Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
кабельщик
alexyz, у себя выставляю порог на 15-20% ниже допустимого напряжения для конкретного случая (транс + частота). Т.е. если мой транс на выбранной мной частоте терпит 280вольт в нагретом виде (а при 300вольтах уже валится в насыщение), то ему выставляю порог около 230-240вольт.
Проверьте, где критическая точка вашего транса, немного ниже нее и настройтесь.
electrovoz
RUN1, там КТ3102, а стрелка не туда на схеме, даже не заметил. Если есть небольшая жесткость дуги, сложнее залепить электрод, так как увеличение тока при уменьшении вых. напряжения - это по существу аркфорс. Если слишком жесткая дуга - брызгает. Из книжек типа Закса и других подобных следует оплимальный наклон порядка 10-20% (который определяется отношением амплитуды пилы на токовом входе к порогу (1В)). И не брызгает, и варить удобнее. Это ИМХО.
golub
"книжек типа Закса", к сожалению не читал. Но тот же упомянутый супериор, пытался понять. И там почему-то, работают по среднему току ( да, понимаю, расточительство), но фичи аля хотстарт и аркфорс, регулируемые, вплоть до полного их отсутствия. Кстати, очень полезно при работе с жестянкой.
Ну типа такую точку на 0,6 мм оцинковки поставить. Очень хорошо просматривается работа аркфорса.
electrovoz
Это конечно правильно. А небольшая компенсация дает более легкую работу в ржавым железом, не особо ухудшая с жестью. На все случаи аппарат будет иметь кучу регуляторов, а это какое-то среднее решение для большинства случаев. Опять ИМХО.
golub
Стерео легуляторы ещё никто не отменил.
и я тоже.
RUN1
electrovoz большое спасибо!Сделал по второму варианту с 6-ой ногой дуга стала мягкой и без шумной просто кайф!
С уважением
electrovoz
Стараемся. Я не зря второй вариант ввел и подобрал номиналы.
alexyz
Спасибо, понял, сейчас перематываю Е70 15/5 . 18/ 6 без укорочения К зап. не проходит, а 21/7 не влезает в окно. Поступиться сечением не хочу. Буду претворять в жизнь!!!! Беспокоит наводка силы в верхнем драйвере. Буду искать виновника(корректировать разводку). Основа разводки COLT. Уже есть претензии.
golub
К кольту?
alexyz
Цитата(golub @ 20.4.2009, 21:41) *
К кольту?
К печатной плате COLTа , на основе которой я ваял свою. Автора не могу найти.
Цитата(gorbun75 @ 20.4.2009, 22:24) *
Поясните ,пожалуйста,как это " 18/ 6 без укорочения К зап. не проходит, а 21/7 не влезает в окно ", что-то насчет бузины и дядьки выходит .Т.е. 18/6 в окно влезает а Кзап. не проходит ?Какой Кзап.?
18/6 не проходит по насыщению феррита. 21/7-по площади окна. Кзап. =0.45
gorbun75
Должно проходить , многие так делают . Где- то у вас ошибка . Но в данном случае несчастье помогло шагнуть дальше вперед .Успехов .
Камелот , я на ICQ .
golub
Да у вас ПД1 должны быть по 120 рубасов, про ИКСУСЫ вообще не разговор. 50 кгц и нихт.
alexyz
E70 зазор 0.2 ,18/6- на Лысом загиб на 200 В, 30 КГц, Кзап. =0,45. Занимаюсь укорочением. Спасибо за ответы. Успехи будут. Буду делиться.
PC50U куплены 2 года назад. Руки дошли до применения только сейчас. Из чисто спортивного интереса. Купить готовый сварочник нет проблем.
gorbun75
Раз время есть собери калькулятор из "Радио " .Спокойно на питании 15 в проверишь свой транс .
Покрутишь и напругу и частоту .Может там у тебя ошибка . Или частоту подберешь .30 кгц маловато , конечно , хотя бы 38 (как в сотке) . Больше 50U не дадут .
Единственная польза от кризиса увеличение свободного времени , согласен .
alexyz
Так показательно испытать транс в реальной схеме -вылезают помехи от силы на выходах драйверов и т.д. и т.п. Кстати прорабатываю предложения по перезапуску реле времени после кратковременного пропадания сети. Отмакетирую-выложу для критики.
gorbun75
С помехами ,конечно , надо бороться не оставлять их на таком уровне , чтобы учитывать их в констр. транса . Конечно , раб.режим -окончательная проверка и транса и прочего , но если заранее проверить транс . меньше будет взрывов .Частоту ты не покрутишь на инверторе , а здесь есть возможность проверить мин. частоту для транса -это запас по надежности . Можно феном нагреть транс и посмотреть На форуме советуют накидывать 30 % на нагрев , а реально это гораздо меньше .
Подскажите плиз может кто мотал на Е80? Для 70 кГц скока витков? На Е70 мотал 11/4 гуд было.
Ewgeniy_RZ6LYE
это то что мелькало здесь на форуме ( в первых частях форума )
3хЕ80...........15 витков.............5 витков........25 кГц
2хЕ80...........18 витков.............6 витков........30 кГц
Цитата(golub @ 21.4.2009, 3:57) *
Удивляет однако, а почему до сихпор 4хЕ80 нихто не проверил?
Ведь, как утверждает уважаемый чукча, пострадавшие были.
что такое 4 шт Е80 по сравнению с 20шт Е42 от советских теликов... а ведь народ и на Е42 собирался монстра ваять с витками 3х1 виток icon_smile.gif
golub
uurraaaa
ребята подскажите сгорели выходные транзисторы PD1 и обратный диод 150EBU02 какая причина может быть
RUN1
electrovoz вчера еще первый ваш вариант с транзистором погонял скажу вам весьма весьма не плохо выходит! просто и сердито!
С уважением
САНЕК
Скорее всего перегрелись EBU,а затем потянули ключики.Было такое на самом первом аппарате.
RUN1
Да причин валом может быть! Одна самая простая сначало сгорел 150EBU02 а потом ключи хотя должен был уйти в защиту по теплу если есть она и вообще по предоставленной вами информации о вашей проблеме помогут только карты торо icon_smile.gifстарайтесь больше инфы выкладовать парни
Коля
Цитата(RUN1 @ 21.4.2009, 10:00) *
Не ФАКТ! Кроме карт торо ещё на кофейной гуще можно смотреть! Кабельщик может так!
Перемотал ТГР несколько раз и пришёл к выводу: всё буду мотать эмальпроводом, но с хорошей межслойной изоляцией. Что можно использовать в качестве тонкого, прочного, гибкого диэлектрика? Изолента думаю толстая, хотя в принципе может и покатит. Из доступного что можно использовать?
Gooddi
Можно ФУМкой изолировать, а можно каждый провод нитками обмотать виток к витку, а после намотки пролачить это дело. Требует старания и много времени, зато будет чем заняться пока в твой магазин транзисторы привезут.
САНЕК
Колян,забей ты на всякие ТГРы.Переходи на оптику и заканчивай с этой мотавнёй.А то к шаману придется идти,бубен брать на прокат.
RUN1
кабельщик
Коля, у меня кофейной гущи нет, поскоку потребляю обычный "Nescafe" (основную часть времени нахожусь на работе). Гуща есть у жены и тещи, им дома делать нечего, развлекаются зернами, кофемолками и турками... Могу попросить их погадать icon_biggrin.gif .
Коля
Фум- лента, это та, которой сантехники пользуются? ИМХО очень непрочная вещь, легко порвётся, да лак не впитает. А про нитки вы наверно пошутили. Так получится в четыре раза толще, чем компьютерным сетевым проводом мотать. А про лак я не забываю. И в этот раз я пропитал транс лаком, но один хрен пробило. Может я не опускал колечко, а просто лаком красил, поэтому плохо впиталось? Одно знаю- что силовой транс хорошо пропитал лаком даже без вакума. Просто в полулитровую( или какая самая маленькая? Из дачных, в которых маринуют) стеклянную банку налил лак, 1 см оставалось до верху. И потихонечку транс опускал. Наконец он полностью погружен в лак. Закрыл крышкой. И так на 2 сутки. Вытащил транс, оказалось, что полбанки лака в транс впиталось. И это при том, что лак был не сильно жидкий, хотя в этом вижу небольшой плюсик: когда вытаскивал транс, из него не капало, потому что лак там внутри густой был. Туда же в танку дроссель хотель впихнуть, да не получилось. Кисточкой пришлось. Ну на дроссель 1 см( по уровню в банке) лака ушло. Лак был обычный сосновый, но в следующий раз буду бакелитовым пропитывать. Он термостойкий.
Всё это написал, чтобы форум оживить icon_biggrin.gif А то скучно как-то стало.
Цитата(RUN1 @ 21.4.2009, 10:30) *
Эх всем бы так. А то пристали ко мне: принесли 2 электрокофемолки ( бош и скарлет) и говорят почини. Рзаобрал, а там движок- еле вал бедненький крутится, а они хотят, чтобы это всё ещё работало. Эх китайцы... А они пошли и ещё 2 штуки купили icon_biggrin.gif ( Честно, не вру!) И скоро у меня 4 штуки этого хлама будет icon_biggrin.gif . Шнуры сетевые только кусачками и в ящик к себе. А мусор на свалку.
Ага, как раз в шкафу фонарик стоит светодиодный, фотоприёмник ещё надо найти icon_biggrin.gif Из комповской мыши ещё можно сделать icon_biggrin.gif . А если серьёзно: сколько стоит оптика? Писалось не раз, что это дорогое
удоволльствие.
Что-то я выполнил весь план за этот год по флудированию. Уже молчу!
Gooddi
Цитата(RUN1 @ 21.4.2009, 12:30) *
Ну можно автоматизировать процесс, жену, тёщу привлечь.
КоЛя Фумка вполне крепкая, импортная в отличии от нашей вдоль практически не тянется. Мотнул ряд, макнул в лак, заизолировал.
А оптику ещё и питать отдельно надо, а ты пока даже штатный БП не запустил, так что делай выводы.
RUN1
Колян мож лак активный к эмали провода у тебя вот и замкнула а не пробило а сетевые провода гуд правда всеровно толстоваты в шашку 7х7 врядли влезет
Коля
Лак не активный к эмали. Этим лаком не первый раз пользуюсь. Транс питания на УМЗЧ на 100Вт до сих пор нормально работет. Больше года уже прошло.
У меня не шашка, а кольцо
Александр_М
Вот человек оптику поставил.
http://www.samopal.su
Gooddi
По кольцу тебе же советовали, 1 и 4 эмаль проводом. 2 и 3, сетевым и всё аккуратно влезет.
gorbun75
Не влазит даже и по 25 витков , позавчера попробовал .
Я лаком пользуюсь как все , а сам думаю нужен ли он . В силовом тр-ре да , там витки двигаются от тока и трутся , лак скрепляет их кроме всего прочего . А в ТГР витки не двигаются , лак врядли залезет в само место бокового контакта проводов -они плотно прижаты друг кдругу . Заводской лак дает 600 в пробивного напр-ия и так.Главное хорошая межслойная изоляция . Так ли уж дефицитна лакоткань (этот проверенный годами из.мат.), что нужно использовать подручные строительносантехнические материалы .Фумка конечно тоньше , но с злектрической точки зрения вызывает вопрос . Сверху покрыть лаком вместе со всей платой -это обязательно .
Ewgeniy_RZ6LYE
...что из доступного можно использовать в качестве тонкого, прочного, гибкого диэлектрика? ...
купил на рынке конденсатор К75-53, 1мкф х 5кВ, квадратная банка размером 7,5х6,0х12,0 см, "болгаркой" срезал шов сверху банки и извлек 2 брикета конденсаторов ( они внутри запараллелены), брикеты в ведро с теплой водой и СМС (марка стирального порошка), часа через 2 после того, как масло которым залит кондер, частично всплыло, размотал 1-й брикет в ленту. разделил ленту на слои ( она состоит из 4 слоев пленки оклеенных бумагой и 2 слоев фольги) смотал пленку на кусок текстолита. прополоскал пленку еще раз в СМС а затем в чистой теплой воде и окончательно смотал пленку на текстолит.
на выходе имеем: 8 лент пленки толщиной 0,01 мм, длина 1 ленты ~ 10 метров, ширина 10см. стоимость кондера на рынке 70 рублей.
о таком способе добычи пленки узнал где-то из инета... но сама пленка очень удобная, не рвется, тонкая, и пару на киловольт на пробой держит держит icon_smile.gif
yjriy
Да накрути ты его (ТГР) НА Ш7*7 проводом ПЕЛШО И НЕ ПАРЬ НАРОДУ МОЗГИ, типа пробило -не пробило. Пропитать и просушить конкретно, а то пока от тебя дуги дождешся- от старости ослепнешь и ни хрена не увидишь твоей росписи ляктродом по мэталлу ( хорош выпендриваться и доделывай аппарат по нормальному)
Коля
Дык дугу-то я давно получил! Правда на минимальном токе на транзюках ирф 740. Для себя уже решил, что мотать буду эмальпроводом и в лак на 2 сутки. За ответы спасибо. Кстати кондёр на 1 мкф 5 кВ есть. Он такого серого цвета. Фум лентой сделаю межобмоточную изоляцию. Этой ленты у нас дохрена. Ещё раз спасибо!
RUN1
Не колян эт не дуга эт породия вот когда хотяб спалиш десяток электродов один за одним на максимальном токе (в твоем варианте 100А) и аппарат уйдет в защиту по теплу и через пару минут будет опять готов к очередному десятку вот тогда эта ДУГА!
Коля
Да будет ПОБЕДА!!! Скоро. Недолго осталось, потерпите немножко! Я как раз спалил ( вернее высрал) 10 электродов на минимальном токе. Осталось поставить регулятор на максимум и также спалить 10 электродов на тех же ирф 740 icon_biggrin.gif Кстати,тогда транзюки не сильно нагревались, и всё это было без обдува и при температуре окружающей среды 20-25 гр. Выходит IRG4PC50U вообще несильно будут греться, тем более при постоянно включенном вентиляторе. ХФА вообще не грелись, зачем их тогда на радиаторы ставят? Какую дату следующих испытаний назначить? Или вы сами скажете когда? icon_smile.gif Вот думаю, германиевые диоды как установить лучше: в кембрик с термопастой и в радиатор с термопастой, или всё-таки прижать? Пожалуй я в радиатор лучше засуну для лучшей точности. С диодным мостом то же самое. Ладно до скорых встреч!
Valter
Вопрос к гуру по блокам питания на ТОРах, прикупил RM10 (диам керна 10,7 мм) и RM12
(12,5 мм) без зазоров, сколько витков мотать на том и другом, есть готовые импусники, которые
раньше использовал но в данном случае не устраивает ихний конструктив, делаю третий аппарат
уже для себя на оптике и PD1, вопрс к знающим как лучше запитать оптику - DC\DC или от ТОРки.
Для тех кто не хочет париться с пересчётом заполнения рекомендую такой приборчик, выдаёт в процентах, частота, ёмкость всё меряет гуд, если бы ещё и L мерял цены ему бы не было
(цена в пределах 10 баксов)
HEMELL
Коля, сверли лунку в радиаторе, заполняй пастой и за подлицо в пасту, на уровень с алюминием вставляеш диод, припаянный к платке, платка крепиться к радиатору.
Genadiy
Посмотри инвертор Лисова,там то что ты ищешь.Как раз на РМ10,на ТОРе и питание для оптики.Только пересчитай обмотки для 18В.Там заниженные данные.Отталкивайся от 12-14В источника,на нем данные правильные.
Valter
Спасибо Гена, совсем забыл забыл за эту схему, счас найду посмотрю. (спасибо за разьёмчики)
Gooddi
Платка от Д713. То что получилось у меня. Не так красиво как у Евгения. Практически всея комплектуха БУшная. Транс Е20. На мой взгляд очень удачная разработка Евгения. Достаточно компактная (можно даже ещё поджать).
Может бредовая идея, но планирую вставлять в слот ISA. (не попутал бы кто, втавляется не в компьютер, а в плату с силой icon_smile.gif).
Basill
Подтверждаю. Я уже лет 5 пользуюсь вот таким приборчиком (рассказывал о нём здесь неоднократно).
Для L собрал простейший генератор-приставку на микросхеме LM311 (K554CA3), о которой тоже рассказывал не раз (см. самую первую схему из здешнего "Файлового архива форумов").
Кзап тоже меряет точно, проверял по кварцованному заводскому частотомеру в режиме измерения как длительности импульсов, так и периода. Во всяком случае, результат получается точнее и намного быстрее, чем по лучевому осциллографу с его отсчетами по клеточкам, правда импульсы должны быть прямоугольными...
Нажмите для просмотра прикрепленного файла Нажмите для просмотра прикрепленного файла
Д713
оперативно..
желтенькие китайские кондеры во времязадающих цепях не есть гуд,подуйте на них феном (можно у жены незаметно взять напрокат) и посмотрите на изменение частоты,будете неприятно удивлены.
Gooddi
Цитата(Д713 @ 21.4.2009, 20:19) *
оперативно..
Про не стабильность ТКЕ у китайцев в курсе, просто под рукой не оказалось нужных наминалов, а включить не терпелось icon_smile.gif. Обязательно заменю.
Гость_Илья_*
Мужики увеличил емкость на 4 четвертой ноге UC до 6300пик вместо стандартных 3300 так для проверки, плин при подачи силы через латр появляется неприятный свист, дальше емкость уменьшил до 4000 все равно пищит хотя осцил кажет 37кГц пробовал подгонять резистор как на диаграммах которые были тут выложены(все сопротивления делал согласно емкости на диаграммах) свист все равно есть. Вернул на стандартное? на дровах посчитал каф зап 0.45
но при подачи силы +300 что-то творится странное иль я ошибаюсь? на обоих одинаково.
http://s60.radikal.ru/i167/0904/95/68c673689de7.jpg
И при подачи силы+300 на ключах скачет ширина импульса. Почему так происходит и на что надо обратить внимание? Должно ли так быть?
http://s50.radikal.ru/i130/0904/ca/e37ff85eb6cd.jpg
очень прошу помочь!
lds84
Собрался мотать дросель вот на таком железе
1) Правильно я понимаю что мотать надо на одной стороне этой буквы О ?
2) Для частоты 27-28 кгц хватит половины этого железа ? или всеже оставить так ?
3) Сколько нужно примерно мотнуть витков на такую железяку ?
