Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
ingener99
Можно разряжать электролиты блоком питания (инверторным, на ТОРах и пр). При напряжении 15В подключенный постоянно резистор 180Ом обеспечит нагрузку около 1,2Вт, что эквивалентно подключению резистора 75кОм на электролиты при напряжении 300В.
Wasiliy61
Добрый вечер, пол дня провозился с антистиком, помнится обсуждали что на колекторе, тоесть на выходе не нужен подстроичный резистор 2,2к, а Серёгин сказал что он нужен, так вот он прав, резистор просто не обходим, тем более узкий промежуток срабатывания. Можно попробывать уменьшить до 1,5к.
Нажмите для просмотра прикрепленного файла Вот эта схемка.
Серёгин
Да ,Wasiliy61, он нужен .Можно уменьшить , даже нужно .Удобнее будет настраивать .
Wasiliy61
На заводском блочке тоже не стоял резистор, видимо с контроллере стоял подогнанный постоянный резюк. Я его разобрал и сделал по этой схеме, печатка подошла.тольло в одном месте перерезал дорожку.
ГонZZа
Вечер добрый.Антистик сейчас ставлю от уважаемого Толяна(схему выкладывал oleg1ma),очень хорошо работает.Сегодня запустил очередной(9ый)аппарат.Фото пока не показываю,так как пока нет верхней крышки.Ради интереса попробовал сделать силовой транс на ОСках.Взял две ОСки(одна большая от ЦВетника,а другая поменьше от монитора),вложил одну в другую,намотал первичку 30витков,а вторичку 7витков.Подсоединил амперметр на 200а и сделал КЗ,ток КЗ зашкалил за 200а,пробовал варить-варит не хуже чем аппарат на ТВСах!Месяц назад в телемастерской отдали ОСок 37штук,так что как ТВСы закончатся,буду делать на ОСках.
Wasiliy61
Добрый вечер,а далеко-ли спрятана схемка толяна, а ОСки Вы не ломаете пополам. и как на счёт размагничивания.
ГонZZа
ОСки и так пополам сломаны,а на счёт схемы от Толяна(в сообщении zario Отправлено: 2.4.2013, 11:11)
Wasiliy61
Благодарю,а ОСки я так понял- отклоняющая система, да когда разбираешь её она разваливается на 2е части, я вспомнил.
Lemm
на мастерах давненько постили , что спустя год эксплуатации СТ намотанного на феррите от ОС , деградирует феррит - снижается индуктивность первички , и приходит композитор .
ГонZZа
Lemm,время покажет.На мастер Сити ставили одну ОСку,а я поставил две,если не перегревать и не вводить в насыщение,то думаю будет работать.
gorbun75
есть еще мешочек ферритов от тв .могу поделиться .
kvaka
oleg1ma Здравствуйте. Практически дособрал вашего "Липина". Встала проблема немогу найти индикатор с общим анодом. Есть только с общим катодом! Возможно ли преминить такой а вашей конструкции??
oleg1ma
Нет нужен только с общим анодом.
kvaka
Ну нету у нас с общим анодом!! Чтоже мне из за копеечного индикатора весь проект бросать в дальний угол??? А если так?
Dedan
Нужно порыть Юрину ветку по атмеге8. Там уже пристроили с ОК.
nikon
Воткнул сегодня в розетку очередное детище, вот что получилосьНажмите для просмотра прикрепленного файла, осцила на нижнем ключеНажмите для просмотра прикрепленного файла, на выходеНажмите для просмотра прикрепленного файла. Что то мне подсказывает что жить будет. ingener99 обратите внимание на осциллограмму на выходе, мне кажется такая правильней будит
ingener99
так нагляднее для сравнения.
чем может быть вызвана такая осциллограмма в моем аппарате? Отсутствием дросселя, зазора в сердечнике? Высокой частотой? Повышенной индуктивностью первички (более 5мГн)? - не в курсе. Но пока убить ключи не удалось. Довелось поварить и в гаражной сети тройкой. Пришлось выкручивать регулятор заметно сильнее, чем на хорошей сети. Но никаких приключений пока не замечено.
oleg1ma
Завалили ремонтом с началом сварочного сезона icon_biggrin.gif , вот уже второй мост, типа САИ(VITA, ТАВР ит.д) просят переделать, на липина на 200ампер, приходится умощнять силу на два ключика и радиаторы посолиднее, благо места вагон.Почему-то ненравятся людям китайский сварпром.Процес....
Wasiliy61
Ребята, посмотрите какой термодатчик с регулировкой температуры, прикручивается болтиком к радиатору.
Wasiliy61
Цитата(sergey777.68 @ 15.4.2013, 23:07) *
а утюга не будет в комплекте?.
Если радиаторы будут слабо грется то.........
p210
Цитата(sergey777.68 @ 15.4.2013, 19:07) *
Такую управу можно
При отрицательных температурах поимеете проблемы... yjriy & electrovoz не просто так применили LED-индикаторы.
VOVA 555
kvaka
http://www.electrik.org/forum/index.php?sh...mp;#entry233676 Вот тут ищите . Сообщение #2717
soud
. beer.gif Такую управу можно и к Бармалею прикрутить.
Схемку с печаткой можно глянуть?
Wasiliy61
Добрый вечер, может кому пригодится точный метод настройки вот такого антистика.
Включаем силу +300в через лампочьку скажем 100вт, при этом она не должна гореть. Переодически замыкаем выход сварочкика и вращаем подстроичный резистор 2,2к и быстро находим точку в которой лампочка ярко вспыхивает, и через пол секунды гаснет до накала. Это и есть та точка которая нам нужна, антистик совсем не глушит шим, но ключи разгружает здорово. Скорость сбрасывания зависит от кондюка на базе транзистора.
kvaka
oleg1ma дособрал управу. Индикатор собрал из четырёх штук. Всё работает. Но есть одно но, даю напряжение смешения через переменник на 15 ногу тл. И не наблюдаю ревкции шима. Чё за фигня?? При нажатии кнопок напряжение на с3 меняется на 2.5 вольта.
oleg1ma
Цитата(kvaka @ 16.4.2013, 22:19) *
Чё за фигня??
Незанимайтесь ерундой, собирайте все по схеме дальше.Доклепал очередного, был VITA, стал липин-vita icon_biggrin.gif Вот что в итоге вышло.
Wasiliy61
Колеги, мы делаем шимы на UC3825, мне кажется она половчее 3845.
sergey777.68
kvaka
Олег подскажите почему блок питания икает? Всё проверил. фазировка правельная.
oleg1ma
Какая индуктивность первички? Икает в двух случаях, или попутана фазировка или что-то напутал с клампером.
kvaka
В рбщем дело обстоит так. Индуктивности пробовал разные от 1200 до 3000. А икать начинает когда запаиваю диоды обмоток оптодрайверов. Одна управа работает нормально.
eger
так проверяй диоды и все что за ними и диоды должны быть как на схеме либо с подобными параметрами ну и фазировка само сабой
kvaka
Такое ощущение что перегрузка.Подключаю один канал пару раз икнёи и запустится. Подключаю второй канал и всё не запускается а только икает.
oleg1ma
Попутана фазировка обмоток драйверов.Проверить легко, измеряем индуктивность первички и потом соединяем по одной все обмотки, (конец с началом)которые есть и с каждой новой обмоткой, опять измеряем индук., она все время должна увеличиватся.Если с подсоединением, какой либо обмотки индук. становится меньше - это и есть обмотка с неправильной фазировкой.
DANTIST
Очень неплохо вышло! Хорошо, когда под рукой есть VITA.
Олег, вот только кнопочки управления током неплохо бы сделать поболее. А то сварному тискать их будет крайне не удобно. Они же, сварщики, довольно грубые мужики. А тут такие пиндюрки маленькие.
Всех с международным Днем Радиолюбителя!
kvaka
Олег обмотки проверил! Фазировка правильная! Самое интересное что один канал драйвера работает подключаеш второй икает. Отключаю первый второй работает. Подключаю на горячую работает.
oleg1ma
Увелич зазор в сердечнике.
kvaka
А до какой идуктивности доводить? Сейчас 1100.
oleg1ma
Да просто увелич немного, я даже и такую неделаю индуктивность, в среднем от 1200до 1500мкГн.Может у тебя ферит плохой.БП на тинках переделал уже более 30шт. и никогда таких проблем неимел, может у тебя, что лишнее подключено и мощность больше чем 6ватт, если так то нужно просто тупо заменить тиньку 264 на более мощную и все.
kvaka
Да вроде всё по схеме. Если только индикатор другой (из четырёх MAN6960G). И чем можно заменить( я и эту ждал 2 недели ( у нас в городе один ларёк с запчастями )). А VIPER22 не пойдёт??
oleg1ma
Заменить на TNY265,266,267,268, про випер нескажу. Какого сейчас стоят номинала резисторы на катоды индикатора?А реле силовое уже подключенно?
владимирон
подскажите чем лучше всего намотать транс силовой первич и вторич 2 штуки на е65 № 87 эпкос
kvaka
Резисчторы по 330. Реле и не подключал. Транс на EI 28 от компового тблока питания. Витки вроде пересчитал.
Wasiliy61
Смотря какой ток Вы хотите получить. Мотать можно хоть чем, в среднем что-бы первичка была 4-5 кв. а вторичка в среднем 14-16кв. Можно и больше сечение, но на Е65 впихнуть будет трудновато.
oleg1ma
Озвучте Ваши моточные.
kvaka
Моточные получились практически такиеже как в дешовом сверкальнике. Тоесть практически пополам с этими.
slavyann
VIPER - у нужна обмотка самопитания
владимирон
есть в наличии медная лента толщиной 0,1 пойдет для первички изоляция фторопласт. вобще по идее чем больше площадь сердечника тем меньше витков или я не прав
oleg1ma
Фторопласт несоветую, плывет, прежде чем что либо мотать нужно определится что хотите получить, может и одного комплекта хватит.
Wasiliy61
[quote name='oleg1ma' post='283451' date='19.4.2013, 1:08'][b]
Вы про что, что придумал. Я просто не внимательно прочитал сообщение, я подумал про сечение провода, я поправился. oleg1ma а нет ли на форуме печатки на 3825 на управу.
