Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
Цитата(ДядяВася @ 14.12.2011, 21:24) *
покрутить болт, к которому подходит и 0, и земля, скорее всего он там один
в РФ не разу такого не видал
ДядяВася
А я видал последствия. Один гражданин, нетрезвой наружности, по какой то ему одному известной причине, решил проявить инициативу. Трансформатор на пол села стоит прямо в его огороде, огороженный, но это его не остановило. Залез туда, и из самых лучших побуждений открутил заземление. Напряжение гуляло покруче, чем у vovaanа, и не всякое электрооборудование выдерживало это издевательство.
Если у кого на это счет есть свое мнение, я не против. Излагайте его, типа - крутите только ноль, и ни в коем случае не заземление! Желательно аргументировать почему, а не рассуждать, что ноль и земля - две большие разницы.
p210
Дядя Вася, и все-таки, "ноль" и "заземление" -это разные вещи. Тот гражданин устроил в своем селе сеть с изолированной нейтралью. При неравных нагрузках на фазах напряжение на них ессно будет разное. А "ноль" - он заземлен, канешна (в наших "глухозаземленных" сетях).
UVM
Может всётаки кто нибудь из спорящих заглянет в ПУЭ гл. 1.7, там даже картинки есть того о чём вы спорите, электрик даже со II группой это должен знать, а здесь сайт электриков, это первое, а второе что для этого есть свой раздел и соответствующие темы!
ДядяВася
Цитата(p210 @ 14.12.2011, 22:43) *
... и все-таки, "ноль" и "заземление" -это [b]разные вещи.
Еще раз читаем сообщение 11791. Кто-то видит фразу, что 0 и заземление - это одно и то же? Может рассуждения на тему 0/земля помогут Вованну решить проблему? Сомневаюсь. Если мой совет неправильный, то, пожалуйста, скажите в чем ошибка, и дайте правильный. И хватит флудить, нашли развлекуху, а то придет строгий модератор с косой...
Полностью поддерживаю.
прямоход
В своё время я предложил такой вариант улучшения закрытия нижнего диода
Уважаемый Толян
Должен ли этот дроселёк участвовать в прямом ходе?
как лучше?
спасибо за помощь
толян
Цитата(прямоход @ 15.12.2011, 11:24) *
Уважаемый Толян
как лучше?
спасибо за помощь
А он и участвует в прямом ходе смягчая момент закрытия обратного диода.
САНЕК
Просто это две разных вещи и полемику можно долго разводить....
А Вовану это точно не поможет.
Возьмите УЗО и подключите по схеме с ЗЕМЛЕЙ,при этом подаем 0,что получится?...... icon_biggrin.gif
KSV
Вопрос к любителям ETD59. Потянет ли 160а при 50кгц. Сам как то делал АЛЯКОЛЬТ на ETD59 50кгц , но при 150а напряжение на выходе было 18-22в (точно не помню) и четвёркой он варил без переноски с горем пополам а больше 150 побоялся транзисторы жалко (50B60PD1).
zario
Это зависит от сечений литца который сможещ впихат в данный сердечник.
KSV
Габаритная мощность сердечника далеко не бесконечна.
zario
Согласен, но в сварочниках он работает с превышением габаритной мощности, именно этот факт определяет ПН всего аппарата
oleg1ma
Для Вашего случая ничего криминального.
электросталкер
Цитата(delivero @ 11.12.2011, 16:16) *
Я использую диоды BYW99W200. 2x15A 200В. никаких проблем с выходом диодов.
Чем вызван выбор именно таких диодов?А цена у них какая?
delivero
Я купил 50 шт. диоди BYW99W200 0,7 $ за 1 шт. просто очень хорошей цене.
для 120A прямых 2шт. в противоположном 3шт. полностью достаточно.
у нас 1шт. 150EBU04 e 10-12$.
zario
И насколько греется по сравнению с EBU? Выигрыш есть?
oleg1ma
Цитата(zario @ 19.12.2011, 8:44) *
А откуда можно скачать эту прогу?
Брал здесь
zario
Цитата(oleg1ma @ 19.12.2011, 15:17) *
Брал здесь
Благодарю!
fantom-2011
Приветствую Всех и каждого. Уважаемые подскажите плиз кто какие стабилитроны использует в драйверах Бармалея ну или других конструктивах косого ( не SMD) кроме КС 515 и КС 213 ? А то 213 кипят гады, а 515 еще не купил.
p.s. Паралельно читаю ветку Володина про драйвера.
KSV
В драйверах COLT применял обычные (импортные стеклянные) на 15в 0.5 и 1.5вт, больше грелось сопротивление 120ом паралельно первому диоду.
wkaktuz
Приветствую всех форумчан! Парни подскажите кто собирал аппарат с управой на TL494 до рабочего состояния, есть ли схемка?
UVM
Всех с праздником!
День энергетика сегодня если кто забыл.
не забыли
sarmat
Олег (oleg1ma) собирает схему Липина. На этом Шиме, правда крутилка на проце. Есть еще схема Лысова. Полный мост. В принципе управу можно использовать для других топологий.
wkaktuz
Я бы хотел использовать ее без проца!
oleg1ma
Поконкретнее, что хочеш собрать?
wkaktuz
У меня есть транс уже готовый ферит, правда параметров на него нет ( инвертек в 300 или стт-2) определьть немогу, есть уже готовая сила похоже от POWERWAVE® AC/DC 1000®. Прочитал весь форум и решился собрать для себя инвертер из этих лялек. Теперь собираю инфу.
oleg1ma
Тр-тор с зазором?Фотку брось.
wkaktuz
транс с зазором фотку кину вечером
oleg1ma
Тогда если собираешся его использовать, нужно делать косой мост.
wkaktuz
У меня сила уже готовая есть
схема силы
wkaktuz
Выкладываю фотки транса, рабочий ток примерно до 350 ампер
zario
Что за монстр это?...))))
wkaktuz
Какой то инвертек, определить немогу.
oleg1ma
Это у тебя что-то вроде спарки косых, нужно искать схему и востанавливать как было.
wkaktuz
Очень сильно похож нa invertec STT-2, но неуверен. Хотелось бы его использовать.
oleg1ma
Цитата(СМК @ 23.12.2011, 22:31) *
Похоже,просто обмотки поделили пополам.
Да нет, судя по силе спарка, только на одном тр-ре.
wkaktuz
Первичка две независимые обмотки, вторичка две последовательно соедененные с центральным отводом. Очень толковый трансик, но пока неопределился с управой чтобы начать сборку.
MaX 123
Скорее идея из области фантастики, но все же
Если для дросселя использовать ферритовый (может он и не ферритовый) раструб (соответствующим образом разрезанный) от кинескопов телевизоров для намотки дросселя
oleg1ma
Проще посмотреть на дросселя какие делают к примеру Dantist или Толян, дешево и сердито.
UVM
Никакой фантастики, видел фото сварочника на отклоняшке но это никому не нужный изврат!
MaX 123
Имеется в виду H образные из П образных половинок?
Может в этом варианте будет меньше фонить, чем от рогов H-образного сердечника
oleg1ma
Имел в виду на обычных полосках тр-рного железа.
zario
Братцы подскажите, кто нибудь делал силовой транс из несколких колец, например из четырех 40X25X11
STASKIN
Цитата(zario @ 26.12.2011, 20:33) *
Братцы подскажите, можно ли делать силовой транс из несколких колец, например из четырех 40X25X11
И какое сечение проводника с изоляцией Вы намерены вместить в отверстие 25мм. ?
wkaktuz
Lemm
поищите "чебуран Гиратора" icon_smile.gif только там вроде 14 колечек .
UVM
по форуму гуляют фотки "бинокля" из колец, так наверно нормально войдёт.
STASKIN
zario
Первичка лицт 1,8кв.мм вторичка 6,5кв.мм. Как в бармалеевском сотке, частота 60кГц
Прямая Ссылка есть?
