Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
DGEC
Цитата(Коля @ 15.6.2010, 17:09) *
Будь другом, найди время, нарисуй схемку пожалуйста что и куда цеплять. Интересует очень простой, но рабочий вариант, когда куда-то стабилитрон подключается, чтобы сместить порог отключения уськи ближе к 11 вольтам. По ссылкам пошёл- ничего не нашёл.
С возвращением из ссылки!!
Коля
Три года-то ( дня) не срок
А жизненый урок
( Бутырка)
Basill
См. фрагмент моей схемы. Номинал стабилитрона (3,9 V typ) связан с напряжением включения UC-ки (8,4 V typ), напряжением её выключения (7,6 V typ), напряжением питания управы и ТГР (15 V), передаточной характеристикой IRF540 при VGS=7 V (см. фрагмент даташита), минимально допустимой амплитудой импульсов на затворах силы (принимаем 11 V). Дальше - простейший многовариантный анализ, ну, и допуски +- на все величины, конечно, как в любом инженерном расчете.
Сразу скажу, что для напряжения питания управы 12 В стабилитрон на 3,9 В не пойдет (может не включиться микросхема при Uпит=12-3,9= 8,1В. Вообще, для решения данной задачи простейшим способом (стабилитроном) напряжение питания управы 12 В не есть оптимальный вариант. Надо пробовать другие схемы защиты от U пит мин, более навороченные и совершенные (советую попросить помощи у форумных гуру, схем тут выкладывалась масса).
Нажмите для просмотра прикрепленного файла Нажмите для просмотра прикрепленного файла
Ewgeniy_RZ6LYE
...как сместить порог отключения уськи ближе к 11 вольтам...
когда-то на форуме Кабельщик выкладывал свою схему для "короткого транса" Нажмите для просмотра прикрепленного файла , фрагмент схемы на VT7, VT8 отключает ШИМ при просадке питания ниже 11В...
sorry
На новой работе обнаружил осциллограф ОСУ-20 20мГц. Подойдет такой для настройки косого? Может кто таким пользовался.
KLIM
Граничная частота пойдет, а вот особенности этого образца увы не знаю.
Иванн
Как обычно полтиники уходят в мир иной, с музыкой или без?
Умер верхний ключ, и нижний замыкающий диод совсем тихо, и при этом предохранитель остался цел. Не подскажите как такое могло произойти. При этом варил двойкой при макс. задатчике, но ток был не большой, около 60А. Выпаял, на всех выводах КЗ.
sorry
KLIM Спасибо за ответ. У продавцов пригодятся такие параметры- "Характеристики модели:
Универсальный осциллограф
Полоса пропускания 0_20 МГц;
Один канал;
Высокая стабильность параметров калибровки;
ТВ синхронизация;
Развертка внешним сигналом (режим X-Y);
диапазон развертки - 5мВ-20 В/дел; 0,2 мкс-0,2 с/дел;
максимальное входное напряжение: 400В;
Новая технология в цепи возбуждения;
Исполнение: горизонтальное
ЭЛТ: диагональ 6дюймов, площадь - 8 х 10 делений;". Полное описание пока не скачал, может этих данных будет достаточно?
maxx
Всем привет. По поводу снижения напряжения-думаю отслеживать не имеет смысла, если дежурка импульсная, т.к. при испытаниях её грузят с запасом и видно насколько проседает(мелочи), а вот отслеживать дребезг и "ики" это надо. У меня это реализовано следующим образом- кондёры заряжаются определённое время по схемке с транзистором и конденсатором, далее с большей задержкой используется таймер как в схеме бармалея(только без релюшки) ну и с него соответственно разрешение на работу ШИМ. Т.е. в момент ика или дребезга, пока не зарядится конденсатор в цепи таймера ключи будут закрыты. Но это всё моё ИМХО icon_smile.gif
KLIM
Один канал;
Сгодится! Для сварочника хватит заглаза. Бери сразу с делителем 1/10 на 400-500 вольтов, пригодится!
maxx Ну все правильно написал. Только я уже год наверно об этом талдычу, слышат только единицы... Есть дополнение - отслеживать просадку нужно, подумайте о ближних соседях и монтерах электриках... допалите ведь проседающую проводку.
Полтинник не при делах... умер замыкающий диод и потянул за собой пробоем ключик. Диод то какой?
Иванн
HFA15TB60. А он почему? Сильно не грелся.
maxx
Я имел ввиду снижение напржения в управе, а насчёт просадки сетевого напряжения я только ЗА, но у меня этого в схеме нет. Можно при настройке БП сделать нужный диапазон, но это не хорошо и скорее не правильно, т.к. опять будут перезапуски. Лучше ввести какую-нибудь доп. защиту от этого.
KLIM
Сапрессоры стоят на нижних транзисторах? Как организован отвод тепла?
Иванн
Сапрессоров нету, все как в оригинале Бармалея icon_rolleyes.gif. На одном радиаторе стоит полтиник через термопасту и два диода через две прокладки из слюды (на всяк слючай, при этом сильно не грелся). Может из-за кривого монтажа проибило на радиатор?
Basill
Мне понравилась схемка контроля диапазона входного напряжения из Тельвина172, на базе сдвоенного компаратора. Прикольно, что здесь она оформлена в виде примочки к служебному БП и гальванически развязана от управы через оптрон. Думаю вставить её в свою следующую самоделку.
KLIM
Я темами чтото перепутался, про резер подумал. Пробить могло скорее всего только из-за кривого монтажа, скорее всего убило выбросом напряжения, ибо по току умирает громко а по напряжению тихо... кристалл не успевает вскипеть. Конденсатор демпфирующий висит на транзисторах по питанию 300вольт?
Ставь!!! Ибо варил недавно у тестя на поселке - сеть проседала так что лампочки притухали (слегка малиновые были) и вентилятор на 220 вольт SANON останавливался вообще. Если бы не продумал эти фокусы в аппарате - упалил бы 100% а так соседи жаловались и холодильник....
Иванн
2х1мкф, но возможно мало, так как греется последний сетевой кондер (не сильно, но заметно, по сравнении с первым. который стоит ближе к диодному мосту), а также провода от них до силы (длина не более 10см, сечение 2,5мм2, при этом они теплее чем провода до кондеров 1,5мм2)
sorry
Эти конденсаторы должны находится как можно ближе к ключам, по этой причине у многих горели транзисторы.
Иванн
Ближе уже некуда, почти на выводах ключей. (как у Бармалея)
bell
Из особенностей ОСУ20 - дерьмовая пайка, непредсказуемость работы после длительного прогона(4-5часов). Фокусировка - ГАВНО!!!
Кабели с делителями лучше сразу поменять на 60мГц-овые
Самый херовый вариант из китаезов. Такое ощущение, что делают его в китайском кружке - умелые ручки.
С1-125 - б.у. намного лучше.
allhimik
Иванн, проверь слюду под убитым ключём и диодом, может быть маленькая дырка возле резьбы и на радиаторе остаётся точка, у меня так же было из-за не раззенкованных отверстий, хотя после нарезания резьбы в радиаторах, отверстия шлифовал а затем полировал до блеска.
kyzmi4
Я бы не стал ставить под ключи слюду или номакон.Только напрямую с пастой и БЕЗ прокладок!!!
allhimik
Судя по эскизу, который выложил Иванн, без слюды под диодами не обойтись, а ключи можно напрямую на радиатор, я по такому же эскизу собирал.
kyzmi4
Вот только надо хорошенько изолировать корпус диода от радиатора,чтоб не пробило.Можно еще лаком все промазать для надежности.
Кто знает,бывает какая-нибудь более дешовая замена 150EBU02???
(Кроме кд2997).
А то диоды самые дорогие детали в сварочнике получаются.
spesso
Дешевле только даром.
Иванн
Ключи напрямую через термопасту, диоды через 2 прокладки из слюды (для подстраховки), ни дырки в слюде, ни точки на радиаторе не нашел (отверстия раззенкованные). Смотрите вложение (извеняюсь за качество - телефон). Как сильно греются диоды? Может для них поставить свой маленький радиатор и изолировать от большого?
KLIM
Да диоды то не сильно герюццо, ватта по 3 не более. Но ток пиковый у них амперов по 50-60, и на него нужно рассчитывать!
STASKIN
А делал кто бармалея в SMD? Есть рабочие печатки?,а то перелопатил (ну нескажу что все) много но ненашел. Может кто выкладывал?
kyzmi4
Иванн,может причина вылета транзюков это проволочные резюки(у них же индуктивность побольше,а это плохо).
Я бы посоветовал поставить баян МЛТ на 240ом Х 6штук.И будет все ОК!
electrovoz
Нет. Следует обратить внимание на зеленые конденсаторы, а тогда и выбросить их.
duck
задаю тот же вопрос если не знаем ответа так и скажите
решил на основе сварочника собрать пусковое для машины. при этом возник вопрос расчет конденсатора включенный последовательно с первичной обмоткой выходного трансформатора. проще говоря влючения в паралель несколько силовых трасфоматоров для схемы типа моста. к стати так выполнен сварочный и модефикации - arc 160. подскажите где можно найти теорию расчета, ведь иногда два маленьких транса проще намотать чем один большой.
DANTIST
[/quote]
Два маленьких транса намотать в два раза сложнее, чем один большой. Если речь идет о двух ETD59 и одном Е70.
vit336
Поляцкий "Бармалей"
кабельщик
Купил десяток IRG4BAC50W-S по 5,6грн. Кто уже пользовал - отзовитесь, как оно...
logic777
собрал бармалейника на 165а. уже потестил на 740-ых от латра- все гут.
начал делать блок диодов и транзюков и дроссель.
вот по последнему и вопрос.
решил делать на 4-х половинках сердечника от строчника мнс3000/ они самые крупные из советских строчников. собрал буквон "Н". влезает примерно 18 витков в два провода шинкой 2*6.
нормальный дроссель получится, или лучше искать другой сердечник?
fantom-2011
В СВОЕМ БАРМАЛЕЕ Я ПОСТАВИЛ ДРОССЕЛЬ ИЗ ДВУХ ПОЛОВИНОК МНС 3000 ОТ СТРОЧНИКА И НАМОТАЛ ТАКЖЕ 16-17 ВИТКОВ ШИНКОЙ 3*6 В ДВА ПРОВОДА - ОТЛИЧНО ВАРИТ 2-ОЙ И 3-ОЙ. И СОВСЕМ НЕ ГРЕЕТСЯ. fun.gif
logic777
из двух половинок или из двух комплектов?
и это разве не перебор по сечению?
как стабильность дуги? хватало индуктивности дросселя?
petr0757
]задаю тот же вопрос если не знаем ответа так и скажите[/quote]
Знаем, но конденсаторы к Бармалею никакого отношенния не имеют, спросите в другой ветке.
А Вы буковки не перепутали?
petr0757
Не перепутал, не тот человек. Дашитов нет, видимо новинка. Всего торгует одно фирма "Чип-Трейд", под заказ, цены нет.
DANTIST
А сам-то как думаешь, как может работать ключ за 0,7 $?
Den2
Даташит есть http://doc.chipfind.ru/irf/irg4bac50w.htm
кабельщик
Думаю, что вопрос цены не стоит рассмотрения ( Обращение продавца к инженерам ). Ибо многоэтажная машина торговли, накручивающая 500% наценки, вдруг может дать сбой - и вы имеете шанс купить почти по цене производителя . Нет, ну конечно, и мне тоже кажется подозрительно дешево для аналога полтинника, посему проверим соответствие основных параметров.
Я имел ввиду не вопрос - тянет иль не тянет, а какие у кого наработки по технологии монтажа подобных корпусов.
Даташитный IRG4BAC50W имеет корпус Super-220™(TO-273AA) . Те же , что я купил (IRG4BAC50W-S) - в корпусе SUPER SMD220 .
Т.е. нечто похожее на D2PAK ...
gyrator
Цитата(Wiew @ 19.6.2010, 14:30) *
странно что на офф. сайте IR про него ничего нет...
очередная матрешка?
кабельщик
и что это значит применительно к конкретной ситуации ?
grek
Цитата(gyrator @ 19.6.2010, 16:59) *
Это значит временный. То ли даташит, то ли транзистор.
Lemm
если перевести на понятный нам язык ,наверно должно означать "экспериментальный"
Коля
Ничерта вы не разбираетесь в буржуйском:
PRO- professional- профессиональный
VISIONAL- видимый
PROVISIONAL- с точки зрения профессионала icon_biggrin.gif Давно не флудил icon_biggrin.gif
fantom-2011
Я ЖЕ НАПИСАЛ ЧТО ДРОССЕЛЬ СДЕЛАЛ ИЗ ДВУХ ПОЛОВИНОК. НЕ ИЗ КОМПЛЕКТОВ. РАБОТАЕТ ОЧЕНЬ ХОРОШО. В БАРМАЛЕЕ В СОТКЕ ТАКОЙ ДРОССЕЛЬ. ЕСЛИ Я НЕ ОШИБАЮСЬ. drum.gif
OlegarX-RUS
кабельщик, а где вы их брали??? а то тоже бы прикупил попробывать
кабельщик
На тут Радиокомпоненты
