Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
golub
Вроде разговор был про дежурку бармалейника, как я понимаю 30-35 ватт, вы мотнули 130 ваттный источник, а это немного разные вещи. Разбивать первичку они рекомендуют при проектировании многоканальных (два и более). Зарядите в проге 224 ТОР и гляньте расклад обмоток. Хотя сам я и дежурки 30 ваттные мотаю и половиню первичку.
Genadiy
Цитата(golub @ 15.6.2009, 21:51) *
вы мотнули 130 ваттный источник.
145Вт
Не смогу....у меня уже и топы 224 и прога к ним кончилась.Остались только GX 249 и 250.Для слабеньких блоков есть TinySwitch,но слабенькие в последнее время делать не приходиться.Пару лет назад набрал удачно Самсунговских блоков 14В-3А и их еще мне на долго хватит. icon_biggrin.gif
Когда делал раньше на 224 и не разделял первичку то сопрессоры кипели,приходилось ставить 1.5КЕ+ радиатор на него.После того как начал делить первичку на две части то сопрессоры даже при максимальной нагрузке больше чем 50гр.не нагревались.
RUN1
Парни вчера еще подрыгался с дежуркой транс у меня почти Е19 намотан пол 1-ки потом пусковая затем 2-ка и остальная 1-ка не чего не греется
поставил 3n60 и оставил uc3845 потому-что uc3842 запускается у меня со 170вольт а uc3845 стартует со 100вольт оставил наночь нагрузил пятью куллерами по 2,6w все Ок .Мужики не подскажите по подробней какие меры надо принять чтоб оставить UC3845 буду очень благодарен?
С уважением
RUN1
[quote name='supryur' date='15.6.2009, 22:34' post='95340']
Ну вот третий аппаратец ....... наконец муки с напильником и дрелью закончились
Ни че так норма!Вот только выхлоп мне кажется маловат!И алюкобонд для передней и задней панели не хлипковато? А так гуд но я бы есче
САНЕК
Народ,появилась альтернатива PI Expert,http://forum.cxem.net/index.php?showtopic=48352
Я немного погуглил,нашол сайт с софтом,там много всякого,а для прямоходов не нашол.Кто аглицким владеет,гляньте.Я про ПИКсИ Дисижн.
supryur
Да выхлоп маловат , а переднюю панель -что было то пришлось прилепить, ну так вродиб все крепенько, вес 7,5 кг без шнурков , чса такое время что и ложки на метал поздавали, еле лист нашол что бы закрыть , а покрасить обязательно - енто со следующего калыма icon_smile.gif будет краска!
Alex72
Цитата(Svarnik @ 15.6.2009, 20:00) *
Имеется сгоевший транс Е65 от заводского аппарата. Есть погоревший "сотка" (делал чуть больше года назад, погорели выходные КД2997, за ними отправились транзисторы -на фото).
На 70 кГц скока витков впихнуть чтоб 250в держала(подстанция за забором) ,т.к хочется транс заоднемя переделать? Прикидывал 15/5...
12/4. зазор 0.04
Но это впритык. Мож частотой поиграться придется. Бумага из кондеров.
Калькуль. лысого обязателен.
bell
А сколько диодов стояло? Себе тож поставил по 10 шт в плече, ток до 180,не крякнут?
Andrey_G
bell, я себе в 120-ку ставил 4 прямые и 5 замыкающих, живут нормально... правда при первом включении на нагрузку (40А на балласт) два диода новернулось, может кривые были, волялись долго, пока пригодились - состарились однако icon_smile.gif.... один на замыкающем в коротыш ушел, а второй, на прямом, как то странно новернулся - подзванивался в обратную сторону, но кортыша не было... потом, чтоб посмотреть живучесть остальных, накрутил ток до 140-150А - пару 4-ок спалил температура радиатора даж до 65 не дошла (радиатор пневский P4, они там все в куче на медной пластине 3мм, ну а пластина к радиатору). И как ни странно, но ключи выжили, а стояли полевики IRFP360 (я их при первом включении в каждый аппарат пихаю, жалко если от какого нибудь касяка нармальные новернутся). Радиаторы разогрелись секунд за пять градусов до 90, думал кирдык ключикам, ан нет, живы icon_smile.gif.
KSV
Доброго всем времени суток.Собрал аля КОЛЬТ на 3845, PD1,53Кгц тран ETD59 24/8 индуктивность 900Мкгн.При испытаниях по калькулятору получилась такая картина.
Напругу давал от 0 до 300в зуб появляется сразу.Менял зазор пила ливо увеличевается либо уменьшается остановился на минимальном накале (лампочка на 10вт еле горит)
индуктивность 840Мкгн.Напругу небольшую давал при 100в больше чтоб фазировку ТТ проверить дальше не решился(на бармалеях такого не было).Подскажите на что грешить. 1-Калькуляятор 2-затвор 3-эмитер колектор под напругой 300в
Нажмите для просмотра прикрепленного файлаНажмите для просмотра прикрепленного файлаНажмите для просмотра прикрепленного файла
Valter
Ага, чтоб на солнышке цельсиев внутрь добавить.
Chaynik
KSV Что там за снаберы стоят?
golub
А чем вас смущает этот зуб. Он там и должен быть.
Вот вам ещё зуб, дык это почти без снаббера. Лампа 40 ватная должна еле подкаливаться, а не 10 ватт.
electrovoz
У ТОРов рекомендуется мотать вторичку ОС возле вторички, потому что по ней идет регулировка. Если 3845, то вторичку ее питания лучше мотать последней, это даст минимальную инд. рассеяния и нагрев снаббера или супрессора, поскольку стабильность ее особо не нужна.
RUN1
electrovoz благодарствую! Так и сделаю.
С уважением
KSV
Снайберы стоят КОЛЬт (10ом и 4n7)
Зуб не смущает а настораживает PD1 жалко на БАРМАЛЕЕ небыло а лампа на 10вт под рукой оказалась
если она еле горит то на 40вт накал всяко меньше будет
golub
В бармалее наверно и Кзап был другой, да и частота не 53 кгц. Про PD1 не переживайте, дубовые они, правда против лома... .
Genadiy
Цитата(Коля @ 30.5.2009, 17:48) *
Слыхал где-то здесь пиборчик для измерения К. зап., но у нас я нигде не видел, стоит ли искать?
Шо-то Колю давно не слышно.....Коля Ау-уууууу.Я тебе фотки приготовил,могу еще и печать выслать для приборчика по сообщению
#2113,это тот который из Радио №5 для измерения заполнения.
Работает нормально и с первого раза.
yjriy
Наверное из-за серии неудач с соткой охладел парень к инверторной сварке. Нехочет, блин, теорию изучать никакими силами.
electrovoz
Быстро и точно измеряем Кзап:
1. Измеряем среднее значение китайским мультиметром (они все с двойным интегрированием). При питании 13,5 В будет примерно 5-5,5 В.
2. Измеряем амплитудное осциллографом. Будет 11-12 В.
3. Делим первое на второе. 5,5/12=0,458
RUN1
Тоже вариант надо попробовать лишь-бы китаец не врал
С уважением
Basill
Некоторые тестеры имеют функцию прямого измерения Кзап (Duty) в %. Когда-то выкладывал экспериментальные кривые зависимостей Кзап и частоты от Ct, Rt, тогда же приводил описание и фотки измерительного стенда. В центре - корейский тестер Metex P-10 в режиме измерения коэффициента заполнения прямоугольных импульсов.
electrovoz
Чтобы "китаец" не врал, делаем интегратор из целых двух деталей размером 1 ком и 10 мкФ и измеряем хоть Ц20, если у кого есть, осциллографом или тем же мультиметром среднее постоянное напряжение.
hurley
а в чем смысл использования такого мощного и высоковольтного транзистора раскачки на выходе 3845 и вообще такой схемы раскачки ? неужели 3845 сама не раскачает ?
Гость_Pavel_*
Подскажите, подключил трансформатор тока, 150 витков, сопротивление 1 ом, импульсы как то странно уменьшаются, низ широкий а верхушка сужается! так и должно быть ? или нет ?
SRGUT
Может ктонибудь поделитса рисунком печатки управы.Чайник я в разводке ,40 лет пользовал цапонлак через капиляр и только сейчас решил попробовать принтер.Да может программку кто нибудь подсуетит? ЗАРАНЕЕ ВЕСЬМА БЛАГАДАРЕН
Коля
Привет Геннадий! Ветку читаю! Но времени нет абсолютно. Приборчик хороший, но будем искать заводской, хотя чем чёрт не шутит. В этой ветке можно сказать, что живу... Обьязательно соточку доделаю. За помощь ОГРОМНЕЙШЕЕ!!! СПАСИБО!!!!
Всегда пользовался программой SLaoyt 0.4, но уже давно появилась 5.0 ( хотя может и более поздние версии есть, в любом случае они мне не сильно интересны, и в этой программе отличный набор функий)
http://ifolder.ru/12709618
mikael-p
[quote name='Genadiy' date='17.6.2009, 21:00' post='95570']
Генадий, а на 3 фотке программатор похоже сверху.
Genadiy
Да это "Понька-прог".
Гость_oleg_*
А никто не пробовал включить два бармалейника параллельно, моща добавится?
bell
Обязательно!
Только я на всяк пожарный случай параллелил их через диоды( пусть спецы не плюются) icon_biggrin.gif
40 и 34кГц.
hurley
можно соединить сразу за диодами до общего дросселя или нагружать каждую секцию на свой дроссель и соединить выходы дросселей ?
планирую сделать 4х фазный генератор на контроллере для многофазного преобразователя,
в сумме должно получиться более 400А.
толян
Во первых , как то здесь промелькнула информация про ДИСКОН , позвонил , от цен на радиаторы ужаснулся , от цен на вентиляторы
получил , в некотором виде , удовольствие , вентиляторы SUNON , довольно качественные , недорогие , менеджер - Алексей, телефон -
8 - 050 - 750 - 12-23 , есть довольно недорогие модели .
По поводу спарки из двух косых - применяю давно , по параметрам вполне соответствует , кстати применял и три в одном ,
аппарат - бомба получается , суммирую после дросселей , по программам для плат - применяю LAYOUT5.0 , потому , что пятёрка
гербер формирует вполне реально.
Кстати и фотки вкладывал по спаркам на предыдущих постах
Wiew
последнее время беру вентили в Дисконе, очень приличные ветродуи, и по приятных ценах icon_smile.gif
RUS5610
какие размеры на сколько вольт берете и цены если можно.
Wiew
вибирайте какие надо:вентиляторы SUNON, первый раз для пробы взял самые дешевие
KD1208PTS1.13 по 12грн, 80Х80, потребляемый ток 0,15А, а делает компутерные с потребляемым 0,28А которые стоят значительно дороже.
Ориентируюсь в выборе по параметру CFM, и inch-H2O
вот таблица з переводом этих величин Нажмите для просмотра прикрепленного файла
strannicmd
толян,
А ссылочку не дадите?! Хотел бы взглянуть... Спасибо.
толян
Цитата(strannicmd @ 20.6.2009, 18:23) *
толян, А ссылочку не дадите?! Хотел бы взглянуть... Спасибо.
Даю. http://www.electrik.org/forum/index.php?ac...ost&id=4332
http://www.electrik.org/forum/index.php?ac...ost&id=4394
strannicmd
толян,
Даю.
Я думал Вы спарку собирали в одном корпусе с синхронизацией... (типа модульной конструкции..) По картинкам я этого не вижу, (не вижу двух трансов..) Вы просто паралелите 2 независимых инвертора? Каждый в своём корпусе? Или Вы просто имеете ввиду баян ключей?
толян
Цитата(strannicmd @ 20.6.2009, 23:09) *
толян, Я думал Вы спарку собирали в одном корпусе с синхронизацией... (типа модульной конструкции..) По картинкам я этого не вижу, (не вижу двух трансов..) Вы просто паралелите 2 независимых инвертора? Каждый в своём корпусе? Или Вы просто имеете ввиду баян ключей?
В одном корпусе параллельно подключены два раздельных модуля на 150 ампер , даже если один откажет - второй будет пахать ,
но для аппарата - это уменьшение тока в два раза , модули не синхронизированы , как следует из конструкции, это для меня технологичней. На картинке видны лицевая сторона одного модуля и тыльная второго , а на старых фотках модули стоят горизонтально ,
но конструкция по электрической одинакова. Две платы , два транса , два дросселя , всё это параллельно. Фотки строенного не
делал , параллельно три модуля , питались от разных фаз , но с общим нулём , ток до 350 ампер , сделано 3шт для профи , но на
вынос параллелились по питанию и можно было спокойно варить от 220 вольт , только мощи давать поменьше, делались для цеха ,
там какие то толстые железки варят. А спарки делаю регулярно , клиентам нравится запас по моще .
Д713
..потому , что пятёрка
толян,гербер для сверловки или еще и фрезеруете?
..параллельно три модуля , питались от разных фаз , но с общим нулём..
для "общего нуля" не в напряг?он вроде потоньше фазных.
golub
И не для силового использования.
SRGUT
Д713, При равной нагрузке на фазах звезду можно ваще без нуля.
Д713
у толяна другой случай.
gyrator
ИМХО, мостик с разделёнными обмотками оптимальнее однотактов, как при питании от 220В (параллельное включение диагоналей), так и при работе от 380В (последовательное включение диагоналей с автоматическим симметрированием напряжения на последовательных емкостинах входного фильтра) без нейтрали.
strannicmd
gyrator,
Это что? Типа 2 косых на один транс? С общим двухтактным контроллером? Я так понял? Или в "штангу"... icon_smile.gif
gyrator
Цитата(strannicmd @ 21.6.2009, 15:35) *
gyrator, Это что? Типа 2 косых на один транс? С общим двухтактным контроллером? Я так понял? Или в "штангу"... icon_smile.gif
strannicmd
gyrator,
Ты правильно понял.
А где про это более подробно почитать можно? Ссылочку не дашь? Спасибо.
толян
Сперва про Sprint- layout , просто та же Александрия и не только , требует файлы для производства плат или в пикаде или в протэле ,
или просто в гербер-формате , а спринт вполне лояльно формирует гербер-файлы , и сверловку и маски и т.д. Пользуюсь.
По поводу нуля в три-в-одном сварочнике , там кабеля в цех приходят толщиной с руку , просто развели по рабочим местам розетки
трёхфазные с приличным нулём и всё , там и болгарки и прочая инструмента тож через 0 питается , киловаттом больше, киловаттом меньше по 0 , какая разница. Мне проще было три стандартных модуля в один коробок запихать , чем заморачиваться с полным
трёхфазником.
gyrator
Цитата(strannicmd @ 21.6.2009, 18:41) *
gyrator, А где про это более подробно почитать можно? Ссылочку не дашь? Спасибо.
Ссылочку давал, но тов. Петров еЯ пришибнул. Видимо воспринял как рекламу конкурирующего сайта.
Извиняюсь, в азарте видимо.
Где-то здесь http://valvol.flyboard.ru/topic85.html , а начало на старом форуме в ветке про усовершенствование кривенького и пряменького мостиков-полумостиков.
Схемка буржуйского приборчика, в котором это (220-380) реализовано, скрывается в недрах Города мастеров.
