Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
aleksandr64
Какое ещё время восстановления если они стандартные выпрямительные.
spesso
Частота кстати указанна.
Mazik
Цитата(AS65 @ 21.7.2011, 10:43) *
Mazik
Очень зря не хочешь мерять,при 53вольтах ХХ импульс даже без иголки чуть больше 100вольт,
+ иголка = -диоды.
Ну очень они не любят выбросы.
В общем меряю стрелочным китайцем - 65 В (а 53 В - это я ошибся оказывается, разучился стрелочником пользоваться icon_biggrin.gif ), осцилом на выходе смотрел идет ровная полка 50 В примерно и иголка еще сверху примерно 15-20В, при включение - вольтодобавки китаец меряет примерно 120 В, а если по осцилу смотреть, то там на волны похожи импульсы примерно со 120 вольтовой амплитудой, в городе на 230 В пробовал варить со 120-ти зажигается отлично (притащил кувалду ржавую из сада для этих целей), думаю в саду на Uвх = 200 тоже будет хорошо, правда к столбу буду подключаться на прямую скорее всего, вчера аркфорце ваял, подключил крутил-настраивал-варил не понял разницы вообще, убрал нах ее, оставил только антистик - это вещь! Спасибо за внимание.
Всем доброго времени суток, вопрос есть такой:
Был макет сварочника, проверил варит, на балласте гонял, решил собрать все в корпус, собрал проверил - все ок, силовая плата с ключами находится внизу корпуса дорожками к нижнему основанию на расстоянии от онного где то 1,5 см, так как я собрал все капитально и разбирать совсем не охота, как эту плату снизу покрыть лаком? Голову уже сломал. Есть автомобильный акриловый лак в баллончике и есть термостойкий КО-85 он жиденький такой пойдет наверно в ручной брызгалке типа для цветов, если брызгать в промежуток между корпусом и платой то интересно на дорожки что нибудь попадет?
толян
Цитата(RA6XOJ @ 23.7.2011, 9:09) *
кому интересно
А ведь конструктив от китаёза не отличается сильно. Та же куча проводов.
Инсекторату --- Ваш , наверно получше будет.
кабельщик
Нефотогенично выглядят последствия самореза, закрученного в текстолит с торца (опосля слов "...все сделано культурно-аккуратно...", примерно на 5-й минуте). Если ролик снимался аки реклама - это место надо было вырезать...
Д713
скажите спасибо,шо не загнутый гвоздь.
и брызгает аппаратик чрезмерно,и "резальщик" как-то с третьего раза дугу зажигает,на 200А-то..
вобщем поспешили хлопцы с обнародованием рекламы,шо эквивалентно обратному.
прежде чем что-то собирать,в первую очередь следует подумать над тем,как это разбирать.
если при ремонте требуется разборка до атомарного уровня-это уровень исполнения.
толян
Да , брызгает , конечно очень сильно . Дособираю следующую 250-тку , сниму , и покажу как надо резать , или варить . кстати с модуляцией . вернее как у меня получится и резать и варить.
Д713
давай Толян,на запорожских казачков надёжи нету.
Mazik
Всем здравствуйте, домотал дроссель до 120 мкГн, варить стал мягче и форсировку прикрутил обратно, на минимальном токе дуга не тянется и двойкой стал варить нормально, во всем диапазоне регулировки тока - меньше брызгать стал. Хотел у народа спросить: если во вторичной цепи отключить диоды, а оставить дроссель (типа переменка для люминия) и пробывать поискрить, что с аппаратом будет, на 36 вольтах на вход подавал - ничего не понял? Наверное можно к бармалейнику аргонную горелку прикрутить чтобы нормально варить или нет? И еще вопрос: как прикрутить стабилизацию вых. напряжения (ОС по напряжению) к UC3845? Заранее благодарю. С уважением.
AS65
Mazik
По поводу аллюминия слишком легко отделатся хочешь.
На форуме всё есть только читай.
А по поводу ОС по напруге оптопара по 1 ноге решит твою проблему,
смотри чтобы тебя за такие вопросы в угол не поставили icon_biggrin.gif .
Mazik
Цитата(AS65 @ 25.7.2011, 14:30) *
Mazik
Спасибо. По поводу люминия - нужно друние ветки смотреть наверное, а то в бармалейной ветки не нашел вразумительного ничего прочитав его с 1-й части и до 439 страницы 8-й части. Конечно сильно не пинайте но на первой ноге какой диапазон напряжение должен быть? Так я и забыл уже у меня к первой ноге антистик прикручен, не получится сделать ОС по Uвых icon_sad.gif
AS65
Mazik
Ну почему же не получится, посмотри может тебе это поможет или выложи свою схему управы
чтоб понятно было что там у тебя.Нажмите для просмотра прикрепленного файла
Или вот этоНажмите для просмотра прикрепленного файла
Mazik
Цитата(AS65 @ 25.7.2011, 15:21) *
Mazik
Доброго всем времени суток!
Схема и управа - классика Бармалей-165 несколько изменены моточные данные да баян по два полтинника, частота примерно 35-37 кГц, нагрузочный резистор ТТ - 1 Ом, к схеме на 1-ую ногу прикручен антизалипин с польской схемы бармалея (может это они с чьей нибудь слизали) плюс подключен на верхнюю ногу задатчика тока форсировка из схемы - Kosoy-120. Я когда мотал силовой транс мотанул сервисную обмотку для всяких нужд, сделал из неё вольтодобавку для плохой сети, включается через кнопку, хотелось бы конечно автоматизировать процесс и отказаться от вольтодобавки поэтому я и спрашиваю про стабилизацию Uвых ХХ. Вот и думаю - если еще один оптрон прицепить к 1-й ноге получиться наверное каша. Кстати дроссель смотал до 30 мкГн, до этого домотал до 120 мкГн, - стал варить по взрослому - не понравилось icon_sad.gif, ощущение как будто у дуги температура стала меньше, до этого был 70 мкГн так двойкой на малом токе мелочь вообще невозможно было варить дуга тянется как сопля на рукаве, 3-й и 4-й нормально было, сейчас с 30 мкГн всеми электродами спокойно варит и дроссель намного меньше стал греться icon_biggrin.gif .
А почему интересно эта ветка совсем стала неактивна? Я начинал читать с начала так там активность ого-го была какая, а сейчас такая низкая, непонятно конечно почему так icon_sad.gif, есть конечно мысли некоторые по этому поводу, если можно уважаемые жители форума хотелось бы услышать Ваше мнение по этому поводу. Ну и по поводу стабилизации помогите пожалуйста, можно конечно попробовать через свкад прогнать, но это для меня сложновато пока, надо сидеть с ней разбираться - я больше практик.
STASKIN
Эт наверное потому что нужно и в соседние ветки заглядывать,народ рассредоточился по веткам и огородам icon_biggrin.gif ,да и много интерестных конструкций там есть. Почитайте,поглазейте-половина вопросов отпадут,появятся новые интересы,идеи. Форум на месте не стоит-форум ушел от Вас далеко вперед! icon_sad.gif
Mazik
Вы правы конечно, бармалея начал собирать более 4-х лет назад, деталей купил, управу собрал, как раз в это время у меня родился ребенок, все как то закрутилось завертелось, бармалея я забросил, много конечно за это время воды утекло и вот только сейчас (появилась острая необходимость в сварных работах) да и интересно самому, месяца 2 назад продолжил собирать (сейчас собрал уже) и заодно форум читаю, так что наверное я отстал от форума да и от жизни, сейчас наверное все уже двухтактники и резонансники собирают под 200 кГц ампер наверное на 350 размером с чуть больше коробка и CPU всем процессом сварки рулит icon_biggrin.gif ... А не подскажите малость отставшему, на каких ветках сейчас самые плюшки и все самое интересное?
AS65
Mazik
По поводу второй оптопары - каша не получится каждая будет отрабатывать своё и главное в разное время.
Одно не пойму что ты там собрался стабилизировать или хочешь ХХ понизить чтоб дуга не тянулась?
У тебя вторая нога на земле? тогда между землёй и первой ногой включай оптопару и рули ей с выхода через резюк + стабилитрон.
Mazik
Цитата(AS65 @ 27.7.2011, 7:36) *
Mazik
Хочу чтобы Uвых ХХ было примерно одинаковым при Uпит от примерно 180 до 250 В, чтобы отказаться от схемы вольтодобавки и использовать доп обмотку для разгрузки дежурки питающей дополнительно 4 пропеллера. А вторая нога подключена к задатчику через резистор 33 кОм плюс диод анодом на землю - как в схеме бармалея. Показал бы, но с работы нельзя ничего загружать.
AS65
Mazik
Ну и рули по первой.
Mazik
Цитата(AS65 @ 27.7.2011, 8:30) *
Mazik
Как то мелькала схемка бармалея на форуме где если я не ошибаюсь красным шрифтом было подписано то ли на 1-й или 2-й ноге уровни напряжения, и если можно ссылочку (тоже мелькала здесь) на русский шиит UC3845. С уважением
AS65
На 3845 русского даташита нету.
По моему таймер 555 первую ногу садит на землю при блокировке инвертора,туда же и оптопару
вешай,а с напряжениями не заморачивайся ,ссылок у меня нет на память не помню,или посмотри
даташит если не лень icon_biggrin.gif .
Basill
Цитата(Mazik @ 27.7.2011, 8:00) *
русский шиит UC3845
Mazik
Ладно не буду заморачиваться по поводу стабилизации ХХ, вольтодобавка есть и хватит.
Тут вчера один кекс пронюхал что я собрал инвертор, а он недавно купил себе PICO 180, и решили мы как говорится померяться х... т.е. устроили тест-краш-драйв. Исходные данные:
Я, этот кекс и профессиональный независимый сварной, отрезок рельса, 3 отрезка трубы 150-ки, по 10 электродов 4-ки на каждый аппарат, Напряжение сети 225 В, выходной ток установили на обоих аппаратах 180 А.
1-м начали с пико отключение по перегреву на середине 5-го электрода(не рельсе все электроды подряд, с паузой на замену) далее сварка двух отрезков трубы остатками электродов не спеша.
На моем аппарате сварной сжег 10 электродов (не рельсе все электроды подряд, с паузой на замену) , ну и сварка отрезка трубы еще 3-мя электродами не спеша, перегрева нет. Субъективное мнение сварного следующее:
пико вроде мягче варит меньше брызг, провар средне, по поводу моего сказал - немного жещще брызг стока же провар намного лучше, вообще говорит моим приятнее варить.
P.S.
Сам пробывал буржуйским варить - я конечно не профессионал с многолетним стажем, но варить умею, раньше варил тока бодиком, мой получше будет если еще учесть ПН моего аппарата, а о перегреве он вообще никогда не слышал даже когда я им кипятил ведра воды на балласте, а если сравнивать стоимость вложения в аппарат, количество морального удовлетворения при сборке аппарата и стоимость PICO 180, то последний тихо курит в сторонке... это конечно чисто субъективное ИМХО. Сообщив дополнительно человеку с пико, что за те деньги которые он отдал за свой инвертер, - я соберу как минимум 5 таких как у меня, он совсем поник настроением и тихо ушел.
Огромное спасибо всем участникам этой ветки, и всему сайту! Я рад на все стопитсот % brake.gif
Цитата(Basill @ 27.7.2011, 11:02) *
Спасибо большое!
У нас тут с комплектующими немного немного туговато обстоят дела: народные полтинники U и W появляются иногда, а остальных транзисторов под наши нужды вообще не бывает, с ферритами вообще туго, я 2 месяца назад последние 3 комплекта Е70 забрал, провод намоточный если в радиомагазинах брать небольшими катушками, то разорится можно, а так 5 - 30 кг катушки можно купить по ценам за килограмм, шинок медных и лент вообще не найти, а с остальным вроде более менее сносно. Мотал транс на 2хЕ70 проводом из раскуроченного трансформатора от APC упса на 700 ВА, от этого же транса из прямоугольных пластин собрал сердечник для дросселя.
Так что после сборки остались у меня корпус от упса, 1 комплект Е70, 1 кондер 1000 мкФх400В, 4 полтинника (два из которых дохлых наверное) да и рассыпухи и мелочи разной на пару мозгов к бармалейнику, как нибудь соберу наверное в этом корпусе что нибудь близкое к 70-100 кГц ампер на 200, силовые ключи скорее всего придется заказывать, но это в будущем, сейчас впереди отпуск так что работы хватит icon_biggrin.gif .
kubinichek
Уважаемый Mazik. Поздравляю с успешным прохождением -"тест-краш-драйва". Все дело в том, что в PICO 180 радиаторы ключей маловаты, экономия, около 250 см.кв. В тех аппаратах которые я видел стоят HGTG30N60A4D две штучки. Хотя в плате есть разводка ещё на два и на радиаторе предусмотрено крепление для них. Опять экономия. Ну и сравните вес PICO 180 и своего изделия, если они равны я очень и искренне рад за Вас.
STASKIN
Типа этого может поможет.
kubinichek
русский шиит UC3845
А на UC3846...56? На русском.
Mazik
Спасибо icon_smile.gif , вес PICO 180 в магазине смотрел 7,9 кг а цена 32680 руб. цена конечно ппц!!! Мой весит с кабелем питания 8,3 (корпус весит 2,7кг), по затратам точно не могу сказать примерно 7000 руб., много ушло на инструмент (например: набор для нарезания резьб, дремель китайский, L/C метр, китайский стрелочник, ну и так по мелочи), да дело даже не в деньгах, а в удовольствии полученным во всем этом процессе, электроникой с самого детства занимаюсь и как появилось более-менее время решил изготовить, а купить - много ума ненадо!
Цитата(STASKIN @ 27.7.2011, 11:50) *
Да, спасибо - то что нужно.
STASKIN
Почитайте "Мой инвертор ММА, В корпусе UPS APC-400",может и оставшийся корпусок и Е70 пригодится icon_biggrin.gif
Mazik
Так у Еlectrovozа корпус практически в 2 раза меньше icon_smile.gif, морды пластмассовой у меня от корпуса не осталось (хотя есть и АРС 400 рабочий правда он немного уже и длиннее Електровозовского - если совсем туго станет, то разбомлю его icon_biggrin.gif ), в этом корпусе морду сделаю по человечески, вообще хочу в следующий раз уделить больше внимания эстетическому виду приближая к заводскому виду, этот корпус как раз подойдет, только над передней панелью придется поработать, а то у первого моего аппарата корпус Mini-ITX, переднюю панель пластиковую выкинул, прилепил стеклотекстолитовую пластину на ней получается неудобно торчат (выходят за пределы длины корпуса ручка задатчика, выключатель, кнопка, выходные клеммы), особенно боюсь как бы не выломать задачик, например об угол или в багажнике, а так в корпусе от упса утоплю немного переднюю панель.
kubinichek
Mazik, брось взгляд в сторону ATV-200 Толяна. Все поместится.
Mazik
Это вы к теме стабилизации ХХ, о которой я до этого писал или про корпуса?
kubinichek
К теме постройки другого аппарата в корпусе АРС 400 .
AS65
Mazik
Во первых рад за тебя и твоего монстра icon_biggrin.gif .
Во вторых я тебе говорил не заморачиваться напряжениями на микрухе,а не стабилизацией
напряжения ХХ.
Сделав ОС по напряжению ты поимеешь классный питальник к полуавтомату.
В третьих будет повод переделать корпус и сделать универсальный сварочник,
тогда у соседей точно уши попухнут.
icon_biggrin.gif .
Уф,прямо страна советов. icon_biggrin.gif .
Mazik
Цитата(AS65 @ 27.7.2011, 17:30) *
Mazik
напряжения ХХ.
icon_biggrin.gif .
Пока мне этого хватит на первое время, а потом может аргон прикручу да ченибудь для люминия, а пока много работы на даче с черным металлом, а соседи и так опухнут icon_biggrin.gif, может еще и шабашка какая получится. Дочитываю ветку бармалея, потом по аргону ветку читать буду. Хотя как говорится нет пределу совершенства...
haleks
Цитата(stalker-dass @ 19.5.2011, 11:07) *
master-makc
сбрасываю все свое платы в сборе, разберёшься удачи, если что непонятно пиши.
http://sderni.ru/65189
печатки по бармалея схеме ?
lapa
Цитата(Mazik @ 25.7.2011, 5:14) *
Всем здравствуйте, домотал дроссель до 120 мкГн, варить стал мягче и форсировку прикрутил обратно, на минимальном токе дуга не тянется и двойкой стал варить нормально, во всем диапазоне регулировки тока - меньше брызгать стал. ......
Цитата(Mazik @ 26.7.2011, 5:41) *
.. Кстати дроссель смотал до 30 мкГн, до этого домотал до 120 мкГн, - стал варить по взрослому - не понравилось icon_sad.gif, ощущение как будто у дуги температура стала меньше, до этого был 70 мкГн так двойкой на малом токе мелочь вообще невозможно было варить дуга тянется как сопля на рукаве, 3-й и 4-й нормально было, сейчас с 30 мкГн всеми электродами спокойно варит и дроссель намного меньше стал греться icon_biggrin.gif .
Цитата(Mazik @ 27.7.2011, 11:40) *
... Субъективное мнение сварного следующее:
Кажется мне что противоречиво зто всё. И вывод о преимуществе элементарного косого моста над Пико полагаю сомнителен. При всей святости Бармалея это минимальная конфигурация способная работать как сварочник. И в нём нет никаких решений влияющих на его вольт- амперную характеристику ( есть правда емкость на третьей ноге). Залипание-отлипание ВАХ не изменяет.
Muxa1101
Здраствуйте.
Можна ли в драйвере управления использовать супресори 1,5КЕ12СА, вместо стабилитрона КС213Б?
Д713
это ягоды с одного поля,и "лучшесть" там субъективна.
для мелкотравчатых работ годятся обои.
Mazik
Это точно, для бытовых нужд пойдут, я ж не для завода делал свой - для варки очень ответственных узлов, хотя думаю и моим и буржуйским можно много чего сделать. Просто меня смущает цена пико, наверняка 70 % стоимости - это бренд.
Писал выше форсировалку прикрутил, по осцилу смотрел, да и на ощупь - довольно интересно работает, минусов пока не замечено да думаю ВАХ неплохая будет. Можно конечно еще кучу всего прикрутить icon_smile.gif, как говориться нет пределу совершенства, решил остановится пока на этом.
Доброго времени суток уважаемые.
Есть мысль такая для облегчения сварки инверторами на сельской сети:
Взять N-ое количество емкостей допустим 450мкФх400В штук так нацать на 10000 мкФ, прикрутить мост и заряжалку с таймером, выход подключать к банкам инвертора и все это засунуть например в АТХ, будет ка доп. оборудование к сверкальнику:), думаю таким образом можно хоть и не полностью, но компенсировать провалы сети?
AS65
На совсем дохлой сети данное устройство обеспечит без проблемный поджиг,а дальше напруга всё равно съедет,эффект будет только если в самом инверторе занижена ёмкость банок.
Подключать инвертор к такой штуке можно стандартно как к 220 переменки.
Mazik
У меня 2 банки по 1000 мкФ, больше не влезло, думаю по емкости нормально. А подключать как к 220 я бы не стал, у меня 2 моста и тогда на постоянке в каждом мосте будут работать постоянно только 2 диода, а это не есть хорошо, тем более с такими мостами как - KBPC5010. С уважением.
stalker-dass
В большей степени да(печатки Бармалея), но кое что изменено, подкорректорованны размеры плат перенесены некоторые элементы.
haleks если что надо пиши
Mazik
Уффф. Наконец то дочитал бармалеевскую ветку. Следующий аппарат с нуля буду делать полностью на микропроцессорном управлении, сила будет косой, контроллер буду полностью сам придумывать и софт писать.
STASKIN
Ток уже обговаривалось icon_biggrin.gif . Нехватит скорости процу,на нем есть резон(если есть)организовать сервис,индикацию,а ШИМелка так и останется... Или у Вас другие идеи появились? Смотрим стр.520.
Mazik
Так выбор проциков большой с 4 - 33 мГц тактовой частотой для шима думаю хватит, чтобы построить чистый меандр из единиц и нулей на 70 - 100 кГц и для других нужд инвертера благо алгоритм управление прост да и количество обрабатываемых данных не велико.
кабельщик
Mazik, вы такИ жеж прислушайтесь к советам. Ежели говорят - не хватит, значит знают, о чем говорят. А ишшо поломайте голову над тем, по какому признаку будете делать прерывание, ежели он подвиснет на прямом ходе...
Mazik
В принципе и прерывание можно прикрутить, только все это усложняет конструкцию, я склоняюсь больше к сервисной функции, т.е. шимка отдельно рулимая проциком, только схему с нуля хочу разработать ну не изобретать велосипед конечно, но это все пока в будущем
yjriy
УжО трудится, самый дешевый и массовораспространенный Ат8. Мож на неделе его окончательные фотосы со схемой выложу. Однако на скорости стошисят Ампер он мне на балконе розетку выплавил с телефонным штепсюлем. Вывод: не годятся телефонные штепсюли для подключения четырехкилловаттных устройств icon_wink.gif
кабельщик
Надоть было контакты подпружинить... Тогда сгодились бы и даже такие
STASKIN
Mazik
Всем здравствуйте.
Если к бармалейнику подцепить аргонную горелку, а газ руками регулировать, дугу поджигать допустим об уголь то варить получится? Если да то как провар, качество как будет?
