Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
pansim1
Цитата(nikon @ 14.3.2013, 0:14) *
Вот это спасибо, ostap. удружил. А я то с дуру думал перемаркер и на 160 ампер впиндюрил по паре. Теперь понятно почему у меня радиаторы ключей холодные.
А частота у Вас сколько кГц??? Ключи ОЧЕНЬ медление. Не понимаю как они холодние icon_confused.gif:
Серёгин
Судя по всему где-то 50кГц и 0.44 заполнение , если не ошибаюсь ..Ну немного всё же ошибся icon_smile.gif
Wasiliy61
Цитата(KT117 @ 14.3.2013, 13:15) *
Вот вам расчеты витков для трансформаторов в косом. Подставляйте свои частоту, заполнение и смотрите витки.
Спасибо,хорошая програмка для подсчёта витков.Да витков малавато будет.
Серёгин
Ну и сколько витков насчитал ?
Wasiliy61
Если сечение Е70=6,67 то на 35 кгц получится 18витков.
Серёгин
Цитата(nikon @ 14.3.2013, 15:14) *
Начинающему просчитать все нюансы силовой электроники не возможно, а вот использовать те детали что указанны в схеме запросто, придерживайтесь рекомендаций автора и все, а уже что получилось испытывается на практике. И если не знаешь к примеру как работает снаббер то как можно рассчитать номиналы деталей к нему, а очень просто ставь то что ставит автор.
Так то оно так . Но зачастую , достать точно такие же детали , какие стоят у автора , не имеет возможности .Я свой первый Бармалей собирал из того что было у меня в наличии .А до ближайшего магазина , где есть детали 100 с лишним км ! А по поводу , тупо копируй и всё ,это только для тех , кто собирает на продажу и кому не очень интересны процессы происходящие в схеме . А мы просто радиолюбители , мы собираем ради удовольствия !
Wasiliy61
Полностью поддерживаю Ваше мнение, я тоже радиолюбитель со стажем, просто как-то сильно не доводилось с инверторами капаться. Мне тоже главное процесс в схеме и интерес к этому.
Wasiliy61
Подскажите пожалуста, сечение ленты также толщину на ширину.
Спасибо.
Серёгин
Спасибо.
Про какую ленту вы "говорите " ?
Wasiliy61
Медная полоса, которой был намотан транс. Я снял все обмотки и так без пропитки, просто прикинул, намотал на дно каркаса. У меня получилось почти 17,5 витков,А вторичка была на дне 4 витка и после первички 4. получается она была в двое .У меня в 2ое не хватит.Её размеры:толщина 0,5мм ширина 36мм=18.правильнно или нет.
Wasiliy61
Цитата(Серёгин @ 14.3.2013, 20:56) *
То есть , вы сначала первичку мотать будете , а потом вторичку ?
Думаю да, мне хочется эту полосу в дело пустить.А затем намотать вторичку, если так можно.
Серёгин
Можно по разному мотать .Я на первый Бармалей мотал сначала вторичку а потом первичку . Можно пол первички потом вторичку и снова пол первички .
Wasiliy61
Спасибо, я обдумаю эти варианты, но подругому с лентой ничего не получится.
Серёгин
Ну как успехи ? Намотали трансформатор ?
Wasiliy61
Добрый вечер. Транс пока не намотал, сделал только каркас, сейчас сейчас его склею. он-же был без каркаса-короче боковых щёчек небало. Сегодня привёз провод 2,44мм, думаю намотать им пол первички затем лентой вторичку, иопять пол первички. Если влезет.
Серёгин
Я думаю 2,44мм2 первички мало будет . Делайте в 2 провода 2,44мм2 первичку .
Wasiliy61
Я по тоблице посмотрел 2.44мм это 4,68-сечение, что этого маловато будет.
Серёгин
Я делал 4мм2 ,6мм2 и 8мм2 ,на первичку .Мне показалось с 6 мм2 лучше , 8 мм2 сложнее ,но если делать лиц с помощью малярного скотча то влезет всё , что хочешь! . вторичку 16мм2 не меньше ! , толкать !Хорошо бы это всё пропитать эпоксидной смолой. При этом ещё , что бы обдув был . На больших тока ,140-160 ампер и выше греется . При этом ,конечно ,зависит от рабочей частоты .
Wasiliy61
Обдув хороший винт 220в с того-же Кратона. У меня есть провод 3,5 мм, в сечении незнаю надо в таблице искать, но я дамаю 6 должно быть или около этого. Провод этот в нитке, но он грубоват ,с ним навенно будет тяжело работоть. А что косой серьёзно на 2-ух ключах может отдать 160а.
Серёгин
[/quote]
А почему бы и нет ? Смотря какие ключи . У меня 140 выдает , и это не максимум !
KT117
Почитайте про вариант косого под названием Липинский. Там транс мотается на торе, первичка диаметр 2,12мм, на 2 ключах 4PC50W легко отдает 160А. (И даже 180А может icon_smile.gif -но я не пробовал)
Монолит 3,5мм замучаетесь мотать на каркас-кувалда нужна в помощь icon_smile.gif , тогда лучше ПВ3 взять, квадрата на 4, снять изоляцию и одеть в термоусадку. И мотать легче и сечение нормальное.
Wasiliy61
Но в принципе я так и расчитывал сделать 140-150а. Ключи у меня 75а, есть ещё 50а.
И всё-таки я думаю защиту Негуляевскую попробовать.
Wasiliy61
Да где-то мне попадался Липинский сварочник. Но на торе наверно КПД больше.
nikon
Мотайте своим проводом 2,44 и на заморачивайтесь. Защита реле на выходе что ли?
KT117
icon_smile.gif Хм. Где то попадался. Наверное в этой ветке чуть раньше по времени? icon_biggrin.gif
http://www.electrik.org/forum/index.php?sh...44&st=11439
Я на одного косого мотал транс на Е65 , первичка монолит 2,12мм, 14,5 витков, вторичка ПВ3 16кв.мм, без изоляции в термоусадке, 5 витков. На частоте 55кГц спокойно отдает 120А. Правда греется. Феррит. Не Епкос, какойто другой. И в связи с этим вопрос-как сделать контроль температуры транса? Простое термореле не катит-нагревается токами ВЧ. Или я туплю и все же можно прикрутить термореле к обмотке?
Wasiliy61
Да защита от кз,реле блокировки электролитов с выхода.
Серёгин
Греется ,значит насыщается феррит . Витков в первичке мало .Лучше перемотать транс. Я делал не Е55, сотку ,частота 47.535 ,15 витков . На ХХ немного греется ,за 30 минут , 40 градусов . Я с него вытянул 120 ампер.
KT117
По расчетам-получается с запасом. Частота 55000Гц, Кзап=0.42.
Меня интересует возможность контроля температуры транса. Так сказать-пассивная защита от остановки ветродуя. Может прикрутить одноразовые термопредохранители? Там корпус алюминиевый и не должен нагреваться токами.
Серёгин
А как насчёт вот этих ? http://www.micel.ru/one.php?id=787425
nikon
Тогда придется вместо резистора зарядного ставить конденсаторы, монтаж раздувается. Резистор при размыкании сгорит, сила ведь под нагрузкой.
KT117
Прикручивал. Такое ощущение-что они нагреваются сами токами ВЧ. Проверял температуру обмотки внешним термометром на ds18b20 -термореле срабатывало градусов на 20 ниже своей заявленой температуры
nikon
LM 335 и TL 431 простенькая схема от Лисова, можно паралелить сколько хочешь датчиков.
Wasiliy61
Да там стоит кондер 4 мкф и 5ватт 10ом.
nikon
А кроме этой защиты что нибудь есть, просто мне кажется в силу своей энерционности и скорострельности это не серьезно
Серёгин
Можно сделать антистик. Проверенно , работает на 2 аппаратах.
nikon
Я тоже склоняюсь к электронной защите чем к механическому реле. Не знаю уровня вашей подготовленности, но скажу, я год боялся начать собирать управу YIRIYя но когда собрал и прошил сам черпая данные из форума, и знаете для себя решил что другого делать не буду.В ней есть все что необходимо, и не так она страшна как кажется на первый взгляд.
Wasiliy61
Он работает по 1 ноге управы,я ток понял. Похожий блочёк у меня есть готовый, только там 1 транзистор, оптрон тоже стоит.
Серёгин
А можно взглянуть на то , про Что вы говорите ? на управу YIRIYя
Wasiliy61
Посмотрите такой пойдёт -он у меня готовый.
Серёгин
Да , он самый .Только надо между коллектором и 1 ногой микрухи сопротивление подстроечное поставить
на пару килоом
Wasiliy61
на пару килоом
Да всё понял, резистор для настройки сробатывания. Вы советуете его поставить, он наверно надёжней реле.
nikon
на пару килоом
Для чего? Мне кажется Транзистор открылся коротнул вывод микрухи, а что регулировать там? А вот вместо R1 подстроечник чтобы регулировать порог срабатывания, другое дело.
Серёгин
Ну у меня на 2 аппаратах стоит .На одном , правда долго настраивал ,не до конца шим глушил .
Люди рекомендуют ставить .
Wasiliy61
Благодарю,приятно было пообщатся.
Наверно тоже правильно, настройка должна быть на базе,я не глянул на схему-просто знаю что он готовый.
zario
У меня на Е55 при частоте 35 кГц была так: первичка 30вит. (1,9кв.мм) вторичка 10вит (6,5кв.мм). у вас как то странной количество витков для ваще частоту, честно говоря просто ФАНТАСТИКА
З:Ы: чёта последние время форум ложными информациями заполняется
KT117
Ну почему ложная информация? Вы возьмите и просчитайте число витков для транса на Е55 на частоту 47335Гц
Пример http://clip2net.com/s/4L5LqT
А вот пример для частоты 35000Гц
http://clip2net.com/s/4L5WXT
Дело в самих датчиках-как и что прикрутить к обмотке транса что бы сам датчик не грелся токами ВЧ?
zario
А вы сами делали реальный транс по резултатам этой проги? И аппарат без проблем работает с таким "суперкоротким" трансом...? В днях я попробую пересчитат витков для Е55 по этой проги, и посмотрю по лысому что там будет твориться. Резултаты отпищу если кому будеть интересно
KT117
Я-делал такой транс. И можете пересчитать в этой проге трансы для всех схем на этом форуме-результаты совпадают. Но и Ваши данные тоже будут очень полезны с практической точки зрения.
DANTIST
Серёгин, по какой формуле ты считал витки? И сколько, интересно, ты заложил размах индукции. При 0,4 уже получается 18 витков. А при норме (как-то этот вопрос обсуждался недели 2 подряд) 0,2, получается аккурат 32 витка. При твоих витках транс за минуту будет как кипяток. А у тебя за 30 минут нагрелся только до 40 гр. Да и вообще аппарат работать не будет. Ты, часом, в сообщении ничего не перепутал?
Для Е65 при 50 кГц 15 витков первички - в обрез.
nikon
А сколько тока с него снимаете? Просто лежит такой сердечник и провод 1,6 диаметром есть и шинка для него подходящая по габаритам, все хочу малыша собрать,руки не доходят.
