Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
SHA-SEREGA
Подскажите, подал на силу 30в, на выходе при к.з. импульсы на затворах не схлопываются, полярность тт менял, где искать?
SHA-SEREGA
Регулятор в верхнем по схеме, а вообще пробовал по разному
SHA-SEREGA
С 40в просаживается до 36, обвязку сто раз проверил, целый день убил, уже голова пухнет
Lemm
если вместо тт на 3 лапу подать регулируемое напряжение через переменный резистор с 5 вольт - должны схлопнуться . порог очень острый .
KSV
R шунта надо запаять побольше, 10-15 ом , должно заработать, если нет других косяков. У меня на 30в работало.
SHA-SEREGA
R шунта это который 1.6 ом по схеме ?
Serega30
Уменьшыл разистор на Тт до 1,6. Ток 125А. Похоже это придел для моей сети.
Jorg63
если четверка электрод будет варить нормально то ток у тебя реально выше будет. похоже твой амперметр врет
KSV
Через диод, параллельно ТТ.
Serega30
При сварке тройкой напряжение сети падает до 160в, а на дуге держытся в пределах 20...25в.
slavyann
icon_eek.gif ну на такой сети только двойкой варить
Сергей_74
Вечер добрый.. Есть конденсаторы Epcos MKP X2 на напряжение 305V AC..
хочу их использовать в качестве блокировочных входного выпрямителя(паралельно эл.литам)
по ДШ написано что, макс. постоянное напряжение 630V.. Использовал ли кто такие именно конденсаторы как блокировочные?? Если верить написанному то вполне годятся..
Kalin Ivanov
скажите мне пожалуйста ,у меня здес такой ферит для Тт -20/10/7.5 , Материал K5500. Сколько витков нужно для 130А. Нагрузочный резистор ТТ 1,6 ома.
Jorg63
я думаю этот феррит не пойдет.но попробуйте ,какой сигнал выдаст транс тока.
а количество витков в трансе тока значения сильно не влияет. нужный ток можно подобрать нагрузочным резаком в трансе тока.
covex
Цитата(Kalin Ivanov @ 16.3.2014, 23:06) *
..ферит для Тт -20/10/7.5 , Материал K5500. Сколько витков нужно для 130А. Нагрузочный резистор ТТ 1,6 ома.
Мотайте столько, сколько написано в схеме которую делаете.
Здесь важен коэффициент трансформации ТТ. Я бы намотал так, чтобы влез один слой провода до заполнения около 100 витков, для этого кольца примерно 0,25-0,3 мм. А нагрузочний резистор можете подобрать, его лучше делать из паралельных большего номинала.
Опередил Jorg63...
KSV
В архиве есть расчёты для ТТ и ТС посмотрите.
DANTIST
Сергей, а чего ж их не использовать? Я их регулярно использую. На фото типичный пример использования. В этом деле главное сделать ноги покороче. На фото кондеры, что стоят на силовой плате, расположены несколько неудачно. Но там место не позволяло поставить его вертикально. Да и обдув резисторов он бы перекрыл. Короче, так не ставь! Были случаи отгорания ног с последующим выгоранием ключей.
На банки я, обычно, ставлю от 1 до 2,2 мкФ. На ключи 0,47, 0,68. Желательно 2 кондера. Иначе один отгорит и труба дело.
В крайнем 3-х фазнике применил крутой кондер на ключи. CBB15. 0,47х1200 В. Круто, но дорого.
И еще небольшая статейка по кондерам.
Сергей_74
Спасибо понял..
Меня вначале смутила надпись на корпусе 305V AC, вот отсюда стал колебаться, прочитав ДЩ понял, что можно применять, и на всякий случай решил еще уточнить у спецов icon_smile.gif..
Wasiliy61
Цитата(Сергей_74 @ 17.3.2014, 18:47) *
Спасибо понял..
Такие кондёры можно ставить и на которых написанно 275V, это указанна переменка, а постоянки они выдержат 275 х 1,42=390,5V
Сергей_74
Еще раз спасибо, именно этого я не знал, вернее полагал, что это правило касается только эл.литов.
Serega30
Мира нам! Кто делал Ктр 2,5 и что надо при этом учитывать? Спасибо.
DANTIST
При этом нужно учесть, что на хорошей сети будет много (относительно) напряжения на выходе.
Serega30
Wasiliy61
Цитата(Serega30 @ 18.3.2014, 17:35) *
Serega30, если ты зделаешь Ктр2,5- мне кажется тогда и ключикам будет потуже, я думаю что всё дело в силовом трансе, ты всё что-то выгадываешь- мотаешь тонким проводом, тонкий провод просто не может набрать желаемую плотность тока. Намотай транс хорошим проводом, и я думаю что у тебя будет всё окей. Твой транс наверно сильно греется, когда ты с него пытаешься вытянуть побольше.
DANTIST
Цитата(Serega30 @ 18.3.2014, 10:35) *
Тю! Люди через себя лампочки на 220 В зажигают. И ничё. Ты ж не КЗ, надеюсь.
Слушай, Serega, меня терзают смутные сомненья, а ты, случайно, не... Коля? Что есть общее.
Lemm
выходные диоды на 200 вольт уже не пойдут .
Wasiliy61
Цитата(Serega30 @ 18.3.2014, 19:40) *
Стоят ЕБУ04
Меня тоже они иногда терзают, вот и уточняю информацыю. P.S. а кто такой этот Коля?
Коля, да он не так давно нас посещал, сейчас он занимается форсированием двигателей, или увеличивает степень сжатия, чёт тип того- наверно помнишь, он посечал нас последний раз с поршнями, как наплавить или наварить.
truevoxdei
Цитата(Wasiliy61 @ 18.3.2014, 20:53) *
... он посечал нас последний раз с поршнями, как наплавить или наварить.
В следующий раз посетит уже с ракетными соплами .... куда наплавить и что наварить. Вангую.
dikobraz
Добрый вечер. Сегодня перемотал наконец то транс, первичка 4мм2, вторичка 19мм2, зазор каптон, индуктивность первички 660 uH, инд. рассеяния 3,1 uH. Намотано в один слой 12 витков первички и один слой 4 витка вторички. Для второго раза думаю достойно, хватит ли для этого транса 60 кГц?
slavyann
если на Е 70, то прога говорит, что хватит; а почему в зазор каптон ?
Wasiliy61
если поточнее
Если Е-70 то вотНажмите для просмотра прикрепленного файла
Если Е-65 то вотНажмите для просмотра прикрепленного файла
truevoxdei
Цитата(Wasiliy61 @ 19.3.2014, 1:38) *
это из какой программы?
RadioГубитель
См здесь
dikobraz
Ну все, счастливый как слон теперь!!! А каптон под рукой был, да и толщина у него 0,05 почему бы и нет.. Мужики спасибо за помощь, буду двигаться далее, медленно, но вперед! aaa.gif
DANTIST
Цитата(dikobraz @ 18.3.2014, 20:13) *
Serega30
Хлопци, вывод конца первички(см. фото), можно так пускать под вторичной обмоткой, или это конкретный косяк? P.S. Имеется в виду влияние на работу транса...
tranzistor3102
[quote name='Sereg
Serega30 не какого влияния на работу транса от выводов конца первички под вторичной обмоткой не должно сказываться.если конечно в обмотках нет к.з
DANTIST
Serega, зачем тебе лишний геморой? Сделай в щочке пропил и выведи туда шину. А потом поверни ее также, но поверх вторички. Как раз на этот вывод и колечко ТТ накинешь.
Примерно, как на фото. Только тут у меня вторичка так повернута.
DANTIST
Цитата(Serega30 @ 19.3.2014, 8:22) *
А на сколько Ампер сей девайс коль не секрет?
... Витки 17/6, Кзап 43%, f=46,8 кГц,.
Serega, ну какие тут секреты. На нагрузке 0,17 Ом он показывал 160 А. Сеть домашняя, но довольно хорошая.
А что у тебя за феррит? Е65, Е70?
DANTIST
Serega, я тут как начал мотать трансы для очередного аппарата. Будет 2 транса Е65 последовательно.
Небольшая фотосессия по ходу дела. На правом фото первичка покрыта эпоксидной шпаклевкой с меж обмоточной изоляцией.
RadioГубитель
Подскажи маркировку таких классных каркасиков. А то у нас один сифилис сплошной, ломаются еще до намотки icon_biggrin.gif
DANTIST
Каркасы с сердечниками брал у Терейковского в Харькове на ferrite.com.ua. Зовется ЕЕ-6502. На рисунке он с ножками. Но там ниче не было. Довольно крепенький такой.
UVM
Я очень похожий в "ЛЕПКОСе" брал, они только Юр. лицам и ИПшникам продают(высылают), ходили слухи что Терейковский тоже там оптом отоваривался.
p210
Изменились порядки? Давно там не был. Раньше высылали всем, кто закажет. Я вот просто физ. лицо.
RadioГубитель
Я там брал месяц назад. Не такой плотный попался. Хрупкий. А физикам они шлют, без проблем. В малых количествах правда цены конские
DANTIST
Этот тоже не сильно крепкий. Есть материалы покрепче. Типа капрон, что ли.
Неудачно прижал уголок при намотке - откололся. Клеил цианопаном.
RadioГубитель
у меня капроновые е70 - намного лучше. а 65 подобных не видел. бяда
KSV
В митино в цокольном этаже есть ларек с ферритами, их там море всяких и цени нормальные. Я там недавно брал ETD59, кольца и мелочевку для БП и ТГР, есть и китай и фирменные. Если нужен номер , то завтра, визитка на работе.
RadioГубитель
там нету icon_smile.gif я завсегдатай той палатки.
Сергей_74
в "ЛЕПКОСе" они только Юр. лицам и ИПшникам продают(высылают)
С какого это перепуга? я месяц назад получил свой заказ как физ. лицо
