Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
Serega30
С вашего позволения немножко добавлю по Тт: на выходе инвертора выбросы U снизились до минимума. Такой вывод был сделан исходя из следующего: при измерении напряжения на баласте стрелочный м-метр стал показывать вполне вменяемые значения,(раньше завышал U на ~20% при макс. токе). При Uсети 175V, 123А показал 19,5V. Баласт-0,15R. Осла-нет, так что осцилограмами подтвердить сей факт не могу.
Wasiliy61
Серёга, а что осциллографа вообще нет, так без него совсем тяжко.
Kalin Ivanov
Oleg1ma ,где моежт найти прошивка 140А для Липин с режима " сна" Нажмите для просмотра прикрепленного файла
zentr
Цитата(DANTIST @ 27.5.2014, 8:05) *
А какого он не должен работать?! Люди без сердечников ставят и работает.
Шина эмалированная? На фото не совсем понятно.
А накрутил красиво. Вручную крутил или на токарном станке?
Добрый вечер ! Шину надо лачить,так как она была в бумажной изоляции и пришлось удалить ,потому как при накрутке на станке она бы порвалась.Вручную не крутил ,но мне кажется ,что без приспособы на ребро 6мм. не накрутить аккуратно .
oleg1ma
Тут.
Wasiliy61
DANTIST, вот посмотри- намотка ручной работы. Конечно прямо на трубу не получилась намотка, но в течении часа сделал приспособу- и вот что получилось. Дроссель потом покажу. Меж витками потом загоню нитку, и залью либо лаком, либо эпоксидкой.
Нажмите для просмотра прикрепленного файла Кому интересно, могу показать приспособу.
KSV
Покажите ,если не сильно секретно. Я давненько приготовил сердечник, правда сделан из Ш образного при помощи
шлифмашинки и думал намотать на трубу не на ребро пару слоёв.
Kalin Ivanov
Спасиба Oleg1ma!
RUS5610
Василий а на сварочнике ручка от холодильника?
Wasiliy61
Взял кругляк нужного диаметра- можно трубу, сверху нужно приварить какой-нибудь рычаг, за который нужно будет крутить, и одновременно придавливать в низ -чтобы шина не шла гормошкой. И ещё приварил упор с зацепом для шины.
Затем нашёл железку с подходящей дыркой, т.е. отверстием, и приварил к ней упорную пластину, так чтобы вход был шире шины, а дальше сходил на ширину шины, или чуть чуть побольше.
На остальное не обращайте внимания, это плуг от трактора- просто на нём всё удобно расположилось, было удобно работать. Ну а дальше Процесс пошёл очень быстро.
Да, всё что валяется, пускаем в дело.
DANTIST
Повезло тебе Wasiliy! У тебя плуг есть!
У меня нет плуга, поэтому я мотал несколько иначе. Фото приспособы вечером выложу. Дома.
Гармошка - это не страшно. Даже веселее. icon_biggrin.gif Потом, перед вбрасыванием внутрь катушки сердечника, стянешь ее в 2-х, 3-х местах ниткой.
А как же теперь холодильник без ручки? Если остудить чего понадобится перед употреблением? icon_biggrin.gif Хотя, ручка "валялась". Вот если бы лежала - это другое дело.
Wasiliy61
Да этот холодильник я давно изрезал на корпуса, ну а остудить есть в чём.
RUS5610
Молодец! Рукастый мужик!
DANTIST
Вот, Wasiliy, моя приспособа. Не плуг, конечно, но все же.
Вот тут, как раз и нужен "рукастый мужик". Ну, в смысле, чтобы руки были крепкие. icon_biggrin.gif
Wasiliy61
DANTIST, извини- наверно я не въехал, или всё-же я правильно мыслю, /шина зажимается в эту приблуду, потом матается на трубу/, да? Если так, то всё орегинально просто, и получается окуратно. Не знаю что-бы я делал, если-бы не было плуга с трактором, один бы плуг я наверно-бы свернул, хорошо что он прицеплен к трактору. Шутка конечно, моталось очень легко, но у тебя просто, конечно не знаю -трудно-ли мотать твоей приспособой. Просто мне попались на глаза эти железки, и я за час сляпал приблуду.
Alexzav
Подтверждаю!!!руки золотые, как сейчас модно говорят: "не из клавиатуры растут а, откуда надо"
Тоже пока лето - корпуса клепаю, зимой негде болгаркой работать.
KSV
Wasiliy61 молодец, китайцы б до такого не додумались, получился практически трубогиб, с таким рычагом шину можно и потолще брать. Я как то пытался дросель на рогах от строчника мотнуть, сначало в руках, чуть пальцы не сломал, потом в тисках и дело пошло на лад, да феррит не выдержал. С тех пор полубил ETD59
DANTIST
Цитата(Wasiliy61 @ 28.5.2014, 15:56) *
DANTIST, извини- наверно я не въехал, или всё-же я правильно мыслю, /шина зажимается в эту приблуду, потом матается на трубу/, да? ...конечно не знаю -трудно-ли мотать твоей приспособой.
Да, Wasiliy, ты все правильно понял. Шина должна довольно легко скользить внутри приспособы. Не легко, конечно, мотать. Я мотал где-то 4х6 мм. Эта приспособа исключительно для того, чтобы шина ложилась попендикулярно. А то она постоянно норовит свалится на бок.
На трубе закреплен винт для заделки начала обмотки (изогнутого буквой "зю"). А дальше дело техники: трубу в тиски, шину на трубу. Трубу постепенно проворачиваешь, где-то на 1/3 оборота по мере намотки.
golub
Блин. Красочно-то как? Особенно- "На трубе закреплен винт для заделки...".
Serega30
Всем привет! Примерно так и дожно быть?... Или все же косяк где-то?
Jorg63
МУЖИК! Не занимайся херней! работает аппарат и радуйся! А то шаловливые ручки доведут тебя до буха icon_biggrin.gif Или карманы деньги жмут? icon_sad.gif
Serega30
Цитата(Jorg63 @ 29.5.2014, 10:46) *
Не занимайся х...
Да не лезу я никуда! Просто спросил насчет таких результатов измерений... Гуд... Не гуд.. Может кто-то получил другой результат... Как говорится, хочу шоб все четко было.
DANTIST
Ты ж понимаешь, по нонешним временам нужно все подробно расписывать. И все равно могут быть вопросы.
Не совсем как бы гуд. Если уж придираться, то выходное напряжение не соответствует формуле. 20 + 0,04 I.
Да и сеть у тебя, мягко говоря, ни в туда, ни в красную армию! На больших токах выходных могут пукнуть ключи по току.
Хотя с ключами 50B60PD1 на херовейшей сети мы варили 3-кой.
В любом случае, нужно брать и варить. Чё там гадать, рванет, не рванет. Рванет - значит ему не судьба.
Serega30
DANTIST, вроде как для этой формулы надо изменять Rнагр. под каждый диапазон измерений... Или я не прав?
Wasiliy61
Серёга, ты хочешь шоб качественный, чёткий бах получился.
DANTIST
Serega, ты имеешь ввиду вот это? Но это несколько другое. По поводу Rнагр тоже масса мнений. Вроде остановились на эквиваленте дуги 0,17 Ом. А какое требование к источнику 230 В? Какое допускается падение под нагрузкой. Я как-то работал на сети с падение с 238 до 235 В на 4-ке. Вот это сеть!
Так что врубай! А там видно будет.
Serega30
Именно это... А че врубать-то?... Все давным-давно работает. Вопрос заключался в том, сколько инвентор потребляет и сколько отдает. Конечно, с сетью с падением U при сварке в 3V на это можно забить, но не с моей-то сетью где падение U десятки вольт. Тут каждый ватт дорог.
KT117
Поможет ККМ, поищи у Володина
Wasiliy61
Серега, ты включаешь в разетку, а может у тебя проводка дома тонкая - тогда будет сильная просадка, может подвод плохой. Так это что тогда за сеть, что от 3квт так сильно проваливается.
Serega30
То-то же... И это еще днем. А вечером и 185В бывает. Замерял специально: 3В всего-лишь падает на проводах при 3кВт нагрузки в розетке.
Павел(Sp)
Вот время выдалось, ..наваял в шпротеусе термозащиту для бармалея,с мигалкой(светилкой) и пищалкой(или жужжалкой,кто как любит).
На lm35,очень удобно крепить даже к цамому маленькому радиатору а если постарацца то и на сам ключ не очень сложно прилепить. температурный гистерезис регулируется в широких пределах.На вольтметры не обращать вынимания, это для настройки ,чтоб было видно что куда крутить.С данными что на картинке 35-70 градусов..
ЗА и ПРОТИВ¿¿¿
SERGIO84
Подскажите как переделать схему для датчка на размыкание.
RUS5610
Поставь релюшку мелкую повторитель.Термиком запитывай реле а контакты релюхи НЗ в управу.
oleg1ma
Цитата(SERGIO84 @ 30.5.2014, 10:50) *
Подскажите как
Так
SERGIO84
Цитата(oleg1ma @ 30.5.2014, 10:18) *
Так
А куда делся индикатор"работа"с рэле.
Wasiliy61
Если индикатор включения реле, так он в другом месте.Нажмите для просмотра прикрепленного файла
По другому, это готовность аппарата.
SERGIO84
Теперь всё ясно.Огромное спасибо за растолкование.
Wasiliy61
Вот нормальная схемка, можешь воспользоваться её.Нажмите для просмотра прикрепленного файла
Serega30
''...выходное
формуле. 20 + 0,04 I.'' Тогда какое Rнагр. следует применять для расчета U по этой формуле?
oleg1ma
Почему это у тебя не соответствует, видимо занятся нечем?
Serega30
Это DANTIST написал...
oleg1ma
Dantist написал, а ты для чего написал?Пиши в личку, какие нужны деталюхи, вышлю, займешся делом.
KSV
Доделал сегодня малышка на 120а, только на количество троек не испытал, сварной ногу подвернул. Всё работает.
Нажмите для просмотра прикрепленного файлаНажмите для просмотра прикрепленного файла
Wasiliy61
Молодец, аппарат выглядит здорово.
tranzistor3102
можно попробовать вот так _ работает проверено
Wasiliy61
Обь разбушевалась. Караул-тонем!
Nikolay1
купи надувную секс куклу
Lomaka
Всем привет. Принесли мне вчера моего первого монстроидального бармалея, не работает мол. Думал ключам кирдык пришел. Оказалось что сгорел транзистор кт 815, выключилась релюха и ток пошел через ограничивающий резистор тот долго сопротивлялся, но тоже крякнул.
Вот и думаю, это еденичный случай или лучше будет в будущем этот узел заменить....
Serega30
Резистор лучше заменить на последовную RC цепочку, например: 5R/5W и 5mF/250-350V (но только если контакт реле до диодного моста!). В таком случае, при несрабатывании реле, гореть ничего не будет.
DANTIST
Nikolay, а что у вас там такая сильная радиация, что такие глобальные генетические изменения? icon_biggrin.gif
