Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
slavyann
санекнс, а зачем вы 44-ю пихаете ? чтоб убедиться, что у нее Кзап. 100 % ?
Nikolay, а что будет с аппаратом при таком дросселе ? ? ?
Nikolay1
Цитата(Nikolay1 @ 26.2.2014, 21:57) *
ну эта если аппарат целым останется
ты хоккей видел?
tranzistor3102
нечего с ним не произойдет.а что с вами будет неизвесно после самогона или брагиicon_biggrin.gif
Wasiliy61
Цитата(Nikolay1 @ 27.2.2014, 1:05) *
ты хоккей видел?
Ребята, кто что-нибудь понял. Аппарат будет работать с таким дросселем.
Wasiliy61
Цитата(санекнс @ 27.2.2014, 0:56) *
Wasiliy61 Сделал управу по вашей печатки ставлю 3845, осцилла таже что и на фото 11111 попробовал з штуки 3845, сегодня поехал в магазин купил 3844-2шт и 2845-2шт, ставлю 3844 тоже самое обе, ставлю 2845 и все в норме Кзап 47%, не знаю что с 3845 и 3844 но заработала нормально 2845, а 3845 работает как 3842
Заполнение надо -бы убавить, и на 3845 должна схема работать нормально. Если на другой печатке, и на другой микре, одно и тоже- значит косяк в какой-то детали, или попутан номинал.Печать что я давал 100% рабочая.
slavyann
Цитата(Nikolay1 @ 26.2.2014, 20:05) *
ты хоккей видел?
видел, после хорошего самогона и не такое привидится, только вот дроссель причем ?
вывод : Nikolay просто перепутал аппараты - сварочный с самогонным
KT117
Что то странное творится с вашими усками. Как вы 3844 и 3845 загоняете в заполнение 97%? Опишите подробнее обвязку уски-схему, номиналы, печатку. Интересно же icon_smile.gif
DANTIST
Цитата(Wasiliy61 @ 26.2.2014, 8:02) *
Wasiliy, нормально работает дроссель. Не раз такие применял. В крайнем тоже такой стоит. А Мыкола 1-й похоже еще не отошел от 23-го. icon_biggrin.gif
Павел(Sp)
Цитата(DANTIST @ 25.2.2014, 11:21) *
Не первый же год делают Бармалея и всё еще, оказывается, чешут репу, как намотать транс. Витки давным давно пощитаны для всех трансов, подходящих для этий целей. Или осталось что-то эксклюзивное?
Интересно, много ли народу пользовалось калькулятором Лысого, кроме самого Лысого?
А вот здеся, при всем уважении ты брат не прав.. вот к примеру мой клинический случай..
Такого феррита как у меня, даже у меня больше нет.. и калакульяторомъ я пользовался,правда так нихрена и не понял,что есть то не отнимешь.Но витки именно ним подбирал,потом правда но приборе Гумерова-Зуева проверял,но калькулятором Лысого на мой взгляд попроще будет.
Кстати у мине праздник- мне латр подарили,500w вот ,и транс 500w 220-220 от сети развязаться,так шо как только время будет возьму себя в руки и....если вдохновение не придет опять...
Цитата(санекнс @ 25.2.2014, 14:43) *
А может быть пере маркер
uc3845n в uc3842n проверил все, купил 4шт uc3845n и на всех одинаковый сигнал на 6 ноге скважность 3 процента. а может быть из за неправильной разводки платы, может наводки, попробовать пере развести посоветуйте.
подстроечник не в обрыве часом, уз дюже похоже..
Цитата(Wasiliy61 @ 26.2.2014, 17:33) *
Будет работать на 55кгц.
Василий,100% шо будет работать,я всегда когда стационарно в цеху варю,кабель массы на ножку стола наматываю или первую попавшуюся болванку железную,поджиг лучше,а то в сварочнике что на работе дроссель-колечко из чегото внутри корпуса на выходной шине висит ...а в полуавтомате вообще 12м кабеля массового, его как намотаю на железяку....но в инверторе очень заметно доп.индуктивность..
Wasiliy61
Теперь мы знаем почему Nikolay1 редко здесь появляется, он пьёт свой хороший самогон, как кончится самогон-он сюда не надолго заскочит, а там и новый замес на подходе.
Serega30
На днях смотрел инвертор разобраный на ток 250А. Расскажу вкратце: косой мост, генератор на 3844, полевик, много SMD деталей, ТГР. Ключи: спарка IRGP20B60PD 2шт в плече. Транс чуть больше Е-65(может даже Е-70), первичка 1,5-1,8мм диаметром, от вторички идут провода около 7...9 мм2 длиной 10-15см. Транс притянут к плате одним хомутом. Далее 4 трехногих диода(ноги не спарены), как влючены-не удалось рассмотреть. Дроссель шинкой 10мм2 на какой-то трубе, диаметром 15-20мм. Извините за карявое описание, разбирал аппарат знакомый, я только в гости зашел и одним глазком глянул. Стремные какие-то параметры на такой ток...
санекнс
Сначала я сделал свою печатку управы 3845 фото3, купил 3шт, на всех трех сигнал на 6 ноге фото2 ,Wasiliy61 скинул на форум вариант своей печатки, я не много переделал ее под оптодрайвера сделал фото4 ставлю 3845 на всех трех тоже самое фото2 поехал купил 3844-2ш и 2845-2шт, ставлю 3844 тоже самое фото2, ставлю 2845 все в норме фото1, обвязка 4 и 8 ноги 7,5к и 3нф, не могу понять что с 3844и3845 работают как 3842 хотя маркировка четкая. схема управы фото5 все номиналы управы один в один кроме обвязки.
DANTIST
Serega, а ты застал те времена, когда на Шарпах (и не только) писали 1000 Вт, 1500 Вт?
Люди же смотрят на шкалу регулятора и при виде магической цифры 250 А, теряют силу воли, а руки автоматически тянутся к кошелькам.
Думаю, как-то оно так.
Wasiliy61
Ты делал на 2ух разных печатках, а детали использовал одни и те-же?
Serega30
Ага, застал. Еще раз убедился: в наше время нельзя верить никому, даже себе). А инверторы ходить покупать с нагрузкой, шунтом и амперметром.
DANTIST
Та не. Не нужно с собой таскать все это. Если человек хоть один аппарат сам сделал, то уже по внутренностям сможет оценить возможности предлагаемого девайса.
А что же делать остальным? Может быть читать отзывы в сети... Или покупать такой же, как у соседа...
Хотя, много раз на рынке наблюдал, как людям при покупке дают поварять аппаратом. Но тут тоже есть нюансы. Время года, сеть, электрод и т.д.
KSV
Я как то ремонтировал СВАРОГ 180 (полный мост с одним трансом без всяких драйверов, куплен года 3 назад)и не поленился проверил , что выдает. Прогнал на баласте на разных токах и на 180а выдал 180а по амперметру и 23 вольта, сам был удивлен. Другой инвертор приперли на моденнизацию, на вес был тяжеловат и когда глянул в дырочки, а там простой транс даже без диодов, зато италия(написано было).
санекнс
Детали теже выпаял и поставил на новую плату, только в новой плате нет подстроечников, по даташиту микры 3845 см фото при уменьшении R и увеличении С в обвязке меняется Кзап но пробовал играть ими, на моих 3845 и 3844 меняется но Кзап всегда больше 50%
KT117
Не могли бы вы попробовать на этих 3844 и 3845 на 4 ноге поставить такие номиналы
R=680 Ом , С=33 нФ
Какое будет заполнение и частота де факто?
poma_s
Доброго времени суток.
Извините что не в тему.
В начале хочу поблагодарить всех форумчан за титанический труд и проведенную работу.
Сам собрал сварочку по варианту одноплата уже год назад, проблем никаких. Получилась ампер 140 на дуге, 50 вольт на ХХ .
На сегодня появилась необходимость запитать ею полуавтомат, но варить невозможно.
Проволока испаряется не доходя до метала. Если возможно, помогите разобраться как снизить Uxx? без переделки трансформатора. Управа собрана на UC3845.
KT117
Смотрите соседнюю ветку Инверторный полуавтомат http://www.electrik.org/forum/index.php?showtopic=11502 . Там есть схемы на 3845 с регулировкой напряжения.
Wasiliy61
Мой крайний сварочник, правда слегка не доделанный http://www.electrik.org/forum/index.php?sh...st&p=330905
urdint
Аппараты с такими дросселями работают, и успешно!!! Читайте, ранее было описание. Да и один из моих аппартов тому подтверждение. Правда на железе от 100-ваттного транса, мне кажется,
работант лучще...
санекнс
R=680 Ом , С=33 нФ
Попробовал временно впаял подстроечник 1к СП5-2 и корндер 33нф перепробовал 3844-2шт и 3845-3шт все как одна на 680ом и 33нф примерно совпало по расчету пробовал крутить сп5 Кзап меняется от 25% до 65% при этом частота меняется от 32кц до 42кц при этом на каком сопротивлении не смотрел. ниже 25% и выше 65% не идет крутишь на с ужение доходит до 25% Кзап и пропадает сигнал на нуль. крутишь выше Кзап65% схлопывается резко до Кзап 97%. Что же это значит.
KT117
icon_smile.gif Перемакер это значит. В более популярные 3845. Интересная тенденция.
А фото этих микросхем крупно-можно сделать?
Если интересно стало-скачайте програмку по расчету частоты на UC38xx http://forum.cxem.net/index.php?app=core&a...ttach_id=185599 Сравните свои результаты с расчетами
ПыСы. Наверное с такими частотозадающими цепочками можно эти микры использовать в бармалее. Если только не случится какой-никакой катаклизм и заполнение не подскочит до 97%.
Но тут я уже пас- разве что Гиратор захочет проверить в эмуляторе. icon_smile.gif
санекнс
Vs55
санекнс,
Верхние правильные, потому и работают. Нижние грубый перемаркер, даже логотип производителя поленились нарисовать.
slavyann
интересно, из чего нижние перемаркированы ?
поделка грубоватая конечно
санекнс
2845 работают как положено, а 3845,3844 при тех же номиналах Кзап 97% по программе расчета для uc38хх похожи на 3842
KT117
Ставьте 2845-отличная микросхема. А про 3845 которые не 3845 напишите в ветке http://www.electrik.org/forum/index.php?showtopic=16316 - пусть все знают врага в лицо icon_smile.gif
Wasiliy61
Ни когда-бы не подумал, что такую дешёвую микру станут перемаркировывать, а оказывается .... .
oleg1ma
Wasiliy61
Цитата(Nikolay1 @ 27.2.2014, 0:39) *
в качестве сердечника водопроводная труба
Так что аппарат с дросселем из водопроводной трубы /трансформаторное железо/,как ты назвал- работает нормально, дуга зажигается на молом токе, конечно на мин. не ставил- так как пробывал тройкой.
romantik
Классный аппарат!
Serega30
Всем привет! Настроил аппарат на 31-73А для тестов. Гонял на токе 31А, нагр.0,15R-10мин , температура радиатора ключей 40*С. Можно ли поднимать макс. ток при таком?
KT117
При таком -что? Нагреве радиатора? Нормальный нагрев. Особенно если сейчас без обдува.
Serega30
Да, при нагреве. Радиатор в обдуве.
KT117
Ну и поднимайте до своего максимума. По другому не определишь-будет работать или нет. И нагрев трансформатора смотреть-чтоб феррит не перегреть.
Serega30
Вот и варить попробовал... 3ка горит от 40-50А. На максимуме рег.тока напряжение на дуге ниже 20в не падает. Пробовал топить электрод-фигушки, горит и все, залепить электрод трудновато, но возможно. 4ка совсем не горит.
satinstaller
и металл проплавляет при этом?
Serega30
Посмотрел шов-больше похоже на второй вариант). 2ки нет что б попробовать. Буду ток поднимать.
DANTIST
Serega, ты так очкуешь, как будто это второй сварочник испытывается после Бармалея. Чего ты так испугался? Или у тебя ключи по $100 стоят?
Делай нормальный ток, смотри на балласте и вари.
Serega30
Все... Диод размагничивающий умер, заодно и ключик прихватил на тот свет. Дело было так: включаю в сеть, что-то тихонько затрещало... и погас свет. При разборке полетов оказалось что размагн. диоды в месте крепежного отверстия со стороны радиатора пробили оба катодами на радиатор. Обидно даже, до этого все было в норме...
tranzistor3102
[quote name='Serega30' date='1.3.2014, 2:13' post='331099']
[/quote
изолировать от радиатора диод надо было лучше icon_biggrin.gif в своих сварочных аппаратах использую прокладки от комп.бп пока полет нормальный.просто излишнее усилие не надо прикладовать при затяжке крепежного винта. icon_biggrin.gif либо использовать диоды с изолированной подложкой
Serg SP
+1. В фиксе, что сейчас пытаю, поставил диоды (их там 3 шт в первичке, а именно 1 в снаббере и 2 в цепи размагничивающей обмотки) через 2 прокладки типа Номакон, изоляция получается будь здоров, а греются эти диоды очень слабо, так что такого теплоотвода вполне хватает. Вероятность пробоя двух прокладок практически нулевая.
KT117
Интересненько. icon_smile.gif У вас оба диода на одном радиаторе закреплены? Если на разных -то посмотрите схемку внимательно-изолировать требуется только катод одного диода. Хотя все зависит от разводки платы.
При подготовке отверстия в радиаторе нужно сделать хорошую фаску и обязательно шлифануть посадочную плоскость диода-часто есть заусенцы от штамповки и при прижиме они продавливают изолятор.
Ну и просто для сведения. Вот так реализовано крепление размагничивающих диодов в AVT200 из соседней ветки-работают нормально. А в своем первом аппарате на 130А -диоды вовсе стоят без радиаторов, нагрев градусов до 50.
Serega30
Ключи и диоды на одном радиаторе. Фаска дествительно не очень... Может и пальнуло из-за этого...?
KT117
У меня было такое. Фаска маленькая и прошило слюду в этом месте на катод. А в другой раз на кромке заусенчик не снял-прошило. С тех пор все корпуса по наждачке елозятся перед монтажем.
А еще может и номакон быть поганеньким (особенно если он БУ много раз)
Serega30
KT117
Цитата(Serega30 @ 1.3.2014, 11:52) *
Посадочные места (фланцы) диодов и транзисторов. Проведите пальцем по кромкам фланца нового диода и почувствуете сами.
