Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
gorbun75
Цитата(Genadiy @ 14.7.2009, 9:25) *
Коля на релюшках на 30 кГц?????Да она на 50гц затыкается.Не все таки ты ВЕЛИКИЙ специалист,за тобой не угнатся icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif
На 30 не пойдет , твердотельная кгц на 10 потянет , если снаббер помощнее поставить icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif
Коля
Вечером фотки покажу- и вы в магазин за ЕВРО коплектухой нового сварочника на реле потянетесь!!! icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif
Genadiy
Коля!Лучше схемку срисуй,только реле с модулями не перепутай,похожи здорово. icon_biggrin.gif
4333
Коля , у меня есть РЭС22 много, подойдут? Я тоже сторонник сварочника на релюшках. А ещё есть МП25. Может их тоже можно между релюшками затолкать? Коля, а вазелином ты пользуешься? У меня тоже есть!
Д713
Вставлю свои пять копеек в инверторостроениею..
Коля,Вы хоть приучитесь самостоятельно мусор за собой убирать,потом уже копейки в инверторостроение вставлять..
sorry
Еще один вопрос к специалистам. Кто использовал схему elektrovoz а. Вопрос о дежурке. Была у меня плата для дежурки на UC3843 таких мс неру вот и поставил то что было UC3844. Заработала правда с какойто задержкой на выходе 15в. Подумал что напряжение питания разное и вместо трансформатора на ЕЕ19 поставил за ранее намотанный транс по данным elektrovoz а. Тоже заработал сразу но напряжение дергается без нагрузки а при подключении нагрузки в виде сопротивлений 60 ом напряжение падает до 0. Решил что фазировка не правильная на служебной обмотке. Поменял начало и конец. Опять работает. Подключаю сопротивление опять напряжение падает до 0. При отключении сопротивления пытается запустится и сразу запахло горелыми резисторами. Сгорел один о UC3844 на затвор транзистора и один на датчик тока. Вывод 6 ой отгорел. Транзистор по тэстеру не звонится. Транзистор 2SC2828 довольно мощный для такого б.п может и целый остался? Вопрос что не так сделал может зазор подобрать чтоб нагрузку держал?
Alex72
Цитата(igorka @ 13.7.2009, 22:32) *
igorka110@rаmbler.ru заранее благодарю!
Ошибка
Недопустимый адрес
Адрес igorka110@rаmbler.ru не существует или заблокирован. Письмо не было послано. Исправьте ошибку и отправьте письмо еще раз.
Вот так ...
исправляй ошибку
толян
Ещё несколько плат , правда в СПРИНТЕ 3.0
Wiew
3843 предназначена для обратноходовых преобразователей, а 3844- для прямоходовых (мои умозаключения)
плюс у них разные напряжения старта, так что не химичте ищите нужную микру, посмотрите в нете описание на них, его там полно.
однако можете забить на мою писанину и использовать 3844-45 о чем подразумевает Д713.
Д713
3843 предназначена для обратноходовых преобразователей, а 3844- для прямоходовых..
это игде прописано?
если это Ваши умозаключения,то так и пишите-мне так кажется..
Andrey_G
Цитата(sorry @ 14.7.2009, 18:10) *
Еще один вопрос...
Действительно, в самом деле без разницы какую UC-ку втыкать, работать должно в любом случае, другое дело что в обратноходе желателен запас по прямому ходу, а в 44,45 он ограничен на ~48%. Зазором же играть не нужно, а просто выставить требуюмую индуктивность первички, какая она кстати? и к тому же есть основания пологать что попутаны концы на вторичке (ну или на первичке относительно вторички). Сфазируйте правильно транс, выставьте индуктивность первички и только после тренеруйтесь...
sorry
Индуктивность старался сделать около 1000 мГн вышло около 1200- 1300. Точно не помню надо померить. Сколько должно быть по вашему? Еще сгорел диод на вторичной стороне SF306. По току не должен может по напряжению не выдержал?
RUN1
Действительно старался icon_smile.gif Может индуктивность 1000мкгн эт норма
Не мучся тут camelot не раз схемку дежурки выкладывал заводится с пол пня я ее собирал на E19 и UC3845 все ок 2ампера легко держит 14,7V заводится от 100v перед тем как ставить эту дежурку 2дня над ней издивался (так сказать UC-ka+полевик проверка на прочность)все ОК.
Парни не подскажите КЗАП 0,42 не маловат с лега дуга пульсирует все-таки пауза большевата наверно?
С уважением.
sorry
Чтото не припомню на 3845. Видел на 43 и 42. Если можно подскажите где искать примерно? Я и управление хочу на 3844 сделать как у elektrovoz а . Там питание управы 21.5в . Так что буду плату переделывать.
RUN1
Правильно она на UC3842 но она у меня запускалась только от 170v по этому пришлось поставить UC3845 меня устраивает 45-ая все работает каратковременное кз на выходи дежурка держит полевик 3n60. вчера уже сдвоенного фиксера(в смысле баян из 2 ключей) с этой дежуркой гонял все нормально.Вот схемкаНажмите для просмотра прикрепленного файла транс Е19 1\120\запуск12\выходная10 + добавил блок конденсатор на оптрон ну не без этого пришлось малеха понастраивать но это касаемо меня у вас может будет работать в арегенале в арегенале транс если E19 то 1\120-пуск15выход15 зазор по среднему керну.
golub
С минуса на анод стабилитрона резючёк ом так на 330 не помешал бы.
RUN1
Ув.golub а можно по подробней что он даст и про КЗАП 0.42 не подскажите не маловат будет?
С уважением
golub
Начальный ток стабилитрона он обеспечивает. Делайте 0,44, но думается что причина пульсации глыбше, там по сараю и при 0,1 варить обязан. Другое дело, как?
RUN1
Так в том то и дело как дуга как будто поттухает дроселя пробовал разные .Спасибо ув. golub за ответы на счет дуги и кзапа сегодня еще поэкспереминтирую .
С уважением
golub
С фазировкой всё нормально?
Вобще-то 3842 обязана пускаться при 115 вольтах, согласно шииту. Щас проверю.
Как с куста- 82-85 пуск, при 65 выкл.
RUN1
С фазировкой вроде порядок просто тупо заместо 42 воткнул 45 только пришлось отмотать обмотки(пусковую и выходную) а то на хх на микруху(7нога) шпарило 17вольт под нагрузкой в 2 ампера 24вольта и выход в раене 20 вольт сейчас хх 11вольт под нагрузкой в 2ампера 15.5(7нога) выход 14,7 под нагрузкой в 2-2.5 ампера выход малеха подымается до 15.1 вольта по теплу если гонять одну управу то полевик можно без радиатора оставить сопрессор тоже холодный только выходной диод греется с хорошей нагрузкой например автомобильная лампочка не 21w пуск = со 100вольт выкл 60вольт вот такие пироги. По шиту если не изменят память 42 с 10вольт а 45 8,5вольт ну вобщем как я не колдовал 42 ниже чем 170вольт не пускалась.
С уважением
gorbun75
Раз пульсации дуги видны глазом - то частота их несколько герц , имхо они не связаны с Кзап ШИМа, где частота 10-ки килогерц . Я бы посмотрел напряжение на банках (и в сети) , не скачет ли оно синхронно с этими пульсациями .
Junior
golub писал
Ув.golub, как я понял схема на 3842 не менее популярна, чем на ТОРе, и очень похожа.
Тоже обратноход, только вместо ТОРа здесь 3842+IRF820? По идее, трансы можно считать
тем же PI Express, как и для ТОР?
Вы наверняка экспериментировали и с 3842, и с ТОР, подскажите что лучше выбрать, какие
между ними отличия в работе:
капризность в запуске, надёжность и т.п.
Просто, сейчас буду заказывать детали, закажу и то, и то, но чего-то нужно заказать больше. icon_biggrin.gif
Какой схеме (на 3842 или на ТОР), по вашему мнению практика, оказать предпочтение ?
Извините, я только начинаю, поэтому такие вопросы.
RUN1
Да может я уже придераюсь она как ба не пульсирует а подтухает малость сантиметр шва подтухание совсем мизерное на шве не видно но когда варишь заметно такое чувство что запас энергии кончается подтухание набор энергии опять сантиметр нормально снова подтухание и тд....... хотя вчера уже поздно апаратец гонял часа 3 ночи было мож глюки у меня были
Wiew
а у вас электроды хорошие, я когда всякое гамно палил то похожее замечал, получалось метал выгорал быстрее обмазки и дуга внутри удлинялась ток при этом немного уменшался.
RUN1
Wiew да именно так электроды уоньки 3мм метал горит быстрей обмазки эдакое дупло получается мм5-6 вовнутырь метал сгорает обмазка нет значит дело всегото в электродах надо другие попробовать чтото вчера не допер, благодарю!
С уважением
Коля
С уважением
До меня тоже три дня назад не допёрло, что проволка на полуавтомате гомно, провода все от транса отрезал- трёхфазный транс, 5-ти ступенчатая регулировка тока. Пол-дня я потратил на замену этих проводов, проверил диоды, дроссель, управу, чуть-чуть лучше стал варить ( неправильно была подключена первичка! Хоть и подключал проффи), но также срал. После замены бобины ( старая закончилась) всё опять заработало как надо, сейчас как по маслу, работает ОТЛИЧНО!
Camelot
Golub
а толку от начального тока стабилитрона? какое преимущество перед отсутствием такового?
Junior
схему на 3842 + полевик я вывел в массы потому что мне стали попадаться поддельные топики которые сгорали унося по 5 баков за раз, схема на 3842 ни разу не подводила и стоит без преувеличения на порядок дешевле чем на топике. если частоту сделать как у меня на схеме 100 кгц то транс можно считать программой для топиков.
RUN1
стартует почему то слишком поздновато у тебя моя дежурка, при токе нагрузки 0.5А она стартовала вольт с 60 и глохла при 20, с падением до 12В на выходе она пахала даже от 12 вольт с принудительным кратковременным запуском от аккумулятора, но это 3842 при питании от 12 вольт у неё Кзап был около 98% с 44-45 ми микрухами такой фокус непройдёт. на плате я тоже ставил блокировочную ёмкость на первую ногу 1000пф дорожка от оптрона до микрухи длинная...
Wiew
это часом не Клима аппаратик? icon_biggrin.gif ссылка
yjriy
Кажись его, правда он успел цену на 50 гривен поднять, ведь заявлял 2800.
То что этот девайс с Запорожья можно даже по ручке переноски определить. Она с автомобиля Таврия, выпускаемого там-же icon_biggrin.gif
Автор кажется им доволен как СЛОН
Andrey_G
sorry, индуктивность в 1000мкГн в принципе нормальная, и еще, менять тупо 3842 на 3844 низя, в 44-ой же тригер пополамный, потому частота генератора должна быть в два раза выше.... (может припохднился с ответом, отсутствовал).
RUN1
Парни ктонибуть ставил такие резы в снабераНажмите для просмотра прикрепленного файла сказали что с очень малой идукциеей я поставил но шото не особо доволен на ощуп греется чуть меньше чем 10W(керамический) или это потому-что он в алюминивом корпусе не подскажите?
С уважением
Коля
Мужики, огромнейшая просьба! Прошу вас ( ну очень прошу) выложить нормальные печатки для сотки, соторую я собираюсь доделать. Печатка должна быть проверенная, желательно без навесных компонентов, без СМД (не смогу номиналы у нас найти). И буду очень очень благодарен за монтажную плату ( с расположение компонентов, чтобы не по схеме делать, а раз взял и всё воткнул, чтобы наверняка заработало и без ошибок. Всем откликнувшимся буду очень благодарен. Ну помогите Коле, у которого руки от правильного места растут! Времени конечно мало, но вечерами буду доделывать.
sorry
Коля я наверно такой-же специалист как и ты. Но печатную плату рисовал сам. Заработало сразу даже успел поварить. Схема немного другая в управлении и силовой части как в 165 ке только драйвера на IR2101 с бустерпным питанием. Одновременно читал форум с самого начала и понял что драйвер такой рано или поздно рванет. Зато плата вместе с драйверами получилась очень компактной. Тоже искал готовые чертежи плат но каждый использует детали которые есть. Так что лучше не ленись и сам займись этим делом. Чужую печать посмотреть тоже стоит чтобы использовать в качестве заготовки под свои нужды.
шумный
Для RUN1! Такие резисторы стоят в снабберных цепях источников бесперебойного питания больших мощностей, но 50Вт только на радиаторе.
yjriy
Брось ты на --х эту сотку и слепи из этих-же железяк нормальный аппарат в нормальном корпусе
Genadiy
Коля!Где фотки а то не знаю какие евро-реле покупать?Думал взять наш ПМЕ-100,но потом решил что он больше 5 Гц не вытянет,а я к нему транс на эту частоту поднять сам не смогу icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif
Alex72
Цитата(RUN1 @ 16.7.2009, 7:03) *
Парни ктонибуть ставил такие резы в снабера сказали что с очень малой идукциеей я поставил но шото не особо доволен на ощуп греется чуть меньше чем 10W(керамический) или это потому-что он в алюминивом корпусе не подскажите?
С уважением
имеются у меня такие - используются в аналитическом оборудовании в качестве ТЭНов для стабилизации температуры.
Вот только индуктивность у них большая - (сам мерял) и в снабберы ставить не стал.
Проверь, померяй индуктивность.
кабельщик
Каким путем предлагается померять индуктивность резистора?
RUN1
Ок парни спасибо. Я наверно уменьшу емкость до 3n и воткну 2шт10w (керамику) стоомных реза в паралель всеровно больше 150 качать не буду
RUN1
Camelot
RUN1
[/quote]
Да!, вот я и думаю чего не так нагородил ну да ладно следующую дежурку запущу на 42 из кожи вылезу icon_smile.gif
KLIM
Да прям уж icon_smile.gif не как слон. Нормальный рабочий аппаратец. Доволен только тем что это мое первое серийное изделие, так сказать проба пера icon_smile.gif.
Коля
А разве обычным ЛС метром не померить индуктивность у сопротивления?
Wiew
Юра наверняка имел в виду автора того сообщения icon_biggrin.gif .
RUN1 , попробуйте электроды "прожарить" может поможет, уони кажись рекомендуют всегда просушивать перед использованием.
Д713
про АНО,УОНИ и не только-
http://paton-ozsm.com.ua/produkcija_elektr...tih_stalej.html
для начинающих сварщиков могу порекомендовать АНО-36 "Монолит",на постоянке вполне приличны,на переменке не пробовал.
для УОНИ чистый "бармалей" без "нашлепок" малопригоден.
толян
Сделайте для тройки аппарат ампер на 170-180, поменяйте полярность , плюс помягче характеристику и УОНИ варят прекрасно.
По поводу Климовского аппарата - ежели 200тка стоит 2800 , то я без работы не останусь, радует.
Д713
про полярность мы всё понимаем,режимы на пачке 3мм электродов УОНИ 13/55 "Монолит"-
нижнее-80-100А
вертикальное-70-90А
потолочное-70-90А
нигде про 170-180А не упоминается.
про "помягче" тоже.
Wiew
если стоит хорошая управа то марка электрода уже почти перестает играть роль даже для начинающего сварщика icon_smile.gif
yjriy
Да прям уж не как слон.
Имел ввиду Харьковского владельца твоего аппарата.
Кстати сейчас серию косарей днепропетровсие ваятели выпустили. 3 аппарата одинаковы на вид, но разные по мощи. Фоток нет.
Camelot
RUN1
в этой дежурке запросто запуск настраивается пусковым резистором, это компромисс или большое сопротивление малой мощности и тогда запуск с более высокого напряжения или поменьше резистор большой мощности и тогда и запуск будет от низкого напряжения и запускаться будет мгновенно, я делал большое пусковое сопротивление по двум причинам, вопервых дежурка запускается спустя 5 сек после подачи питания, значит таймер на реле можно выбросить и во вторыхъ резистор маленький и холодненький. да и вообще на самом то деле напряжение запуска дело десятое, главное чтобы при последующих проседаниях напруги дежурка не глохла а с этим у этой схемы всё в порядке.
