Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
spesso
Цитата(RUS5610 @ 3.10.2009, 0:19) *
Буквально вырвал этот рабочий модуль из рук деблоидного электрика,который хотел с помощью молотка посмотреть что в нутри.
Сначала колесовать, потом четвертовать, потом на кол посадить.
Для наших целей пойдет?
Да, 1200В 200А.
petr0757
Цитата(steppee @ 2.10.2009, 23:10) *
Автомат после выбивания ещё и остужать надо.
Не надо, поскольку если выбило С25А то уже надо востанавливать инвертор.
steppee
Я как-то не увлекаюсь модой на миниатюризацю автоматических выключателей (которые стоят на вводе) и на их дугогасительных камерах тоже не экономлю пространства. Сеть у нас в гаражах с малым импедансом и, чтоб ограничить ток КЗ и повысить коэффициент мощности выпрямителей, я ставлю на вводе токоограничивающие реакторы, адекватные нагрузке. Когда у меня автоматы выбивало, я их не восстанавливала, потому, что они не портились. Для защиты проводки от перегрева предпочитаю пользоваться отдельными тепловыми реле, в которые при необходимости можно заложить адекватную модель проводки. Впрочем, у нас по гаражам идёт проводка такими ломовыми кабелями, что её чёрта с два сожгёшь, остаётся только забота - делать защиту для своей аппаратуры.
haitah
Вот что предлагают поляки
DANTIST
Это практически один в один схема, по которой я начинал делать сварочники. Штуки 4 сделал по ней. Неплохая, ксати. Потом перешел на Кольта. Но когда первый Кольт начал выделываться, даже была мысль снова вернуться к проверенной схеме.
Схема прилагается. Мож кому надо. Только я ставил несколько другие элементы (ключи, транс...) для умощнения.
RUS5610
Да, 1200В 200А.
Да спасибо уже нашел даташит.
А хорошем качестве есть схема? Мелкоту не видно
Дмитрий25
Подскажите пожалуйста
У меняя твс 110пц15 6штук
А там окна мало
Можно разширить твсы доставить их кусочками ?
yjriy
А там окна мало
А ты их сложи квадратом, т. е. О- образно. И на каждой половине намотай по пол. первички и полной вторички. Первички последовательно, а вторички впараллель. Сечение вторички на каждой стороне в два раза меньше расчетного, ибо потом- ведь впараллель. И все туда без литца прекрасно влазит.
Направление намотки нужно выбрать правильным, чтобы потом при соединении обмоток небыло длинных концов
sorry
У меня тоже 6 ТВС сложены в Ш 18х6 сечение первичка 8мм2 литц . вторичка 20мм2 4 шинки 5х1мм. Окно 18х30 примерно? И то сечение можно было меньше делать.
Пук
Дэвушка явно практикуется в эпистолярном жанре. Здуреть можно.
KLIM
Цитата(RUS5610 @ 2.10.2009, 20:19) *
Буквально вырвал этот рабочий модуль из рук деблоидного электрика,который хотел с помощью молотка посмотреть что в нутри.Для наших целей пойдет?
Варвары.... у него же цена баксов 70 продажная...
Для целей пойдет, но в полумост... косарик с него не выйдет. Зато полумост на совесть. И дрова ему нужны не детские. Типа тех что оптика с буфером на 540/9540 транзисторах, емкость затворная офигенная. Так что попотеть прийдется. Да кстати - частота 30кГц максимум.
RUN1
Мозги сделал для нового аппарата, сейчас крою остальные части. Уже недолго осталось. Заодно достану УОНИ и попробую с ними подружится.
spesso
по eFind 260...500$
RUS5610
Спасибо Клим!
KLIM
Цитата(spesso @ 3.10.2009, 14:57) *
по eFind 260...500$
Яж забыл блин, цену старую сказал... таки да - СТОИМОСТЬ находки выросла icon_smile.gif
Этого бы монстрика оставить на аргон переменку по выходу поставить. Вот тут ему самое место!!!
Кстати - RUS5610 - если интересно то я могу сфотать то что в середине этого модуля, только 100 Амперный. Ну так, для электрика, как моральная компенсация icon_smile.gif
dez
[quote name='VrnAlexM' date='30.9.2009, 22:25' post='105586']
Если вы мне.
Это что-то среднее между полумостом и пушем, в народе зовется "Полумост с разделенными обмотками"
спасибо , со схемы вижу - полумост
haitah
Я вообще то про Антистик.
Только кажется что хлопотно это будет.Так можно и ограничение+контроль вых напряжения регулировать?
maxx
А можно более качественее картинку?
usta Vazgen
приветствую всем!
захотел почитать форум но количество страниц уже под 1000 кто ни будь может указать на последнее подведение итогов. ну типа куда приехали что выяснили что планируете icon_cool.gif что бы не прочитать все 924 страниц.
спасибо!
maxx
Цитата(usta Vazgen @ 3.10.2009, 22:27) *
приветствую всем!
спасибо!
Бармалейник работает icon_smile.gif, можно(желательно) поменять сердечник, ключики. Сам жду вести от KLIMa, я так думаю будет то-что надо-"новый-народный". Гложут правда мысли по поводу снимания тока на выходе с помощью шунта...
usta Vazgen
ну а смый полений такой узловой момент где находится на форуме ну скажем где пришли к конкретной схеме.
спасибо.
KLIM
Я Вас немного огорчу. Была мысля приделать шунт, но это уже не народно/общедоступный сварочник. Люди вон переодически немогут обычного Бармалейника запустить... я уже молчу за чуствительность ОС на шунте. Хотя Мысля для сварника на шунте - вполне здравая. И буду позже двигать туда. Вообще есть желание приделать процик для рулёжа по среднему, и оставить таки ШИМ контроллер для отработки граничных токовых режимов (защит) а может просто будет генератор и дрова с токовым контролем транзистора. Вообщем посмотрим. Основная цель - это вообще убрать разбрызгивание (насколько смогу), вот это будет достойно потраченого времени!
maxx
По мне так, проц для "сервиса", а в работе сварочника можно обойтись ШИМом и вспомогательной рассыпухой. Буду рад если Вы с RUN1 представите всеобщему обозрению схему по среднему того что у Вас получилось, хотя кусками вроде всё понятно, но ньюансы... , раскажите про всё icon_smile.gif
KLIM
Расскажу но когда закончу, ато трепологией попахивает.
А насчет проца - Вы немного не правы. Сервис - конечно есть хорошо, но ... коли нужна математика процесса сварки, точные процессы каплепереноса и прочие приблуды - вот тут процику нет равных! Хотя всё зависит от серого вещества создателя - но всетаки намного сподручней да и в ногу со временем!
haitah
САНЕК
KLIM
Сикёшь куда поляков понесло,прокоментируй этот антистик icon_smile.gif Вроде ты этим узЕлком давно занимался.
sorry
Наверно стоит представить схему "голой" управы по среднему току. Без дополнительных функций. Все доп примочки обсуждать отдельно указывая точки подключения к основной схеме?
petr0757
Осмелюсь представить почти голую управу на древней TL494. делаю ее с начала инвертостроения практически без изменений почти семь лет.
KLIM
Цитата(САНЕК @ 4.10.2009, 5:22) *
KLIM
Так а чегог тут комментировать? Я бы стабилитрон не 8.2 вольта поменял бы на 10 вольт, может на максимальном токе на прогретом электроде не срабатывать. Ну и резистор на коллекторе 1.2 кОм - поменяй на 330ом гдето, может и меньше, по сработке глянуть. Да и кондер на базе оставь на 330 мкф. Пару секукнд дать задержку должно, чтоб электрод сразу не примерз. А так по большому счету у меня уже компаратор этим занимается, с выставленными задержками на включение/выключение, перестал я любить хаотические процессы. Я к тому что этоти кондерчики на 1000 и 330 мкф подсохнут (годик другой) и начнут здорово долбать мозг пользователю, поэтому лучше где можно поставить тантал. На себе проверил.
sorry
Схема голой управы по среднему без проблем вырезается либо с кольта, либос ополяченного телвина, а вот причесать её для исключения возбудов - этим и занимюсь!
Да кстати 494 - тоже в этом виде сдорово себя показывает НО может пропустить пики тока при скажем максимальной уставке и закорачивании электрода в ванну или при поджиге... черт его знает сколько транзистор в этот момент вытерпит, пока 494 сообразит что чтото не так. Тот же фокус в схеме инвертора Лисова.
yjriy
А вот потому он и забубенил туда дросселек на 110 мкГн
толян
Положу и здесь свою управу .
RUN1
RUN1
[/quote]
Клим Ок самое интересное я думаю как варить будет icon_smile.gif ну и твой вердикт конечно думаю всеже сильно плох не будет мож она будет не так хороша как на 3525 хотя чем черт не шутит icon_smile.gif но всяко лучше голого и по сложности не какая icon_smile.gif вобчем ждемс icon_smile.gif удачи!
RUS5610
'KLIM'
[/quote]
Так что этот модуль совсем на Бармалея не пойдет? А фото можно, интересно посмотреть.
VrnAlexM
Какие переключатели используете для установки предела тока.
maxx
Ранее Golub выкладывал, ещё раз выложу, может поможет общему делу.
толян
А зачем так сложно?
maxx
Цитата(толян @ 4.10.2009, 22:54) *
А зачем так сложно?
С этим вопросом к производителю, схема выкладывалась ради "шунта на выходе". Кстати, может свою схему целиком покажите, что куда? CN1, CN2 ну и вообще.
толян
Описание простое в схеме ,выход оптрона на 9 ногу 3525 в силовом блоке.
Схема на 3525 на форуме про двухтактники.
теоретически можно, конечно посидеть нарисовать полностью данный вариант девайса , но я делаю разные
модификации косого и поэтому полных схем не рисую для себя , я ж их и так наизусть знаю.
petr0757
Можно любые, но у меня много МПН-1, правда они на 10 положений.
lapa
Цитата(sarmat @ 30.9.2009, 12:16) *
Сегодня "приехали" HGTG30N60A4D с Унисервиса по 94 р. 10 штук. Никаких следов вмешательства в заводскую маркировку. Толщина стандартная - около 4,8 мм. Отправила Норкина Валентина с Королева. Павильон 684 в митинском.
Павильон 604! Забрал 3 последних HGTG30N60A4 105р сказал чтобы подвозили. У HGTG30N60A4D корпус весь в царапинх (плохая прессформа) побоялся брать хотя они дешевле.
шумный
На бармалея нужно два таких модуля, но кусается больно если не на халяву достались.
spesso
Фиксатого можно.
Maxim_Z
Цитата(spesso @ 5.10.2009, 13:04) *
Фиксатого можно.
Дмитрий25
petr0757
Естьт печатка в лойте
Хочется повторить
Как подрегулировать частоту
Camelot
неужели на тл494 так трудно печатку самому нарисовать, она же не так чувствительна к разводке земли как 3845, частота регулируется резюком и кондёром на пятой и шестой ноге, в даташите на 494-ю есть формула для расчёта частоты (это если нет частотомера).
толян
Ферриты беру на фирме ТЕРАТРОН.
www.teratron.com.ua/
Не в целях рекламы , а дабы ради ознакомления.
petr0757
Цитата(толян @ 6.10.2009, 6:03) *
Ферриты беру на фирме ТЕРАТРОН. www.teratron.com.ua/ Не в целях рекламы , а дабы ради ознакомления.
И в Россию высылают и как с оплатой?
Цитата(Дмитрий25 @ 6.10.2009, 0:21) *
Есть печатка в лойте
Camelot, правильно сказал. Кроме того никогда не делаю по печатке более одной партии, всегда приходится что то подвинуть, переставить, да и к тому же все резисторы, конденсаторы SMD во всех конструкциях.
KLIM
Вот обещанная трипанация модуля на 100А 1200 вольт митсубиши
Всё неестественно черное - это сгорание полупроводника. Верхний кристалл сгорел вертикально, нижний правее отгорел вывод.
Кстати есть возможность помочь достать на 600 и на 1200 вольт, да простят меня модераторы и админ icon_smile.gif. Все вопросы в личку. - Таможня даёт добро. ©
sorry
Подскажите какую длинну Сварочных концов делаете. Ведь для инвертера ( в отличии от бодика которому по барабану какая длинна ) это имеет значение.
толян
ЭЛЕКТРОВОЗ !!!!!!!!! Глянь в личку , тебе письмо.
Прошу уважаемую публику простить.
petr0757 на их сайте есть и телефоны и почтовые ящики , спроси , в кризис , я думаю будут обслуживать всех , мож у них представительство есть в России.
HEMELL
Не получаеться ни как у меня запустить Кольт 1300. Прошу помощи у тех, кто зтот апарат повторили. Я зтот апарат собрал (вернее его блок управления) чисто по статье Валодина (Радио нр.4 2007г.) Частота 50кГц. К.зап.- около 0,43 - 0,44.транзюки - ПД1. Исходные осцилы - вроде все нормальные (я выкладывал здесь на ветке) вроде нормальные. Душой чувствую, что что-то с ТТ. Резистор R13, R15 (Радио нр.4 2007г. рис.1) уже стоят 10ом и 00ом соответственно, а ток даже до 40 А. не доходит, ивообще, на регулятор (задатчик) как то не очень реагирует. Кто что подскажет, где порылась собака, и вообще, как сфазировать ТТ? Спасибо.
