Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
Wasiliy61
Цитата(Basill @ 3.7.2013, 16:27) *
По поводу полиэстеровых CL20 - видимо, это аналоги наших лавсановых К73-17, К-73-11, при баянировании работают в качестве блокировочных неплохо, многие форумчане подтверждают это.
А мне что-то пересоветовали ставить вот эти в первого бармалея, по сейчас валяются.
p210
Цитата(pansim1 @ 3.7.2013, 12:14) *
Для ИР2153 пауза 1.2мкс
Вы не совсем правы. Это типовое значение. А может быть, как в даташите указано.Нажмите для просмотра прикрепленного файла
oleg1ma
Цитата(Basill @ 3.7.2013, 12:27) *
при этом на одну "мину" (как правильно выразился коллега несколько постов выше) в аппарате меньше. Естественно, имхо.
Ставлю Х2 на ключи, так-же китайские красненькие, все работают нормально, если нормальная разводка.Если-бы были минами, то поверьте не ставил-бы, аппаратов уже наклепал более 40шт.
От частота не зависит
А вы игрались с частотой?Попробуйте.
Wasiliy61
Нажмите для просмотра прикрепленного файлаВот коллеги, готовый шим с силовой частью, осталось впаять блокировочные кондёры. Как вы думаете 1,47 мкф хватит, потому что в блоке питания на электролитах тоже будут стоять блокировочники. Я бы поставил 2 кондёра по 1мкф, но он только один, А баян лепить-места маловато.
Basill
Охотно верю, я сам вначале поставил их в Юрины аппараты на Атмеге (стоят-то ерунду, и везде есть), никаких вопросов не возникло. Потом подвернулась оказия, и пришла свежая жменька синеньких MKP 654-х эпкосов (заказывал для несварочной темы), заменил Х2 на них по причине своих "внутренних побуждений", начитавшись англоязычных статей о внутреннем устройстве и принципах работы X2. Знаете ли, иногда, внутренние "тараканы" и прошлый опыт мешают взлянуть на некоторые вещи свежим взглядом icon_biggrin.gif Но если статистика говорит, что всё работает, то факт есть факт. Меня интересует только отношение "серийщиков" к этому моменту, не более того.
P.S. Если разводка силы правильная, то там достаточно импульсного МКР 0,22 мкф (например, серийные РитмАрк, Тельвин...).
oleg1ma
Пока, что мои тараканы меня не беспокоят, за мой выбор и продолжительная эксплуатация девайсов тому подтверждение.Применяю в основном такие.
pansim1
[quote name='oleg1ma'
[/quote]
Олег, специально для тебя поигрался с ИР2153. Результат на видео хорошо виден. Частота меняю в два раза /примерно/ а мертвое время стоит как вкопаное icon_biggrin.gif
Посмотрите - думаю вопросы не будет...
http://www.youtube.com/watch?v=sjB6OvffV34...eature=youtu.be
oleg1ma
Какая частота и как ее изменяли?
pansim1
Частота 60 - 120кГц /примерно/
Меняю резюк на 2-я и 3-я нога ИР2153, точнее там ставил потенциометр.
oleg1ma
Cогласен, беру свои слова назад, сам только, что проверил на полумостике, стоит одинаково 1.2мкс в диаппазоне 20-200кГц. icon_biggrin.gif
pansim1
Kalin Ivanov
пожалуйста, скажите мне, какие данные есть трансформатор БП по етава схема.Уменя ест провод 0,19 и 0,32.какой зазор ?
Я делал Липина "дешевый сверкальник".
tolik-gsm
Зазор по индуктивности первичной обмотки, остальные данные на схеме смотрите внимательно.
KT117
Kalin Ivanov
Да ,я запустил бармалея,работает харашо.Я навил БП для липина -74 витки первичка,но получил 1000мкН а не как 1500,зазор у меня 0,5!
oleg1ma
Зазор уменьши и получиш 1500мкГн.
Kalin Ivanov
он становиться 1450,может ли так?
oleg1ma
Так и оставь.
Kalin Ivanov
спасиба. Я навил ТГР с провод 0,35 .Первички 29 витки ,вторички 34 витки.Зазор 0,5.
получил первички 150мкН ,вторички 210мкН.
oleg1ma
Цитата(Kalin Ivanov @ 5.7.2013, 22:53) *
Зазор 0,5.
Сделай 0.1мм
Kalin Ivanov
ok. oleq1ma.
Kalin Ivanov
oleg1ma , я полочил на гейта irf630 такая осцилограма . Честота уменя 41,60кГц ,коефициент получил около 0,458.
осцил. 5в./5мсек .
Можно также остаются.
oleg1ma
Да.
Kalin Ivanov
я уменшил на 0,44 честота 41,37кГц ,осцилограма правилная ли ?
П.п может ли на такой ферит делает силой трансворматор и данние одинаковы ли они как на схема указано!
KT117
Kalin, намотайте на этот феррит 10 витков провода, замерьте индуктивность и определите начальную магнитную проницаемость програмкой мю-Калькулятор или другими в сети, и если коэффициент мю приближается к 2200 ( материал №87 от Епкос) то по формуле расчета трансформатора найдете к-во витков для этого кольца для своей частоты
Для быстрого нахождения частоты по осцилограмме я пользуюсь таким файлом
Wasiliy61
Ребята, упустил из виду и не заказал, чем можно заменить P6KE200 в блоке питания.
Jorg63
RCD цепочкой. конденсатор на 0.63-1kv напряжения. вместо сапресора ставиться RСцепь. Резистор подобрать можно чтобы на канденсаторе было напряжение 160-190 вольт.
Kalin Ivanov
Мая осцилограма правилна ли ,дайте ваше мнение?
Wasiliy61
Jorg63, большое спасибо.
DANTIST
Это какое-то дежавю, блин! Не так давно мы говорили, что Р6КЕ200 нужно заменить на 1,5КЕ200. И про RCD цепь тоже...
p210
Цитата(DANTIST @ 7.7.2013, 20:35) *
Это какое-то дежавю
KT117
Kalin Ivanov
Не так много как у бармалея ,поэтому я хочу ваше мнение.
oleg1ma
Правильная, двигайся дальше.
and_w
Всем добрый день! Наконец-то доделал свой сверкальник на 160А. Пока , правда сильно не насиловал, но первые результаты впечатлили- хороший поджиг, мягкая работа, четкое отрабатывание всех функций.. Да, забыл сказать- это не совсем чистый Бармалей, вернее это Бармалей+ управление от аппарата yjriy. Просьба не бросаться электродами, но делал я его без осцилографа.... Нет пока такого в наличии... Но это временно. Просто читал форум с первой страницы и делал все по рекомендациям, начиная от БП на TOP224Y, который, кстати завелся с пол-пинка, заканчивая силой и силовым трансформатором. Делал этот аппарат в расчете на деревенскую электропроводку.
Нажмите для просмотра прикрепленного файла Нажмите для просмотра прикрепленного файла Нажмите для просмотра прикрепленного файла Нажмите для просмотра прикрепленного файла
И как результат-сварка топора icon_smile.gif, правда сварщик из меня как из г..на пуля.......
Спасибо всем форумчанам, кто отвечал на мои, может быть дурацкие, вопросы!
RUS5610
Во молодец!
Kalin Ivanov
Цитата(and_w @ 8.7.2013, 9:31) *
Всем добрый день! Наконец-то доделал свой сверкальник на 160А. Пока , правда сильно не насиловал, но первые результаты впечатлили- хороший поджиг, мягкая работа, четкое отрабатывание всех функций.. Да, забыл сказать- это не совсем чистый Бармалей, вернее это Бармалей+ управление от аппарата yuriy. Просьба не бросаться электродами, но делал я его без осцилографа.... Нет пока такого в наличии... Но это временно. Просто читал форум с первой страницы и делал все по рекомендациям, начиная от БП на TOP224Y, который, кстати завелся с пол-пинка, заканчивая силой и силовым трансформатором. Делал этот аппарат в расчете на деревенскую электропроводку.
Где может найти "управление от аппарата yuriy".Я хочу сделать для моей Бармалей?
Basill
Соседняя тема на этом форуме ЗДЕСЬ
Kalin Ivanov
oleq1ma, может ли такой ферит для силовьй трансформатор для Липина? http://www.ebay.com/itm/55mm-Outside-Dia-I...=item43bbd7081d
и для дроссель у меня здес такой ферит он на фото?Нажмите для просмотра прикрепленного файлаНажмите для просмотра прикрепленного файлаНажмите для просмотра прикрепленного файла
oleg1ma
Ферит подойдет, а какие размеры кольца на дроссель?
Kalin Ivanov
Как на схеме, R55x32x18 ! Скажи меня що значит P4 на ферите?
У тебя какой провод для дросела использовать?
Зазор на етой ферит таг-3,5мм - как на схема ?
oleg1ma
Р4 - марка ферита, провод на дроссель 10-12мм2.Для кольца того, что на фото, зазор ненужен.
Kalin Ivanov
Спасиба, я делаю дросел на етой ферит без зазор!
oleg1ma
То что на фото - это не ферит, а распыленное железо.
Kalin Ivanov
понимать!
Kalin Ivanov
Oleg1ma , на етой ферит для 1 витка ест 40мГн? ферит скачанный от честотньй преобразовател для асинхроньй двигател,он был на входа преобразователя где соединяет питание 380 волта! Нужно ли делаю зазор?
oleg1ma
Цитата(Kalin Ivanov @ 10.7.2013, 10:21) *
от честотньй преобразовател был на входа преобразователя где соединяет питание 380 волта! Нужно ли делаю зазор?
Ну если это ферит, то конечно зазор нужен 3.5мм.
Basill
Kalin Ivanov, у вас полная каша с данными.
Во-первых, я бы не связывался с покупкой кольца по указанной ссылке на e-bay.
Не понятно, из чего сделано кольцо - из феррита (какой марки?) или из распыленного железа с низкой проницаемостью (подчернуто красным в скрин-шоте).
Судя по цвету и размерам -из феррита, правда, редкого размера - только Cosmoferrite такое предлагает в каталогах (подчеркнуто красным в таблице).
Распыленку такого размера не встречал. Но тогда как быть с противоречиями в описании?
Во-вторых, для одного витка 40 мГн - это 40000 мкГн, вы хоть сами понимаете, что вы намеряли? Даже если кольцо на вашем фото из феррита с высокой проницаемостью (для входных фильтров) то индуктивность одного витка (параметр AL), по таблице для данного кольца - 14 мкГн (или 14000 нГн) по номиналу.
Wasiliy61
Уважаемые форумчане, кто ставил реле от автомобиля для блокировки литов, и какой марки или серии. Я купил реле для стартера,но ставить не стал, так как ток потребления обмотки меня ошарашил, аж 350ма и греется как хрен знает что.
ostap
Стоит в 3-х изделиях для блокировки зарядного резистора - проблемм не наблюдалось - ток потребления и температуру не мерял icon_smile.gif
