Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
Serega30
При одновременном отключении управы и силы управа отрубается сразу, в то время как на литах еще висит 300в!!! ОПАСАЮСЬ БАХА при таком расскладе. Хочу сделать типа ''ждущий режым'': отключение силы без отключения управы и охлаждения- на случай перекуров или чтоб случайно не коротить держак на массу-явление достаточно частое в кругах сварщиков-любителей.
AS65
Serega30
Запитай дежурку от злектролитов и не мучайся.
Давно уже не ставлю включатель по сети,просто блокирую шим
маленьким тумблером а вентили ещё минуту крутятся при выдёргивании
вилки из розетки icon_biggrin.gif .
Serega30
Цитата(AS65 @ 24.1.2014, 17:11) *
Serega30
За счет чего...?
pashatt
Serega30 я к "липинскому" прикрутил такую схемулю,(позаимствованно в АВТ200), при корректировке некоторых номиналов установил сон~10сек., Astic~2сек., узел темоконтроля на TL431 убрал;
всё питается от одного БП, при включении аппарата первым стартует антистик (тем самым идет проверка на КЗ и
целосность вых. диодов). Так-же добавил монитор питания-глушит шим при выключении(менее 14-16в), и при нештатных
ситуациях(выдернул с розетки,вырубило автомат во время сварки и т.д.).
KSV
Цитата(Serega30 @ 24.1.2014, 16:58) *
Чето попроще надо... Еще такой вариант: сделать развязку по питанию управы и куллеров на диоде Шотки, на управу емкость пару тыс мкФ, на литы резак 50к+можно добавить разрядную цепь литов на нормально замкнутом контакте реле с 5ти w резаком.
Если проше, то запитайте БП от силовых электролитов, а БП включит реле. Ничего не бахает, единственный минус ,при выключении реле пару раз щелкнет. Вариант посложнее, на TL431 или транзисторе сделать задержку 2-3 секунды, а с разрядкой литов и не заморачивайтесь, это лишее, главное руки туда не совать после выключения, даже на следующий день, сам испытал. Я первую сварку запускал напрямую без реле и резюков.
AS65
Цитата(Serega30 @ 24.1.2014, 18:19) *
За счет чего...?
за счёт силовых банок.
Serega30
Запитал ИБП о силовых литов. Все заработало отлично. Просто и надежно: при виключении литы разряжаются практически до 0, реле всего 1 раз щелкает. ИБП стартует от 150в постоянки, отключается при 47в.
Evergreen
питать ИБП в работе всё же надо от своего выпрямителя а не от банок. Так правильнее
pansim1
Почему????????
nikon
А где бы почитать об этом правиле?
Serega30
Сделано очень качественно! Не разглядел че за прокладка под ИЖБТ/диодами и радиатором... похоже на медную пластину(не пойму зачем она там? Разве что радиаторы ''дырявые'').
Wasiliy61
Да, это медная пластина, раиаторы силуминовые /сплав алюминия + кремний, ну может ещё чего немножко/, а такой сплав имеет меньшую теплопроводность - поэтому рекомендуют пастелить медь.
Печатка сделанна под транс на кольце, но на Е65 лежал -ранее сделанный мной,и я его впихнул- правда малость не культяписто получилось, но ничего.
satinstaller
Для моментальной "расконцентрации" тепла от кристалла.
Чтоб диоды не померли, так и не нагрев радиатор, простыми словами.
Смонтировано все хорошо и красиво.
ingener99
Wasiliy61, вторичка выполнена медной шинкой? Если да, то какого сечения?
Wasiliy61
Да, вротичка- шинка от зиловского стартера, намотанно в двое-наложена одна на другую, сечение общее примерно 12-13 кв.
Цитата(Serega30 @ 25.1.2014, 21:38) *
Wasiliy61, частота, судя по виткам транса, будет около 70-90кГц ?
Нет, транс 15/5.-это 50кгц.
matlah
Wasiliy61, если можна дайте печатки плат. У меня есть такие радиаторы, думаю поставить. Я задавал вопрос по поводу, почему у меня малой размах сигнал с микросхемы. Никто нечего не порекомдовал. Даже не знаю чего дальше делать, сижу голову ломаю, чего такого может быть.
Jorg63
Нормально силумин отводит тепло,,кремний сам по себе обладает отличной теплопроводностью.как раз кремний и добавляеться для лучшей теплопроводности.А вот то что не пролужена сторона меди к радиатору это плохо- гальваническая пара. Да и равномерного прижима меди к радиатору точно у вас не будет приживши в 3 точках. так что вопрос насколько хорошо будет отвод тепла открытый.Проверить это можете проверкой температуры в месте контакта меди и радиатора. увидите разницу температуры. Насчет установки термореле то поставить надо и на ключики как раз на медную пластину для оперативного контроля температуры. ключи менее выносливые по перегреву чем Ебуки. выше 75 градусов термореле на ключи не ставить, а Ебеня легко и 90 градусов вынесут нагрев.
Wasiliy61
Я его уже выставлял, только силовая собрана та что на кольце-она покомпактней, ну а Е65 влез без проблем. На счёт твоего сварочника- у тебя ослик правильно кажет?, и посмотри нет ли просадки в Б.П. при подключении управы. Вот здесь печатки со схемой.Нажмите для просмотра прикрепленного файла
Wasiliy61
Пластина посажена через термо-пасту,гальванической парой они считаются если они кантактируют в электрическом режиме, а так вроди ни чего страшного. А вот теплопроводность Нажмите для просмотра прикрепленного файла
Jorg63
А с чего вы взяли что теплоттвод силумин?Даже если гипотетически предположить что силумин,то все равно через ваш сэндвич будет хуже теплоотдача от корпуса ключа ,чем прикрутив ключ напрямую к радиатору,тем более ключ прикручен напротив пустоты в радиаторе.основание в точке прижима можно сказать никудышное.
Wasiliy61
Так пластину и прокрутил-тоже с учётом пустоты-чтобы тепло передевалось по всему радиатору. Хотя они и стоят неточно напротив пустоты, болт не вышел в пустоту. А болтов крепящих пластину, можно добавить- ничего не разбирая.
Jorg63
Когда еще на эту пластину термо пристроишь то будешь в шоколаде icon_biggrin.gif
Wasiliy61
В некоторых аппаратах ставил по одному t* датчику- на диоды, так как греются сильнее, ключи сильно не грелись, но а здесь посмотрим.
RUS5610
Медь однозначно хорошо! всякие гальваники здесь по барабану!
sergey777.68
Wasiliy61 Отлично сделал . beer.gif и размер аппарата достойный.
ingener99
Правильно он сделал,тонкая медная пластина под ключом лучше, чем сразу массив алюминия. Теплопроводность гораздо выше, и не надо смотреть на цифры, а достаточно попробовать поварить ТИГом для сравнения алюминий и медь. Кто варил, знает. Медную деталь, пока всю до красна не прогреешь, невозможно расплавить. Так быстро она отводит тепло.
maxx
Цитата(Wasiliy61 @ 25.1.2014, 11:02) *
Мой крайний проект. Не впаял пока блокировочные кондюки, и нет пока дросселя.
Всё сделано замечательно. Какой зазор(какая прокладка)? Ток х.х. меряли? К. заполнения?
slavyann
Serega30
Цитата(slavyann @ 25.1.2014, 22:28) *
Все зависит от макс. вых. тока и ключей... Кстати, какие ключи стоят?
slavyann
макс. ток известен - 165, ключи тоже
Serega30
Тогда я не понимаю откуда берется 1,6 Ома при 100витках Тт в схеме 165А Бармалея... Раз мощности больше выжать нельзя то оптимально 1,8...2 Ома.
Павел(Sp)
Wasiliy
Я прозевал момент...если не трудно какие ключи на 50кГц???
Красиво собрано,поздравляю.
Родил я наконец транс, 6 строчников с Панасоников и проих.
Первичка 18вит скрутки из индукционной плиты,наверно с 4мм2, вторичка посчитал около 20мм2(размагнитка пополам и вдвое)
Прокладка скотч малярный , индуктивность первички 1270мкГн,вторички140мкГн Lc думаю что в райне 20мкГн, .мин разрешение шкалы мерила 20мГн,так что Lc мне выдает 0.02мГн,помазал так по бокам епоксидкой и сжал в тисках.Имеет право на жизнь или нет такой транс?
Кстати к прошлой дискуссии по эпоксидке.Оказывается есть разные композиции смол иногда даже не совместимые,тот затвердитель что мне подогнали -и цвет и запах и все прям как надо, а с нашей эпоксидкой,можно сказать что даже смешивается с трудом..
Wasiliy61
Ключики стоят GP50B60PD1. Частота 50кгц, кзап 0,435. Больше ни чего не пробывал, прошлую ночь просидел, пока собрал в кучу- он весь по запчастям лежал. я думаю должен работать, у меня был похожий проект.Тт у меня 85витков, резистор 1 с копейками ома -точно не помню, надпись внизу оказалась. С блокибовочниками проблемма, в близайшем городе МКТ- маленькая ёмкость, дома нашёл только вот что Нажмите для просмотра прикрепленного файла
В гараже нашёл катушку зажигония от ЗИД 4.Нажмите для просмотра прикрепленного файла
Оказалось она разборнаяНажмите для просмотра прикрепленного файлаХотел на половинке дросселёк сделать, немножко смущает, что пластины склёпанны.
mono
Найдите нормальный прибор и измерьте, если в самом деле получится 20 мкГн, то это очень много, однозначно перематывать.
slavyann
Павел(Sp)
да уж куда нормальнее искать, 3 дня как приехал,в магазине точно такой же ,только не за 15 а за 30 евро....надо попробовать самодельную мерялку откалибровать.
А чем чревато что индуктивность высока у сколько допустимо???
slavyann
ключам совсем плохо может быть
Velgosh
и снова сдрасте! скжите пожалуста, провод каким мотают ТГР по Бармалею 0,35мм, а многие мотают интернетовским(я также ним мотал) но он у меня он мает целых 0,48мм, ето важно? может из за етаво у меня получаетса малое напряжение на затворах (2,3в)?
P.S. купил все таки осциллограф, где то на днях приедит http://aukro.ua/oscillograf-s1-55-i3889770787.html думаю его хватит штоб запустить инвертор
Serega30
Цитата(Velgosh @ 26.1.2014, 13:01) *
у меня он мает целых 0,48мм, ето важно? может из за етаво у меня получаетса малое напряжение на затворах?
Такой разброс погоды не сделает
Velgosh
то нету смисла перематывать?
Serega30
Цитата(slavyann @ 26.1.2014, 11:01) *
Уважаемый, с этого момента по-подробнее если можно... Речь идет о стандартной схеме ''Косого'' с питанием от 220.
Если феррит на Тгр нормальный-то нет.
oleg1ma
Ну что тут поподробнее. если сеть ваша хорошая, ставте по два тр-ра в плечо, сделайте нормальный тр-тор и снимайте на здоровье хоть и 220а.
Serega30
Да не 220А много для дома. Хотя ключи 75-амперные-200А можно думаю). Только нафиг надо...
Wasiliy61
Мотал ТГР разнами проводами, -0,18. 0,25. 0,3. разницы не заметил, если конечно с витками всё в порядке. Иногда мотаю первички проводом ПЭЛ, ПЭВ, а вторички проводом в виниловой изоляции. Если позволяет место, то мотаю все обмотки в виниловой изоляции. На чём ТГР? Если 0,48 влезло.
Velgosh
кольцо 28 12 8
а от чего же зависит напряжение на затворах?
KT117
Вот придет осцил-и все увидим
Velgosh
даа, сам уже недождусь
zentr
Velgosh
Цитата(zentr @ 26.1.2014, 17:21) *
прибор ето горошо, но еще надо наверна уметь ним пользоватса и знать что где мерять, а я осциллографом ниразу непользовалса, более таво даже не видел как ето другие делают, так что прейдетса учитса и наверна с вашей помощью icon_redface.gif
