Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
RUS5610
Поставь фильтр после ветродуя.
СМК
При большой запыленности помещения (особенно если пыль проводящая) проводится ППР (при которой аппарат регулярно чистят,промывают,продувают).
Д713
плата заливается 2-3 слоями лака для этих целей предназначенного и усе.
Лопух
Цитата(СМК @ 19.5.2010, 18:18) *
Пилить же радиаторы можно,если не гнаться за весом и размерами аппарата,а получить удар током проще в розетке.
Интересная мысль. Только как это соотносится со сварочником Бармалея и десятками других,сделанных в БП АТХ с пиленым радиатором? Или вам нужно еще меньше?
Д713, посоветуйте какой нибудь доступный лак
mer59
Когда собрал сварочник поначалу лелеял и берег,первенец всетаки.В прошлом году,после четырех летней экспулатации товарищ мой снял крышку провести работы по перечню тек. экс.
Принес мне в пакетике то что там было.Вот это то что там было и перевесило все разумные доводы в пользу конструкции более простой и рациональной.Надо сказать последние два года я беспечно относился к своему творению,таскали его все комубыло нужно.
А по поводу сеток и фильтров,кто может похвастатся в регулярной чистке системника,а он в стерильных условиях по сравнению со сварочником.
Вот если поменять тему,хочется вопросить кто снимал ВАХ на баласте управы от Телвин или другой модели,которая легко кушает УОНИ?
Д713
для меня пока доступен S00609 с наполнителями,фирмы Sherwin-Williams Company.
дает толстую пленку простым распылением.
DANTIST
Аппарат, конечно, нужно чистить чаще, чем раз в 4 года.
Зачем тебе ВАХ? У тебя есть Телвин и ты хочешь сравнить свою ВАХ с чьей-то ?
Думаю, Бармалей скушает УОНИ. Он что угодно скушает. На то он и Бармалей.
Den2
Я сам когдато задавал такой вопрос,Камеолт посоветовал Паркетный полеуретановый лак.С тех пор им и покрываю платы.Нет нечего лучше-доступный(в любом строительном магазине),дешевый,прочный более мение.Но трансформатор и дросель пропитывать им не желательно-не термостойкий,хотя для платы самое то.И смотрится очень аккуратно
OlegarX-RUS
Бармалей отлично кушат УОНИ правда у меня стоит цепь компенсации пилы (на транзисторе и резисторе) от Электровоза и резистор я поставил на 4,7ком а не как в оригинале 6,8ком.
STASKIN
А как замена резюка проявилась на работе аппарата?
OlegarX-RUS
Субьективно намного лучше и мягче чем в оригинале, а если верить шунту с амперметром то при зк 250А на дуге 220А электрод 5 мм, на элктроде 4 мм при том же положении задатчика всё примерно так же плюс позволяет более далеко дугу тянуть ну, а тройкой при томже положении режет как автогеном метал струёй с листового метала слетает
Коля
Ну я тут сотку в порядок привожу по ходу. Так вот, ТГР на шашке вообще некомпактный получается, решил на старом кольце намотать. Намотал проводом МГТФ. Всё как полагается. Ну при проверочке я конечно же с IRF740 подключил да через лампочку. Так вот колечко снова насыщается, хоть убей pain05.gif . Колец подобных не смог нигде найти ( вдруг проницаемость не та промаркирована ( 2000нм) ) Значит буду брать чуть побольше. От шашки я точно откажусь- кубик 3 см*3 см некуда впихнуть. Хотя в новом корпусе можно с компановкой поколдавать.
mer59
Да нет что помягче типа МР Бармалей пережовывает,а вот УОНИ он шамкает беззубым ртом что очень вредно для правильного переваривания оных.
Тема обсуждалась про управу Бармалея,как бы получается лучше управлять по среднему току.
Видимо различие будет в динамике,в статике как?Для полноты картины так сказать.Может кто измерял.
К сожалению сравнивать могу поциклового бармалея только со своим аппаратом,там чоппер рулит током,в статике ВАХ почти одинаковая,вертикальная,ток КЗ у Бармалея выше на пяток ампер при 130 выставленных. Разница в том что у чоппера заполнение 0.95 против 0.43 Барм.
Соответственно скорость нарастания выше.Электроды не высокого качества попались МР.
Так вот при сварке Бармалеем они регулярно тухли,а чоппером нет.Вот и хочется докопатся где собака порылась,обрисовать характеристики как бы идеального аппарата.
DANTIST
Я как-то недавно показывал формулу жесткости Welding Machine для штучных электродов. Согласно ГОСТ Uвых=20 В + 0,04 х Iдуги.
А что значит "они регулярно тухли"? Такое может быть в Кольте. Там есть антистик. И он длительный повышенный ток сварки может принять за КЗ. У меня как-то такое было. Че-то я намутил в цепи антистика и он регулярно секунды через 3...4 срабатывал. В Бармалее (не навороченном) такого нет.
electrovoz
Это формула описывает ВАХ дуги, а не аппарата. Аппарат должен иметь совсем другую ВАХ, даже не похожую.
Dimmch
немного не в тему
На 290 странице ув.electrovoz выкладывал схемку зарядки с защитой от переплюсовки на TOP
Ни у кого не сохранилась?
RUS5610
Мужики подскажите ; подарили кольца большие на вид феррит,сопротивление в любой точке около 600ом. Что за материал? Сняли с бесперебойника промышленного.
Wiew
какой-то низкочастотный.
RUS5610
Черт его знает.Может еще кто нибудь подскажет и решим что с ним делать.
Д713
куркулятор лысого еще никто не отменял.
RUS5610
Это да совершенно верно!
Albertish
А может кто-то, выложить тут кулькулятер Лысого...(мозг Лысого type.gif )
spesso
На гугле забанили?
Den2
самурай
Цитата(самурай @ 10.5.2010, 8:45) *
двигаюсь дальше!
закончил испытания Бармалея 100 . получил 135А КЗ,125А рабочий МАХ ток, сердечник епкос65,транзисторы 60РД1 . коструктив разместил в полностью убитом китайце (остался лишь кулер да радиаторы). попробовал разгон при испытании и получил ток КЗ 180А , но потребы в нем нет. всем спасибо за возможность читать и спрашивать icon_biggrin.gif
САНЕК
RUS5610
Мои поздравления! Молодец!
mer59
Неправильно выразился,по времени хаотично,но 5-6 раз на электрод.В дросселе под обмоткой керн ослаб и отчетливо слышно как тукает,когда ток прерывается,как электромагнит.
А Бармалей без наворотов голая поцикловка,единственно ограничилка импульса от напруги на банках стоит.
lipinskyy
Собрал инвертор Бармалея (165а вариант) пока без силовой части (заканчивается стабилитронами). В одном плече осцилограмма на стабилитроне такя же как у Бармалея ,а на на втором сильно просажена. Моментольно нагреваются оба резистора по 4,7 ом. Ляпов нет, согласующий транс намотан в два поровода 1-2 первичка , в два провода 2-3 вторичка. В чем проблема?
Den2
Попробуй поменять выводы ТГРа местами(там где нормальные импульсы посади туда где они искажены,просажены) Проверь стабилитрон,резисторы(может поставил по ошибке не тот номинал) а еще там где просажены проверь фазировку подключения обмоток.попробуй еще выпаяй стабилитрон и проверь без него(все действия в драйверах)
lipinskyy
без стабилитрона резисторы не греются. номиналы резисторов правильные, стабилитрон нормальный,фазировка не перепутана так как мотал двумя проводами. и еще-у меня стоят обычные 13в стабилитроны , КС213Б на Львовском базаре не достать, все импорт.
grek
Может поставить два 13 вольтовых встречно - последовательно.
Коля
И амплитуду выходного напряжения померьте.
Кое-кто тоже мотал в два провода, и начала соеденил в одну точку- так легче было icon_biggrin.gif. Нужно начало с концом. А форма импульса прямоугольная?
OlegarX-RUS
Не надо стабилитроны встречно параллелить, там обычный стабилитрон отлично становится.
lipinskyy, Скорей всего или вы переполюсовали стабилитрон или вам подсунули на более низкое напряжение.
lapa
Материал пластиковых бутылок (ПЭТ) полиэтилентерефталат - лавсан обладает заметными термоусадочными свойствами поскольку бутылки получают раздуванием заготовки. Это легко проверить.Термоусадка
lipinskyy
стабилитрони одинаковые, менял местами. всеравно греются резисторы 4,7 ом
maxx
Это те которые на затворы?
lipinskyy
ДА, ТЕ КОТОРЫЕ НА ЗАТВОРЫ 50ЫХ
maxx
Попробуй irfd123(или ему подобный исключить), спад завалится, но картинка должна измениться. Убирай всё до нагрузочных резисторов, там разберёшься...
убери с вых. драйверов всё.
lipinskyy
можно проверить осиллограмы на согласуещем трансе без нагрузки ?
maxx
На ТГР. Если мотать одинаковое кол-во витков, то напряжение на, скажем так выходных обмотках, будет примерно равно на первичке, увеличив на виток или 2 вторичку получим больше вольтаж. По вопросу-что такое без нагрузки, если без транзисторов, то конечно и даже нужно вместо них вешать кондёры 10н.
Basill
Вот ещё одна версия, читал на другом форуме задолго до того, как подсел на сварку...
Camelot
здарова всем! давно не виделись и не списывались, как всегда оффтоп, господа помогите маленько кто шарит в контроллерах, какой то косяк с AVR Studio 4, пишу код для атмеги128, всё было нормально пока не заюзал порты F и E, после чего студия начала кричать что типа знать не знаю че это за порты и чё с ними делать. сорри что не по теме, пишу с проклятой москвы, которая уже оскомину набила, нэт по предоплате, поэтому немогу особенно шоркаться по инэту часами в поисках нужной инфы. заранее благодарю за помощь.
electrovoz
Это плохой вариант, я его ликвидировал. На ТОРе оказалось сложным сделать переход стабилизации ток-напряжение в широком диапазоне выходного напряжения, ибо он питается от оптрона, и если оптрон темный (на выходе сильно мало), то будет перезапускаться. Сделал на 3845, все отлично. И КЗ, и переворот аккумулятора. На том же трансе.
Dimmch
vit336,electrovoz спасибо за информацию.
У меня БП-зарядка на основе старого БП АТХ с раздельными регулировками по току(0.5-6А) и напряжению (5-15в)
Интересовала именно защита от переплюсовки аккум.
Насчёт 3845 спасибо,учтём на будущее
gynik
Засветил бы схему что ли?
electrovoz
7.5А
maxx
Я делал так, правда для шуруповёрта
Ewgeniy_RZ6LYE
Версия Бармалейника от друзей из Польши, с режимами MMA-TIG. Статья из польского журнала. Нажмите для просмотра прикрепленного файла
Gulbariy
постройте на микрухе L200C, всего 5 деталек, но это именно зарядное устройство!!!! а его в свою очередь можно прицепить к любому подходящему БП
