Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
nikon
Цитата(KT117 @ 5.6.2013, 19:39) *
Можно шагать дальше. На будущее, хорошим тоном будет если станете указывать размерность делений, гляньте в ветке http://www.electrik.org/forum/index.php?sh...c=35361&hl= пост №11 как DANTIST оформлял свои осцилки-образец для подражания.
Не нужно быть экстрасенсом что бы понять что питание управы порядка 14 вольт, а ослик выставлен на 5 вольт на деление и 5 мкс на деление, или я не прав Magnitogorsk? Можете смело шагать дальше, все у вас в норме.
Magnitogorsk
NIKON все верно вы сказали 5 вольт деление 5 мкс деление управа питается 14.4 вольта. насчитал я так,заполнение 0.428 почти 0.43 частота 33.6 почти 34 .
KT117
icon_biggrin.gif посмотрим на Ваши экстрасенсорные способности, когда Magnitogorsk начнет выкладывать осцилки с ключей и транса без пояснений. Проходили это и не один раз. Так что лучше сразу привыкнуть давать информацию подробно и правильно.
Павел(Sp)
Здрасте всем.
ух, аж страшно..
не бейте если чего не так...
раздел N1(пояснения)
На первой фотке сигналы снятые после ТГР на входе драйверов.
На второй фотке сигналы на выходе драйверов ,без ключей.Или надо чего нибудь припаять чтоб видеть более реально.
полярность сигнала если я правильно понял правильная, надо уменьшить К.Зап.
или вообще все неправильно, что то я никак в толк все эти премудрости не возьму,на выходе драйверов получается инвертированый сигнал относительно того что есть на выходе TL3845 ?
Раздел N2(фотки)
осцылки удаляю, как неправильные
KT117
Павел(Sp), почитайте Нажмите для просмотра прикрепленного файла , там подробно описано про управу.
Сигнал на выходе с драйверов должен быть такой же как и на 6 ноге UC3845. Проверьте фазировку ТГР, или проверьте подключение щупов осцила.
Павел(Sp)
Видел я уже этот док.
Но все равно, огромное спасибо ибо навел он меня на мысль, хоть и не на ту...
Так оно и есть,неправильно подключена первичка ТГР.
Завтра перепаяю.а то смотрю к.зап наоборот получается..
Ну как гритца на ошибках..
Serega30
Здарова всем. Народ, очень нужна помощь профи. У мен9 така9 просьба: скажыте че нибудь толкового о даной схеме, рабочая ли она, и что в ней можно улутшыть elwo.ru/teoria/inver.jpg Интересует именно применение ир2110 в косом и схема включения ир для косоглазого). Заранее благодарен!
Jorg63
в косом для будстрепной части драйвера 2110 желательно отдельное питание. Ноги 5-6 драйвера. работают отлично в косом 2110 если лень ТГР мотать
oleg1ma
Цитата(Serega30 @ 6.6.2013, 22:33) *
понял. а как насчет схемы?...
oleg1ma
В смысле схему.Если ищеш простенькую схемулю, рабочую, то посмотри тут
Павел(Sp)
вот, перепаял.
На 1-й фотке на входе драйверов на второй на выходе.
Шо скажут гуру.
Про цену деления и все такое ,думаю понятно.
KT117
Все нормально, можно двигаться дальше.
Павел(Sp)
Мда, проще этой только гвозди и молоток...
Павел(Sp)
Народ, а к.зап 40% маловато будет? а то впаял конденсаторы в плату и совсем не то уже что было на осцылках,, в смысле к.зап уменьшился..
oleg1ma
Где смотриш?Cмотри на 6 ноге.
nikon
Цитата(Serega30 @ 6.6.2013, 23:43) *
Может кто-нить знает от чего коротит 3 ножки у ИГБТ.
В моей личной практике силовой транс не успевал размагнитится, на ХХ работает, при подаче малейшей нагрузки ключи тихо ушли в мир иной, все выводы закорочены.
Wasiliy61
Цитата(Serega30 @ 7.6.2013, 13:16) *
ну к примеру что нужно подбирать в ЗГ или в силовой части чтобы исключить такие душотрепающие моменты что приводят к вылету силовых ИГБТ
Нужно побирать зозор в силовом трансе, если витки правильно высчитаны.
Wasiliy61
Цитата(Serega30 @ 7.6.2013, 14:39) *
20 витков на 6-ти твс-110 зазор 0,3
А какая частота.
Павел(Sp)
Вообще то на выходе с драйверов,но к.зап теоретически не должен меняться,или подъем и спад импульса играют роль в этом, потому что осцилки снимал с одним длючем впаяным в нижний драйвер,какойто 9 амперный попался под руку ну я его и впаял чтов какое нибудь различие увидеть, но так ничего и не увидел..
Вечером посмотрю на 6 ноге..
KT117
Цитата(Wasiliy61 @ 7.6.2013, 11:45) *
А какая частота.
http://elwo.ru/teoria/inver.jpg на схемке все указано. Serega30 интересует работа именно 2110.
Wasiliy61
Мне попадалась эта схема но я не рискнул её делать, что-то всё упрощенно, и отзывы не понятные, толи кто собирал, толи так просто слепили схему , но не пробовали. Хотя вроди должна работать, но надо-бы добавить RCD цепочку.
Wasiliy61
Цитата(Serega30 @ 7.6.2013, 17:18) *
Благодарен всем за ответы. что касается ТРАНСА частота где-то 36 кгц
Нажмите для просмотра прикрепленного файла Воспользуйся вот этой программой для подсчёта витков, поставь свою частоту, Кзап и площадь сердечника, и узнаешь витки. Попробуй силу подать через лампочку, лампочка не должна гореть без нагрузки.
ingener99
Цитата(Serega30 @ 7.6.2013, 15:11) *
транзюки пробивает при кратковременном кз выхода. Но! Пробовал без вых дроселя.
Кто ж так пробует. Даже при частоте 90кГц не рискнул замыкать выход аппарата напрямую (только на концах проводов по 3м).
А для проверки через лампу рекомендуется отсоединить электролиты и вместо них малый кондерчик 5-10 мкФ - даже при нештатном режиме ключи должны выдержать разряд
KT117
Цитата(Serega30 @ 7.6.2013, 14:11) *
а по поводу ИРКИ какие затворные резисторы ставить или не ставить их воще для irg4pc50w ?
...можно на ты) я не такой уж старый...22 скоро стукнет. Об схеме транзюки пробивает при кратковременном кз выхода. Но! Пробовал без вых дроселя. Делал оригин Бармалейник(там 2 сразу вылетали) а в схеме с ир2110 пробило нижний транзюк. В чем может быть проблема? Большой ток кз или чтото ещо? Пробовал через лампу результат тот же.
Если собирал по той схеме- то у тебя заполнение 0,48 будет, это многовато, транзистор обязательно пробьет. Уменьши заполнение до 0,42-0,43. БП трансформаторный проверь, что бы держал напругу при просадке сети И если есть осцилограф-сними осцилки с ШИМа, на затворах ключей и на К-Э ключей и на обратном диоде (до дросселя) Тогда и можно будет что то посоветовать, а так просто разговоры будут.
icon_smile.gif током не шибает, когда крутилку вертишь? А то как никак -300В приложено к обвязке УСки
KT117
Цитата(Serega30 @ 7.6.2013, 14:56) *
Извиняюсь че так тупо выкладываю свои сообщения, просто с телефона сижу. Вопрос так-сказать может быть и тупой но все же как уменьшыть заполнение можно в схеме с иркой? Спасибо.
Заполнение меняется конденсатором на 4 ноге УСки, почитай доку из поста 16869 http://www.electrik.org/forum/index.php?sh...st&p=290959 , там по диаграммам подбираешь конденсатор и резистор для нужной частоты и заполнения. И посмотри внимательно схему бармалея-к твоей можно многое оттуда применить.
KT117
Тогда уж и датчик тока сделай как в бармалее, на кольце-и гальванически развяжешь ШИМ от силовой.
soud
Serega30 вы бы для начала собрали голого бармалея для начала а потом уже эксперементировали
VOVA 555
icon_biggrin.gif Да теперь я начинаю понимать и сочуствовть бывалым форумчан, которые здесь помогают новичкам .Сам етот форум почитую больше года и меня тоже начинает воротить . Одни и теже вопроы по тысячному кругу пежовуются. Них_________ а нивички нехотят читать .
Serega30 ищите на етом форуме провереные схемы и печати и небудете разорять свой симейный бюджет. В етой ветке полно их начните хотябы 500 страницы .Тот же Липин от Олегмы или ММА на атмеге из соседней ветки .Многа форумчан повторили и остались довольны.
VOVA 555
Serega30 http://www.electrik.org/forum/index.php?sh...mp;#entry205150 http://www.electrik.org/forum/index.php?showtopic=25898 http://www.electrik.org/forum/index.php?sh...292&st=3940 http://www.electrik.org/forum/index.php?sh...mp;#entry214148 http://www.electrik.org/forum/index.php?sh...7034&st=140 http://www.electrik.org/forum/index.php?sh...0108&st=160 http://www.electrik.org/forum/index.php?sh...mp;#entry234187 http://www.electrik.org/forum/index.php?showtopic=34629 http://www.electrik.org/forum/index.php?showtopic=13644 http://www.electrik.org/forum/index.php?sh...mp;#entry272587 http://www.electrik.org/forum/index.php?sh...mp;#entry272587 Вот побродите по етим сылкам там многа полезной инфы.А с етой схемой намучаетесь . Удачи вам .
Serega30 Сифония Баха у вас может поисходить по разным причинам . Ту нюансвов валом. Невидя ни осцылограм подписаных (что откуда снималось) ни пичатей ни фото бевайса вы так до старости будете ковырять ету схему и не факт что запустите. Удачи.
oleg1ma
Цитата(Serega30 @ 7.6.2013, 21:40) *
...может у каво есть опыт применения ИР в похожых схемах токо делится нехочет...) ?
Конечно есть опыт и немалый, люди поделились с вами, почитайте и все найдете, но видимо лень, но не лень написать за сутки более 20 сообщений. icon_biggrin.gif Вот мне надо давайте, icon_biggrin.gif icon_biggrin.gif
Wasiliy61
Цитата(Serega30 @ 8.6.2013, 1:46) *
Схема у меня работала до момента кз выхода на 3 ра3. И пробило нижний транзюк. Кроме него все целое. Даже ИР !
Возможно у вас коротнул транс.
Jorg63
Цитата(Serega30 @ 7.6.2013, 23:14) *
Я канечно извиняюсь кого уже достал но в споре рождается истина ... Это факт.
Повторюсь ... Я сижу с телефона и на комп перейти ща нет никакой возможности. Пересмотреть информацыю всю просто нереально на даный момент. Вот и пытаюсь выяснить хоть что-то.
я вам отправил по ИРКАМ сообщение в личку.
Serega30
Первичка транса несколько жыл в лаковой изоляции+сверху автоизолентой все обмотано
VOVA 555
Serega30 http://www.ex.ua/view/61733312 http://www.ex.ua/view/61724332 Вот почитайте ети архивы (качать многа но инфы валом)
P S Без етого осцылограм подписаных (что откуда снималось) ни печатей ни фото девайса вам нихто не поможет.А вопще вам решать по какой тропе идти.
Wasiliy61
Да эта изоляция ерунда, нужно заливать поксидкой или лаком. Я почему так подумал, ты же говориш что схема работала, и сейчас у тебя в схеме все детали целые.
tranzistor3102
Цитата(Serega30 @ 7.6.2013, 19:56) *
РАНЕЕ Я ПИСАЛ что бармалея собрал, вот токо с тгр не понравилось... Гемора много, идеальных импульсов очень трудно достичь.
незнаю какие у вас были импульсы у меня уже 3 бармалей не какого гемороя небыло и импульсы были в норме icon_biggrin.gif
aog1996
Уверен, что ИРка целая? Она ведь в нештатном режиме работает - без токоограничивающих резисторов.
владимирон
похоже смертник апаарат делает а вы ему помагаете на тот свет уйти раз такое отношение к гальванической развязке
Цитата(Serega30 @ 7.6.2013, 16:24) *
да дело не в развязке... Вот что быстрее срабатывать будет... Я думаю резистор для даной схемы все-же лутше будет. А чтоб развязать по питанию-то неполучится ... в зад ген и у ирки должен быть один общий провод который ещо и идет на нижний ключ -300в. Эсли я не прав-поправьте.
...в зад ген... -это кто не понял- ...В задающем генераторе...
собери на оптике 3120 и будет тебе счастье и мотать не надо тгр только в блоке питания добавить 2 обмотки на20в они точно импульс не искажают что ты и хотел
tranzistor3102
[quote name='Serega30' date='8.6.2013, 19:08' post='291359']
Да не смертник я... Просто экстримал) токо с тгр не понравилось...
[/quo
Странный человек сначала пишет *(токо с тгр не понравилось... Гемора много, идеальных импульсов очень трудно достичь.)и написал сейчас( С оптикой дело не имел воще. Как то на нее не прет.)а на чем вы собрались собирать? намотай обычный трасформатор 50гц там вообше некаких импульсов смотреть не надо icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif
Wasiliy61
Нажмите для просмотра прикрепленного файлаНа стабилитроне. 5мкс. 5в/дел. Ребята, что вы всё оптика-оптика, на ТГР картинки тоже ничего бывают. Сейчас снял осцилку с выхода драйверов, с того что сейчас в проекте.
Павел(Sp)
Добрый вечер всем.
Усиленно медитирую над трансом,поскреб по сусекам и кроме колобка ничего не наскреб..
6 строчников от буржуйских телеков диаметр круглого керна 15мм другая сторона 12х15мм получается около 1000мм может чуток меньше из-за вырезов под скобы.Я конечно паровозные рельсы резать не собираюсь... Если кто навскидку покажет где транс посчитать можно буду очень и очень/
Недавно где то проскакивало,поищу сам,конечно, но если кто даст пинка в нужном направлении окажет большую услугу.
А то есть около 6м провода 2мм диам(2 куска по 3м, добыл из транса от бесперебойника) и несколько петель размагничивания.
медная полоса что обещали обросла волосами по причине скотства супершефа человечка который обещался добыть, так что бармалей всетаки будет франкенштайном..
Вот вопрос технический.. как лучше строчники ставить,круглым внутрь или наружу,внутрь охлаждение лучшей будет а наружу мне каатца убодней обмотку сделать,шоб как у людей было,на деревяшке,потом пропитать и на транс надеть
Павел(Sp)
Цитата(slavyann @ 8.6.2013, 21:48) *
мда, класно все это только я ничего не понял..
придется как Dantist сказал... емпирическим путем..прибором геморова-взуева...
Короче первичка :начнем взрывные работы с 21 витка..по какому критерию выбрать толшчыну провода для первички,
Вообще не то что запутался а вообще заблудился,
по ентим калькуляторам нужно начальную проницаемость, если б ферриты умели говорить, они б мне сегодня все рассказали.
А где найти какой нибудь мю-вычислитель?
TSL2
Буквально пару страниц назад. Сообщение 16894. Что вам мешает по этой формуле определить хотя бы примерно кол-во витков. Почему никто ничего читать нехочет?..... Далее в помощь вам калькулятор Лысого. По нему уже точно узнаете ток намагничивания своего транса, и границу насыщения сердечника.
Павел(Sp)
Не,оно конечно не совсем так..у меня на чтение приходится чуть меньше чем на сон,вернее на поиски где его почитать..
Кстати через сылку эту етой ночью раз 5 наверно переступил и не видел,хоть ее тоже искал.
Ну в принципе направление уловил.
Вот опрос тоже,тут с трансформаторами трува дело,особенно с латрами.
Можно ли вместо латра использовать регулятор напряжения для паяльника
с фазовой регулировкой.
Вставить симистор на 25а или около этого у меня есть.Я пробовал пускать от такого регулятора енергосбрегайку вроде ничего,теоретицки должно срботать.
Изменяя длину выходного импльса и пропустив его через выпрямитель на конденсаторах получим заряд изменяющийся в зависимости от положения движка регулятора ,т.е. можем выставить напругу больше или меньше.
Реально такое?Пробовал кто нибудь?
Шоб не городить этот огород зря,если древо сия плод не принесет пригодный.
А если идея сия удобоварима,то можно будет отказаться от бомбоподобного латра ввиду невозможности иметь его ,как в моем случае или по крайней мере не таскать его из кладовки на кухню,как,думаю,приходится делать многим,и заменить его небольшой коробочкой.
slavyann
Jorg63
Павел(Sp)
не занимайтесь ерундой и не изобретайте велосипед. на этапе запуска используйте лампу ват 60 в разрыв сетевого провода,она как ограничитель заряда литов будет и при неcштатной ситуации ограничит ток по силе,просигнализирует своим горением. Если все ОК то лампочка вспыхнет на время заряда литов а потом практически должна погаснуть. На литах напряжение установиться около 270 вольт,уже можно иметь более менее реальную картину измерив импульс на участке К-Э ключей. Если нормально все то лампочку можно закоротить и просмотреть сигналы на полной силе. литы на силе емкость бы я уменьшил на этапе отладки до 100 микрофарад и поставил предохранитель в разрыв +/- 300 вольт после литов до ключей на 2-3 ампера.Включив последовательно с предохранителем пару ом безиндукционный резистор(типа МЛТ) можно просмотреть пилообразный сигнал,по которому станет ясно с количеством витков первички. если линейность пилы будет нарушена имется загиб на вершине,то это признак насыщения и витков мало первички.Замер проводить при полной силе. При 270 вольтах может быть и нормально с сигналом.
KT117
Павел, читайте не только эту ветку, в других то же есть информация.
http://www.electrik.org/forum/index.php?showtopic=12292
http://www.electrik.org/forum/index.php?showtopic=29492
И скачайте архив от VOVA 555 , http://www.electrik.org/forum/index.php?sh...st&p=291430 , много-много полезной информации. icon_smile.gif
tranzistor3102
зачем так сильно городить огород.я поступаю намного проше нашел трансформатор от лампового телевизора тс-270 перемотал вторичку вольт 60.запускаю аппарат от данного источника смотрю осцилограммы и проверяю нагрев радиоэлементов(бывает разное) гоняю с час под небольшой нагрузкой.если все в норме подключаю уже к 220 через лампу 100W а дальше по ходу дела icon_biggrin.gif
TSL2
Цитата(Jorg63 @ 9.6.2013, 11:06) *
Павел(Sp)
Настраиваю тоже именно так. Только временную ёмкость ставлю 47мкф. Пилообразный сигнал смотрю на резисторе 1ом включенного в разрыв первички силового транса. Переключатель ослика на делении 1вольт, ток получается 1ампер на клетку.
Подскажите, кто юзал MUR860G в качестве размагничивающих диодов. Как они в работе? А то HFA закончились.
