Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
Wasiliy61
Нажмите для просмотра прикрепленного файла Вот ребята фото ферритов, те что я говорил. Тот что слева от Рассвета, справа не знаю от чего, но на нем написанно 3000нм.
RadioГубитель
Цитата(Серёгин @ 29.3.2013, 21:54) *
Если на ключи то там 6800пкф (0,068мкф )
6800пФ=6,8 нФ =0,0068 мкФ=6n8 маркировка
0,068мкФ=68нФ= 68 000 пФ
прочувствуйте разницу.
Серёгин
А что , я ошибся ? Вроде по таблице смотрел .Да немного ошибся , прошу прощения icon_smile.gif старый стал , плохой стал . icon_biggrin.gif
RadioГубитель
Таблица не противоречит моему изречению)))))))))))
Wasiliy61
Нажмите для просмотра прикрепленного файла Товарищи соврал я, этот зверь 30мкгн -я неправельно пощитал по шкале. Значит он должен подойти. Сегодня мотал ещё на 2ух разных ферритах от твс, результат один 40мкгн.-второй 60 мкгн.
KT117
Ставьте смело, где то выше я выкладывал расчет дросселя для косого, или найдите в журнале Радиохобби №4-5 за 2009 год.
К стати, можете просто из спортивного интереса поискать в ветке все формулы по расчетам силового транса, дросселя и ТТ. Это будет заодно и познавательно и увлекательно icon_smile.gif
Wasiliy61
Что-то всё молчат, аж скучно стало.
KT117
icon_smile.gif Значит-все работает и никаких проблем.
Нажмите для просмотра прикрепленного файла Статья из журнала Радиохобби №4-5 за 2009г. Есть и формулы по расчету СТ и дросселя.
Wasiliy61
[quote name='KT117' date='31.3.2013, 21:19' post='279138']
Спасибо, ценная информация. Силовые диоды, аноды написанно надо отгибать, но наверно у кого как установленны.
KT117
Если интересно про диоды-можете посмотреть страничку автора http://adsh.ukrweb.net/radiohobby/viewtopi...id=1970&p=1
Wasiliy61
Уважаемые форумчане, а что управа обязательно должна быть на 2ух стороннем текстолите сделанна, а то у меня на одностороннем сделанна. Тогда придётся экран мудрить. Благодарен.
Wasiliy61
Цитата(sergey777.68 @ 1.4.2013, 19:47) *
можно весь аппарат собрать на одной стороне.
Апарат работает нормально?
Wasiliy61
На 4ёх строчниках кто-нибудь делал силовик, лежат без дела 8шт. Сколько можно взять с 4 шт.
Wasiliy61
Цитата(sergey777.68 @ 1.4.2013, 21:58) *
работал на 140а 35кгц.
Но это вообще-то не плохо, на 6 наверно лучше, но громоздский получится. Это я на будущее, сейчас у меня на Е70 сделан.
sergey777.68
у меня был собран в компьютерном блоке питания.
Wasiliy61
Какой аппарат себя лучще чувствует, ТГР или на опто-парах.
sergey777.68
Юрин драйвер рулит.(оптика + усилитель по току+стабилизация выходного импульса с отрицательным смещением).
Wasiliy61
Юрин драйвер это на кт973 что ли.
sergey777.68
так точно.
ГонZZа
Вечер добрый.Wasiliy61,все аппараты делал на 4ёх комплектах ТВСов.В 7 и 8 аппаратах частоту сделал 42кГц 142-157ампера ТВСы были от цветников(маленькие).
Wasiliy61
Вечер добрый. Но это вообще прекрасно, ТВСы у меня с телеков 3 покаления.
ГонZZа
Wasiliy61,ещё делал на ТВСах от ЧБелых теликов,они вообще "сказка",у них окно такое,что можно меди напихать очень много!
Wasiliy61
Да те хорошие, у меня в гараже 1 толи с рекорда, толи с горизонта завалялся. Там окно большое.
soud
Гонза как вы изготавливаете каркас для транса на строчниках? А то валяется жалко выбросить
ГонZZа
soud,делаю без каркаса.Измеряю центральное керно(4ёх ТВСов),нахожу подобные размеры деревянного бруска,оборачиваю двумя слоями бумаги и слоем ХБ чёрной изоленты.Поверх изоленты мотаю обмотки(они обмотаны ХБ изолентой),по этому витки не разъезжаются,а липнут друг к другу.После намотки силового транса обмотки стягиваются капрновыми стяжками.
Nikolay1
ГонZZа,
Привет земеля. Когда нас обрадуещ с очередным 9-ым аппаратом
ГонZZа
Nikolay1,9ый аппарат почти готов,но меня (моё барахло,из чего делаю аппараты)перевозили в другой кабинет,по этому аппарат начат-но не доделан!Руки чешутся доделать!
zario
Мужики а что в виде тора не делаете вроде витки тем же будет что и в "Ш", зато меньше гемора.
Wasiliy61
А наверно кольца большого деаметра сложнее найти.
zario
Вы про что? Я о ТВСе говорю сложенный вот так [ ]
Wasiliy61
Понял, а какие результаты, и из скольки Вы делаете.
mono
сечение слабовато у пары, да и с проницаемостью проблемы, написано 3000, а меряю кальком, 1500 получается, хотя кальк проверен не раз, при стоимости 63-го кольца меньше пяти баксов заморачиваться не хочется.
zario
У всех возможности разный. Я бы 15 баксов отдал за эти кольца, но в моём деревне не где их купить
Wasiliy61
Подскажите пожалуста, ставить антистик -достаточно что-бы он просто глушил шим или ещё и реле блокировки отключал. Благодарен.
Серёгин
Приветствую .Достаточно того , что шим отключится .Ключи закроются .
zario
Где это вы тут реле видите
Wasiliy61
Спасибо.Установил диоды на радиатор, подключил транс, двигаюсь дальше.
Серёгин
Значит скоро первый пуск ?
Wasiliy61
Практически осталось все блоки прикрутить на место, да и так по мелочам маленько. С амперметром проблема, шунт не искал ещё.
Нажмите для просмотра прикрепленного файла Фото будующего аппарата.
Серёгин
Кто нибудь такие видел или делал на таких каркасах ? Может знает где можно их купить .
Wasiliy61
Чёт я подумал одноплатник наверно лучше,раз и всё наместе.
Серёгин
Вот следующий и будете одноплат делать .
Wasiliy61
А Вы делаете и те и другие.
Серёгин
Ну 1 делал одноплат .У меня есть несколько вариантов исполнения.
and_w
Так делать без разницы как, можно и не одноплат, только в этом случае я бы блокировочных кондюков бы понавесил где-то по 0,22 мкф , в частности прямо на ноги ключей, куда подается напруга с выпрямителя и банок... плюс выходные диоды каждый можно зашунтировать либо варистором на 180-200 вольт, либо двуханодником 1,5КЕ180СА
Wasiliy61
Да у меня кондюки получились на ногах,2 по 0,47-к73-17 и 2импортных по 2.2мкф последовательно, потому-что по 250в-подпаяны к К73.
slavyann
Wasiliy61, красивый корпус у вас. где брали ?
Wasiliy61
Это бывший инвертор Кратон. Есть какой-то корпус поменше, но метал потолше.Если вырезать под винтилятор думаю потом попробовать в него ещё собрать.
slavyann
я на днях вырезал под вентилятор в 1,5 мм металле, замучался, но вырезал )
Wasiliy61
Тот корпус наверно тоже примерно такой-же толщины.А ниже фото этого.
Нажмите для просмотра прикрепленного файла Вид спереди.
