Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
Dimon4ig
спасибо
Dimon4ig
Я только что пришол к выводу, что ослика моего нужно колибровать, поэтому наличие сигнала и его форму я могу отслидить а вот показания... Поэтому у меня просьба к Вам oleg1ma, раскажите пожалуйста как расчитывать емкость конденсатора, сопротивление резистора и количества витков для трансформатора, или скажите какие я данные получу при 4к7 и 4700пФ, и какие моточные для этого нужны?!
oleg1ma
С конденсатором ошибся, какую частоту хотите и на каком сердечнике будете мотать?
golub
Окалибровать более менее можно довольно просто, открыв ваш системник.Частота часового кварца возле ЮМ- 32768. ну а по напряжению- Любое питающее вашего БП в том же системнике, лучше +5в.
А по второму, вот
Dimon4ig
мотать буду на е70. транзисторы у меня 4pc50w,поэтому частоту исходя из них,какую посоветуете,ну и коофициент заполнения тоже подскажите какой лучше 0,44 или 0,45.
по поводу ослика: спасибо за идею с кварцом,но вот только колибровать я пробовал по блоку питания от компа,но к примеру отколибровав на приделе 1в/дел, переставляю на другой придел и измерения уже не ветны( на моем ослике есть колибровка в приделе измерения "4 деления" вроде как от внутренего генератора,но как ей отколибровать я незнаю(
oleg1ma
Dimon4ig, частотозадающую цепочку поставь такую:резистор 2к4, конд 6800пф, частота будет 50кГц, зап. 0.43, больше и не нужно.Тр-тор мотай 15/5, зазор по 0.05 под боковые керна.
Dimon4ig
oleg1ma,спасибо за помощь,буду собирать.
tranzistor3102
всем здраствуйте в бармалее 165а будут работать транзисторы IRGP4068D icon_biggrin.gif
KSV
Ставил в аппараты Юрия, работают отлично.
Dimon4ig
Всем добрый вечер!
Уважаемые знатоки,подскажите, достаточно 860мкГн для первичной обмотки?
oleg1ma
Достаточно.
Dimon4ig
Благодарю.
Еще вопросик: для выходного дроселя 42 мкГн хватит?ато шина закончилась...
oleg1ma
Хватит, какой сердечник?
Dimon4ig
от строчника ТВС-90ЛЦ2-1
Dimon4ig
Собрал все в кучу, включил(без силы), смотрю осцилограмы на стабилитроне (затвор-эмитер):
Такое на обоих ключах.
Только вот проблема одна есть, жестко греются полевики драйверов, сами стабилитроны, резисторы на 200 Ом2Вт и резисторы обвязки драйверов на 47 Ом. Это нормально?
oleg1ma
Что-то у тебя опять напутано, щупы правильно подсоеденял? земляной на змитер, сигнальный на базу?Сними оцилку на резисторах те что 200 Ом сигнальный щуп цепляй на тот вывод обмотки где точка по схеме.Резисторов на 47 Ом в драйверах нет, есть на 4.7 Ом.
Dimon4ig
Да, действительно,перепутал, не 47 а 4,7 Ом
Вот:
Земляной щуп ставил на конец обмотки, красный(сигнальный) на начало.
я так понимаю перепутаны местами начало и конец 2 и 3 обмотки?
из-за этого может грется все вышеперечисленное?
oleg1ma
Да нет непопутаны, оцилка нормальная, на втором резисторе такая-же?Какие стабилитроны и полевики стоят?И какое питание дежурки?
Dimon4ig
да, на втором такаяже. Полевики irf630N, стабилитроны на 15В, если продавец не перепутал, но меня смущает то что на осцилограмме на стабилитроне амплитуда значительно меньше чем на выходе ТГР,хоть у меня и ослик не отколиброван но разница заметна. Если стабилистрон не тот, и нагрев от сюда может быть?Я правильно понимаю? Питание дежурки это что такое?
oleg1ma
Питание дежурки, это питающее напряжение твоей управы.Проверь напряжение стабилизации твоих стабилитронов.Выпаяй один, до катода припаяй сопротивление 300-1к0 и подключи до блока питания 20-30вольт и измерь напряжение на стабилитроне.Так узнаеш что тебе продали.
Dimon4ig
напряжение дежурки 14.22в. сейчас проверю стабилитрон.
странно,но стабилетрон действительно на 15 вольт. подскажите,куда дальше смотреть?
oleg1ma
Сколько витков на ТГР
Dimon4ig
в тгр по 35 витков. вопрос уже решился icon_smile.gif у меня неправильно включены стабилитроны были, они аказывается не двух анодные были,поэтому их включение имело значение.перепаял, нагрев ушол везде кроме 200 ом 2вт,но и там стал поменьше,и осцилограммы стали вроде нормальные. огромное спасибо за помошь,самбы долго разбиралсяб! завтра выложу осцилограмму, проверите?!
Dimon4ig
а вот и осцилограмма:
заодно отколибровал ослика по напряжению, так что там теперь действительно 15в(1 в/дел стоит),и частота получается 51кГц и кооф. заполнения 0,435.
oleg1ma
Ну теперь лучше, можно двигатся дальше.
Dimon4ig
Добрый день!
собрал сегодня все в кучу, силу подал 24в от блока питания, вроде все работает,на выходе при этом 4 вольта, включил лампочку от поворотника на выход,горит в пол накала, осцилограма на выходе(на лампочке):
далее смотрю осцилограмы на эмитор-колектор, обе по форме одинаковые, вот такие:
далее поставил токозадающий резистор на 10 Ом, закоротил выход, сигнал схлопывается гдето в 3 раза.
что можете сказать по поводу формы сигналов?
oleg1ma
Вижу сигнал только один. Сними к-э и с выхода без нагрузки не путая щупов.
Dimon4ig
чтото картинка пропала. вот на колектор эмитер,на обоих ключах одинаковая:
а вот на выходе без нагрузки:
что скажете?
oleg1ma
Нормально, бп на 24в убирай, вместо предохранителя что на питание силы припаяй лампочку 40-100ватт и включай в сеть на прямую, и измерь на ней падение напряжения.К выходу ничего не подключай.
Dimon4ig
подключил все как сказали,вольметр паралельно лампачке(галогенка 75вт 220в), показует 9,5 вольт,питание латером вел от 120 до 220, на выходе сварочника при этом мультиметр показует 49 вольт.
от трансформатора вроде звук есть тихий тихий,на шум воды или шелест листьев похожий.какие дальнейшие действия?
RUS5610
Запитай силу от 24в,руль на мин.тока и замыкай выход тонкой проволочкой 0,2-0,3мм.Если при замыкании писки и визги то меняй фазировку ТТ.
oleg1ma
Теперь нужно аккуратнее.Дроссель уже стоит?Убираем лампочку ставим предохранитель на 20а.Токозадающий резистор ставим 2-3ома.Ставит крутелку на мин ток и цепляем балласт и смотрим на контрольный амперметр и убеждаемся, что ток регулируется, крутя крутелочку, если ТТ сфазирован правильно.Без дросселя ничего не замыкай.
mono
Dimon4ig, на холостых должна быть мёртвая тишина, иначе на нагрузке она превратиться просто в мёртвую, странно то, что такой маленький ток намагничивания, по оскам мне показалось, что он должен быть больше, но если так то хорошо, но ищите проблему шума.
Dimon4ig
уже пробовал при 25
4в замыкать выход, писков не было,на минимуме маленькие искры пробивали,при увеличении тока крутилкой искры возростали.
посмотрел осцилы на 220 в на э-к,так вот на ниженем вот такая:
а на верхнем такая:
а так ведь не должно быть?
дросель стоит, амперметра на 20А для операции с нихромом хватит,или шунт искать?
да шум вроде не сильный,только если прислушиватся то в далеке шелест еле еле есть
oleg1ma
Оцилки нормальные, с верхнего просто наводки идут. Нужен шунт, калибровать-то как-то нужно сварочник по максимальному току.Шелестеть может и дроссель.
Dimon4ig
только что закончились 40 минут,которые я гонял аппарат на хх, по результатам радиаторы транзисторов еле еле теплые, тгр слегка теплый, полевики драйверов тепленькие как и полевик раскачки тгр,горяченькие резисторы и диоды рцд цепочки ключей. силовой трансформатор слегка теплый,вроде нечего сильно горячего не было.
предохронителя на 20а щас нету,на 25 не много будет?
напомните пожалуйста как шунтом пользоватся.
oleg1ma
Какой шунт есть и что на нем написано?
Dimon4ig
поставил резистор 3 ом, включил, минимальный ток 6,5А, начал поднимать,в районе 20-30А, гудел дросель,дальше перестал гудеть, на максимуме удалось получить 66А. вот теперь думаю: получится ли с резистором 1,6 Ом выжать хотябы 140А?
oleg1ma
На мин токе зделай КЗ, потом отпишись.
Dimon4ig
сделал,все нормально,искры небольшие летят. еще заметил чтона самом минимуме задатчика подгуживает транс и дросель,стоит на 2-3милиметра повернуть его звук проподает. вот сдесь видео где слышно этот звук: http://zalil.ru/34124421
Dedan
Цитата(Dimon4ig @ 29.12.2012, 21:43) *
сделал,все нормально,искры небольшие летят. еще заметил чтона самом минимуме задатчика подгуживает транс и дросель,стоит на 2-3милиметра повернуть его звук проподает. какие дальнейшие действия?
А потенциометр не глючный? У некоторых как раз в крайних положениях плохой контакт.
oleg1ma
Dimon4ig, все получится.Про дальнейшие действия написал на прошлой странице, отчет неполучил
Dimon4ig
может и потонциометр,поищу такойже,поменяю.
дальше ставить штатный токазадающий резистор (1,6ом),и опять с нихромом и шунтом повторить операцию?
oleg1ma
Зделай КЗ на мин. токе на задатчике и напиши какой ток, при резисторе 3 Ома.
Dimon4ig
сделал, получается 36 А.
oleg1ma
Теперь измерь напряжение какое у тебя на твоем балласте при максимальном токе.
Dimon4ig
померял, 31в
oleg1ma
Ток был 66а?Если так то балласт у тебя почти 0.5 Ома, теперь проделай тоже самое с замером напряжения но на половине балласта.
Dimon4ig
прошу прощения за отсуцтвие.
на половине баласта на максимальном токе 15 вольт
oleg1ma
А ток то какой?
