. Маркировано белой полосой.При 15 витках на двух кольцах 30 мкГн?
yjriy
нервы.
Даааа Саня обосрал он тебя публично, ибо думает чем больше сообчений тем больше хвору. Интересно: а хватит духу у Камелота также публично извиниться.
Хороший аппаратец на заре инверторостроения ты слепил, а некоторые в те далекие времена еще и не слыхивали про них. Молодца.
Camelot
не в количестве сообщений счастье! за количеством это к Коляну.
Levs
не сомневайтесь что мне хватит смелости не только обосрать публично но и извиниться.
прошу прощения что спутал вас с тёзкой с поялнега.
когда прочтёте напишите в личку и я удалю свои последние посты.
KLIM
Первая картинка моя, работает исключительно но выглядит намахано, это для баянов, модулей и прочей монстроидальной комплектухи. Можно оптику через протой буферок на 2-х транзюках типа 972-973 или как Levs транзюки назвал.
Вторая картинка - это масло маслянное. Зачем закрывать сиовой транзистор выносным транзистором когда в самой микрухе он уже стоит и весьма не кислый.
Levs
Levs
Да нормально всё. beer.gif С кем не бывает.
Вообщем получилось как в анекдоте:
-"После вашего ухода, мы не смогли найти свои серебрянные ложечки.
Ложечки, правда, потом нашлись, но неприятный осадок на душе остался". icon_biggrin.gif
А ник мой означает (Lev)chenko (S)asha, причём на многих сайтах не мог под
ним зарегиться - писали, что у них уже есть свой такой.
Ладно, проехали. beer.gif Теперь будете знать, что я не тот дебильный модер, и вообще не модер.
UVM
Пардон!
Basill
Levs, KLIM
спасибо за ответы!
шумный
Может кто-то использовал оптику без транзисторов как я, у нее и так 2А по выходу
Andrey_G
Basill, второй вариант я предлагал, один транзюк вместо двух или четырех, всмысле для баянов (на схемке один транзюк схемотично), а управлять одним вполне сама hcpl-ка может. А вообще что-то не очень мне оптика понравилась - выход красивый, но доп. питание всю красоту на нет сводит. Короче приемуществ в конечном итоге ни каких, но это сугубо мое мнение, на дискуссию не нарываюсь icon_smile.gif .
Levs
Дык, многие и пользуют. Чукча пользовал, Лисовой пользовал, Yuriy пользует, вы пользуете, ну и ваш покорный слуга тоже.
Плата на два транзистора, двухсторонняя.Варианты питания:
1) транс +диоды+ кондёр на платке, а к нему дежурная переменка 100-400кГц от дополнительного DC/AC от дежурки питания
(Чукче нравится именно такой вариант питания)
2)диоды + кондёр на платке, а к нему переменка 100-400кГц от отдельного транса, стоящего на плате DC/AC
3)кондёр на платке, а к плате отдельно постоянка от дополнительного DC/DC от дежурки питания
Ну и, собственно, на плате можно делать хоть с отрицательным смещением затвора, хоть и без онного. А нужно одинарные,
разрезал плату нах и всех делов.Если нужны сапрессоры на транзюк, паяются прямо в плату, ну и сама она паяется либо на ноги транзюков
вертикально, хошь горизонтально, хошь проводками короткими. Вообщем универсально. icon_biggrin.gif
А с буферным каскадом - это модули питать, или "баяны". С одним транзистором и без буфера сама HCPL неплохо справляется, проверено.
Я когда буферы делал, так я по два 40U баянил, а для одного не нужно.
UVM
Пардон!
maxx
UVM
Это Вы себя так хвалите или хотите поделиться схемой и печаткой?
RUS5610
Diso
Мой вариант на 4х полевиках, взят из "Руководства по применению от IRQ".
Работает супер, но даже для двух в параллель избыточен.
На на нагрузке в 0,1мкф дает фронта не хуже 150-180нс.
Применил этот варьянт по принципу "на всякий случай".
VrnAlexM
Намотал 18 витков для дросселя на одном комплекте строчкиков, после узнал что такой дроссель насыщается при токе ~ 80А.
Хочу задать вопрос. Извините если он уже встречался.
Подскажите, пожалуйста, ток насыщения дросселя зависит от частоты и от чего зависит?
Для трансформатора мне понятно.
gorbun75
К вопросу о драйверах .Крутил ТГР целый день в свое время , но на PD1 не смог добиться фронта меньше 300 нс. Спад - 180 нс . Какие допустимые значения для этих параметров ?
