Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
oleg1ma
slavyann
Цитата(Serega30 @ 20.3.2014, 23:51) *
Если верить этой статье: http://radioskot.ru/publ/bp/svarochnyj_inv...malej/7-1-0-632 то у меня не хватает сечения вторички(11мм2).
то есть, если увеличить сечение вторички - ток автоматом вырастет ? так получается ?
RadioГубитель
Цитата(Serega30 @ 21.3.2014, 1:51) *
Знаю, уже задолбал вас...Сделал следующие: транс перемотал 16/6 (первичка/вторичка/первичка), f=53,53кГц. Так феррит практически не греется, зато греются обмотки. На нагрузке 0,217R получил I-115А при U-25v. На нагрузке 0,16R-20v 124А, при сети 180v. Значит все дело только в сечении обмоток...? Если верить этой статье: http://radioskot.ru/publ/bp/svarochnyj_inv...malej/7-1-0-632 то у меня не хватает сечения вторички(11мм2). Может Кзап попробовать добавить до 45% ?...
Серега на 180 вольтах в сети ты больше и не получишь. Найди хорошую сеть и испытай на ней.
gyrator
Если Кзап "кастрирован" до <0.5, то не получит. А ежели не "кастрирован", то без проблем.
RadioГубитель
Гиратор, у него же кастрированный Кзап. Поэтому, как грится, только ККМ поможет.
Wasiliy61
Ребята, да Serega30 мотает обмотки тонким проводом,он сам говорил- авось пойдёт. Отсюда и нагрев, и малый ток, он обе обмотки мотал в облегчённом виде.
DANTIST
Цитата(Serega30 @ 20.3.2014, 22:51) *
Знаю, уже задолбал вас...Сделал следующие: транс перемотал 16/6 (первичка/вторичка/первичка), f=53,53кГц. Так феррит практически не греется, зато греются обмотки. На нагрузке 0,217R получил I-115А при U-25v. На нагрузке 0,16R-20v 124А, при сети 180v. Значит все дело только в сечении обмоток...? Если верить этой статье: то у меня не хватает сечения вторички(11мм2). Может Кзап попробовать добавить до 45% ?...
Serega, нихрена не могу понять, чего ты мучаешься? Феррит у тебя Е65. Надеюсь, нормальный. Зачем ты мотнул 17/6. Поднять напряжение на слабой сети? Но ты одновременно подсадил ток.
Не трахай мозги. Мотай 18/6. Но приличным проводом (шиной, жгутиком). На первичку 5-6 мм кв. На вторичку в 3 раза большим сечением соответственно.
Делай КЗ 0,46-0,47. Сколько у тебя сейчас, если ты собираешься подымать его до 0,45? 0,4, что ли? Максимальный КЗ будет только на ХХ. Под нагрузкой будет меньше. Если на ХХ не стрельнет - будет жить. Я и 0,48 делал, когда старался выжать току поболе.
Нагрузку для испытаний бери 0,17 Ом. Испытывай на более-менее приличной сети. Твоя сеть как раз для экстремальных испытаний.
Кстати, по поводу работы на слабой сети пообщайся с Оleg1mA. У него большой опыт.
Короче, делай как нужно. А не подстраивайся под слабую сеть. Это уже будут проблемы заказчика. Или ты и есть заказчик? icon_biggrin.gif
ingener99
При КПД 90% потребление из сети будет около 15А - не так уж и много.
Кзап надо смотреть не на выходе UC, а на самом трансе, ибо часть % может потеряться в драйвере-затворе ключей (53кГц не каждый IGBT отработает быстро, по включению может быть заметная задержка)
RadioГубитель
На такой частоте попрет 14/5. На Е65.
UVM
Цитата(Сергей_74 @ 20.3.2014, 21:58) *
С какого это перепуга? я месяц назад получил свой заказ как физ. лицо
Я брал давно, пришлось через ООО товарища оплачивать безналом, наверно поменялось.
oleg1ma
Цитата(Serega30 @ 21.3.2014, 10:54) *
нужного тока нет?
Какой ток хочеш получить?Какая емкость сетевых литов?Какой ток на нагрузке 0.1 Ом и при КЗ?
DANTIST
Я мотал на Е65 15/5 на частоте 50 кГц. Но, это как бы впритык. Лучше немного перебдеть.
Опять же, как считать. Если помнишь, тут чуть до рук не дошло из-за одного коэфициента в формуле. Долго гутарили. icon_biggrin.gif
oleg1ma
Помню, как сделал малыша комповского, самый умный гиратор кричал, нахрена все это, проще купить готовый, маленький магазинный, варить и радоватся.Вот эти класные аппараты(в финансовом плане для меня icon_biggrin.gif ) обходите стороной и отговаривайте друзей от этого барахла, результат их работы на столе, это принесли за неделю и это в моем мегаполисе, а какой маштаб по украине, подумать страшно, люди явно не радуются такому приобретению дешевой варилки. icon_sad.gif А малыш мой трудится исправно.
oleg1ma
Литов всегда ставлю из расчета 100мкф на 10а вых тока.Какой ток на нагрузке 0.1 Ом и КЗ на плохой сети?Озвучте моточные ТТ и резистора токозадающего.
oleg1ma
Цитата(Serega30 @ 21.3.2014, 14:02) *
Тт=100 витк., токозад.R=2,2R, на 0,16R-ток 100А (U=16v)
При ваших данных тр-тора, резистора и ТТ, на плохой сети так и будет.Считаем 100/2R2=45.45А, умножим на коэф. трансформации, 45.45х2.66=120ампер- это при хорошей сети!!!!Для получения тока 150а, резистор токозадающий должен иметь номинал 1.7 Ома
oleg1ma
Если-бы умел считать, мозги людям не парил-бы.Нужно помнить что при пониженной сети ток через тр-ры растет, а вых напряжение на выходе варилки падает, от сюда и снижение тока.И я не зря спрашиваю про ток КЗ, так вот чтобы в дуге было 150, ток КЗ должен быть минимум 200-210а, для голого балмалея.
oleg1ma
при заполнении 0.45 и так все будет, постав резюк 1.6-1.7 ома и проведи замеры, на баласте 0.15ом и КЗ.И я уже неоднократно писал, что липинский, где ОС по вых. шунту(то-есть по реальному току), более предпочтителен для работы на гнилых сетях.
oleg1ma
100а - 2.8мм2 первичка, 150а -3.2мм2, э то минимум для первички, вторичку желательно набирать на плотность тока 10а на мм2, это для шашек и 15а на мм2 для кольца.
oleg1ma
Лучше липинский сделать.
sigizmund
Здравствуйте Олег .А можете пояснить конкретно , почему Липин лучше для "гнилых сетей" ? И ещё вопрос ,я начал собирать Липина по вашим платам ,вы какую прошивку использовали ? можете поделится ?
oleg1ma
В бармалее контролируется ток через ключи, то есть, при протекании установленного уровня, происходит блокировка шим, при уменьшении входного питающего напряжения сети, ток через ключи растет, что не позволяет аппарату держать установленный ток.Липинский-же работает стабилизатором тока и его ОС старается поддерживать тот ток, который вы задали задатчиком до последнего.Прошивки все есть на ветке, от 100а, до 200а.
sigizmund
Большое спасибо Олег! Теперь всё понятно. Только уже второй день лопачу форум 8-ой ветки а прошивки так ещё не нашёл. Хотя вру , нашёл на 140 ампер вроде .Родные Липина тоже подойдут ?
oleg1ma
Вот держите, это все Руслан и делал по моей просьбе, перезалил.
sigizmund
Спасибо огромное Олег!
Сергей_74
извиняюсь за офф. топ (это для интересующихся закупкой в ЛЭПКОС)
Обычно народ начинает напрягаться увидев выставленный счет на оплату по безналу, но тут все просто, берете этот счет и идете с ним в ближайшее отделение любого банка, отдаете оператору этот счет и необходимую сумму и на этом все, никакие фирмы для перевода Б/Н не нужны.
TSL2
Цитата(Serega30 @ 22.3.2014, 18:53) *
Я тут немножко поигрался с Кзап: добавлял до 46%
Прежде чем играться с Кзап, нужно контролировать форму импульса К-Э транзюка.
При повышении заполнения транс может не успевать перемагничиваться. Отсюда нагрев элементов, и до БАХа недалеко.
DANTIST
Цитата(Serega30 @ 18.3.2014, 23:37) *
Хлопци, вывод конца первички(см. фото), можно так пускать под вторичной обмоткой, или это конкретный косяк? P.S. Имеется в виду влияние на работу транса...
Serega, здесь продолжение изготовления трансов:
Vs55
Сделал четыре малыша и никогда не заморачивался с подобными изиерениями. Вероятно потому, что нет подходящего балласта для проверки. Подключи шунт, возьми электрод 4-ку и пробуй зажечь дугу. По шунту увидишь какой ток может дать твой аппарат в дуге. Если не получится с 4-кой, перейди на 3-ку. При работе с 3-кой ток в установившейся дуге порядка 110А, большего я не видел, используя несколько типов электродов.
При том токе КЗ, что в твоем аппарате, неплохо бы было иметь, если еще нет, хотстарт и антистик. Это поможет легче удержать дугу при твоей сети.
Serega30
У меня ''голый'' Бармалей. А схемы сех приблуд можно посмотреть?
SHA-SEREGA
при увеличении тока близкаму к максимальному на балласте 0,15 Ом перегорает предохранитель 20А который стоит между минусом электролитов и ключами,подскажите в чем может быть проблема? может исключить его из схемы?
KT117
Исключите. Сами можете посчитать ток в первичке: (Ток на балласте/Ктр)*Кзап
Можно на вход поставить предохранитель на 30А для защиты проводки от КЗ в аппарате
Сергей_74
Доброго дня всем..
Запускаю 2й аппарат..F=49,8; Кзап 44,5%; оптика FOD3180; ключи IRGP50B60PD1; СТ ETD54 30/10 чеки под кр.кернами (Ls=3,8мКгн); выходные диоды 150EBU04.
По входу(ЛАТР) плавно поднимал до ~230V , отдельный выпрямитель +310V на ключи идет через лампу 150W, падение на лампе 54В icon_sad.gif icon_sad.gif , в итоге на ключах имею всего +252V, дежурка пока питается от отдельных +310V
осцилки в архиве..
Подозреваю косяк в СТ icon_confused.gif придется перемотать , слишком большая просадка по силе, после прогона 15мин на ХХ заметно нагрелись обмотки, рука еле терпит..
второй блин(СТ) к сожалению пока комом, а первый сразу получился нормально.. icon_smile.gif
Ваш вердикт уважаемые спецы?
Vs55
Без проблем. Я собирал управу по этой схеме.
oleg1ma
Сергей_74 если в ферите уверены, то скорее всего что-то намудрили с обмотками.Мотали слоями?Сейчас прикинул, то на первичку нужно не менее 33витков, можно просто поднять частоту до 55-60кГц.
Vs55
Цитата(Сергей_74 @ 23.3.2014, 10:19) *
Доброго дня всем..
Я, конечно, далеко не спец, но как по мне, то осцилки нормальные. Посмотри еще на калькуле Лысого. У меня как-то приятель намотал транс и он почти закипал. По приборам все в норме, но был большой ток по Лысому. Когда размотали транс - оказалось в первичке в слоях разное количество витков.
Сергей_74
Спасибо за подсказку.. попробую приподнять F.
В ферите уверен N87, мотал слоями Ls получился приемлемый. Считал 2мя разными программами результат схож.
PS Осцилки насколько я понимаю нормальные так?
По количество витков я уверен все как и должно быть, а вот длинна провода в верхних слоях получается немного больше, за чет заполнения бобины предыдущими слоями..
Vs55
На это уже давно никто не обращает внимания. На калькуляторе Лысого увидишь хватает ли витков в первичке и заодно проконтролируеш ток намагничивания.
Не думаю, что картина изменится от подъема частоты. Мы сейчас мучаем транс на Е65 с 14-ю витками в первичке на 43 кГц - не греется. Хотя по расчету должно быть не менее 18-ти витков, либо частота 60 кГц. Скорее всего подозрения по поводу СТ оправданы.
Сергей_74
Приподнял на 6кГ, падение на лампе понизилось на 10В, теперь на ключах 262В, но это погоды особо не меняет, поставил на прогон ХХ.. Думаю что, чудес не бывает..
PS 10мин. и обмотки горячие.. Переделаю..
Мотну наверное на R 60/38/20 посчитал W39/13 на F50kHz.. Что скажите?
tranzistor3102
наверно правельнее на r63\38\20 на кольце даже проше и охлаждение лучше
Vs55
По кольцу Олег скажет, он спец в этом. А пока еще не разобрал транс, увеличь в нем зазор вдвое и снова погоняй на ХХ. Если и это не поможет, тогда мотай новый. А то жалко разбирать, если не в нем дело.
Сергей_74
сейчас замерил штангелем, действительно так, в магазине видимо ошиблись написали как 60/38/20 и я так написал
tranzistor3102
бывает всякое они сами незнают что продают icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif
SHA-SEREGA
удалил предохранитель, все работает, сжог два электрода на3 все холодное только дросель чуток теплый и очень сильно разбрызгивает, шов получается какойто широкий электрод растекается по металлу, это из-за дроселя?
KT117
Может и из-за дросселя, а может и полярность при сварке поменять надо-разные электроды по разному себя ведут при сварке прямой и обратной полярностью.
tranzistor3102
может быть из-за дрисселя но не из-за предохранителя icon_biggrin.gif полярность попробуй поменять на держаке
KT117
Витков много. Уменьшите до 30/10. По технологии намотки -ищите сообщения Олега по Липинскому в этой ветке. Можете так же тут посмотреть.
P.S. Кольцо точно померьте-может у вас такое R 58.3 х 40.8 х 17.6 (mm) ?
Сергей_74
Ок спасибо..
oleg1ma
Кольцо сечением всего 2.5см2, первички 33-36, кольцо ломать.
Сергей_74
Кольцо уже сломано и склеено.. по виткам старичковая прога тоже выдала 33/11 после внесения точных размеров
KT117
