Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
Nikolay1
ГонZZа,
Привет Гонза! Когда нас удивиш своими наработками? Жду с нетерпением
DANTIST
Цитата(ГонZZа @ 20.2.2014, 19:24) *
Вечер добрый.DANTIST,каждый вечер читаю форум,чтобы не забывать как собирать Бармалея.А так в свободное от работы время собираю ветрогенераторы,перематываю автогенераторы,клею магниты,добываю халявное электричество из ветра.
Вот это дело! Много ли добыл электричества? А там ведь тоже нужны преобразователи DC/AC. Т.е. ты недалеко отошел.
Мыкола, ну шо ты такой нетерплячий? Человек только начал осваивать ветроэнергетику. icon_biggrin.gif
matlah
Имеется 4 комплека ТВС, хочу их использовать, посколько имеются, сечение набраного провода первичка 12мм2, вторичка 32мм2. Просто было у меня уже готовые скрученые такие жгуты. Размотовать выпрямлять а потом опять скручивать не схотел. Какое количество надо намотать витков сылового транса, частота 38кГц, К зап.=0.44.
Я тоже приветствую Гонзу. Читал про его девайсы. Жду с нетерпением его наработки.
Павел(Sp)
4 твс не знаю как оно будет. Некто Мультик, думаю старожилы его помнят, делал на 6твс аппарат на 240а, там правда частота была 30kg ..давеча читал о сем девайсе..(черт, сейчас пинать начнут..)
Я не агитирую за строчники конечно,но как вариант..Сам слепил вот на 6 строчниках (правда на буржуйских..) но все нет времени до конца доделать.
Намотай пробную,поганяй на калькуляторе лысого,метода верная.(взаместо латра -то о чем я говорил выше,если еще есть транс гальваноразвязку сделать то вообще лепота).
Токо вот как по мне первичка 12см2 как то жирновато выглядит,вторичка 32 квадрата тоже как то уж очень..ну там если сил хватит скрутить ее на сердечнике то хай себе и будет..
truevoxdei
Парни, а что там на Украине? Включил телевизор и просто ужас какой-то! Не понятно, кто и кому врёт или лукавит...
KT117
Делали люди на 4 комплектах, правда частота была выше 50кГц.
Для вашего случая нужно намотать приблизительно витков 18-21 первички и 6-7 витков вторички.
Потом калькулятор лысого в руки берете и смотрите насыщение.
Впихнете такое сечение проводов в окно сердечника?
soud
oleg1ma вы где то выкладывали преобразователь с 12 для питания оптодрайверов. Не могу найти.Может подскажите где.
oleg1ma
Держите.
владимирон
[quote name='AS65' date='20.2.2014, 20:38' post='329758']
Ага и диодными лентами подсвети,зелёный всё ОК,жёлтый-нагрелся,красный-перегрев,
а чо это правильная мысль
Павел(Sp)
Извиняюсь за офф,не политический форум однако,но ссылочку дам,там оччень все правдиво рассказывают,с фото и видео,и новости последние всегда самые свежие... держи http://tsn.ua/
SANDER57
Доброго дня всем.Кто силен в PI E,скиньте пож проект на БП "малыша"Липина на TNY266.
combajn
НЕ кащунствуйте.
SANDER57
Вы зто про что?
sergey777.68
KT117
PIexpert9 эту микросхемку уже не поддерживает.
Вот что есть у меня , поправьте только вторички-разделите их
SANDER57
2КТ117.Спасибо,у меня как раз 8-й.Сейчас попробую,может получится
oleg1ma
Попробуй.
ГонZZа
Вечер добрый.DANTIST, програмисты отдали(подарили)списанные бесперебойники от компов-2штуки по 500ватт и 1штука по 1000ватт,вот их и использую!Работаю в автосервисе и насобирал по боксам акумов 6штук(3шт по 55Ач,2шт-63Ач,1-110Ач),зарядил их проверил и подключил в параллель к ветрякам,пускай заряжаются.Ветряков(мачт) пока два,на одной мачте установлено два автогенератора(как на самолёте),а на второй мачте поставил три шаговика от старых (списанных програмистами)принтеров,лопасти из канализационной трубына 160,
по три лопасти,вложений требуют только на неодим магниты.Но и сдесь нашёл лозейку,у тех же програмистов скупил Жёские диски от компов(в каждом диске по 2шт магнитов).Прошу прощения,что не по теме.
truevoxdei
Цитата(golub @ 21.2.2014, 21:54) *
чёт пишешь херню? Какие мирные студенты?Схема пробита как минимум с лета.
Оригинал сообщения не успел прочитать, но видимо что-то реально важное было.
Спасибо за новостной ресурс. Согласен, что не полит. форум - да и не нужно. Просто такие ужасы показывают по ящику, что даже не знаешь кому и где верить. Шокировали кадры бойца Беркута без глаза. Всяким "ютубам"... лентам... вестям... мэйламру... и подобным "местам" уже давно и "по-серьёзному" не верится. Зажрались и заврались.... Поэтому и спросил здесь, где хоть "трезво-мыслящий" народ. Всё таки был дед из под Киева (Броварі) так что к Украине всегда внимательно ( там его все родственники и целая куча сестер). Так что всем Гайдукам привет, если есть такие icon_mrgreen.gif
SANDER57
Олег,Спасибо.
владимирон
кто бы драйвер управления нарисовал я бы сделал и лента есть 3 цветная пол метра
Сергей_74
Цитата(oleg1ma @ 21.2.2014, 13:57) *
Держите.
Олег.. размер Ш и моточные можно узнать?
oleg1ma
Можно
Сергей_74
Цитата(oleg1ma @ 21.2.2014, 21:56) *
Можно
я имел ввиду данные на выложенный выше DC_DC.zip
oleg1ma
А по схеме непонятно?Cердечник Е16.
DANTIST
ГонZZа, ну ты чёрт! Нигде не пропадешь! icon_biggrin.gif Электричество-то хоть уже добываешь? В виде конкретных кВА.
iban2
Цитата(sergey777.68 @ 21.2.2014, 20:38) *
Эх. Купить бы готовые печатки. По-соседски (проживаю близ Магнитки).
С уважением.
владимирон
подскажите что будет если подключить датчик перегрева марки кдс напрямую к первой ноге. соответствено он на замыкание работает без всяких транзистором
и микросхем
Wasiliy61
и микросхем
Можно смело ставить.
maksim24
Здравствуйте уважаемые сваркостроители! Давненько слежу за вашей темой, хочу попробывать собрать данный аппарат. Вопрос такой с какой схемы посоветуйте начать с 165а и 100а? Мотать думаю силовой транс мотать на 2хш20х28 для 165а или 1хш20х28 для 100а ,знаю что много было сказано но всетаки скажите пожалуйста каким проводу по диаметру оптимально мотать, как в статье? Где то здесь читал что вроде как все наматывают пол первички-вторичку-пол первичку, вообще если можете поделитесь советом? И еще реально эта входная сборка держит 50а(сопливая она какая то) просто я на через нее 10а пропускал она греется как собака и плохо тепло к радиатору отдает, тут она справляется? Заранее спасибо!
and_w
Ну, вобще-то, все есть на форуме..... Ну а так- для 165А достаточно комплекта Е65 N87 для силового тр-ра, для дросселя можно 2 комплекта от строчника. По проводу- на первичку от 4 кв.мм, на вторичку- от 12 кв.мм. По виткам-зависит от частоты, на которую считаете... Я бы брал за основу 50 кГц..
Настоятельно советую печатку , нарисованную Д713 на 2-х парах транзисторов.... Просто я делал первый аппарат на ней- завелось все с пол-пинка...
maksim24
Где бы взять Е65 у нас негде токо в чип и дипе а у них цены кошмар а ш20х28 реально достать и если можно что за печатка одноплат (сылку если можно) знаю что на форумах все есть но все перечитать духа не хватит.
KT117
У вас-это где? Москва? В Москве есть человек Сергей , зесь он под ником Serg SP
, продает комплектующие на сварочники, цены хорошие, детали качественные. Смотрите его сайт http://power-electronica.narod.ru/index/0-2
maksim24
Я из Нижнего Новгорода а почему нельзя применить 2хш20х28 в статье именно он указан?
Serega30
Можно, но феррит Ш20х28 некачественый, сильно отличатся проницаемость половинок феррита(даже из одной партии) и надо ставить два комплекта Ш20х28 вместо одного Е65...
Jorg63
качество оставляет желать лучшего и разброс значительный по параметрам. но как говориться раз на раз не приходиться. могут вам попастись и нормальные ферриты.но всеже для транса что нибудь получше надо. для выходного дросселя эти ферриты прокатят точно.
maksim24
Ладно попробую поискать, а феррит с каркасом брать надо? А epcos или китай разнича есть могут на радиорынке сказать че хочешь? А еще вопросик можно не использовать автоматический датчик для регулир вентиляторов ну который кт814 можно как сделать чтоб они вкл сразу на полную просто убрать датчик или лмку тоже?
Сергей_74
Наконец то закончил с корпусом... Финиш.
После удаления всех "соплей" в виде длинных проводов до/от моста, аппарат на максимуме отдал 130А.. Продув очень порадовал..
Wasiliy61
Каркас можно не заказывать, а сделать самому из текстолита, или гетинакса- с помощью этой программы. Я все каркасы делал сам.Нажмите для просмотра прикрепленного файла
Бармалея можно сделать вот по этой схемеНажмите для просмотра прикрепленного файла
Питание 15вотьт, можно сделать одно, если реле и вентилятор потребляют не много.
maksim24
Спасибо за ответы и за схемку. Порылся в закромах нашел 2 комплекта ш12х16 посчитал Sc и получилось как у етд 59 может на них попробывать сначала для 100 а должно хватить? И вопрост по трг по вашей схеме на чем можно сделать ш7х7 есть от дроселя телика но там каркас не очень а на маленький сердечник както не удобно делать из текстолита может чашки использовать (кольца ломал по нормальному не получается)?
DANTIST
Молодец, Сергей! Очень аккуратная работа.
Сергей_74
Ну так есть у кого учиться...
Мужики всех с праздником!!!
truevoxdei
Парни, Всех с Праздником 23 февраля!
Украинским парням мира и благополучия! Пусть праздник всех объединит!
Wasiliy61
Спасибо за поздравления. Я тоже от души ВСЕХ поздравляю с праздником, ВСЕМ СЧАСТЬЯ, ЗДОРОВЬЯ, и ТВОРЧЕСКИХ УСПЕХОВ. С УВАЖЕНИЕМ ВАСИЛИЙ.
Serega30
Народ, Всех поздравляю с праздником 23 февраля! Мира и стабильности в жизни, удачи в творческих проектах.)
VOVA 555
Доброго времени суток форумчане . Присоединяюсь к выше сказанным поздравлениям .
maksim24
Присоединяюсь ко всем ВСЕХ С ПРАЗДНИКОМ!
Dominys
Wasiliy61
Ш7х7 у меня тоже много валяется, но я его так и не рискнул применить из-за качества феррита на Тгр. Может от того что было что ставить, хотя и его вроди применяют. В первых аппаратах делал на кольцах, маленькие легко ломаются - там где надо. Надпиливаешь надфелем места слома, ложишь этим местом на 3ёх гр надфель, сверху не большой брусочек, и легонечько ударяешь. Также и большие кольца ломают.В последующих аппаратах применял вот такой феррит, от импортных телеков.Нажмите для просмотра прикрепленного файла
Ш7х7 иногда ставлю в Б/П.
maksim24
Спасибо Василий61, будем пробовать, попробую сотку , делаю печать под бп на топ потом займусь управой будем придерживаться схемы с кольцами проблем слава богу у нас нет. Буду писать походу сборки! Всем спасибо!
