Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
Wiew
Цитата(САНЕК @ 24.10.2009, 19:39) *
Так после моста......310в.как минимум,не ибанёт?
так у них 250В переменки, а амплитудное для синусоиды в 1,41раз больше, тоесть держат 350В
во... так причина все- же в кондерах.
САНЕК
Вот и фотка их там три было.а амплитудное для синусоиды в 1,41раз больше, тоесть держат 350В.Так на пределе.За что и боязно.
maxx
b32654-a6155-j проблем небыло.
Wiew
а кондерчики такого типа (фото) желательно из более мелких номиналов набирать
maxx
Цитата(САНЕК @ 24.10.2009, 19:33) *
Всё таки проблема "закипания" блокировочной ёмкости не побеждена.
Ранее постил,помениял два комплекта(последний-4х1Мкф)вспучились.Емкостя весят на ногах ключей,провод от банок до ключей 10см.,по такому конструктиву работает не один аппарат.
Суть вскипания:
Работать можно много времени,но при перекуре,т.е. на ХХ ходу ЗАКИПАЕТ ну и следствие-дым.При этом ключи остаються живыми.
В чём может быть проблема??????????
Есть подозрение на ключи(перемаркёр).
? скорее всего ёмкостя
а как размагничивается транс?
golub
А как по мне, сдаётся что разогреваются оные под нагрузкой, а дальше текут и варежки раскрывают. Кабельщик, кажется по пять штук такой краснухи ставит, только меньшего номинала. Я леплю жёлтые что на фотке, возвратов не было.
Прикупил по случаю у Терейковского колечко распылённого железа на пробу, 57х35х25 мм. Ни кто на таком не мотал дроссель?
САНЕК
Цитата(golub @ 25.10.2009, 0:51) *
А как по мне, сдаётся что разогреваются оные под нагрузкой, а дальше текут и варежки раскрывают. [b]
На мастерах тоже самое сказали.И у Володина тема была.Одним словом-гавно эта китайская краснота.
Будем искать нормальные.
Вот чё нарыл
САНЕК
Вот чё бывает когда предохрана нет вообще выгорели зарядные резюки после убоя ключей.
yjriy
Подскажите, плииз, как отправить плату из ПДФ в Спринт 5. Никто не извращался?
golub
Перегоняешь из .пдф в .бмп.
Начинаешь страницу в лайоуте, вкладка "опции"- "шаблон...". "Загрузить", а потом установкой кол-ва дпи подгоняешь масштаб картинки в нужный размер.
А как по твоему в этом случае сработал-бы предохранитель?
САНЕК
Это было проверено ещё когда народные полтинники пользовал.Максимум-дорога от банок к ключикам горела.Просто никогда не ставил предохран между банками и ключами.
golub
Дык вроде ещё в прошлом годе договорились, что предохранитель по переменке (от пожара), а между банками и ключами всё гладко и прямолинейно, и главное- покороче.
А в случае на фотографии- или по какой-то причине не сработало реле и была попытка варить через зарядный резистор с последущим БАХом, или сначала БАХ, а потом выгорание зарядника, если реле запитано от допобмотки. Но во втором случае при бахе успевает выгореть или дорога или предохранитель, если он есть.
САНЕК
Вот так оно и было,ключи в коротыш, дежурка вырубилась,а точек к коротким ключикам через зарядник.Релюха то цела.
Ewgeniy_RZ6LYE
существует програмка ABBYY PDF Transformer, позволяет любую ПДФ-ку перегнать в нормальный редактируемый ( картинки отдельно текст отдельно) формат Ворда, Экселя, или в картинку, при конвертации есть возможность выбирать, что считать картинкой, а что текстом, очень удобная, пользуюсь года 3-4....
yjriy
Golub спасибо, все ОК.
Wiew
Народ, у кого есть опыт применения радиаторных профилей с тонким основанием - 5мм?
интересует равномерность распределения тепла, особенно на эбушках.
KLIM
Есть такие, вопросов нету. Если не силумин то всё ОК. Силумин что обезяна с гранатой, обязательно рванет но не знаешь когда...
Wiew
electrovoz
Конденсаторы входного фильтра с макрировкой X2 выдерживают 1000 В, ибо у них Surge нормирован. Можете убедиться. Например, WIMA на конденаторах пишет соотношение: 650~/1600-. Другие просто не указывают значение для постоянного напряжения. А китайские красные годами работают в БП АТХ, при 1А/мкФ среднего тока. На что они и расcчитаны.
Wiew
http://www.epcos.com/inf/20/20/db/fc_05/X2_B81130.pdf
KLIM
Цитата(Wiew @ 26.10.2009, 9:58) *
Да, люминиевые, нормальные. Извини, сразу не уточнился - я ставлю по два транзистора и по два обратных диода. Если до 160А - все ОК, 180-200 начинаются проблемы... Зависит от типов транзисторов, и качества монтажа. С диодами кстати проблем не было никогда.
Wiew
хух..успокоил, спасибо
KLIM
Кто заморачивался с БП флаем? Есть проблемка, вояю слабенький блочек на 15 ватт с универсальным входом 85-245, на ТОР245, так вот немогу побороть нагрев выходного диода. Шотки при 100 вольтах особых выигрышей неимеют, менее высоковольтный скорее всего погибнет, там под 75-80 вольт в лучшем случае. Обычный кремниевый типа UF5408 закипает при токе 0.7А на 15 вольтах выхода. Ставить радиаторный диод на 0.7А выход - расточительство! Кто что подскажет?
Пук
Ты с мощностью определись сначала. 80Вх0,7А=56Вт!!! И никак не 15!
Wiew
попробуй НЕR308 или даже 208-ой, до 1 ампера греются не сильно
electrovoz
2 параллельных HER307 или 1 SFA806G
Пук
Цитата(Wiew @ 26.10.2009, 17:33) *
Пару пшиков на бокал пива и ребёнку не помеха
KLIM
Ну ёмаё прям как дети, чув звін да нэзнаю дэ він. Я ж написал 15 вольт 0.7А
Вы по ходу (или ТЫ) смотрели напругу на универсальном флае что телепается на диодике??? Если бы смотрели - вопрос бы не возник в принципе. Wiew меня сразу понял icon_smile.gif
bell
Кто заморачивался с БП флаем? Есть проблемка, Ставить радиаторный диод на 0.7А выход - расточительство! Кто что подскажет?
Обычно паяю пластину медную( 0.4мм) к ноге диода.
САНЕК
Не обрезая ног НЕРы прокатывают по одному.
OFATUM
Братцы, выручайте!! Кто пользовал транзисторы G30N60A4( HGTG30N60A4). Пхнут ли они 180..200 А в косом, при частоте не более 35кгц. Интересует, пробовал ли их ктото уже или нет??? Выручайте! titanic.gif
golub
Дантист пробовал. Но кажется больше 160 не накручивал, да и надо-ли. А по частоте их можно погнать легко до 80-ти. Мне приходилось А4 по ремонту менять на ПД, т.к. лучшей замены на то время не было.
Wiew
практически еще не пробовал а от теоретически они дубовей 50PD1, при правильном использовании 200А вытянут.
OFATUM
Если на IRG4PC60U можно снять 180А по одному в плече при его 75А при 25градусах, а 40А при 100 градусах, а при 70градусах ( выставлена защита), выдаст 50А по графику из даташита. А транзистор
HGTG30N60A имеет 75А при 27градусах и 60А при 110 градусах, то судя по даташитам достойная замена. Вот я и спрашиваю опробовал ли их кто?? Действительно ли они соответствуют?
Я заказал уже 4 штучки, буду пытать, и выжимать из них все соки
electrovoz
Китайцы их обычно парами ставят
OFATUM
Я думаю, если можно разогнать до 80кгц и снимать с него до 160, то 180 при 30 кгц должно легко.
supryur
А по цене как? дешевле чем пд1?
golub
Не поспоришь, один сверху, другой снизу.
Wiew
Цитата(golub @ 27.10.2009, 17:37) *
icon_biggrin.gif, ну да, да еще место снаббера помехогасительная цепочка
OFATUM
Дешевле но на какихто 5..6 гривен, это погоды не делает, просто уже заказаны
Oleg555
Ув. форумчане, хотел начать сборку аппарата на 165А, но вот не могу опредилится с печаткой . Может ктото поделится рабочей печаткой, или ткните, пожалуйста, фейсом где она выложена.
Извините за вопрос, но уже закипел перечитовать все 8 частей . Печатки видел , но какая из них провереная и робочая?
САНЕК
Мож кому сгодиться,с оптики погорельца,2мкс.5в на клетку(переход в -)Ноль по серёдке.
golub
Вообще-то здесь не принято выкладывать нерабочее.
Oleg555
А что конкретно посоветуете
golub
Соберите для начала бармалея. А там как попрёт.
RV3BJ
А кто-нибудь сможет объяснить для чего в этой схеме стоят оптроны. Ведь их вход гальванически связан с силовым напряжением. Что это - опечатка или сознательное искажение ?
Wiew
там все управление связано, видимо производителю проще было поставит оптодрайверы, а почему б и нет? ведь ключами надо ж както рулить icon_biggrin.gif
golub
Потому как в этом телвине питание управы на горячей стороне, а изолированы только питающие оптронов.
В догонку.
RV3BJ
Да уж весьма оригинальное решение.
sarmat
В "Унисервисе" HGTG30N60A4 около 100 р. а PD1 порядка 180 р.
Случай с Базой Электроники. Заказывал на днях кое-что по мелочевке. Были и MUR1560. В прайсе цена около 40 р. а на счете по 114 р. Связался с менеджерами и начал разбираться. Они мне пишут, что их на складе нет и их придется везти из-за бугра, поэтому цена выше. Мне жалко стало их. Из-за 10 диодов ехать им за бугор. А сам в их сайте сижу. Ему пишу, что они у вас на складе, 17 штук в наличии. Переправили счет и по 45 р. обещали мне отправить. Смотрел я их счет, то по счету у них на складе только 3 марки стабилитронов. Хотя предыдущий заказ оттуда получил нормально.
Иногда попадается и так: захожу на сайт ДелТел, а там 50W по 91 р -2 шт. и 150EBU02 по 80р- 2шт. быстро кидаю в корзину и получаю счет как есть. Наверно из старых остатков.
