Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
Muxa1101
Цитата(yjriy @ 8.7.2011, 23:19) *
А скоро и блоку питания будет гаплык с закороченными шинами питания внутри микрухи
блок ше кажеться робочий...
UVM
Цитата(Muxa1101 @ 8.7.2011, 23:14) *
мікросхема гріється, то іі значить гаплик?
Перережь дорожку от 8 ножки и померь напряжение на ней (8 вольт длжно быть, если точно помню), если востановилось то микруха может еще жива и ищи коротыш, в монтаже, кондер проверь на пробой.
Не, не должно, в защиту уйдет и всего делов.
maxon
На 8 ноге (Vref) должно быть 5вольт (источник опорного напряжения).
UVM
8 ножка - 8 вольт вот и подзапамятовал, проблем с УСкой ниразу не было, тлько частоту и к. зап. подбирал.
ACER
Подскажите как подключить термореле с нз контактами. реле повторитель не предлагать.Как то Д713 выкладывал.
Muxa1101
Коротке замикання на платі виключено, тому шо NE555 працюють нормально, попробую відключити живлення від UC3845, хоча не пойнятно з відки візметься опорна напруга на 1 виводі, коли немає живлення?
ostap
Можно так
serbun
Всем привет. Аппарат с дросселем на железяке работает идеально но есть одно НО! Батарея силовых кондеров греется на больших токах притом довольно сильно хотя и в обдуве. Батарея состоит из 4 по 470мкф 400в марки he все остальное кроме диодного моста (ему достался слишком маленький радиатор) приблизительно температуры окр среды- мне такое впервые.Непойму это изза дросселя или изза того что всегда ставил 5 банок в батарею а в этот раз сэкономил.
Подскажите пожалуйста на что обратить внимание.
ZPS
Если банки 100% хорошие и больше ничего не по теме не греется, то может проблема быть в входном диодном мосту. Встань осц. на питание банок под нагрузкой и посмотри что там делается, скорее всего увидишь там картину на тему морских волн при хорошем ветре.
UVM
Так коротыш по 8 ноге к 555 она никакого отношения не имеет!
В 7 ногу 14 вольт входит, а из 8 ноги 5 вольт выходит, у тебя 8 нога звонится с 5 ножкой (земля) значит коротыш или в микросхеме или на плате, ну или кондёр 100нан пробит.
Ищи, всё больше по этой теме отвечать не буду!
serbun
Кандеры и мосты я всегда ставил и ставлю одной и той же марки, в этот раз хотел вместо МВ5010 (всвете последних разговоров здесь что они паленные) поставить 2* 3510 в параллель но блин их небыло там где я затариваюсь вот продавец и уговорил взять 1*5010 а я повелся.
Реально до этого мне ниразу небыло такого чтобы кандеры грелись, ну не без того чтобы градусов на 15 выше окр среды так это без обдува!!! А тут хоть в слабом но обдуве и градусов 60 после 4 четверок. Еще и этот мост хваленный- аж обжегся градусов 80-90. Кароче теперь походу паленка нетоко в комодроме. Кстати ЮЦ3845 несоветую брать в космодроме кто обытает в Харькове- это хуже лотореи.
И последняя пара вопросов- при малой индуктивности выходного дросселя или малом зазоре кароче неправильно изготовленном силовом трансе кандеры могут греться слишком большими разрядными токами первички транса.
Изза возбуда может проявляться такая проблемма.
Поповоду осцила- немогу так как пользуюсь х1- 50 в режиме осцила а шнурков головок к нему к сожалению нет- боюсь спалить.
кабельщик
serbun, для того, чтоб посмотреть пульсации на банках (хотя б убедиться, что они 100Гц, а не 50 в случае обрыва диагонали моста...) , не требуется тщательно согласованный делитель-щуп. Достаточно поделить напряжение с банок резисторами (к примеру, 1МОм и 120кОм) и поглядеть осциллом делимое...
tigroff
Добрый день, уважаемые гуру. Проработал мой бармалейчик пару годиков на отлично. А вчера при отрыве недопаленного электрода получил бабах icon_sad.gif Вскрытие показало что выгорели силовые, сгорела дорожка питания силовой части, остальную обвязку за неимением времени проверить не успел. Перегрева не было, радиаторы были холодные, собственно как и все остальное. Планирую потестировать с IRF740 и лампочкой. А вообще - на что грешить, куда рыть? Осциллографа нету, особо пощупать нечем, да и позабывал уже все. Хелп?
stalker-dass
мужики вопрос мой таков, выходные диоды EBU можно ли заменить(в бармалее) на какие нить отечественные диоды? и если да то на какие и сколько надо в паралель ставить?
spesso
Про параллели тут обсуждают, почитай http://www.electrik.org/forum/index.php?sh...120&st=8980
UVM
КД2997А штук 6 на прямой и 8 на замыкающий
Tigroff, а плата и силовая часть как была защищена от влаги и пыли?
А то от болгарки много чего может залететь в аппарат и перекрыть дорожки в неподходящем месте.
stalker-dass
я так понимаю что кроме КД2997А больше ничего не подходит?
UVM
КД213 можно но 15-20шт на прямой и 20-25 на замыкающий
Вот какой баян!
tigroff
Все платы сверху покрыты слоем канифоли на спирту, полгода назад аппарат полностью вычистил. При нынешнем вскрытии - пыли не много, не металлическая, да и не пользовался я в этот раз болгаркой. Все хотел Plastik70 покрыть, не успел.
Могут снабберные емкости шалить?
stalker-dass
КД213 таких у меня валом но такой баян лепить это чересчур, буду искать 2997А, огромное спс за своевременный ответ на мой вопрос
кабельщик
tigroff, вопрос обсуждался...
баян
UVM
Канифоль нужно удалять ещё до настройки, во время и после.
Про насыщение горячего транса и к. зап. лучше сразу предусмотреть 30% запас и не будет проблем.
Аппарат в котором 30% запас по трансу и к.зап 0,4 выдержал пробой первички и соответственно её выгорание, витков 5 сгорели, а ключам (PD1) пофиг. Эксплуатировался агрегат жёстко, задатчик постоянно на мах (150А), у выходных 150EBU0,4 диодов ноги синие и внутри на платах миллиметр сплошной пыли, было пластиком в три слоя было всё покрыто, а силовуха ещё и силиконом залита.
tigroff
баян
Нагрева ферита не было точно, не успел бы он, успел спалить всего полтройки. А вот насчет первого предположения про "узкое место" - думаю вполне, но тогда непонятно как он два года отпахал... Постараюсь найти осциллограф, еще раз все перещупать.
Не помню свой к.зап., постараюсь перепроверить. Транс был с запасом на Е70м ферите. Хотя... Буду искать.
Платы до настройки отмывались растворителем от старой канифоли, и уже потом на чистовую вскрывались канифольным лаком. Всегда так делаю, может я чего-то не знаю?
serbun
Да все уже стало на свои места- МВ5010 оказался паленным я после банок поцепил вместо силовухи 2 киловатный чайник и пока вскипала вода мос раскалился и банки стали заметно теплыми. Такшо купил 2 МВ3510 параллельно втулю и пускай трудятся. Да и кандеры щас стали хуже хоть и беру "с малым импендансом, для работы в импульсных цепях, 105град..." В следующих аппаратах вместо 5* 470мк буду баянить 10*220 мк.
И последний вопросец есть какието марки кандеров заведомо не паленные, скажите кто какие юзит, еси мона фото киньте.
UVM
Так нельзя ни в коем случае делать, на канифоль осаживается пыль даже на сухую, а если температура малость поднялась то канифоль для пыли как клей на ленте для мух.
tigroff
Ну да, логично, как починю - вскрою пластиком.
Recto
Здравствуйте! Подскажите, возможна ли замена в данном инверторе IRG4PC50U на IRGP50B60 или на IRGP4063? Смотрел даташины на оба:
http://www.irf.com/product-info/datasheets...rgp50b60pd1.pdf
http://www.irf.com/product-info/datasheets...irgp4063pbf.pdf
Параметры у них близкие, по току перекрываются с запасом. Возможно, я чего-то не учитываю?..
Lemm
подходят оба . лишь бы не перемаркер попался .
Muxa1101
Осцилограма передного фронту керуючого сигналу:Нажмите для просмотра прикрепленного файла
то є нормально?
Чи має бути крутіший (тривальсть 400нс).
Задній фронт керуючого сигналу:Нажмите для просмотра прикрепленного файла
(тривалість 200нс).
витя
Muxa1101, а что по русски не бум,бум-сайт то рчсскоязычный догадываться приходится, ну если не в напряг.
ДядяВася
Не обращай внимания, это патриота из себя корчит. Типа, Я, на своей земле, учите мову, и т.д.
UVM
Я отвечал, но вот это последнее просто не пойму что на фото и где снято.
Dr. Санчес
А патриотизм здесь нипричём . Просто у некоторых ( и у меня ) проблемы с украинским языком . Ведь Muxa1101 скорее всего владеет русским , почему бы на нем не писать ? Тут скорее не из Вити патриотизм прёт , а из его оппонента - национализм .
Никому не в обиду , но у меня много друзей и знакомых на Украине , и никто из них не станет разговаривать со мной на украинском , зная что я практически им не владею .
АлексейС
Всё правильно,нех выеживаться,хай по-москальски балакает!Это он залез на этот сайт а не мы все на его украиномовный.К тому же 100% он русский знает.Алексей.Харьков.
serbun
Ну и набросились! Может и незнает человек москальского язика.
Что за пластик и где его можна купить? Как строительный силикон себя ведет в качестве защиты от пыли? Никогда непробовал но думаю что на него пыль будет садится не хуже чем на канифоль.
Всегда юзаю акриловый лак- аэрозоль. Вот только пленка слишком тонкая получается.
АлексейС
Как это не знает москальского?А ответы на свои вопросы он собирается получать на украинском?И как он вообще попал сюда если ни бэ ни мэ по-русски?
Muxa1101
Екскюзми за украинский, перегоджу на ламаний руский, бо ответа на мой вопрос не получил.
Собствено шо я спрашиваю, картинка 1 ето управляющий сигнал на затвор нижнього транзистора, тоэсть його передний фронт, как видим время нарастания ~400нс ето есть нормальноили надо подшаманить чото с драйвером.
Картинка 2 это той же самий управляющий сигнал, но задний фронт, время спадания ~200нс.
Вопрос будеть ли жить транзистор при таком переключении.
ДядяВася
Резонансник будет, бармалей нет. А вообще-то учи грамоту, не позорь страну, потому что читая такую писанину, страдают и мучаются не только москали, но и украинцы.
UVM
Сожми горизонтальную развёртку чтобы на экране было видно 2 меандра, если будут вот "П" такими то хорошо, ну и покажи нам.
Muxa1101
спасибо за ответы вечером представлю осциллограммы импульса двух периодов.
Гугле Транслейт рулит,,,,
STASKIN
Нажмите для просмотра прикрепленного файлаНапример это может натолкнет на правильный ход мысли.
sarmat
Первый раз услышал про новый язык-москальский. Это по моему русский язык. Мой аварский язык не хуже русского, украинского, английского или португальского. Но русский язык я выучил с первого класса и на нем говорю со всеми, кто не знает моего родного языка. Все национальности ---это люди в конце концов. Сколько можно издеваться. Если Миха считает себя умнее всех, то пусть сам разберется. Видите ли, исклюз ми и переходит на ламаний руский язик. Все языки хороши. Но на этом сайте пишут на русском, чтобы все поняли о чем речь. Я начну на своем писать, то хрен какой гугл поможет с переводом. Уважайте друг друга хоть виртуально, а то мы и так в заднице цивилизации со своими национальними лозунгами.
Muxa1101
С языками я думаю разобрались, если сайт русскоязычный то пусть так и будет.
Подскажите какие знечення должны иметь (в нс) нарастающий и спадающий фронты на управление транзисторов.
kubinichek
Языковый вопрос закончен.
витя
Не обращай внимание на выпады, но пиши лучше на ломаном русском, я вот считаю себя казаком донским (дончак), русский мне родной и украинский ну просто не понимаю, а ломаный русский без проблем.
Санек извини за флуд. Не пойму казак это что не русский что ли у меня дед с дона в сибирь пришел и всегда считал себя русским, почему Русь киевской звалась. по моему все мы русские украинцы и белоруссы из одного гнезда искусственно разделенные. Все больше на эту тему не пишу.
Осцилы бармалея
Д713
400 нан для фронта многовато,если транс с малым рассеянием.
200 нан спада вполне неплохо,там рулят снабберы.
Muxa1101
Затягивание переднего фронта возможно потому что был использован вместо резистора R1 не 4,5 Ом а 10Ом.
Насколько я понимаю, то растущий фронт задается резисторами R1 + R2, а на спадающий R2.
Попробую поменять R1 на 4,7 Ом и ​​посмотрю на результат.
Д713
понимаете верно.
фронт желательно обеспечить до 150 нан.
вообще говоря это эмпирическое пожелание,многое зависит от индукции рассеяния силового транса и от индуктивности подводящих проводников.
Muxa1101
Цитата(Д713 @ 13.7.2011, 20:35) *
понимаете верно.
вообще говоря это эмпирическое пожелание,многое зависит от индукции рассеяния силового транса.
т.е. если плохие фронты то будет греться силовой трансформатор, или транзисторы?
Д713
транзисторы-ключи в первую очередь.
IGBT-это биполяры в ключевом режиме со всеми своими тараканами.
