Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
gynik
Маленький вопрос к знающим форумчанам - от чего зависит величина тока КЗ и как ее можно уменьшить. Транс 2 х Ш20*28 Н2000НМ-8 16/5.5 вит., раб. частота 75кГц. Выходной дроссель 35мкГн. Ток 160А, ТКЗ 320А.
Лопух
Цитата(gynik @ 10.11.2010, 4:45) *
от чего зависит величина тока КЗ и как ее можно уменьшить. ... ТКЗ 320А.
Ничего себе ток КЗ! Надеюсь, КЗ проверяете не на прямую на клеммах, а на сварочных кабелях? А то уже был прецедент. Вообще-то регулировать ток КЗ можно RC на 3-й ножке ШИМ.
HEMELL
Наверно только вместе с максимальным током. Лично мне Т.Т. представляеться еще и как измеритель вых. мощности. По этому при К.З. ток выростает потому, что в этом случае напряжение падает очень низко. Глядя на формулу W=IxU Т.Т. стараеться сохранить это произведение (матимат.). ИМХО.
Теперь собственный вопрос: При нормальной работе "косого"ключи должны одинаково нагреваться или разница в температурах всётаки должна быть? Кто такое замечал - ответьте. спасибо.
golub
При одинаковых снабберах, затворных сигналах и теплоотводах, нагрев обязан быть одинаков.
yura_
Сильнее греется диод, на которой дроссель висит.
Wiew
Ток 160А, ТКЗ 320А.
Бармалейник что ли?
может 160А у Вас сетью ограничены, а на самом деле максимум больше выставлен?, или задержки смотрите.
Basill
Зависит от быстродействия (величины задержек) распространения сигнала от ТТ через 3-ю ногу микросхемы (проверить и м.б. уменьшить конденсатор), через задержки в самой микросхеме (возможен брак), а также процессы в узле ТГР-драйвер.
При настройке на минимальном заполнении (с временной цепью регулировки заполнения на холостом ходу) проверить форму импульса на затворах ключей. Если на минимальном заполнении появляется существенное затягивание спада импульса на затворе и резко падает его амплитуда, то ТГР и драйвер работают неудовлетворительно. Возможен даже бах, поскольку правильно не срабатывает ограничение тока по всей цепочке от ТТ до затворов.
И ещё: ИМХО для такой частоты сильно завышена индуктивность выходного дросселя. Это тоже "инерционный" элемент (говоря простым языком), имеющий влияние на первичную цепь и не способствующий увеличению быстродействия схемы в плане ограничения макс тока КЗ.
HEMELL
Голуб и Юра, спасибо.
gynik
У меня не совсем Бармалей (http://adsh.ukrweb.net/radiohobby/viewtopic.php?id=1970&p=79 схема от Jaxon)и регулировка тока по 3-й ноге и емкость там висит 470пФ и делитель малость изменен (для расширения регулировки тока до 160А). Схема работает практически без настройки, если собрана без ляпов. В оригинале там рег.тока 40-120А и ТКЗ примерно 170А. Я изменил данные транса, добавил вх. емкостей и практически всё. Задержка спада примерно 200нС, провала по амплитуде импульса нет. Дроссель немного меньше, чем я указал - ок.20мкГн.
Basill
Извините, я думал Бармалей, раз вопрос прозвучал в этой ветке без уточнений. В своем "Бармалее" задирание тока КЗ я вылечил заменой бракованного конденсатора по 3-й ноге и перемоткой ТГР в соответствии с рекомендациями форума, вот и написал по опыту. Кстати, Ваша ссылка на схему у меня не открывается.
gynik
ссылка рабочая - это ссылка на форум по той схеме. А вот ссылки на схемы
http://www.rapidshare.ru/1319278
http://www.rapidshare.ru/1160312
lapa
Небезспорно. Дроссель правильный тормоз.Он необходим не только прямоходу но и дуге, поскольку стабилизирует ток дуги и препятствует её самопроизвольному погасанию.Чеи больше дроссель тем хуже тухнет дуга, поэтому и тянется.
Возможно 320А ошибка на таком токе должно было блызнуть. Мне крайне не нравится такое включение ТТ. На крайний случай 100 витков и нагрузку 15 Ом. Не являюсь поклонником и трансформаторного драйвера,
а здесь нечто причудливое. Это небходимо моделировать и смотреть нет ли проблем в области малого коеффициента заполнения, а они наверно есть.Возможно нужно взять КТ973 из другой партии. Классический Бармалейный драйвер основательно вылизан сообществоми больших проблем там нет.
aog1996
"...А вот ссылки на схемы..."
Еще раз убедился в непревзойденности Barmaley'я.
EVDOGW
Привет всем! До с кальки можно поднять частоту ключей IRG4PC50UD
славик24
по моему не больше 40кгц
maxx
Dedan
Цитата(STASKIN @ 9.11.2010, 13:29) *
Все в раздумьях-с чего-же теперь их ваять!
Перекуем мосты на косарей!!
maxx
Вопрос не по теме icon_smile.gif , как сделать в P-CAD сквозное отверстие(типа монтажное-в смысле просверленное без металлизации) в виде дуги или другой формы, допустим формы С -ширина 1мм? Может задать линией для контура печатной платы? Примерно так охота, но будет ли эта линия прорезом, или создать вместо одной линии контур вокруг неё более тонкой? Пошлите, в конце концов, меня куда-нибудь в правильном направлении icon_smile.gif , где можно почитать...
DANTIST
А, по-моему, если судить по ШИИТУ, так они вообще никуда не годятся. Но народ на них делает. И я лично знаю одного аматора. Только он запараллелил по два ключа. Частота, если не ошибаюсь, у него была 35 кГц.
Или это - уже началось. Нема шо ставить в аппараты. В ход идет лучшее из худшего.
gyrator
А что здесь думать, когда ясно написано:
Если говорить простым русским языком, то при мягкой коммутации может работать до 200кГц. Например, в фазнике.
Д713
при наличии снабберов можно вполне залезть и за 40 кГц,никем это не воспрещено.
gyrator
Запросто. Однако, наличие демпферов-это уже не hard коммутация. icon_biggrin.gif
Д713
точно так!
для эксперименту было изготовлено пару "бармалеев" на 2хIXGH24N60B (по доллару за корпус,эх-х..) в плече при 70 кГц на одном Е70,все работает и по сей день,умирать не собирается. icon_biggrin.gif
gyrator
Отож. А в виртуале и на 140 кГц мультификсер работает и тем более помирать не будет. icon_biggrin.gif
EVDOGW
Привет всем! Что скажите на счет транзисторов GT40T301 пойдут или нет?
logic777
доброе время суток, инверторная общественность.
возник следующий вопрос. при прошедших испытаниях закончившихся бахом возникла проблема с наблюдением осцыллограм. связано с монтажем.
вопрос следующий: можно ли припаять проводочки от контактов транзисторов, чтобы к ним цеплять щуп?
если да то какова их длинна и пр допустима.
Basill
Когда-то ув. кабельщик выкладывал подробнейший фотоотчет о ремонте Тельвина, включая осциллограммы и способ их снятия.
Вот картинка оттуда:
golub
по пять сМ цепляйте, проблем не будет
HEMELL
Транзистор STW26NM60, 30А, 600V, N-канал, полевой, корпус ТО-247. В Киеве на Кардачах по 20 гривен за штуку. Кто что может сказать на предмет применения этих транзюков в инверторостроении? Ведь дешево и сердито.
logic777
golub и Basill, благодарю. я и думал припаять. но малоли как они себя поведут. а припаивать прям к схеме не особо выйдет icon_smile.gif
а вот пяти. или даже 3 см будет норм и рпиклеить их горячим клеем чтобы не коротнули ненароком.
HEMELL вот эти STGW20NC60VD некий "lapa" покупал. писал об этом на последней странице барахолки инвертостроителей. они близнецы с Вашим. спросите у него как такие в эксплуатации.
gyrator
Отож. Не понятно только, почему сами производители обзывают сей продукт "старьём"? icon_biggrin.gif
HEMELL
А что можно сказать по канкретнее? ...с англицким плохо дружу.
lapa
STGW20NC60VD имеют х-ки близкие к IRG4PC50W ( но лучшие ). Я их так и не использовал. STGW20NC60VD в два раза слабее. Они не старье (2002г. даташит) видимо непошли и попали под сокрашение.
HEMELL
Пугает не это, можно баян поставить (2 в паралель), но сумарная ёмкость затворов какая будет!!!
Konstantin65
Пол года назад делал сварку на STE53NA50,вот там емкость так емкость. Отдал в деревню,до их пор все варят.
logic777
а какие ключи пользовать?
с условием, что не будешь заказывать даже мелкоопт.
мне проще прийти в космодром и купить полтинники W к примеру.
HEMELL
Вопрос к тем, кто "собаку съел" на Кольт1300:
Как правельно определить фазировку Т.Т.? Меняю концы Т.Т. местами при минимальной задачи тока и практически никакой разници в ШИМе не наблюдаеться, т.е. ширина ШИМ одинаковая в обоих вариантах. Мерял на нагрузке вольтметром (нагрузка 1ом) в одном положении показало около 30 вольт, в другом около 28 вольта, выбрал 28 вольт и оставил в этом положении. Это что, так и должно быть?
golub
при одноомной нагрузке ничего и не должно меняться.
При неправильной фазировке ТТ не сможете поставить минимальный ток при 0,2 ома в балласте.
HEMELL
Сейчас при минимальной задаче на нагрузке 0,15ом минимальный ток около 30и ампер, значит я наверно угадал. Спасибо.
HEMELL
А вот собственно и сам аппарат, настроен и работает, осталось кормус сделать.
Транзисторы PD1 припаены на медный радиатор (сплав розе).
На выходе три 150-ых диода. Выходной ток - 160 А. БУ без ХОТ-старта, такой как по статье Володина из журнала РАДИО, но на свободном четвертом элементе LV324 добавлено управление вентилятором.
_http://depositfiles.com/files/84vd4tt5g
sabonis.79
привет всем!хотел спросить,кто заказывал в платане транзюки IRGP4063DPBF,как работают?не подделка?уж больно цена низкая 127р за шт.я ещё там не заказывал,дайте совет пожалуйста
Андрон IV
Попробуй, закажи.....Мне ответили-"нет возможности поставить". А так, вообще- красиво.....127р за шт.
RUS5610
Всем привет! На днях в радио магазине меня приятно удивил продавец что у них есть ключи на сверкальник 140N60 по цене 400р.Кто нибудь сталкивался с такими ключами?
aleksandr64
привет всем!дайте совет пожалуйста
Цена хороша, но в платане не купите.
sarmat
В Платане я брал много чего. Без подделок. Как заметил Андрон, там их нет и врядли будут. Старые запасы исчерпали.
aleksandr64
Если сталкнёмся, то в будущем.
aog1996
Цитата(HEMELL @ 28.11.2010, 19:29) *
А вот собственно и сам аппарат, настроен и работает,...
Красиво и гармонично.
?: не мало железа на дросселе на 160А ?
Basill
Видна аккуратность и тщательность во всём :!:
Вопросы: 1) предусмотрено ли мех. крепление платы управления (поскольку вставляется в разъём без запаивания)?
2) где и каким образом конструктивно устанавливается датчик температуры VD23 ?
HEMELL
Дросель от ТВС 90ЛЦ2, намотан двумя мед. полосами в паралель 32х0,35 (за 21 квадрат) 15 вит. индуктивность - 35 микрогенри, что вроде бы для частоты 50 кГц. достаточно.
golub
для 50-ти многовато.
Да и сытится будет на токе даже меньше заявленного
А зачем ещё датчик, двух термиков мало? Разве что для карлсона.
