Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
mono
Цитата(Vytelis @ 26.4.2012, 16:21) *
сегодня пробовал варить постепенно увеличивая ток до макс, пол электрода сжег и выбило автомат,результат - пробиты оба ключа,хотя нагрелись только до 35 град
Всётаки сначала умерли транзисторы, а потом уж автомат пытался сеть защитить, и видимо помог, мызыки не было?
seljozha
Во,какой транс слепил.Что думаете , не рванет )))))))
Серёгин
seljozha.Текстолит похоже с фольгой ? ТОЧНО РВАНЁТ ! 1000 % !!!
HEMELL
seljozha, а что, нельзя было нормальный транс намотать?
seljozha
Не текстолит чистый.А чем этот плох.Готовые кактушки,собрал и усё.Я одну размотал и пожалел,шина бу,намотать новую оккуратно не получилось.Да и тепловые зазоры меж катушек и феритов для вентиляции.Каждая катушка не замкнет и при ремонте моментально разбирается.Есть недостаток чуть больше габариты,основа учитвалась с учетом установки радиаторов для диодов и ключей.Учитывая эти плюсы на сей недостаток можно закрыть глаза.Вот хотел проконсультироваться.Начинаю собирать БП,вот по этой схеме.Да вот нет NTC1,БЕЗ НЕГО БУДЕТ КРЕТИЧНО?И еще выделенный узел гдето читал что можно заменить резистором и емкостью,но вот не могу найти ту страницу,мож кто подскажет?
ГонZа
Вечер добрый.Vytelis,Радиатор(от пня 4,распилил на два) притирал шлиф-машинкой(работаю электриком в авто сервисе),прикручивал через термо пасту.Удачи.
oleg1ma
Стоят в комповых БП,если нет, можно заменить сопротивлением 4.7-10 Ом мощностью 2Вт.
Putnik
Сопрессор можно заменить, делается это примерно так, как на картинке
mono
Померяй индуктивность рассеяния, уверен, что большая, но интересно сколько. Если при работе начнут ёмкости по одной микрофараде дохнуть на глазах, то придётся перематывать, но лучше начать прямо сейчас.
seljozha
Да нечем померять,а народных способов не знаю
Sergei69
Всех с мир, труд, маем!!! А я опять с вопросами, собираюсь мотать транс на Е70, Бармалей 165А F=30кГц, 18/6. Вот каким образом: пол первички лентой из 6 жил 0,69 по 9 витков в 4 слоя, начала и концы в паралель, потом лента из 9 жил 0,69 по 6 витков 7 слоёв и вторая половина первички в 4 слоя лентой из 6 жил 0,69 по 9 витков. По прикидкам всё это должно залезть, и сечение вроде бы нормальное получается 7/21 квадрата, но вот чё-то не соображу первая половина первички и вторая последовательно??? И как такая компоновка транса???
oleg1ma
Насчитал у тебя 15 слоев намотки.15х0.69=10.35мм.Ширина окна у Е70 равна 12мм+каркас и того останется 11мм.Вывод: даже без междуслоевой изоляции, которая очень нужна, нихрена не влезет.
Sergei69
а без каркаса, тем более,что у меня его нихрена нету. да и не об влезет вопрос, пойдёт такая намотка и как соединить части первички???
oleg1ma
Cоединять нужно так, что-бы намотка и первого слоя и второго, была в одном направлении.
АлексейС
Ув.Putnik!В свое время купил в Космодроме (кто не из Украины - магазин радиодеталей) несколько 1,5КЕ200 и сейчас на праздники решил собрать зарядку на ТОРе.Ничего не вышло,топик клацает.Перебрал всё,результат -ноль.И тут залез сюда и увидел Ваше сообщение.Все заработало!Что обидно,так это то что ВСЕ сапрессоры были говеные.Спасибо Вам!С уважением.
oleg1ma
Неработать могло не только из-за некачественных сапресоров, может на схеме неправильно нарисовано включение его, сам попадал на такое, поменяв местами диод и сапресор схема начинала нормально работать, да и сапресоры бывают разные.
Sergei69
Жутко извиняюсь, в одном направлении это как? Можно чуть подробнее, заранее спасибо.
oleg1ma
Примерно так.
Putnik
[quote name='АлексейС' date='2.5.2012, 15:36' post='235125']
Пожалуйста! Тут все друг другу помогают, обратите внимание на совет oleg1ma может и в самом деле неправильное включение сопрессора
АлексейС
Да схема правильная( http://www.masterkit.ru/info/magshow.php?num=43 ),я её уже собирал,все было ОК.А за совет спасибо,Вы тут как отец всем,из старожилов кажется только Вы и остались.Я не ерничаю,благодаря таким как Вы очень многие (и я в их числе) смогли не только сделать себе классный аппарат но и вообще "въехать" в импульсную силовуху.
кабельщик
АлексейС, как примеры лучше используйте даташиты на микросхему от производителя либо его же аппноты (рекомендации к применению и типовые примеры включения). Как правило, там все ясно и без перевода на русский.
Ибо в приведенной вами ссылке неверно указана цоколевка корпуса Y Package (TO-220/3). Непонятно - как статье, ориентированной на большую аудиторию, можно допускать "бах"овые ошибки...
АлексейС
Честно говоря я на это и не обратил внимания так как в статье есть плата и ТОР наоборот не всунешь,он с диодом прикручивается к радиатору через прокладки.
oleg1ma
Цитата(АлексейС @ 2.5.2012, 20:09) *
Да схема правильная,я её уже собирал,все было ОК.А за совет спасибо,
Ничего правильного, там неувидел, вот посмотрите как правильно.Специально перерисовал с двух рабочих БП.Если не выбросили сапресоры, попробуйте.
АлексейС
Но у меня работало!Ваши варианты при случае попробую.Сапрессоры улетели в окно по причине моего душевного расстройства.Спасибо,с уважением
Д713
мож и зря улетели,они существуют в природе однонаправленные и симметричные.
АлексейС
Эти были однонаправленные с полоской на катоде,да и тестером я их проверял.Так шо пущай полетают...
maxon
oleg1ma по моему без разницы что в схеме стоит к стоку транзистора (диод или сапрессор). Главное правильно ориентировать (для двунаправленных сапрессоров не актуально)
oleg1ma
Я считаю Ваше мнение ошибочным, так как выше писал, что наступал на эти грабли.Дошло чуть ли не до перемотки тр-ра, потом глянул на свою фотку ранее рабочей платы, поменял местами диод и сапресор двунаправленный и все заработало как доктор прописал.
seljozha
Народ,вот собрал БП на TOP224 для инвертора, но ещё не проверял.Его надо подгрузить или он так должен запустится?
oleg1ma
Должен работать и с нагрузкой и без.
кабельщик
oleg1ma, такого не может быть. Вы просто попутно еще что-то сделали-поменяли... Там действительно без разницы, где диод и где супрессор, важно только направление их включения.
oleg1ma
Спорить не буду,каждый волен делать так как считает правильным, в схеме ничего более не менял, но если у Вас один раз запустится БП, а второй раз не захочет, вспомните про цепочку диод сапресор.
Д713
mono
Да проверить то легко, поменял их местами и включай.
oleg1ma
Д713 нет, стекляненький такой с красной полосочкой Д9Б по каталогу. icon_biggrin.gif
Д713
Цитата(oleg1ma @ 3.5.2012, 22:19) *
Нет, стекляненький такой с красной полосочкой Д9Б по каталогу. icon_biggrin.gif
вроде с симметричным супрессором диод и нафиг не нужен.
maxon
По логике вроде и не нужен, а в реальности пробовали? Нет просто времени ради эксперимента собирать обратноход. Но вообще возьму на вооружение и при случае проверю.
ДядяВася
Только при этом симметричный супрессор не 200В, а на 350 или даже 400В. Напруга в розетке иногда вверх пригает, ключику может не поздоровиться.
кабельщик
Лучше не нада. Это Д713 шутит так. Или вы тоже?
maxon
кабельщик ну я не знаю, может и шутит. Я точно не шутил, применить наверное можно, но с рядом оговорок. Сапрессор на 200в тут не подойдет, как впрочем и на 300. Может ошибаюсь, но при рассмотрении симметричного сапрессора как двух встречно включенных стабилитронов верхний стабилитрон на прямом ходу сработает как диод, а нижний соответственно как стабилитрон. Результат или бах сапрессора или срабатывание защиты (БП будет икать). Т.е спасение только в повышении срабатывания напряжения сапрессора до 350в (минимум). Естественно для 600вольтового ключа такое недопустимо. Минимизация и экономия одного копеечного диодика неоправдана.
Хотя Д713 здесь авторитет, да и фотки приводил, только почему то потом удалил свое сообщение. В общем может я что пропустил, так поправьте.
Д713
точно так,сейчас STP полевиков на 900в 3-4-5а полно.
по цене полевик+3843 завсегда уделают любой TOP.
ГонZа
Приветствую всех на форуме.Уважаемые знатоки,подскажите плиз,через какое время должна сработать реле,которая подключает силу к ключам,при включении аппарата?При включении умерли оба ключа(давал родственнику поварить),хотя перед этим всё прекрасно работало.Проверял аппарат и на 212вольтах и на 221вольтах всё хорошо,а вот в чужих руках стрельнуло при включении(не знаю какая напруга была в сети).Может быть глупый вопрос,но задам: как настроить аппарат без осцыла(в наличии только низкочастотный)?С уважением Гонза.
Д713
это известная причина помирания всего-дал соседу,взял у соседа.
надо родственника попытать с пристрастием,чего он аппарату делал. icon_biggrin.gif
ГонZа
Говорит только включил!
кабельщик
Однако смысл экономии одного мелкого диода все одно непонятен. Это приводит к значительному снижению допуска на входное DC.
При отсутствии диода супрессор не может быть на напряжение меньшее, нежели напряжение DC входной банки. Для случая 900-вольтного полевика это будет супрессор на 450V и входной потолок 450V на банке.
При наличии же диода можно поставить супрессор к примеру на 300V и получить для 900-вольтного ключа входной потолок 600V на банке (т.е. условно БП может питаться от переменки 380V при соответствующем вольтаже входного кондера, и уж точно будет иметь мегаживучесть при всплесках входной напруги при питании от обычных 220V).
В общем, диод встречно супрессору избавляет его (супрессор) от прямого прикладывания напруги питания на прямом ходу, за счет этого выигрывается много вольт...
maxon
Цитата(кабельщик @ 6.5.2012, 9:39) *
Однако смысл экономии одного мелкого диода все одно непонятен.....
Так гутор не про экономию был. Применить симметричный сапрессор можно, но с рядом оговорок. Т.е о самой возможности такого примениния.
кабельщик
Если гутор был про применение симметричного супрессора в стандартном варианте (с диодом впослед), то никакого ряда оговорок нет. Кроме одной - полярность включения симметр. супрессора не имеет значения (в отличие от несимметричного , который должен быть ориентирован согласно схеме, т.е. анодом в сторону +пит. , катодом в сторону стока ключа).
ПС. эта оговорка сама по себе выглядит по идиотски тупо, однако помнится, что были вопросы ...
seljozha
Вот попался мне на глаза,автомат с кнопкой принудительной проверки.Кнопка работает на замыкание.Снял боковую крышку и запаял два провода к контактам кнопки и вывел на тепловой датчик 90 гр,работает на замыкание.И таким образом получил комплект по перегрузке 25 А и также по тепловой защите на одном автомате.Тепловой датчик можно также использовать от авто,включение вентелятора радиатора,он работает также на замыкание92-94 гр.
andrei86
Наличие нулевого провода на автомате вашем, говорит о том что это УЗО, там ток срабатывания указан 30ма в сварочник его ставить как мне кажется не лучшая идея, так как возможны ложные срабатывания узо, хотя может быть я и не прав.
И датчик на 90 градусов тоже как мне кажется многовато т.к когда на датчике будет 90 градусов на ключах или диодах будет далеко за эти 90 то есть работать будут на пределе.
ingener99
обычно аварийные датчики всегда работают на размыкание. Так как в случае повреждения проводки или нарушении контактов в цепи датчика все равно сработает защита.
