Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
RUS5610
Мне кажется 2,2а ток намагничевания многовато хотя и считается в пределах нормы.Я стараюсь не выходить больше 1,5а т.к чем больше ток тем сильнее разогревается феррит .Мое личное мнение.
Den2
А еще лучше 1-,1,5А,и ограничилку КАБЕЛЬЩИКА
Коля
KLIM, Кабельщик, найдите времечно ответьте на вопросик, чтобы развеять туман о принципе регулировки уськой. Итак я вот о чём подумал. Сигнал с тт поступает на ногу уськи если амплитуда 1 вольт то происходит огрничение тока. Что в это время регулирует задатчик? 1) Либо он регулирует уровень компаратора уськи, 2)либо длительность, но регулирующуюся только под нагрузкой.
1) Итак, если задатчик регулирует порог срабатывания компаратора. При максимальном токе амплитуда входного сигнала в уську минимальна, но если она доходит до уровня срабатывания компаратора, то уська уменьшает длительность, но как она определит нужную длительность, которую нужно поддерживать? Отсюда вывод, что там стоит что-то аналоговое, которое напрямую зависит от напруги тт. То есть если напруга тт составляет 0,7 в, то длительность составляет например 0,3, если 0,8 , то 0,4.
2) Но мне тут намекали, что ток не регулируется, а задаётся, отсюда вывод, что первый вариант неправильный. И что? Получается, что задатчик регулирует длительность, но она регулируется тогда, когда есть нагрузка. Если так, то смысл гонять аппарат на ХХ? Убрали бы обратную связь и регулировали бы длительность на здоровье. В этом что-то есть. Возможно это для ХОТ старта? Опять же люди почему-то примочкой Кабельщика глушат ХХ. Объясните плиз этот момент.
кабельщик
Цитата(OlegarX-RUS @ 4.6.2010, 18:04) *
Сравнивайте сами особенно обратите внимание на подложку
И вес в 458 грам вам должен что нибудь сказать
Особенно вес и пугает. При равном термосопротивлении кулеров 0,5°С/Вт (при тестах кулеров его обычно меряют между температурой ядра процессора и температурой окр.среды) вес отличается более чем вдвое. Размера тоже разные. Да и цена, думаю, тоже отличается.
OlegarX-RUS
В наших краях такой стоит 61-63 грн. в розницу если учесть, что у него на борту не плохой КарлосоН то считаю, что это совсем не дорого.
А чем вас вес испугал??? ну будет люминь с пропеллерами весить кило и что с этого?
Коля
Чем можно феррит аккуратненько отпилить? Пробовал циркуляркой- немного пилит, потом феррит ломается. Просто у сотки чтобы дроссель в корпус впихнуть надо немного рога подточить. Хотя если подумать, по толщине корпуса можно два феррита поставить, но опятьже рога подпилить.
mer59
Цитата(Иванн @ 4.6.2010, 11:47) *
Ну 2,2А это уже предел?. Значит частоту мне понижать нельзя, так как растет ток?
По поводу намагничевания есть практические замеры.Феррит 2000НМС напряж. и длительность неизменные.
29град.--1,8А
41--2.15А
57--2.5А
До насыщения нечем было нагреть,но к росту тока от температуры надо видимо повнимательней при проектировании.
кабельщик
OlegarX-RUS, по моему, мы друг друга не понимаем.
Я имею ввиду, что не вижу логического смысла брать более дорогой, более габаритный, более тяжелый кулер при равном у обоих термосопротивлении (это основной для нас параметр). Зачем брать на борт 2х400г люминя, если то же самое сделают 2х200г ?
OlegarX-RUS
Понял вашу мысль но не понял почему.
По площади мной предложенный радиатор более чем в два раза превосходит вами предложенный, по воздушному потоку мой вентилятор в полтора раза даёт большей поток, по массе тоже в два раза превосходство в большую сторону,очень не мало важно, что максимальные обороты не слишком высокие по этому он очень тихий и не будет лепить в таком количестве пыль на рёбра, подложка и рёбра тоже толще. На коробочке от него написано что он может рассеять 104W правда неизвестно при какой температуре окр. среды и до какой температуры при этом греется люминь.
кабельщик
Точилом. Только аккуратно, несильно нажимая, особенно если есть биение камня...
OlegarX-RUS
А откуда вы взяли, что данный параметр у них одинаковый да и каким образом и в каких условиях проводились замеры???
Не знаю замеров на делал, но это противоречит моей логике, что при превосходстве во всем он отдаст туже мощность!!!!
кабельщик
на тут Бюджетные кулеры для платформы AMD
и на здесь Кулеры Titan TTC-D3T и TTC-D3TB
KLIM
При 1 вольте на 3-ей ноге ограничивает автоматом, не зависимо от цепи регулировки (ну раз уж появился тут 1 вольт - значит по нему и рубит). Если нужно более раннее срабатывание при меньшем напряжении - добавляется напряжение смещения для внутреннего компаратора на 2-ю ногу, цепь компенсации ОС выходит на 1-ю ногу. Внутрях сигнал сравнивается не просто с опорным напряжением а с ПИЛОЙ, и как только сигнал с ДТ обгонит пилу - останавливается текущий импульс, если обогнать не успел - значит рубит по напруге в 1 вольт. Так понятней? Или еще больше запутал? icon_biggrin.gif
кабельщик
KLIM, с пилой он будет сравниваться только если ее специально замешивали. А в обычном бармалейнике на всех цепях компаратора постоянные напряжения, кроме цепи Current Sense
Коля
Ну вот, непмного попонятней стало, про пилу объяснили. Но всё-таки принцип работы не понятен. Ладно, давайте забудем про этот вопрос. Я сотку сделал, на ней теорию более или менее усвоил. 165 версию закончу ( чтобы её закончить нужно её начать icon_biggrin.gif , ближе к зиме начну.) вот тогда я углублюсь ближе к теории. Типа там применение снабберных цепей, расчёты трансов и т.д. Блин, с формулами сложными не могу подружиться. Это всё от того, что один умный человек ( ГИРАТОР) появляется только тогда, когда здесь пахнет чем-то вкусным. На "простые" вопросы он не реагирует.
Кстати, поставил тепловые датчики- появилась проблема. Просто я решил ещё и на трансформатор параллельно поставить датчик. Пару раз чиркаю и защита срабатыает. Это от трансформатора ( от электромагнитных волн)? Или от того, что я запараллелил 3 датчика и общее сопротивление датчиков уменьшилось?
DGEC
Датчики какие стоят?
Коля
D9, на замыкание не ставил.
Ага, понял, спс.
DGEC
Тогда скорее всего сопротивление уменьшилось
kyzmi4
D9
Может ошибка где???У меня стоит параллельно 5штук Д9 и не знаю проблем.Обвешал ими все что можно.
Коля
Ладно сейчас аппарат разберу, датчик с транса уберу.
DGEC
У диодов запросто может разбег быть
Коля
ПОЗДРАВЬТЕ ГОСПОДА!
http://myfolder.ru/18035955
sorry
КОЛЯ посмотри все ли диоды Д9. Сам когда добавлял третий диод поставил другой очень похожий и защита начала срабатывать. А насчет датчика на трансформаторе тоже писал ктото, хотя датчик был другой - на размыкание, защита тоже срабатывала.
ftor
Большая сотка.
А вентилятор цепляется снаружи?
kyzmi4
ПОЗДРАВЬТЕ ГОСПОДА!
Мои поздровления!Но я бы добавил 2 болта и барашки,чтоб можно было кабеля отключать.А то так носить не очень удобно будет.А так отключил все кабеля,обвертелся кабелями и пошел с аппаратом в руках на халтуру icon_biggrin.gif
DGEC
Господа! кто на вскидку мне подскажет? Какой ток можно снять с баяна в восемь 740 По четыре в плечо?
Лопух
Коля, поздравляю, конечно, но зачем столько проводов. Это все же не самолет. Не дай боже что сгорит, повесишься менять.
Вот смотрите: в холодном состоянии с двух таких транзюков (по одному в плечо) при КТР=3 можно снять 30 ампер на выходе. С прогревом статические потери на них растут почти в 2 раза. Вот и считайте. С учетом снабберов ну ампер 80. Если уверены, что не дадите им прогреться, ну чуть больше, хотя рискованно. Надо учитывать, что ток через транзисторы распределится неравномерно. Самый медленный будет выхватывать по полной. А если вылетит один, улетят и остальные.
Коля
Цитата(ftor @ 5.6.2010, 20:56) *
Большая сотка.
Нет, вентилятор поставлю внутри. Места же там дохрена. Даже два вентилятора хочу поставить- один непосредственно на радиаторы, другой на вытяжку.
Вот как раз здесь я подумал по другому. Зачем вторичные кабеля отцеплять от аппарата. Заметил одну вещь: никто после работы кабеля не снимает с аппарата, а просто обматывают вокруг него и всё. ИМХО Бинзеля нужны в двух случаях:
1) Чтобы аппарат красиво в магазине на витрине стоял. Ведь неудобно же когда вокруг него кабеля. И вид с золотыми бинзелями красивее.
2) Чтобы менять полярность сварки
Первый случай насвообще не касается, а второй нафиг для этой сотки не нужен. Поставлю тупо обратную полярность и всё.
У нас бинзеля самые маленькие стоят 250 комплект, 500р стоят побольше. За что платить? Они мне нафиг не нужны icon_biggrin.gif . Хотя признаюсь, что на 165 верии они будут icon_smile.gif
Да мне кажется, что так даже удобнее, чем на одноплате проверять и ремонтировать. Везде можно залезть только со снятой верхней крышкой. Провода- это хорошо, особенно если они МГТФ да ещё в двойной изоляции icon_biggrin.gif в 165 версии только такие провода поставлю.
mer59
Цитата(Коля @ 5.6.2010, 20:26) *
Ладно сейчас аппарат разберу.
Просмотрел Колины картинки,дурацкое желание появилось вытряхнуть содержимое этой коробки в мешок,притащить в гараж,повесить на крючок,из мешка вытащить три кабеля,интересно работать будет?Только мешок с дырками а то по теплу тормозить будет.
OlegarX-RUS
Лучше сразу в топку или на кройняк в зелёный цвет и в траву да подальше от населённых пунктов.
Коля а вы не повар случайно??? ведь такие макароны сварить и запихнуть в коробочку может только виртуоз.
мне бы стыдно стало такое людям показывать
DGEC
Коля не унывай Нужно оттачивать мастерство До зимы не откладывай - собирай следующий!!!
Коля
А что собственно вам не нравится в этой коробке? По-моему очень даже прилично получилось. Думаю для первого раза нормально. А ТЫ ПОКАЖИ СВОЙ ПЕВРЫЙ АППАРАТ, если ты его делал!
Мне бы стыдно стало такое людям показывать
А ты это видел? http://myfolder.ru/18044511 ( Не в обиду автору, просто меня звставили)
Да я столько мастерства уже отточил, что в роботоспособность схемы уже засомневался. Просто времени мало. Зимой начну.
kyzmi4
Так даже труднее и можно перепалить все нафиг,если провод перепутаешь.Да и искать нужный провод замучаешся,будешь гадать как в кино когда бомбу обезвреживают. icon_biggrin.gif
Делай одноплат и не выноси себе мозг этими проводами.
Необижайся....
Коля
Дык я сделал уже всё запустил, работает, варит, смысл мне одноплат сейчас делать? Я 165 версию буду делать.
kyzmi4
Вот в ней и делай одноплат.
Вот кстати мой одноплат(тогда был недоделан еще),можешь тоже поругать icon_biggrin.gif
http://i027.radikal.ru/1006/1e/1ddc2a5f1fcd.jpg
Коля
Я не из тех, которые от нечего делать уже начинают хамить icon_biggrin.gif . Наоборот, я считаю, что это прекрасно, когда люди сотворяют такие поистине прекрасные вещи. Это куда лучше, чем сидеть и пиво пить. Походу у меня к вам несколько вопросов появилось, ответьте пожалуйста:
1) На чём дроссель намотан? Это случайно не те ферритовы палочки с приёмников? Просто у моей сотки место есть, вот решил дроссель поборльше замутить. Хочу два комплекта от строчников использовать. Кстати, он у меня намотан медным проводом 13 кв.мм.- греется намного меньше транса и диодов! Можно сказать, что теплеет.
2) Ты использовал 4 полтинника? Ты их просто запараллелил или сопротивления в эммитерные цепи ставил ( по управлению)? Что-то радиаторы у тебя детские какие-то. Там точно полтинники стоят?
Я просто на 100% уверен, что копией оригинала 165 версии я не обойдусь, вечно мои ручёнки хотят покруче что-нибудь замутить icon_biggrin.gif Вон сотка у меня даёт 120А при 23 вольтах, а ток кз 140А, вот такие пироги icon_biggrin.gif А второй аппарат будет не менее чем 200А. Хотел оптику Клима использовать, да вот в нашей Промэлектронике их нету icon_sad.gif , также будет геморой с обеспечением ихнего напряжения 16-18 вольт. Думаю два полтинника задубасить по той же схеме Клима, или вообще запиндрючить туда два хороших модуля ( стоимость умолчиваю) . Уверен, что с двух шашек можно и поболее снять. Доктор зазор в этом поможет, можно увеличит его до 0,4-0,6 мм. Если две шашки не помогут- ничего страшного, третью подключу icon_biggrin.gif
Хороший у меня аппетит, да? icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif
OlegarX-RUS
Коля не понравились провода которые итальянскую лапшу напоминают.
А ТЫ ПОКАЖИ СВОЙ ПЕРВЫЙ АППАРАТ, если ты его делал!
Первый не получится по причине что я не владею информацией где он находится icon_smile.gif - его украли, а вот второй с удовольствием завтра покажу.
Коля
Первый не получится по причине, что его украли, а вот второй с удовольствием завтра покажу.
Первый блин всегда комом. Но этот блин исправно выдаёт 120А. Больше ничего от него не надо. А то, что провода есть- ты не видел мой первый усилитель на ТДА7560 выполненный навесым монтажом. Вот там была действительно лапша icon_biggrin.gif
А то, что первый украли- это хорошо! Это говорит о высшем пилотаже! Вору так твой аппарат понравился, что он его спёр icon_smile.gif . Но мой никогда не украдут- под семью замками он спрятан icon_biggrin.gif . Будь здоров!
OlegarX-RUS
Первый был почти такой же как и второй платы повзаимствованы у Д713 (одноплат) с маленькими переделками, но второй сделан чуть аккуратнее чем первый в общем завтра покажу сам увидиш.
Кстати и навесным монтажом можно сделать аккуратно в ветке про ПА2 выкладывал именно такой программатор посмотри.
Коля
Горбатого могила исправит, а мою лаплу тонкие хоммутики, так что не волнуйся. Соточка будет во всей красе icon_smile.gif . Замкнул на балласт- 100А. Балластник поджужживает ( это им свойственно), но вот пластиковый щиток на 3 метрах от аппарата тоже пожжуживает с такой частотой. Писалось, что дребезг в розетке будет черевато выходом из строя аппарата. Сразу вырубил аппарат, разобрал щиток- контакт везде хороший, возможно это от вибрации воздуха. Да нет, вроде щиток жжужит. Может это быть от того, что от воздуха вибрирует щиток, и резонансная частота балластника совпадает с резонансной частотой щитка. И тут гениальное открытие: Я собрал резонансник? icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif . Поржал и дальше гоняю аппарат. Проверяю на нагрев.
Кто подскажет- какой смысл гонять аппарат на хх на максимальном заполнении?
Я расстроен icon_sad.gif . Аппарат взорвался icon_sad.gif . Опишу как было дело. Поставил такую длину балласта, чтобы ток был 100А. Прицепил массу и держак к этому балласту. Термодатчик стоит только на ключах. Вентиляторы пока не поставил, чтобы температурный режим посмотреть. Включаю в сеть. 20 Секрунд под нагрузкой- нормально. Отключаю, щупаю, смотрю, температура везде нормальная-рука везде терпит температуру. Охлаждаю до полного охлаждения. Примерно 1 час оставить остыть. Снова включаю в сеть- 40 секунд под нагрузкой и тут я решил выключить. Выключил автомат и прямо в это же мгновение взорвалось что-то в аппарате. Не секундой раньше не секундой позже, а именно в эту секунду! Посмотрел- отгорела ножка коллектора ( центральная) у одного из транзисторов. Все ножки имеют КЗ. Отсюда вопрос: могло ли это быть от того, что я выключил автомат? Подчеркну, что это быро ровно в то мнгновенье, когда я выключил автомат.
mer59
[quote name='Коля' date='6.6.2010, 18:39' post='137878')
[/quote]
Ну вот логический конец твоему творению и пришол.Есть большой повод начать переделать,то что в этой коробке.Осталось одно главное--ОПЫТ!!!Не пытаюсь тебя учить жизни,хотелось бы подтянуть народ для обсуждения темы по поводу БАХа в момент выключения под нагрузкой.
Случаи писались периодически.Собственно издеваясь над макетом косово со стороны сети,а именно прерывая ток через пускатель управляя им кнопочкой хаотически.Бармалей нагружен балластом на ток 120А постоянно.Отключение делали как можно короче,иммитируя плохой конкакт,не допуская отпускания реле.Примерно 30-40 откл. макет выдержал и стрельнул.
Надо сказать и у пускателя контакты в хлам.
Так вот постоянная времени фильтра блока питания 5мс а питания силы под такой нагрузкой 1.2мс.Как бы напряжение питания драйверов не должно было успеть просесть.То есть силовые банки должны быть уже разряжены нагрузкой к тому времени когда ублока питания напряжение опуститься до опасной велечины,ан нет стрельнул подлюка всеми силовыми приборчиками,акромя выпрямителя.
Есть какие соображения,или не в том направлении я мыслю.
SRGUT
Коля прими мои собалезнования. мои предположения проблема у тебя в блоке питания.Как запитан ? На каком мин напряжении отрубает ?смотрел или нет просадку сети?
Коля
Скажу, что у меня примерно 30-40 выключений где-то и было! Скорее всего в этом-то и проблема была. Ровно в ту секунду, когда я отключил. Кстати, ёмкости банок не хватило, чтобы полтинникам крышу сорвать, но они пострадали. Блок питания у меня хороший заводской. Работает от 100 до 250 вольт ( на коробке так написано). Не проверя я конечно, но примерно так оно и есть. Вижу четыре выхода отсюда:
1) Увеличить ёмкость в блоке питания. Тысяч 5 мкф паллельно питанию поставить.
2) Зафигачить в аппарат оптику, ведь по неоднократным убеждением оптика либо подаёт безопасное напряжение ( 12 и более вольт), либо вообще не подаёт.
3) Собрать всё как есть и перед отключением не замыкать концы. Если специально кз не делать перед отключением, то думаю оно так нигде не замкнёт. (Думаю выберу этот вариант)
4) Либо надо делать защиту у блока питания, чтобы он наоборот при пониженном напряжении сам отключался. Например на 140 вольтах. Вроде Нексор писал , что при пониженном напряжении, ток через ключи идут больше.
Mer59, ваш пост очень важен оказался для меня! Больше так не буду делать!
А просадка сети у меня небольшая.
Иванн
Коля, извини что перебил. Подскажите пожалуйста. Пробывал варить двойкой, при токе больше 20А, начинает гореть кондер 2,2мкф, тот что возле ключей (точнее не сам кондер, а его выводы). Проблему такую на форуме уже встречал. Писали что нужно баянить по 0,47мкф, и еще диод 1,5ке400а. Нормальное решение, или посоветуете что-то получше? Заранее благодарю.
OlegarX-RUS
Была та-же проблема с красным китайцем(у них выводы не из меди). Излечения добился поставив два МКП2 по 0,47 в параллель получился 1 мкф чего вполне хватает
Иванн
Да, точно, красный китаец - СВВ81. На 165А версию Бармалея 1мкф точно хватит?
Коля
Я ставил два коричневых по 1 мкф. В самом начале моего нелёгкого пути один из них ушёл в мир иной. Поменял его, до сегодняшнего дня обра работают. Ёмкости не потеряли.
OlegarX-RUS
А с чего бы им ёмкость терять это же не электролит.
Коля если честно ты как минимум людей с толку сбиваеш своими рассуждениями на уровне юрского периода.
electrovoz
Чтобы не было таких ситуаций, в моем инверторе ММА, а также в ПА есть контроль питания, и при просадке 0,5 В все останавливается. Некоторые из повторявших эту защиту опрометчиво выбрасывали.
RUS5610
Кто нибудь пробовал К73-11 400в-1мкф ?
