Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
oleg1ma
Цитата(petr0757 @ 15.1.2011, 12:56) *
ТПИ в советских БП телевизоров склеены навек эпоксидкой, поэтому ни паяльники, не кипячение не помогут, пробовал, импортные действительно на раз. Попробую в печке, не знаю, как это повлияет на свойства феррита, но эпоксидка сгорит, потренируюсь на ТДКС.
Cклеены они в основном бакелитовым лаком, любоя смола от температуры плывет.Посмотрите мои фото ранее, я разьеденял 8 комплектов от БП и именно в воде.
Lemm
Цитата(SRGUT @ 15.1.2011, 13:27) *
Кипятиш потом под холодную воду и так два -три раза,разеденяеш горячими.
и выкинешь в ведро осколками . феррит при таком перепаде лопается на раз . я приспособился эти тпи разбирать , нагревая их в микроволновке на режиме гриля . исключительно !-гриля . греть надо , контролируя - при температуре размягчения клея каркас тоже становится мягким , и может поплыть сверху . а так - кипячение не всегда помогает .
в основном эпоксидкой с порошком карбонильного железа мне попадались . у бакелита низковата температура рабочая .
Цитата(molotok26 @ 15.1.2011, 10:18) *
Берешь 2 паяльника 100вт и прогреваешь ТПИ с двух сторон на стыках сердечника
тоже рулит - но надо 2 паяльника - единственный недостаток .
Summon
Такая же проблема. Один легко разобрался кипячением а другой не хотит, кипячение, нагрев не помогает. Горячим пробовал этот клей поковырять ножом, так он совсем не размягчился. Пока отложил, еще не придумал как расковырять. Хотел попробовать в растворитель но коль тоже не помогает тогда и пробовать растворитель не буду.
lera
Эту бы страницу-- да в ликбез.
леха-защита
Цитата(maxx @ 15.1.2011, 1:59) *
Может какой-нибудь хотстарт, если ничего не сгорело-пробуй электродом.
Я забыл сказать что уже отключил хотстарт и акфорс перерезав дорожку в управлении между диодами VD11и VD12, а если с этими функциями то ток вышее 30 А не поднимается а регулировка тока резистором ничего не дает?!
oleg1ma
Какой стоит у Вас стабилитрон V9, резать ничего ненадо и какие наматочние тр-ра?
леха-защита
Стабилитрон стоит 9V1,силовой транс Е70 15и5 а тр-р тока 200 витков или какой транс?!
oleg1ma
Cхем от Dantista много по какой именно делаете?Стабилитрон лучше поставить на 12вольт,и какое суммарное сопротивление R6?
леха-защита
Схема Spark-1600 на ТГР,а сопротивление 22 Ом.
oleg1ma
Меняй стабилитрон.И проверь что вышло.
леха-защита
Спасибо за совет, отпишусь что вышло.
sarmat
По Cпарк-1600. Проверь фазировки всех обмоток силового транса по осциллам. Если отключены все функции, то сервисная обмотка тоже не влияет на работу аппарата. Но лучше довести аппарат до нужного тока со всеми функциями. Надо убедиться в работоспособности всех четырех операционников 324. Особенно антистик, который может принимать нагрузку как К.З. Хотстарт на величину тока не влияет, только при зажигании дает толчок. Также надо позаботиться о помехозащищенности проводов датчиков температуры, при наводках на них, схема сбрасывает заданное значение тока. И главное проверь тщательно места всевозможных косяков на печатках. Собрано два аппарата по этой схеме. Прошел через все это.
golub
дык и стабилитрон можно наизнанку впаять, и потактовая будет шлёпать вокруг 30А
серж2105
Подскажите какие номиналы R и C нужны для к.зап. 0.44 ? частота 40 кгц.
Basill
Схема на чём собрана - UC3845 или UC3525 ?
серж2105
Собрана на UC3845 . Спасибо.
Иванн
Сделал вот такую конструкцию, еще не испытывал. Хочу взять вот такой ветродуй: http://www.e-voron.dp.ua/catalog/sunon-fan-dp200a2123xst Воздушный поток: 161,31 м3/час. Это не много для моей конструкции, может искать что-то по слабей?
Подскажите пожалуйста.
KLIM
Ветра много не бывает icon_smile.gif (кашу маслом не испортишь)
oleg1ma
Собираю spark1600 возник вопрос.Моя схема и печатка отличаются, на печатке которая нижняя стоят VD1,VD25,C24,R53 и светодиод а на схеме которая у меня их нет, да и схема включения релюшки не такая.Скиньте схемку у кого есть под мою печатку, или номиналы указанных деталей.Искал сам ненайду,старые файлы неоткрываются пропали наверное.
Gor
Посмотрите. Не было времени разбираться.Может поможет.
oleg1ma
[quote name='Gor' date='17.1.2011, 20:10' post='165881']
Спасибо большое, помогло.Но вопрос по релюшке остался.
HEMELL
А что за вопрос по релюшке? Релюшка должна быть на этой схеме с обмоткой на 24 вольта, контакты должны держать 30 ампер.
oleg1ma
Релюшка в моей схеме 12в .Я писал про различие на плате и схеме.Управление релюшкой на схеме одно на печати другое, потому и спрашивал у кого есть схема под мою печать.
HEMELL
Ну так Вам же в сообщ. 5830 выложили схему под вашу печатку.
серж2105
Что то я немного не пойму . Транзисторы для запуска 740-е ,ограничил на 20 ампер,кз 40 ампер,ТТ сфазирован, на клемах 100 вольт. Нагружаю на 10 ампер, напруга падает при максимальном задатчике на 20 ампер до 16 вольт. при минимальном до 5 вольт. icon_sad.gif В чём дело? Подкинул нагрузуку 20 ампер напруга при максимуме стала 5 вольт. ???
Gooz
'Иванн'
Попробуйте запустить пока без охлаждения. И обдувать надо не все только радиаторы , и конденсаторы электролитические .
Я всю управу отгородил от ветра,и включение навсю мощь поле прогрева 50% на фото мой уродец icon_smile.gif
Иванн
Спасибо. Пока что пробую без ветряка. Греется наиболее замыкающий диод, но так и должно быть.
Интересует вот такой вопрос. Осцила снята с блокировочной емкости, прямо на ключах (осцил включен на измерение переменки 5В/дел, 10мкс/дел). Питание через ЛАТР 110В, в нагрузке 80А, дальше – больше. Это опасно?
Иванн
Подскажите пожалуйста, может у кого то есть осцилы с этого места.
Это больной вопрос для меня. Так как, когда раньше делал первый вариант на отдельных платах с кучей проводов, у меня горели ключи в нижнем плече, и верхний замыкающий диод. Тогда тоже смотрел осцилом на блокировочной емкости (жаль не успел сфотать), и тогда было что-то похожее, только амплитуда в несколько раз больше. При этом сами блокировочные кондеры и последние (по схеме) электролиты сильно грелись
Теперь же у меня одноплат, вроде все аккуратно, кондеры не греются сильно. От не знаю можно дальше нагрузку увеличивать?
IPS
Иванн А суммарная емкость пленочных конденсаторов сколько? и какой марки стоят? чего то большие пульсации время на осциллографе поставь 2 мкс/дел чтоб посмотреть.
Gooz
Иванн Смотри осцилы К.-Э, на затворе, на ТТ.
Иванн
На затворе - почти прямоугольник, иголка где то 1-2В. На К-Э в конце присутствует размагничивание. Лысым проверял - загиба нет.
Вот сделал еще несколько осцилок на блокировочном кондере. 5В/кл, 2мкс/кл
Рис1. на ЛАТРе 140В, в нагрузке КЗ - 50А. 0,68мкФ блок. емк. (кондер МЕХ-Х2)
Рис2. на ЛАТРе 140В, в нагрузке КЗ - 50А. 0,68мкФ+0,68мкФ блок. емк. (кондер 2шт МЕХ-Х2)
Рис3. на ЛАТРе 140В, в нагрузке КЗ - 50А. 0,68мкФ+0,68мкФ+1,0мкФ блок. емк. (кондер 2шт МЕХ-Х2 + какой то зеленый китайский)
Рис4. на ЛАТРе 240В, в нагрузке КЗ - 105А. 0,68мкФ+0,68мкФ+1,0мкФ блок. емк. (кондер 2шт МЕХ-Х2 + какой то зеленый китайский)
КЗ делал не более 10с.
Что скажите по последней осциле, можно подниматься до 160А? Зеленый кондер заменю на один или два 0,68мкФ МЕХ-Х2.
HEMELL
Мне кацца, что в идеальную линию не выровняете, да и зачем?
Иванн
Да я, в принципе, к линии и не стремлюсь. Просто был горький опыт. Точно не помню, но вроде тогда амплитуда была в раза 5 больше.
HEMELL
Господа, не так давно, наверно месяца три назад, на этой ветке, а может на другой кот-то выкладывал ссылку по переделке двигателя от винчестера под вентилятор. Че-то я ищу и не могу найти, если кто-то встречал - ткните пожалуйста.
Basill
На ветке по резонанснику от 21.10.2010: ССЫЛКА
HEMELL
Basill , спасибо.
ostap
серж2105
Подскажыте какие элементы драйвера отвечают за затяжку спада импульса. Минимальное заполнение
С ТГР спад в норме, с драйвера такая лабода
golub
а при чёт тут заполнение, просто драйвер не работает. Не открывается или неисправен закрывающий ключ.
серж2105
Транзисторы целые, на обоих ключах одно и тоже,резисторы промерял, диоды тоже. Сижу смотрю, не могу не чего придумать icon_sad.gif
urdint
И постигло меня глубокое разочарование.... Заказал в Космодроме основные полупроводники, пришли не все позиции и не в полном количестве(вместо 4-х EBU150 выслали всего 1). Видимо все ходовое уже у них выгребли. Но самое обидное что "полтинники" прислали с буквой F, куда теперь их засунуть не знаю. наверное буду сползать вниз по частоте и мотать транс на простом железе.... (шутка). Так что лучше сначала брать в руки а потом платить.
Здесь слепых нет.
Д713
космодром уж примерно с год,как стал обычным "сексодромом"..
примите мои соболезнования..
потеря лица,как говорится,налицо..
тут вроде пока не зажрались-
http://www.radiomarket.lg.ua/index.php?cPa...p;filter_id=186
работают по Украине наложенным платежем,что довольно удобно,в разводе замечены не были.
Славик_ccc
доброе утро, с прошедшими праздниками подскажите, пожалуйста по схеме стоит стабилитрон КС 213 б, облазил весь радио рынок нашол только КС 213Ж можно его поставить или нет
серж2105
Нежелательно , на вид они маленькие ,стекляные но у них разброс стабилизации разбросан.У меня были такие ,стабилизировали около 18 вольт. лучше уже Д814 или 15-ти вольтовые
sarmat
[quote name='Славик_ccc' date='20.1.2011, 9:06' post='166245']
Ставьте импортные 15-16 вольт 1 вт. Можно по одному или две встречно. Когда эти схемы рисовали, импорт был особо не доступен или у разработчиков была задача сплавить куда-то запасы КС213б. Помню, у нас собирали магнитофоны кассетные "Тарнаир", где на выходе УНЧ упорно ставили ГТ403. Хотя элементная база позволяла перейти на кремний. Была задача разгрузить запасы ГТ403.
Славик_ccc
есть импортные стабилитроны на 13 вольт однонаправленные но выглядят они как КС 213Ж таки еже маленькие в стеклянном корпусе или все таки ставеть импортные 15-16 вольт 1 вт
Д713
хлопцы,я уже засыпаю в этой ветке,ставьте 15в импортные стекляшки и усё!
сколько можно трындеть ни о чем?
толян
Выкладываю картинки своего косого. Контроллер - FA5317 , или KA7552 , датчик тока - резистор, установка тока КЗ. отдельной цепью , транс - тор, время сброса по току К.З. - 0,6 - 0,8 сек, переход в спящий - около 10 сек, отдельные входа для регулировки скважности и рабочего тока - удобно для управления в режиме полуавтомата и аргона, габариты позволяют использовать как ремкомплект для Гусей, ИМС , Титанов маленьких и прочих итальянцев. Модификации от 100 ампер до 220 . конструкция не меняется - только количество деталек на силе и размеры радиаторов - конструктив позволяет это. Снабберов две цепи - одна на силовой плате - обычные RСD на плате транса - регенерат. Ток К.З. для обычного режима ММА 280-300 ампер , для аргона - ток рабочий плюс 10 процентов примерно.
