Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
толян
Если успеют нагреться . А то , бывает , что и не успевают, холодными помирают.
Д713
та то они холодные снаружи,а кристаллу трындец от локального сугреву.
Цитата(ДядяВася @ 13.7.2011, 20:59) *
Конечно, язык русский, международный. Объясню, почему поднял волну. За пределами Украины это может вызывать удивление, но у нас особое состояние дел. 99% понимают русский, и 98% понимали!!! украинский языки, сейчас меньше, в связи с модернизацией и Эвропизацией мовы (чтобы меньше была похожа на москальску). Русский не является официальным, и у некоторых имеет статус чуть ли не вражеского. Сам учился в украинской школе, но сейчас часто не понимаю отдельные слова, звучащие с экрана. А некоторые политики (мало чего собой представляющие, но в вышиванке и в костюмах от Бриони) хотят показать что именно они патриоты, а все остальные быдло. И плодят таких же, как они сами. И многие на это ведутся, независимо от образования! И нет для них больше счастья, чем подразнить или унизить москаля, и западло ботать на его языке. На форуме, думаю, не меньше половины с Украины, подавляющее большинство не брезгует русским, и если начинается выпендрёж, это нужно сразу пресекать. Ведь если человек спаял драйвер, получил осциллограмму, и вставил её в форум, то вряд ли он только вчера спустился с гор. И как показало продолжение, это помогает, да Миха? Санек, извини, удалю.
эт Дядь Вась-в точку!
сам я из Симферополя,всегда имел твердую двойку по мове,не осилил за ненадобностью и по сей день.
Muxa1101
холепа получается, поменял резистор R1 на 4,7 ом, растущий фронт лучшим не стал, так и дальше 400нс.
Каким еще способом можно улучшить сигнал?
Д713
шо там с тгр?
параметры?
все эти процедуры лучше отлаживать до стрельбы в силовой части.
Muxa1101
емитер-затвор:Нажмите для просмотра прикрепленного файла
коллектор-емитер:Нажмите для просмотра прикрепленного файла
силовое питание от блока 14 в
Д713
Цитата(Muxa1101 @ 13.7.2011, 21:39) *
емитер-затвор коллектор-емитер силовое питание от блока 14 в
чем меряем?
Muxa1101
Цитата(Д713 @ 13.7.2011, 21:36) *
шо там с тгр?
параметры?
намоточного данные такие как в литературе, все обмотки по 35виткив диаметр = 0,4 мм.
При отключенном драйвере транзисторов, т.е. на выходе ТГР такая картинкаНажмите для просмотра прикрепленного файла
Цитата(Д713 @ 13.7.2011, 21:43) *
чем меряем?
осциллограф-приставка к ПК
Д713
что в затворе транзистора раскачки тгр (резистор какой?).
Вы ее как-то тестировали?
приставку эту?
в 99% это не подход к делу.
лабуду может сама приставка из себя представлять,а не форма сигнала.
Muxa1101
22 Ом согласно схемы (Пупкин, Делаем инвертер Barmaley’я)
приставку эту?
приставка тестировалась самим производителем, по крайней мере к ней является паспорт с приведенными погрешностями на определенных диапазонах
Д713
рекомендую найти нормальный осцил с концами и сравнить.
приличная приставка с диф-входом весит под штуку евров.
Muxa1101
пойнятно
UVM
Я тоже к этому склоняюсь, вероятно и щупы не "фирменные"
Попроуй силовое не подавать вообще, чтобы наводок поменьше было и посмотри что на затворах.
Muxa1101
картинка без подключения силового питания, драйвер вообще отключен, висячие выводы тгрНажмите для просмотра прикрепленного файла
Д713
не может быть.
Ваша приставка ничего не видит.
Muxa1101
Цитата(Д713 @ 13.7.2011, 22:13) *
не может быть.
а что не так????
Д713
Цитата(Muxa1101 @ 13.7.2011, 22:14) *
а что не так????
там должен такой звон стоять,шо мама не горюй.
Muxa1101
при изменении запавнення звон появляется, просто то максимальная длительность сигнала
Д713
пановэ,не морочьте всем голову.
UVM
Попробуй во вторички ТГР витков по 5 добавить, мне раз так помогло, а то звонило мама не горюй, 200Ом резисторы проверь тоже.
Народ, хорош флудить!
serbun
Главное на чем ТГР выполнен? Помнится мне первый аппарат получился нормально а вот второй- дважды бабахнули ключи оказалось (после того как позычил осцил на вечер) на радиорынке браковый ш7*7 попался . Может и можно было бы поковыряться подобрать зазор- но изза спаленных 2 комплектов ключей выкинул и теперь использую все феррыты только эпкос.
Muxa1101
тгр выполнен на феррите от какого блока питания, взял то что первое под руки попало.
Фронты на затворы никак не могу улучшить, растущий максимум 400нс, а ниспадающий 300нс.
Силу пока не подключаю
oleg1ma
Попробуй поиграться с зазором тгр, резисторы те что 200 ом 2вата сильно греются?
Muxa1101
резисторы греются прилично, пальцах печет
oleg1ma
Как и в какой последовательности мотал тгр, от этого тоже зависит качество импульса.
stalker-dass
мужики на форуме пишут что платы потом надо залить спец. пластиком что продается, у меня нет возможности пока его купить, скажите а пойдет или нет лак для пропитки трансформаторов, ведь он и температуру держит и влагу неплохо?
Muxa1101
ТГР мотал сначала параллельно входные обмотки, то есть одночассно управляющую и размагничивающие, что на диод, дальше исходную на верхний ключ и последнюю исходную (вторичную) что на нижней ключ. Изолировал малярным скотчем.
STASKIN
Сохнуть он долго будет,если вообще высохнет,возьми лак обычный,я взял акриловый-и вони меньше и сохнет быстро.
UVM
Бери цапон-лак, можно даже мебельный безцветный всё слоя в три-пять. А вот шерлак не пойдёт его в муфеле сушить надо и электролиты тоже высохнут.
В магазине где детали берёш спроси про пластик или подобный там обычно большой ассортимент спреев, пластик чем хорош так это тем что паять через него пожно при необходимости, а так цапон цапоном.
В блоках питания ставят ещё и фильтры, если феррит от него то он может быть очень низкочастотным 3000-5000НМ и больше и поэтому такую бяку и кажет.
Я одинт раз ТГР делал на феррите от телефонного аппарата и зазор его оставил родной -работает отлично.
Dr. Санчес
Кстати раньше тоже стоял перед делемой - с зазором или без ? Кольца для ТГР у меня на тот момент были только советские .
При введении зазора не только уменьшается время спада на затворе , но и проницаемость такого сердечника уже больше определяется зазором , чем начальной проницаемостью феррита ( так я сраховался на случай если параметры феррита немного "поплывут" ) . И кстати , на счёт советского феррита - замерял индуктивность старых дросселей ДП , ДПМ , при этом у многих из них индуктивность сильно отличалась от написанной на поверхности , причем у многих при допуске 5 и 20% , она не укладывалась ( сильно ) в эти допуски .
На счёт лака для покрытия плат , тут прикупил акриловый лак PLASTIK-71 . Удивило что на пузырьке написан ГОСТ аж 1970 года . Пробивал , по этому госту делали пропиточные кремнийорганические лаки КО , весьма термостойкие . Вопрос в том , если им покрыть плату , то не создаст ли это проблем с возможным последующим ремонтом ?
UVM
Это как это?
Muxa1101
т.е. получается что чем больший зазор то тем большие потери и фронты на выходе ТГР будут сильно затянутого (продлятся дольше, что не есть хорошо)?
STASKIN
Тоже хотел попробовать,но смутила цена,за теже деньги взял акриловый лак-литровую банку,вроде как корабельный-еще и пива попить хватило. Есть и в аерозоле,гораздо дешевле чем PLASTIK-71.Возможно у него и есть преимущества-просветите какие.
UVM
"Акриловый изоляционный лак.
Назначение: Быстросохнущий прозрачный изоляционный лак с высокими диэлектрическими характеристиками для защиты печатных плат, обмоток двигателей, трансформаторов от коррозионных процессов, атмосферных явлений.
Свойства: Создает защитную изолирующую пленку против атмосферных воздействий, таких как влажность, окисления, грязь и пр. Высокие адгезивные свойства по отношению к любым конструкционным материалам — металл, пластик, дерево, стекло и пр. Защитная пленка хорошо противостоит агрессивным средам — кислотным, щелочным, не теряет своих характеристик на протяжении длительного времени. Может быть пропаяна. Предотвращает токи утечек, короткие замыкания и эффект коронирования."
Повторюсь, в остальном цапон-цапоном!
И цена стала icon_eek.gif, брал давно (пока пользуюсь) по 10$ но сейчас уже 25, не-е-е цапон!
Dr. Санчес
Цитата(UVM @ 14.7.2011, 14:32) *
Это как это?
Вот фото этикетки с указанием ГОСТ на лак
Не совсем так . При введении зазора в сердечник , спад импульса получается короче ( транзистор закрывается быстрее ) , но при увеличении зазора , падает индуктивность и ТГР начинает больше потреблять от блока питания . Поэтому надо искать оптимальный вариант . Я например стараюсь чтоб при введении зазора в сердечник , индуктивность обмототки ( любой из четырёх ) была 190 - 210 мкГН . При нормальном заполнении спад бывает нормальным ( 120 - 150 нс ) , но при минималном Кзап ( что имеет место например при залипании электрода ) , спад затягивается и могут возникнуть проблемы .
Лепим к UC3845 схему для изменения заполнения без нагрузки ( сила - само собой отключена ) , выставляем минимальную длину импульса и тогда смотрим . Фронт как правило не меняется , а вот спад может начать затягиваться ( у меня он увеличивался до 250 нс , при общей длительности импульса 1мкс ) .
Muxa1101
[/quote]
собственно у меня проблема что передний фронт порядка 400нс, а спадающий нормальный 200нс.Нажмите для просмотра прикрепленного файла
RUS5610
На счет лака : можно на крайняк пенопласт растворить в ацетоне и этой жидкостью промазать плату в несколько слоев.Дешево и сердито.
толян
А также клей для потолочных пенопластовых панелей. по моему называется ДРАГОН , или как то похоже. застывает очень быстро. Наношу кистью , это для быстрых покрытий для ремонтных девайсов.
SchVePs
Лак в балончиках, для покраски авто.
stalker-dass
вообщем придеться покупать цапон, само приемлемо, а как он потом при ремонте не оч много проблем достовляет с очисткой?
petr0757
Без проблем, ацетоном или 647 растворителем.
UVM
Так он вроде для этих целей и всегда использовался, легко смывается любым растворителем, и скальпелем подчистить можно.
tigroff
Цитата(serbun @ 13.7.2011, 14:30) *
Что за пластик и где его можна купить?
Plastik70, продается практически во всех магазинах, как раз для защиты РЭА от пыли. Пусть садится, до дорожек не достанет.
Вот описание
Sergei69
Привет всем сваркостроителям! Купил термодатчики KSD301 85°C а они оказались на размыкание, один я разобрал и оказалось , что переделка на замыкание элементарна нужно только перевернуть биметалическую пластинку и собрать всё обратно!!! только нужно акуратно отгибать завальцовку крышечки, что бы потом завальцевать. Может кому пригодится.
Basill
Ещё в тех же магазинах можно купить более дешевый аналог Plastik70 - это акриловый лак PRF202 фирмы TAEROSOL
http://www.e-voron.dp.ua/files/pic/kontchi..._202_220__1.jpg
Я его пробовал, тот же пластик. А вообще подходит любой акриловый лак.
Есть ещё Urethan71 - это термостойкий полиуретановый лак (кто работал на спецухе - знает, о чём речь), но он подороже. Бытовая альтернатива - яхтный и паркетный полиуретановый лак.
Цапон, конечно, тоже хорош, но это традиционный электроматериал из прошлого века, и по термостойкости только чуть лучше обычного нитролака.
А вообще тема электроизоляционных покрытий и пропиток на этом форуме - вечно живая icon_biggrin.gif
Только успевай отслеживать витки по спирали (точнее, по кругу).
Кстати, наклейка на акриловом лаке со ссылкой на ГОСТ по кремнийорганическим лакам - чистейшей воды развод, это разные материалы (видимо, требуют какую-то местную "сертификацию" импорта на соответствие хоть чему-то - вот и получите наклейку вместе с "конвертом" чиновнику)
oleg1ma
Хотел тоже одно время купить Plastik70, посмотрел на цену 80грн. перехотелось.Пошел на авторынок и купил автоэмаль акриловая (лак) в 500ml балоне за 30грн.Время сушки 5-7минут и довольно прочная.
wer_1
плата управления в диптрэйсе может кому пригодится. Без б.п.
STASKIN
Аналогично. Только взял в строительном магазине акриловый лак,и для плат и для дома icon_biggrin.gif ,балкончик пришло время лаком вскрыть.
sarmat
Чем датчики на замыкание лучше датчиков на размыкание? Для нормально собранного аппарата вроде пофиг чем заткнуть ШИМ при перегреве.
1exa
В Каком диптрейсе разводили а то схему открыть не могу пишет некорректный формат файла да и плату 1 не открывает (у меня 2107)?
Разводку как делал автоматически или вручную а то кажется что автоматом?
wer_1
дИПтрейс кажется был такой-же . Раскидку делал кажется вручную, точно не помню, а разводка автоматом, Аппарат работает. Просто имея схемку вы можете развести ,как нужно.
Регистрация на 1000 пинов, да и так должен открыться.
User name: Для некоммерческого использования
Reg. key: NY2Z-3UP3-H5CQ-P2GZ
