Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
Д713
Незнаю, читал даташит, там написано Rise Time - 25ns он же и Fall Time. Задержка 200ns - тоже вменяема... чета неразглядел...
gyrator намякивает,шо на 250кГц без мягких переключений делать собственно нечего..
KLIM
Вот теперь ближе к делу icon_smile.gif теперь разглядел, а то я прям как надпись на заборе увидел и давай искать где же оно валяется...
kadet
Поздравляю всех с праздником - Днем Победы в Великой Отечественной войне! Светлая память тем, кто ценою жизни остановил фашистских захватчиков! Низкий поклон ветеранам! Помним, гордимся и благодарим... Спасибо вам! Всех с праздником!!!
Мужик
Время имеет власть. Но память о погибших сильнее власти! Всех сваркостроителей с праздником!
самурай
пришло время и мне обармалеиться icon_biggrin.gif случился все ж у меня конфуз - при уменьшении шим-заполнения падает в 2-3 раза амплитуда с выхода ТГР ( читая форум не нашел намека на это-мож по невнимательности )
DANTIST
ВСЕХ С ПРАЗДНИКОМ! С ДНЕМ ПОБЕДЫ!
Коля
Цитата(самурай @ 9.5.2010, 16:37) *
icon_biggrin.gif У меня случай тайо был, что ТГР сваливался в насыщение. От чего- сам не понял, просто тупо взял да перемотал icon_biggrin.gif . Всё заработало потом нормально. Вот я про насыщение и подумал. Померь на всякий случай ток питания управы.
Может посмотрите/ проверите:
http://myfolder.ru/17638739
Нужно будет общими силами сделать работу над ошибками.
О чём ещё можно написать?
самурай
простите но не смог открыть никак
попробую поменять ТГР
HEMELL
Тоже что то не смог открыть.
Ветеранов в первую очередь, а так же всех с праздником!!!
Wiew
самурай, проверте фазировку.
у кого не открываются Колины труды вот зеркало:Нажмите для просмотра прикрепленного файла
самурай
за архив отдельное спасибо - не встречал
двигаюсь дальше!
Лопух
Всех с праздником Победы!!!
Вот нельзя по праздникам работать. Друг попросил кое-что подварить, тут мой аппаратец и бахнул. Ну, учитывая, что он интенсивно проработал года 2 и что это вообще мой первый бах... Хоть и неприятно, но не страшно. Кстати, бахнул по причине весьма банальной - дребезг в розетке.
Кабельщик, будьте любезны, поделитесь способом намотки трансов лентой из проводов. А то, видимо, из-за недостаточно прямых рук не очень получается.
кабельщик
Лопух, есть только ETD59.pdf . Правду сказать, последнее время делю первичку на три части, вторичку на две , с соответственным перемежением - Lрасс. выходит вообще минимальной. Никаких враждебных вихрей не замечено...
Коля
Ув. Кабельщик, не подскажете что такое индуктивность рассеяния и чем и как её мерить?
кабельщик
Коля, если без посыпания формулами, по простому - то на тут http://members.kern.com.au/users/akouz/chokes.html#H9 ...
Лопух
Спасибо,это я видел.Интересует сам процесс, как укладывали витки лентой.
spesso
На гугле забанили?
Коля
Цитата(spesso @ 10.5.2010, 16:53) *
На гугле забанили?
Нет не забанили. Я объясню почему спросил у Кабельщика.
Дело в том, что есть два типа людей:
1) Люди с образованием и имеющие представления о всех электронных явлениях, знающие и понимающие формулы, решающие различные математические задачи и т.д. и т.п.
2) Люди, любящие практику, простые формулы типа I=U/R, экспериментирующие, и знающие физику в основном по практике. Я из этого числа людей. Это пока, неизвестно что будет дальше.
Так вот, был уверен, что уважаемый Кабельщик подскажет человеческим языком о L расс. И он грамотно отправил на ту страничку, где более или менее доходчиво описаны трансформаторы и дроссели. Там я нашёл что искал, а именно то, что L расс. можно узнать измерив индуктивность первички при кз вторички. У меня вроде ( уже не помню) 5 мкГн. Чем меньше эта величина, тем лучше. Индуктивность рассеяния можно уменьшить при послойной намотке первички и вторички. Вот собственно и всё. Кабельщику- благодарность.
Вот вопрос возник. Будет ли сотка варить нормально ( без бахов впоследствии) на сети 240 вольт? Амплитудное напряжение будет около 340 вольт! Есть файлик EXELный по которому первичка при таком напряжении должна быть 42 витка, либо частоту повышать до 40 кГц, чтобы работал на штатных обмотках (35/10) Уже вопрос пойдёт: выдержат ли полтинники? Или прийдётся ставить IRG4PC50W ( сейчас U стоят)
Давно с форума скачивал. Может чем и поможет.
http://myfolder.ru/17649730
кабельщик
Просто пальцами. Отрезается нужное для одного слоя кол-во проводов нужной длины (кол-во витков, диаметр витка, хвосты на выводы). Хвост-начало закладывается в пазы меж выводов каркаса и загибается внутрь каркаса для временной фиксации от разматывания. Дальше просто нудно-медленная десятипальцевая намотка. Все в руках . Концы провода свисают на пол. Без никаких направляющих. Основная проблема - удержать от разматывания уже почти намотанные витки,
когда вдруг звонит телефон
Для идеально ровной укладки первого слоя в каждой новой части обмотки, наверное, можно использовать слой двустороннего тонкого скотча (как фиксатор-липучка) . Сам, правда, не пробовал...
Лопух
Зависит от вашего транса. Для исключения сомнений в работоспособности перед окончательной намоткой транса его проверяют чукчиным "калькулятором" на напряжении 250 В или прибором, схема которого здесь неоднократно фигурировала.
Спасибо, но это немного не то.
Цитата(кабельщик @ 10.5.2010, 18:34) *
Просто пальцами.
Видимо, мне это не дано. То провод в ленте местами налезает один на другой, то витки расползаются.
Жаль, мне кажется, самый оптимальный транс был бы намотанный лентой, с постоянным чередованием первички и вторички. При этом получается оптимальная связь обмоток и минимальная индуктивность рассеяния, а т. к. по всему сечению идёт чередование первички и вторички, то в значительной мере ослабляется влияние эффекта близости. Да и заполнение окна медью будет больше чем при намотке жгутом.
Д713
Видимо, мне это не дано..
зачем так мрачно?
подберите время,шоб было хорошее настроение,предварительно наведите порядок на столе..
не спешите и все получится!
DANTIST
Слушай, а в чем, собственно, преимущество намотки лентой проводов?
Столько мороки с укладкой проводов, распайкой на штырьки. Я так понимаю, ты делаешь несколько слоев первички, а между ними вторичку. Потом слои соединяешь каким-то образом последовательно. И за ради чего это все? Чтобы на пару мкГн снизить индуктивность рассеивания?
Слой первички - слой вторички. Что может быть проще? Lрасс порядка 3-4 мкГн (китайским индуктометром). И при этом, никакой мороки.
В случае чего, лишнюю Lрасс можно вентилятором сдуть.
кабельщик
DANTIST, не Lрасс. снижения для... Глобальных преимуществ нету, конечно. В основном для максимального заполнения окна медью .
Возни примерно часа два-три (не считая промежуточных сушек лака , если таковые делаются) . И нет никакой распайки на штырьки.
Если ничего лишнего не сдувать с транса и ключей, то ETD59 дает ПВ=100% при выходе 100-120А ...
Коля
Подскажите плиз, на какой частоте работают нормально IRG4PC50U и W. Хочется по частоте маленько подняться. ЛАТРа просто нету, чтобы лысым смотреть.
DGEC
На 50 кГц смело работают
http://www.alldatasheet.com/datasheet-pdf/.../IRG4PC50U.html
http://www.alldatasheet.com/datasheet-pdf/...4PC50UDPBF.html
http://www.alldatasheet.com/datasheet-pdf/.../IRG4PC50W.html
Лучше всех выглядит W
Лопух
Цитата(DANTIST @ 10.5.2010, 19:03) *
... ты делаешь несколько слоев первички, а между ними вторичку. Потом слои соединяешь каким-то образом последовательно. И за ради чего это все? ...
Нет, не так. В несколько проводов на всю ширину каркаса в один слой полное количество витков первички. Следующий слой -точно также -вторичка. И так, последовательно, слоями, до заполнения окна. Ничего распаивать не надо. Выведенные концы паяются как обычно. Зачем- я уже писал выше.
P.S. Насколько я помню Lрасс характеризует ту часть магнитного потока, которая не передается во вторичку. И вентилятором ее не сдуть.
lapa
Дополнительные потери это действительно пустяки. Lрасс еще и балластная индуктивность включенная последовательно с первичкой это требует увеличения коэффициента заполнения, а он не резиновый. Поэтому снижается максимальный выходной ток.
Den2
Всех с прошедшими праздниками! Я лентой мотал так.От пластиковой бутылки отрезал полоску,сгибал пополам,иголкой прокалывал отверстия по количеству проволок,не обязательно одно вплотную к другому(в этом случае они сливаются в одну большую дырку)и вперед сжимая пальцами полоску регулируйте натяжение.Провода не путаются ,очень удобно
Кстати в Радио в последнем номере есть схема измерителя коэффициента заполнения
Витяй
Я намотал ленточным проводом транс Е70.
Первичка: 2 ленты из проводов 0,44 по 42 провода, длина 1,5 м. Вторичка из провода 0,5 - 75 проводов, длина 1м.
Мотал первичку сразу двумя лентами сложенными друг к другу, на всю ширину каркаса, выводы на разные стороны. Через виток запустил вторичку и мотал тремя лентами сразу. Параллельно промазывал эпоксидкой. Вся вторичка получилась между первичкой. Первичку потом спаяю последовательно.
Провод взял из петель размагничивания телевизора.
Ленты делал на малярном скотче, прикрепив его к столу. Провод придавливал ногтем. Когда уложил весь ряд, заклеил его вторым слоем скотча.
Лопух
Как-то странно вылетели мои ключики. Стояло по два в плечо. В каждом плече вылетели по одному ключу, два других, похоже, уцелели. Размагничивающие диоды целые, в сгоревших ключах между базой и коллектором сквозняк, коллектор и эмиттер не звоняться. Что сгоревшие, что уцелевшие выглядят как новенькие. Нюанс: сетевой предохранитель не сгорел, зато сгорел зарядный резистор. Чудеса!
Wiew
тоесть первичка-вторичка-первичка-вторичка-первичка? брррлл....
последовательно или впаралель?, и сколько мкг рассеивается?
Д713
небось блокирующие емкости стояли на ногах "уцелевших"..
это уже следствие,а не причина..
Лопух
Ровно по середине. Поскольку их было 3 штуки, как раз получилось на каждой паре и один в середке.
Ясно, только почему цел предохранитель? И почему не пробило диоды? И умерли ключики тихо и мирно, без хлопков и звуков. Хотя, последовательность событий ясна. Плохой контакт в розетке, несколько попыток перезапуска за несколько секунд (слышно было, как защелкало реле) и бабах. Если бы дошло сразу, в чем дело и успел бы выключить, все бы могло обойтись.
KLIM
Цитата(DGEC @ 10.5.2010, 18:04) *
50U и 50UD можно таки заставить работать и на 140кГц... но только больше тока ХХ они не потянут. Не выживут они в сотке на 50кГц. 35кГц ну максимум 40кГц для них...
50W уже можно на 50кГц пользовать, выше и их стремно. Вы в даташите график зависимости тока от частоты видели? Так его никто не отменял... мощность потерь посчитайте, и всё станет на свои места.
Кстати с прошедшими всех!!!
Коля
Говорят и на 200 кГц-ах можно использовать в резонансных схемах icon_biggrin.gif Хорошо, будем 40 кГц пробовать.
DANTIST
[quote name='Витяй' date='10.5.2010, 20:00' post='134321']
Витяй, да тебе памятник не рукотворный при жизни ставить нужно! Только героические герои могут так издеваться над собой. Надеюсь, ты таким образом намотал только один транс.
А чем, собственно, не устраивает мотальщиков трансов медная лента. Или это такой огромный дефицит?
Я понимаю еще, если мотнуть вторичку парой-тройкой запараллеленных проводов типа 1,5...2 кв. Куда не шло. Но 40...70 проводов в один слой... За ради чего?
Не так давно пришлось ремонтировать китайский транс. Там тоже было запараллелено 4 слоя первички по 20 витков лентой в 12 проводов. Ну и вторичка соответственно. Сразу решил повторить, а потом плюнул на все слюной и сделал как обычно по-украински.
Да скрути ты их в канатик и мотай на здоровье.
Что ты выиграл лентой проводов?
Я мотал и жгутиком и лентой медной и просто толстыми проводами. Практической разницы в процессе сварки никакой. Куриные кубики, козьи шарики... Зачем платить больше?
Отсюда сделан вывод: мотать так , как максимально удобно практически. Т.е. каждая обмотка, по возможности, в один слой. Первичка - жгутик, вторичка - шина.
кабельщик
Именно так. Треть витков первички > половина витков вторички > и т.д. до конца. Т.е. последовательно (хотя без разницы как, можно и параллельно). Lрасс.~1µH ...
Коля
Цитата(кабельщик @ 11.5.2010, 8:39) *
Lрасс.~1µH ...
А L расс. 5 мкГн- нормально?
кабельщик
Вполне...
DANTIST
Цитата(кабельщик @ 11.5.2010, 6:50) *
Вполне...
Т.е. и 5 мкГн нормально и 1? Поясни. А то снова получаются козьи шарики...
кабельщик
DANTIST, Lрасс.~5µH нормально, а Lрасс.~1µH - хорошо . Если б Lрасс. получить 0µH - было б супер...
dnp
Разница в коэффиценте заполнения медью.
У шины (если хорошо лупить киянкой на поворотах) самое лучшее заполнение, у ленты похуже, у жгута самое дохлое заполнение. А от этого - омическое сопротивление, активные потери, нагрев, ПВ...
А вот сколько он выиграл, то-есть численное выражение его стараний в Омах, Ваттах, Цельсиях или ПВ, это действительно вопрос.
В принципе, эту разницу можно даже попробовать посчитать, замерив КзапМедью для жгута и многопроволочной ленты. Было бы желание icon_smile.gif
кабельщик
Примерно прикидывал. При зачистке двух козьих шариков (макс.заполнение окна медью + выигрыш на коротком трансе) активные потери в обмотках ETD59 составляют около 20Вт против 40-50Вт оригинала-сотки. Как понимаете, отсюда и растут ноги у ПВ 100% .
KLIM
Подскажи - с ETD59 при ПВ 60% 160А снять можно на 50кгЦ ? У меня по расчетам получилось что ДА но на грани.. я для сравнения спрашиваю.
кабельщик
KLIM, думаю - можно, однако тут больше потребуется расчет по максимальному размаху индукции. Чтоб не схлопотать по полной от перегрева самого феррита...
sarmat
Вытащил свой первый бармалейник из хлама, второй день вожусь с ним. Транс намотал на Е70 (18*6). Получается такая картина. На выходе хоть тресни больше 15 вольт не выходит. Управа с выходом ограничения ХХ, антистик и аркфорсе. Думаю все дело в трансе. Намотан 18 витков для 40 кГц. Нет под рукой хороших ключей чтобы повыше по частоте подняться. Есть 50U и 50W. Пока воткнул 50U. Для пробы. При измерении индуктивности первичка около 2,3 мГн (зазор целофан от сигаретной пачки), а вторичка почти ничего не показывает. Для сравнения намотанный на Е70 (18*6) транс для фиксы без зазора- первичка 3,3 мГн, вторичка - 330 мкГн. Транс намотан так первичка 3 слоя по 6 витков шиной 5*1 чередуя со вторичкой 3 слоя по 2 витка лентой 38*0.5. Разместить 18*6 на Е70 по другому не получилось. Короче, коэф. трансформации получился не такой, хотя соотношение витков соблюдено. Хотя, истинный косяк наверно выясниться при вскрытии самого транса icon_sad.gif
Мужики, все выяснил. Последные два витка вторички намотаны против движения. Индуктивность на первых слоях нормальная. А после последней почти ничего. Буду разбирать. Хорошо, что последные витки.
lapa
Оценил влияние Lрасс на простейшей модельке косого. Частота 50 КГц, длительность импульса
8 мкс, Rн=0,2 Ом. Lрасс=0µ1 ток 169А 1µ - 166А 3µ -160А 10µ -140А. Изничтожать Lрасс совсем не следует она сбеспечивает включение транзисторов при нулевом токе.
sarmat
Долбанный интернет...снизили скорость передачи данных на спутнике...людей мучают...не могу нормально работать....транс уже исправил...щас попробую посверкать пока не потемнело
кабельщик
lapa, спс за информацию...
Wiew
кабельщик, благодаю, весьма ценная для меня инфа.
можна и так сказать, как то надыбав у бариги моток ленты по 20грн за метр. а покупать бухты по писят кило как-то накладно.
