Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
Jorg63
Цитата(TSL2 @ 9.6.2013, 16:41) *
Настраиваю тоже именно так. Только временную ёмкость ставлю 47мкф. Пилообразный сигнал смотрю на резисторе 1ом включенного в разрыв первички силового транса. Переключатель ослика на делении 1вольт, ток получается 1ампер на клетку.
Подскажите, кто юзал MUR860G в качестве размагничивающих диодов. Как они в работе? А то HFA закончились.
MUR860G по скорострельности не хуже HFA но по току слабее ,надо 2 паралелить. по поводу измерит резака разницы нет где вешать -картинка одинакова будет,просто вместе с предохранителем резак цепляю сразу перед наладкой. а предохранитель не раз спасал при случайном коротыше и без последствиий. надеясь на лампочку можно ключами расплатиться icon_eek.gif
Wasiliy61
Если применять как рекуперационные диоды, то я думаю будут слабоваты, они всего 8А. А в RCD цепочку пойдут, я тоже на снабберы поставил по 2 HER506, работают нормально.
VOVA 555
Jorg63
просто вместе с предохранителем резак цепляю сразу перед наладкой. а предохранитель не раз спасал при случайном коротыше и без последствиий. надеясь на лампочку можно ключами расплатиться .
Можна узнать насколька ампер предохранитель ставите и какой ( если можна фото)?
Jorg63
фота предохранителя? icon_biggrin.gif любой калиброванный на 2-3 ампера,а где ставить прописано выше-невнимательны однако вы
TSL2
По поводу скорострельности "муров" понял, спасибо. Буду пробовать.
А вот насчёт тока рекуперационных диодов, здесь сложилось такое мнение, что меньше 15ампер ну никак нельзя. Ставят и 20 и 30 амперные, зачем? Ведь ток через эти диоды равен току намагничивания транса. А это от силы 2-4 ампера. Т.е. для 8 амперных двойной запас.В пять аппаратов AVT ставил HFA08TB60 и если транс правильно расчитан, диоды без радиаторов градусов 40. Ну конечно перестраховаться никогда не помешает icon_biggrin.gif
Wasiliy61, там и одного хватает за глаза.
Павел(Sp)
А на индуктивность транса влияет чем он мотан?
Думаю нет, только количество витков.
Потому что решил проверить мю ферритов от строчников, индуктивность 17-и витков без зазора около 1900мкГн,
толко вот МЮКАЛК не запускается и какоето рунтайм говорит,если у кого под рукой есть посмотрите ,S=1000мм2
Wasiliy61
Ну так если вы ставили HFA08TB60 и всё работало, то MUR860G практически тот-же диод только чуть пошустрее.
Павел(Sp)
после длительного и бесплодного сношения с прибором геморова -взуева, так и не добился регулировки периода и скважности поотдельно двумя резисторами, оба регулируют и то и другое...(бросил его в тумбочку, до следующего..)
Поскольку я не был готов к построению калькулятора лысого,вспомнил что гдето 2 дня назад читал про калькулятор волосатого, тот же лысого но на более примитивном уровне..
после долговременных туда-сюда у меня вот что получилось, при 40кгц 6 витков первички,если меньше начинает мигать сигнальная лампа о том что если б не она, надоб было доставать новый БП или говоря другими словами в моем понимании транс насыщался, 6 витков мне выдал один из калькуляторов по ссылкам которые мне дали(снова спасибки) причем у меня не получилось добыть из этого калькулятора другое число(без использования екстримальных методов конечно)
внизу осцылка:на ней залом на его величину влияет зазор и количество витков увеличением до 12витков добился то что видно на осцилке, ето без зазора.Осцылка снята с емиттер верхнего-коллектор нижнего ключа.снабберы тоже влияют на картинку
стоит сейчас 2200пф+120ом
питание силы от 14.4в
но 6 витков мне кажется фантастически мало,не думаю что у меня какойто суперферрит хотя телеки были филипсы ,тошибы и тд, 10 лет назад народ тут покупал все самое лучшее..
KT117
Павел, что то вы не то смотрите. Почитайте еще раз про "Волосатого". Там строится график на бумаге, при отсутствии осцилографа.
6 витков однозначно мало. Дайте габариты ваших сердечников, прикинем что к чему.
Павел(Sp)
да про график я помнил, только зачем график если осцил есть правда на резисторе 1ом там миливольты и сигнал как то больше на тругольный похож(на 1ом впослед с обмоткой)
размеры полностью? или центральный керн?центральный 6 штук 15х12мм-пазы от стяжек.. где-то 1000мм
вообще я правильно понял что когда транс клацать начинает и моргает лампа то ето он вошел в насыщение?надо витков побольще..
KT117
По моим прикидкам на 40кГц, заполнение 0.43 , вам надо мотать 12 витков первичка, 4 витка вторичка. Дальше смотреть калькулятором Лысого. Сигнал треугольный, если сверху начинается загиб- то это наступает насыщение
Если ставить 4 сердечника- то будет первичка 18 витков, вторичка 6.
Размах индукции я брал 0.25Тл, с запасом.
Павел(Sp)
КТ117 а у вас сигнал снят в какой точке?
KT117
Снимок не мой, из статьи про прибор Гумерова-Зуева Нажмите для просмотра прикрепленного файла
А снят с резистора в калькуляторе Лысого
Павел(Sp)
Океюшки, завтра посмотрю на резисторе.
Jorg63
только резистора хватит и 2 ватного и не в коем случае не ставить резистор керамический как в саберах практикуют на ЕБУках. Он индукционный и точно реальной картины не получите на резисторе.
nikon
Цитата(Jorg63 @ 9.6.2013, 17:05) *
Смотря какую лампочку подцепить, если киловатта на 2 то конечно, а так по свечению лампочки определяю примерный ток ХХ, и при косяке 99,9 процентов что ключи останутся целыми. В моей практике было что лампа светилась в полный накал, и ничего , все целое.
Magnitogorsk
Всех приветствую!!!Вот дошло дело до намотки транса и дроселя. Подскажите кто уже мотал не раз .имеется транс на двух половинках E70/33/32 N87 B66371-G-X187 эпкос ключи будут стоять IRGP4063DPBF. по одному на плече коофицент заполнения 43 частота 34 проволока эмаль есть 0.6 сварочник будет ограничен на 160 -150 ампер.Скажите сколько витков мотать на эту частоту первички и вторички.или же все это дело мотать как в схеме 18 витков первичка и 6 вторичка Сначала пол первички ,вторичка ,пол первички.
and_w
Ну для 4063 можно, в принципе и на 50кГц замахнуться с витками 15х5.....на 34кГц и 18х6 пойдут 50U
Павел(Sp)
оно конечно спасибо за совет,... я чуть не включил и не сунул осцил.... у меня развязки нет от сети..До субботы ждать ..если чего найду чтоб развязку сделать//
swewe
бесперебойник рулит !!
Павел(Sp)
при наличии,... а поскольку за последних 12 лет перебоев не было, а если и были то прошли незамеченно, а посему бесперебойник отсутсвует..
Короче снял осцилки на резисторе 1 ом..
1я - 8 витков, 0,43кзап,40кгц если я правильно понимаю виден залом на вершине,
с увеличением к-ва витков исчезает, при 9 уже почти не заметен вторая осцилка при 12 витках,
питаю пока от 12в, если это имеет какое-то значение.
Мож к выходным чего соображу для развязки.
А то хотел пустить от 24в от какогото блока по весу 100% трансформаторный, так когда осцил цепляю минусовый провод такая искра лупит шо в темноте читать можна,причем гдето аж через комп все енто кудысь уходит, как вытаскивал usb кабель осцила из компа то тоже шарашит нехило..Боюсь шоб как в детстве не получилось..
Basill
Цитата(Павел(Sp) @ 11.6.2013, 0:17) *
если я правильно понимаю виден залом на вершине...
питаю пока от 12в, если это имеет какое-то значение....
Никакого "залома" (в том виде, каком его ищут на приборе Гумерова-Зуева и/или калькуляторе Лысого) там нет и в помине, да и быть не может при питании 12В на частоте 40кГц. Залом должен быть виден не в виде "горба", а в виде "прогиба" в другую сторону, как на снимке в посте КТ117 см. выше.
По сути, прибор Г-З и калькулятор Л работают на одинаковом принципе. Чем меньше напряжение, тем больше должна быть длительность импульса, чтобы появились признаки насыщения. Еще раз повторяю: играет роль связанная пара параметров: амплитуда напряжения (питания) и время (длительность импульса). В калькуляторе Л меняется напряжение при постоянной длительности (ЛАТР - главная деталь!), в приборе Г-З меняется длительнсть импульса при постоянном напряжении (главная деталь - генератор импульсов переменной длительности).
Прибор Г-З (намного раньше подобную публикацию оформил Бирюков в своей статье) по сути нужен для того, чтобы за счет большей длительности импульса (меньшей частоты) сместить лабораторный анализ катушки с сердечником в более комфортную область напряжений 15-30 В. Если не боитель работать при 300В постоянки - то работайте с калькулятором Л на штатном косаре, тогда никаких дополнительных устройств собирать не нужно.
Wasiliy61
Добрый вечер всем форумчанам, ребята -что-то я не могу раскопать частото-амперную характеристику ключей IRGP50B60PD1 и IRGP4063DPBF в описании даташита, ткните носом. Спасибо.
tranzistor3102
а для чего она тебе василий нужна эта хар-ка если не секрет? ты что хочешь использовать ключи на 100кгц icon_biggrin.gif
Wasiliy61
Ну так некоторые и 50кгц не тянут, хотелось бы взглянуть и убедится. Вот например ключи IRG4PH40UD -41а, а уже при 35-40 кгц от них ни чего не остаётся. Вот взгляни харак-ки.Нажмите для просмотра прикрепленного файла
Андреевич
Так на 3-ей странице представленного по ссылке даташита график зависимости тока от частоты!
Серёгин
Добрый вечер Wasiliy61 , дэк ведь есть и другие транзисторы , вот есть новые , такие ,
STGW45HF60WD . www.promelec.ru/catalog/4/217/233/0/131415/#131415 .они до 100 кгц .
tranzistor3102
ключи про которые ты спрашивал уж(IRGP50B60PD1 и IRGP4063DPBF) точно 50 кгц потянут
Wasiliy61
Добрый вечер, да я понимаю что ключи более новые, просто было интересно посмотреть, да что-то не нашёл нужной информации.
ГонZZа
Вечер добрый.STGW45HF60WD,в двух аппаратах работают на 55кГц,и по цене дешевле(124р),а 50W-165р.
olegators68
Зато есть IRG4PC40W 20А, у меня в параллель по два работают на 50кГц, 160А реальных, и еще просят частоты, но дальше больше граблей с остальными детальками по частоте.
Wasiliy61
Ну конечно с поралельных можно взять, но 160а можно взять с хороших и одиночных ключей.
olegators68
Теплоотдача на радиатор более проблемной будет, выбираем меньшее из зол.
Wasiliy61
Цитата(nikon @ 12.6.2013, 0:28) *
Амперы снять не проблема, а вот при спаривании тепловой контакт в 2 раза больше.
Я понимаю ампер на 200-240 надо спаривать, но на 160 думаю и одиночные ключи нормально будут, тем более не всегда 160а нужны. На днях проваривал уазика-таблетку своим Бармалеем, почти треть пачки сожгли тройки, почти без перекура, останавливались на чуть-чуть, из за того -что держак нагрелся. Ключи стоят какие-то полтинники, точно не помню.
truevoxdei
Парни, подскажите по ключику
MGY30N60D. Нашел даташит мотороловский, но там что-то не вижу хоть "хоть убейте" на какую частоту расчитывать (хотелось бы не ниже 50 кГц). А также сколь тока вытянут эти малыши, если по одному в плечо? И вообще, почему-то на ключике эмблема On Semiconductor.... Может перемаркер?
olegators68
Офф-сайт таких не знает http://www.onsemi.ru.com/PowerSolutions/ex...m1_val=document
truevoxdei
Перемаркер. Получается что так. Хотя выглядят достойно. Протирал ацетоном. Краски вроде никакой нет. Надписи сделаны вроде лазером (под лупой смотрел). Что за чудеса....
Vs55
Wasiliy61, у меня PD1 спокойно работают на 66кГц ток 140А. Еще в одном аппарате на 92 кГц при том же токе, но его пока не особо нагружали, так что о длительности работы ничего сказать не могу.
olegators68
Ну на радиатор подопытного MGY30N60D, открываем затвор, пропускаем ток порядка 10-20А через него, меряем падение напряжения К-Э, делаем выводы, о частоте пока рано.
tranzistor3102
скорее всего перемаркер у имеются такие же только 50n60
Wasiliy61
IRGP50B60PD1 ключи всё-таки 75а. Где заказывали и по какой цене.
olegators68
Цитата(truevoxdei @ 11.6.2013, 22:19) *
Перемаркер. Получается что так. Хотя выглядят достойно. .
Чем достойно, лапками из жести от консервных банок.
oleg1ma
Производители есть разные, так что нерастраивайся.
Wasiliy61
Ребята, а кто пробовал делать транс из отклоняючих систем, говорят аппарат долго не живёт. Но если узнать точно проницаемость феррита, мажно и витки правильно высчитать.
truevoxdei
Ясно. Будем мерять-измерять. Жаль, конечно. Для остальных (ну кто c Иркутска, брал парочку этих ключиков в Электронике, та что на Фурье...). Хотя G80N60UFD (файрчайлдовские) оригиналы. Вот так.
Вопрос в догонку по одному G80N60UFD в плечо на ток 160А можно?
ГонZZа делает из ОС. Вроде живут-варят. Хотя статус "живого мертвеца" ... момент такой. Но раз работают, значит вполне реально и продуктивно использовать ОС.
olegators68
Ну e-find их тоже видит http://www.efind.ru/icsearch/?search=MGY30N60D , но плохо.
А расстраиваться действительно не надо, все попадали, не на Жабиты так на что нибудь другое, рынок, мать его ити.
truevoxdei
Хоть обрадовали чуток. Как говориться, "надежда (а может и Фортуна) ... последней". Но все равно сыкотно стало использовать в дело сие ключики. Лучше перебдеть... Хотя если струльнут ... тут уж как повезет.
Поискал в сети ещё разок. Вот тоже нашел кое-чего
http://electronicservice.shopmania.biz/cum...paign=shopmania
Вот это ключик.
Получается всего-то на 30 Амперов....
Vs55
Wasiliy61, брал у нас в городе на рынке, по 40 наших грн. Это примерно 160 р за штуку.
Magnitogorsk
я брал такие но не рискнул ставить сдал обратно поменяв на IRGP4063DPBF эти держали спокойно 160 ампер но я ограничил 150 -ю амперами аппарат Какими то подозрительными они мне показались по внешнему виду
DANTIST
Я бы эху херню не ставил. Если хочешь ставь. Сгорят - не жалко.
А вообще есть ветка специальная на тему перемаркера. В курсе?
