Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
Ewgeniy_RZ6LYE
... сколько стоит аппарат класса "Бармалей" на рынке...
в г.Таганроге на рынке самый дорогой: - Контур-150 от Чукчи (19 000), самый дешевый размером чуть больше буханки хлеба "Дон" (7 500 руб), но у чукчи полуавтомат а что внутри у дешового - хз... icon_smile.gif но заявленно 150А и у того и у другого icon_smile.gif))
САНЕК
Цитата(Д713 @ 29.4.2009, 19:52) *
а что,ключики определяют стоимость?
Приходилось видеть баяны СМД,и конструктив такой,что задумываешся,почему столько стоит icon_sad.gif
Гость_sergun
В Харькове набарабане спрашивал по чем инверторы цены разные самый дешевый 1800 грн. китайский 160А, еще видел какой-то апапрат на 200 А похож на китаез токо просили 5000 грн.(!!! совсем с у ма посходили!!!).
А вообще в Харькове фирма делает свои, www.svarka.kharkov.ua, посмотрите кому интересно ихний самый простой апарат -160А цена 2350 грн., он там правда немного с наворотами типа антипригара и горячего старта и цифровой шкалы тока.
Д713
да ладно про финансы,все мы тут творческие личности.
дросселек-75 кГц 30-160 А,железо 10х32,зазор 1,2 мм.
шинка 3х5 мм и всего 8 витков,19 мкГн.
Гость_sergun
да, а потом еще бывал на центральном рынке в Харькове, там вообще барыги одни, на силовой электрике, ниже 2000 грн. инвертора нету. Но мне там нравиться выбор электродов: мона найти алюминиевые, чугунные медные, нержи несколько видов, и взять поштучно - типа грн. от 5 за шт.
Даже есть специальные приставки к однофазным бодикам под постоянку: мост на В-200, кондюх на 50000 мкф и дросель. Весит эта ерунда знамо скока, почти второй бодик, так говорят типа рабоатет как инвертор. Вот чудят!
golub
Дело ясное, как Божий день. В крыму, блин, краски другой неТ.
RUN1
Цитата(Гость_Pavel_* @ 29.4.2009, 17:54) *
RUN1, Да феррит 2000НМ 2 кольца 100*60*15
Pavel тем более такой монст причем с хорошей пронецаемостью одного кольца за глаза на транс 25витков первички выше крыши должно хватить на 30Кгц у меня трансы на 1 кольце 82х55х18 30\11 31.5Кгц к насыщению подбирается при 24 витках вот и суди у тебя явный косяк гдето в мотаже
RUN1
Парни ктонить мотал вот так на строчниках поделитесь опытом читал что в таком варианте намотки фигульку снимешь со вторички но видел фото буржуйского инвертора намотанно как на втором варианте на наших строчниках что скажите товарищи?Нажмите для просмотра прикрепленного файла
С уважением
yjriy
Мотали и будем мотать. 3 Комплекта от строчников с расстоянием 72 мм между рогов(применялись в УЛПЦТИ) заменяют Е-70 или 4 с расстоянием 62 мм. Косые работают на 50 кГц (все с накачкой .Ктр =4). Мосты на 35.
Стоят 25 руб (5 грн) комплект, все ваше железо на транс получается 75 руб (15 грн) . Старая цена на Е70 75 грн.
RUN1
yjriy спасибо! правда не совсем понял как намотанно(понял что вроде первичка и вторичка мотается на обоих сторонах вроде) но всеровно благодарствую!
С уважением
yjriy
Сначала склеиваются 2 половинки, на каждой мотается половина первички, поверх ее полная вторичка. Первички соединяются последовательно, вторички параллельно. нужно учесть направление намотки, чтобы вторичку соединить как на фото. При напряжении питания от накачки 425 Вольт мотаю на каждой половине 18 витков первички одинарным проводом и 9 витков вторички несколькими проводами или медной лентой.
Итого: первичка 36 витков, вторичка 9 витков. с 2-х сторон зазор. При 300 Вольтах мотайте как хотите.
RUN1
yjriy вот спасибо дружище за пояснения все понял Ок!
С уважением
supryur
Товарищи специалисты посмотрите пожалуйста на форму импульса драйвера
общая ширина импульса 5 мкс, частота 96кгц транзисторы пд1 , перед ентим стояли IRF740 дуга уже зажигалась красиво ну ток выше 30А разумеется не подымал , ну фронты полутьше конечно были , при подключении пд1 явно стали хуже ну нагрузку пока боязно подавать icon_smile.gif
(одна клеточка 100ns)
Andrey_G
RUN1, делал как то 100 на строчниках в П , http://www.electrik.org/forum/index.php?sh...ost&p=60885 , там правда плохо видно, но видно транс... дальше (на пару постов ниже) там и архивчик есть, в схеме указано как намотан.... посмотри.
Гость_Pavel_*
Цитата(Wiew @ 28.4.2009, 17:56) *
проверте внимательно все силовые цепи, первичные и вторичние возможно где-то коротит, попробуйте временно собрать обвязку для изменения длительности импульсов (обозначена на схеме красным), добейтесь розмагничивания
Собрал цепочку, вместо диода отпаял сопротивление (разомкнул цепь), на 1Ком сопротивлении уровень сигнала меняется от 12В до 0 В. На ключах импульсы не меняются, как шли так и идут. Ширина импульса не меняется.
Wiew
Пороговое напряжение на 3-ей ноге регулируется переменником "Ток" и не может превышать 1в, при превышении этого порога импульс на 6-ой ножке - "обрезается"
Смотрите амплитуду на 3-ей ноге, если она превышает 1в и укорочение вых импульсов в этот момент не наблюдается - меняете микросхему.
RUN1
Andrey_G спасибо! Посмотрел и фотки и схемку я скачивал твое детище, все понял. Вот и я с соткой замарочился приходится все минимизировать по мере возможности уж больно притягивает этот АТХ.Соберу отпишусь.
С уважением.
Quest
Нажмите для просмотра прикрепленного файла Косой плумост. Ключи-по 2 PD1 в параллель. Драйвер hcpl 3120. Плата одностороняя для ЧИП монтажа. На обратной стороне только радиатор ключей. Настройка заключается в правильной фазировке ТТ.
Оцените разводку.
САНЕК
Цитата(Quest @ 30.4.2009, 19:30) *
Оцените разводку.
Оценил.А что волнует?
Гость_quest_*
Проблемами.о силовым цепям печатный монтаж не годится. Со временем из-за перегрева в области контактов с малым сечением испаряется припой, что непременно приведет к пшику в области сначала выводов ключей, а потом и самих ключей. Токи по цепям 300в 16-23А. Сечение связи вывод ключа- печатный проводник 0,035хd контактной площадки. Это 0,035х5=0,175мм". Этого мало для таких токов. Эти цепи надо обязательно усиливать дополнительно. Все это проверено временем. Предудыщий мой сварочник грешил именно этими п
Д713
Со временем из-за перегрева в области контактов с малым сечением испаряется припой..
очень поучительно,но видимо припой все-таки испаряется в момент "пшика".. icon_biggrin.gif
golub
Все сразу повскакали с мест, но тут малец с поправкой влез- "кто не работает- не ест, ты спутал батя"
С праздником ВАС, дарагие товарищи!
Д713
всех с ДНЕМ ТРУДЯЩИХСЯ!
RUS5610
Так же присоеденяюсь к выше сказаному всем здоровья и счастья большого! Мужики кто такой мультик пользует UT10A стоит покупать? интересует точность частоты и кзап.В "Базе Электроники" за 400р продают.
'Quest' можно схему посмотреть?
Quest
Нажмите для просмотра прикрепленного файлаНажмите для просмотра прикрепленного файлаНа 4013 реализована схема задатчика тока КЗ.
Ток намагничивания снят при Uпит 250в.
seven
Уважаемые форумчане подскажите пожалуйста .
Схема 165а выгорает кандер 2.2мкф 400в
1990s начал после того как увеличил индуктивность дросселя. Но варить начал намного приятнее и провар стал приемлимым .
Индуктивность дросселя 0.300 mH
И ещё вопрос писк дуги при сварке это нормально.
Заранее благодарен!!
uurraaaa
Сегодня варил в сырую погоду и обнаружил что может шарахнуть током нехило,вскрытие показало пробой КВС3510 на корпус который был установлен на одном радиаторе с 150еву,,,
yjriy
Ессно, скорее всего ноги у него отгорают, поставь несколько мелких вместо одного большого
seven
У кандёра сначала выворачивает все кишки наружу а патом он сгорает ноги остаются припаяними
AlexPetrov
Постояльцам темы просьба заглянуть на пятиминутку.
Seven какая марка кондёра. Если коричневый китайский или К73-17, то так и будет. У них небольшой импульсный ток. Надо ставить несколько штук или один epcos или wima.
SEVEN
Кандёры китайские поставил 4 штуки поставил по 2 последовательно а потом спарку 2 по 2 в паралель завтра буду испытывать потом отпишусь о результатах.
Унас в минске хреновый радио рынок и найти чтото стоющее сложно!
SEVEN для справки. Китайский СВВ21, аналог К73-17 1/400 импульсный ток 16 ампер. Epcos 1/400 22,5мм 180 ампер.
SEVEN
Можно ли в моём случае использовать полипропиленовые кандёры
SEVEN полипропиленовые конечно можно.
САНЕК
А, что это за осцил такой интересный?
Через USBшник,иль чё другое, типа цифровика?
supryur
Осцилограф OWON HDS2026M . .... вещ не плохая тока индуктивности не меряет а та к все icon_smile.gifи + на компе можно осцилами игратся ......а седня аппаратец запустил 90кгц транзисторы пд1 , Е65 12/4, управа бармалея на смд .... ну пока пару електродов спалил на токе 100а -остальные эксперементы на завтра оставил icon_smile.gif
САНЕК
Молодца!
Где то видел примочку к компу,он становится осцилом.
Valter
Цитата(САНЕК @ 3.5.2009, 18:58) *
Молодца!
Полный аццтой. Докажите обратное.
Juri
Народ, подскажите кто знает, чем в заводских инверторах покрыты силовые дорожки на печатных платах. Или поделитесь, кто как усиливает эти самые дорожки. Медная фольга закончилась, а проводом не эстетично выглядит.
golub
Вот пример неэстетичного фабричного усиления проводом.
Gooddi
Есть такая "присадка" для сварки меди газом (не знаю как называется) стержни прямоугольного сечения. Лудится на ура, жестковата, но можно придать любую эстетичную форму. или экран с проводов. Тут уж на сколько эстетично уложишь.
yjriy
Имеет почти на порядок больше электрическое сопротивление ежели медь
Gooddi
Спасибо, не знал. Но нагрева не заметил.
RUN1
Мужики всех с прошедшим праздником!
Парни не подскажите как лучше организовать защиту если не ставить быстрый автомат а то в АТХ он явно не залезит перед мостом и +300 v рассчитать медную жилу на нужный ток и впаять ее в стекляшку а стекляшку припаять к плате или еще как?
С уважением
Д713
..или еще как?
впаивайте в "стекляшку" 0,4мм медный провод,в аккурат 20А будет,потом припаять к 1мм стойкам в плату.
RUN1
Д713 благодарю!
yjriy
Цена вопроса 1 украинский Тугрик, ровно столько стоит 1 предохранитель на 20 А(или на 10, 15, 30) и плюс к нему держатель на плату, хотя время сгорания ключа или диода раз в 30 быстрее чем самый ультра-предохранитель.
Д713
дык вроде не раз писалось,что предохранитель спасает плату и уж совсем не ключи.
supryur
...Плату и нервный импульс(БАХ) !!!! icon_smile.gif у меня когдато 2А стоял..... ну транзюк(полтиник) так и не спасло ... умер по тихому в месте с предохранителем icon_smile.gif
