Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
Basill
Цитата(Павел(Sp) @ 13.9.2013, 23:13) *
А можно ли мотать обмотки на строчниках обмотки одна напртив другой......или все эти кун-фу выделываются в связи с индуктивностью рассеивания транса?
Для бармалейника - нельзя. См. пример ЗДЕСЬ, ссылка "Как не нужно мотать трансформаторы"
KT117
Цитата(Павел(Sp) @ 14.9.2013, 0:13) *
В принципе тогда можно и на два склееных один на другой строчника мотать как на кольцо(маразм... квдратное кольцо,да ладно вон у мастера Гонзы и не такое бывало..) ?
А почему вторичку в скотч а не в термоусадку тоже? Из-за нагрева?
И вопрос ко всем гуру.. глупый наверно но жопаделаеш ,как мой дядя говоит...
А можно ли мотать обмотки на строчниках обмотки одна напртив другой,как я видел в промышленных трансах на железе? А не одна под другой или как мотают вторичку внутри первички,так вроде охлаждение намного лучше,или все эти кун-фу выделываются в связи с индуктивностью рассеивания транса?
Типа...не гуляйте вокруг озера...а то прийдет бабай..
Я всегда считал, что европейские радиолюбители живут в этаком радиолюбительском раю-и детальки у них есть под рукой всегда самые продвинутые, и программки юзают такие же. На западных радиолюбительских форумах посмотришь-сплошь и рядом разработки на ардуино, меги самые распоследние, про ферриты вовсе умолчу icon_smile.gif.
А тут из самого передового центра Европы такие вопросы идут-склеить строчники...
Можно, конечно и склеить, все будет работать. Сечение только нужно будет набрать под нужную частоту ключиков.
На разных сторонах мотать-для бармалейника нужно минимальное значение индуктивности рассеяния, сможете добиться индуктивности рассеяния не больше 5мкГн чего не намотать.
Но на строчниках проще делать Ш-образно
Павел(Sp)
Можно, конечно и склеить, все будет работать. Сечение только нужно будет набрать под нужную ч и бе застоту ключиков.
Нет,оно конечно все есть и без проблем иди и покупай сколько влезет,только вот бюджет не всегда позволяет,ето так про любые детальки...
А вот с ардуинами и прочим у меня личная идеино-техническая несостыковка,проосто как говорится невосполнимый провал в моем образовании на эету тему.
А вот с ферритами в нашей столице туго,я уже говорил что в моем чемоданчике под шкафом ассортимент такой что оба местных магазина от зависти умрут если эти рудники увидят,только вот все малоразмерное.
А так по рассыпной комплетухе широкого применения тут нет проблем,а вот специфические компоненты некоторые с проблемами,ну типа как любой базарчик,если нет спроса на елки в мае,то их никто и не продает.
Ну честно говоря ключи G80N60 я себе не могу с магазина позволить,а вот на металоломе в эту субботу еще 4 штуки добыл. Тот кто родился в СССР помнит что многое приходилось доставать,хотя теоретически оно было в продаже,тут типа похожая ситуация с некоторыми вещами,хотя в магазине где я покупаю все фаерчилдовское и мнгое дешевле чем китайское в ебее,а вот ферритов толстых нет.
Короче,вдохновение почти вернулось,мож завтра вытяну бармалея из под шкафа,кстати кто подскажет, а то я никак даташит на английском не победю..
G80N60 до какой частоты без грома и молний работать будут или они только для индукционных кухонь годятся,по току они 80а и до 240 в импульсе.
KT117
в соседней ветке http://www.electrik.org/forum/index.php?showtopic=25898 на паре таких ключиков в плече сделали аппарат на 220А на частоте 50кГц
SEDOY69
DANTIST.СПАСИБО.
DANTIST
SEDOY69, посмотри еще вот. Здесь внешний вид, чего получилось. Может пригодится в качестве информации к размышлению. Да и голая печать без фото, как-то не то. Это, похоже, тоже, что и на печати. Аппарат постоянно немного менялся. Вот этот вариант наиболее похож.
Печать управы на SMD перепроверь. Я ее только протравил, но не собирал и не запускал. Пока без надобности.
Удачи.
Kalin Ivanov
Олег1ма , вот мой осцилограми для управление.Они правилни ли?? Нажмите для просмотра прикрепленного файла Нажмите для просмотра прикрепленного файла
oleg1ma
Цитата(Kalin Ivanov @ 14.9.2013, 17:01) *
Они правилни ли??
Да, двигайся дальше.
Jorg63
нормальные импульсы,выбросы уберите чуть меньшим напряжением стабилизации стабилитронов в затворах,хотя эти выбросы погоды не делают.
Jorg63
Kalin Ivanov! Судя по последним импульсам G-E вы подали силу на ключи. импульсы в норме,криминала нет.Какой размах у вас импульса?
Jorg63
Kalin! в пределах нормы импульс
Kalin Ivanov
затем могу папробам варит ?
Jorg63
Вердикт Олега получи! Какой размах сигнала на G-E?
Kalin Ivanov
5V/ дел
http://forum.cxem.net/index.php?showtopic=122567&st=60 на етой фото импул различный из моего
Jorg63
Цитата(Kalin Ivanov @ 14.9.2013, 19:23) *
5V/ дел
судя по вашим осцилограммам на G-E если 5V/div то размах сигнала более 20 вольт???????????усиление ослика регулятор на максимуме?
oleg1ma
Проверь на баласте, потом вари.
Kalin Ivanov
ок, папробам на баласте, да размах 20волта
Jorg63
УДАЧИ!
KT117
Это Липинский, там отрицательное смещение -10В, так что положительная часть сигнала +16В
Jorg63
позже я глянул схему и все непонятки снялись
Павел(Sp)
Вот купил я как дома был такой вот штук.
По внешнему виду это транс ц выпрямителем,снаберными конденсаторами,диодами и дросселем выходным.
Дантист, Олег вы самые старые и стреляные воробьи(есть такоое выражение в народе)..вам не знаком такой елемент?
Его в советской армии использовали в борьбе с мировым империализмом.. может я тут зря вдохновение ищу, просто взять и припаять его в бармалея..?дроссель медной полосой намотан а транс первичка 2 провода 1,6мм, вторичка шиной 16 квадратов,диоды 4шт кд29921.
Только толстый черный провод с клемой имеет один выход.
Ест еще обмотка тонким проводом, на фотке ее не видно почти..ферриты 28х20х80мм.
Встречал кто нибудь такое.Мужик говорил что это с какойто военной передвижной мастерской отковыряли, говорил что дома еще имел, но я уже уезжал..
SEDOY69
DANTIST.спасибо за портфолио.Скажу только одно - УМЫТАЯ РАБОТА. Читал, Вы где-то на форуме выкладывали фотографии намотки тран-ра. Выложите, если остались-пусть люди посмотрят еще раз. Мало кто сможет так намотать.
fantom-2011
DANTIST
Ну пропустил одну букву, ну и чё ?
А транс на кольцах не считаю - их уже умные люди посчитали на этой ветке и на соседних ( Олег , Юрий, Эрика), за что им огромное спасибо.
Последний собирал год назад ММА от Юрия (мега 8 в DIPe). Работает как часы и никаких глюков. Транс мотал на кольце N 87 , витки точно не помню, что-то : первичка - 27 витков, вторичка - 9, частота 45-50 кГц. Точно не помню. icon_rolleyes.gif
Wasiliy61
Нажмите для просмотра прикрепленного файла Ребята, это что за хрень-термодатчик что ли ,и как узнать на сколько градусов.
gravis
Павел(Sp) спросите у Олега, он большой специалист по "квадратным кольцам", многое может посоветовать.
DANTIST
Цитата(fantom-2011 @ 15.9.2013, 16:28) *
DANTIST
Цитата(SEDOY69 @ 14.9.2013, 21:21) *
...Вы где-то на форуме выкладывали фотографии намотки тран-ра. Выложите, если остались...
Из свежего.
Сегодня мотнул транс на Е80. Без каркаса. Частоту придется делать не меньше 60 кГц. На первичку поместилось всего 18 витков. Лучше было бы 21.
В архиве процесс его изготовления. Может кого заинтересует.
Jorg63
DANTIST!Оригинальное исполнение обмотки!при такой намотке ухудшаеться связь с феритом,.по идее характеристика сварочная должна быть мягче. смотрю лакоткань вроде межобмоточная изоляция,.если так то это не очень.
Jegan
Это не лакоткань, а полимидная лента.
DANTIST помоему там 19 витков, или я ошибаюсь?
DANTIST
Да, это лента, не лакоткань. Вот только не было нужной ширины. Использовал с трансов телеков 3-го поколения.
На первичке действительно 19 витков. Желательно было бы намотать 21/7. Но тогда бы на первичке был тонковатый провод. Лентой не стал мотать. Решил поднять частоту и намотать 18/6. При намотке осталось место для 19-го витка. Будет немного меньше выходное напряжение. Может оно и к лучшему. Планируется ММА/МАГ/ТИГ. Если не ошибаюсь, для МАГ коэф. тр-ции вообще рекомендуется 3,8, а для ТИГ - 4,2.
Цитата(Jorg63 @ 15.9.2013, 18:49) *
...при такой намотке ухудшаеться связь с феритом,.по идее характеристика сварочная должна быть мягче.
Лично у меня нет данных по влиянию такой намотки на сварочную характеристику. Но со слов старших товарищей - разницы, практически, никакой.
olegators68
Мультик и зажигалка в помощь вам, icon_biggrin.gif удачи.
Павел(Sp)
Цитата(DANTIST @ 15.9.2013, 18:35) *
Из свежего.
СИЛА... сказать больше нечего, остальное вы видели...
почти, только не зажигалка а кастрюлька с горячей водой и терьмометръ
slavyann
DANTIST, и скока ампериев планируете выжать из Е 80 ?
у самого такой валяется, надож когда то применить )
DANTIST
Планируется выжать 160 А при ПВ 60%. Будет стоять в хорошем обдуве.
Надо сегодня промерить индуктивности. Что-то я упустил этот момент.
сулейман
после кипячения и зажигалкой не страшно ))))
Wasiliy61
Цитата(DANTIST @ 16.9.2013, 12:27) *
Не DANTIST, это оказался не детонатор, подключил его через прибор, стрелка отклонилась не показав сопротивление, далее я опустил его в горячую воду, и он разомкнулся. Проверял градусником, при 57градусах он замкнулся. На нём написанно 331+057Н- значит датчик на 57гр.
Откуда такая хрень у меня взялась, не помню.
DANTIST
Бывает...
Где был я вчера - не найдешь днем с огнем. Только помню, что стены с обоями... icon_biggrin.gif
Wasiliy61
Всё так, только наверно Клавки с подругой не было, иначе-бы они сказали, откуда эта хрень.
oleg1ma
Хорошо, что вдова все смогла пережить, пожалела меня и взяла к себе жить. icon_biggrin.gif
KT117
icon_smile.gif Усе, Бармалейник закончился-началась дискотека.
Wasiliy61
Нажмите для просмотра прикрепленного файла Чёт 2,2к остались только такие, пади ничего.
Jorg63
Оба резака авно полное!!!!!!Особенно левый.В инверторы их и близко нельзя.
DANTIST
Цитата(DANTIST @ 16.9.2013, 10:21) *
...стены с обоями...
Понедельник - день тяжелый. Надо немного разрядиться.
По поводу транса. С зазором в толщину пленки полиимидной (или как ее там) первичка 1 mH, индуктивность рассеивания 4-5 мкН.
Сейчас стал вопрос с дросселем. Есть два варианта. Распыленка и альсифер. Габариты у них практически одинаковые, да и проницаемость где-то рядом.
17 витков на одном и другом дают индуктивность 42 мкН.
Кто, что скажет по поводу на чем сделать дроссель. Все-таки ток не маленький. Нужно порядка 160 А. Я больше склоняюсь к распыленке.
VOVA 555
DANTIST
Я на альсифере делал по размерам помоему один в один до 140 а нагрев минимальный на ощупь градусов до 35 . А на распыленке говорят нагрев больше.
Wasiliy61
А чем они плохи, мощьность мала что-ли.
tranzistor3102
мошность у них достаточная лично я использую во всех своих свар.инверторах .просто такого номинала почему-то не попадалось китайского производства минимум 5ком (попадаются конечно и брак-плохой контакт в начале или в конце резистора)
Jorg63
ну очень быстро начинають"шуметь"
как вариант привести резак,который справа на фото в надлежащий уровень,разобрать его,удалить смазку что была на резистивном слое.но обычно там сухо.нанести тонкий слой технического вазелина.также закрыть отверстия чтобы не поступала пыль.
Ыгар
Цитата(RomzesDn @ 21.2.2011, 17:59) *
на радиорынке в Днепропетровске IRG4PC50U по 35 грн (4,37$).
Цены хоть и не самые низкие, зато не перемаркер. Продавец, он же и хозяин, уже много лет там торгует, пока ниодного случая подвоха. по крайней мерее, на китайских деталях китайские логотипы....)))
Если кому интересно - могу помочь с приобретением.
Подскажите пожалуйста как найти этого честного продавца, заранее благодарен.
slavyann
Jorg63, полное г... это то, что кетайцы в аппараты свои лепят (на фото), а эти совковые работают, мы ж не ламповый усь строим, чтоб говорить о шуме; тогда уж и монтаж нада бескислородной медью лепить
