Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
Павел(Sp)
Олег, чем удлинены ноги у ключей в одной из последних представленных аппаратов?
А то тут меня вдохновение посетило давеча(почерпнул из последних фоток Мастера),разобрал все что было и решил все в человеческий вид привести.
Переделал ВСЕ платы,получается что вентилятор будет дуть сверху на радиатор думаю может лучше когда будет продувать со стороны,как бы сквозной поток делать(как на 3-й фотке ,пост 18061),но тогда надо ноги удлинять.Как лучше?
Что за зверь на фотке что я выставлял,не в курсе?
slavyann
я не очень конечно сведущ в качестве данного устройства,и может это только мне и только раз так повезло, но я видел как в одном простеньком зарядном ток плавал туды-сюды из-за регулятора тока, где тебе ни ВЧ наводок,но других неприятностей..Если резистор шуршать будет ни к чему хорошему это не приведет..
oleg1ma
Нет такого зверя не встречал, ноги удлиннял медной луженой проволкой диаметром 1.6мм.
Павел(Sp)
Еще вопрос, это мост или 2 ключа в параллель? А то вроде как на мост не похоже из-за диодов что рядышком с ключами, потому что 1,6мм как то мало если 2 в параллель,тогда вопрос снимаю с повестки дня.
oleg1ma
Это два ключа в паралель, и 1.6мм диаметром это не мало, ради интереса посчитайте сечение ноги тр-ра и проволочки.
Павел(Sp)
OK!
VOVA 555
Здраствуйте форумчане . Вопрос на засыпку можна ли на етих ключиках IRGP50B60PD1 по одному в плече качнуть 160 А или всетаки ставить по два в плече ? В косом .
oleg1ma
Можно.
VOVA 555
oleg1ma Спасибо за ответ. Попробуем . Я почему спросил . В плане надежности нехотелось бы чтобы он в самый неподходящий момент стрельнул . Собрал ММА на Атмеге наконецта отстроил на 140 А . Выше нерешился лезть .
Wasiliy61
Корпус для очередного Бармалея, в прошлом корпус от холодильника.
Wasiliy61
oleg1ma ,добрый вечер. Помнишь мы пытали мой БП на ТОРике, я его хотел распаять, а потом подумал-пусть полежит до лучших времён. Сегодня у меня был в гостях наш форумчанин - Alexzav, и привёз пару ТОРиков, спасибо ему большоё, так я впаял ТОР и БП запустился сразу, выдал 15вольт- как и планировалось. Но при большой нагрузке БП не может запустится, просто стрелка вольтметра чуть дёргается, нагрузка лампочка 12в, 21вт.
oleg1ma
Увелич немного зазор в сердечнике.
Wasiliy61
Спасибо, попробую.
Зазор был два малярных скотча, сделал 4, результат тот-же.
Jorg63
Цитата(Wasiliy61 @ 18.9.2013, 20:18) *
Спасибо, попробую.
и будет результат тотже! лампочка в холодном состоянии имеет очень малое сопротивление и поэтому ТОР уходит в защиту. . надо активное сопротивление в районе 5-6 ом. а лампочка в холодном состоянии не более 2 ом будет.а зазор верни прежний
Wasiliy61
Зазор сейчас сделаю прежний, так что он с лампочкой вообще не запустится.
Abama
Попробуй замерить лампочку ом метром и сам поймешь, видимо у топика защита срабатывает раньше разогрева спираль лампочки
Нашел в за кормах лампочку, замер показал 0.6 ома если БП на 15в то получается 25 амперий
Jorg63
никаких шансов!!!!! С лампочкой!Ищи резисторы.Нафига тебе такой ток?
Wasiliy61
Да просто на форуме где-то попадалось что обкатывал на лампочке.Может потому что у меня вместо Р6КЕ стоит снаббер.
Jorg63
не влияет
DANTIST
Abama, это что ж за лампочка у тебя такая? 12 В 0,6 Ом? Посадочная фара с Боинга-747?
Хотя, пожалуй ты прав. Сейчас посчитал сопротивление лампы 12 В, 21 Вт при комнатной температуре. Получилось 0,63 Ома. Никогда бы не подумал.
Цитата(Wasiliy61 @ 18.9.2013, 16:03) *
...Но при большой нагрузке БП не может запустится, просто стрелка вольтметра чуть дёргается, нагрузка лампочка 12в, 21вт.
Wasiliy61, а что резистором звычайным нельзя подгрузить. Чё ты мудришь с лампочками?
Wasiliy61
Да конечно можно, просто взялся вечером позаниматься, ну и нагрузил БП тем что было под рукой.
dizel
Доброго дня всем icon_smile.gif Подскажите, возможно ли в косом для сердечника выходного дросселя применить альсифер ТЧ-90 (синяя полоса)? В таблице параметров указана критическая частота 20 кГц, а в косом больше.
Wasiliy61
Думаю что да, так как выходной дроссель стоит после диодов.
psp
Вот тут использовал такой, c синей полосой.
soud
как отверстия делал на лицевой стороне?
Wasiliy61
Сделал разметку, т.е. нарисовал узор маркером, потом сделал пропилы на маленьком болгарочном диске, который стоял на электромоторе- как наждак, потом подравнял натфелем.
slavyann
Wasiliy61, я нагружаю ИИП на ТОРе комповым вентилятором для проверки, всё норм. запускается,
хотя у меня пускался и с автомобильной лампой
зы. равнял ты наверное все таки надфилем )
владимирон
уважаемые сваркостроители на днях принесли на разбор аппарат неон 201 выгорел почти весь осталось целым мост диодов кондеры 400-470мкф 6 шт и транс силовой намотан лицендратом я его размотал до сердечника посмотреть его он круглый диам 115наруж внутр 66 толщин 15 2 штук друг на друге и сломан и склеен с зазором в 4 местах из чего сделан не знаю знаю что аппарат неон это квазирезонансный мост работает на звуковой частоте поэтому вопрос возможно ли использовать этот сердечник в бармалее
oleg1ma
Можно конечно.
владимирон
а то что сломан в 4 местах это нармально
SRGUT
День добрый всем.Решил ликвидровать свою мат-базу,тоесть все комплектующие.Раздам ДАРОМ но только самовывоз из Сургута.Есть всё примерно на пять комплектов Бармалея,чегото и бльше.Радиаторы,ключи,ферит,вых диоды,эл-литы эпкос2.500\450в 2шт ,куча деталей рассыпухи,корпуса самопальные но вполне достойные,шина медная.Просто жалко нажитое годами бездарно выкинуть.да ещё пара стареньких осликов и частотомер.
dikobraz
Цитата(Wasiliy61 @ 22.9.2013, 8:10) *
Приобрел тоже такие, можно ли их использовать? Они вроде как из силумина, у которого теплопроводимость похуже, возможно медную прокладку надо будет использовать..?
RUS5610
Медь не помешает.
Wasiliy61
Я что-то не задавался этой проблемой, но если силумин, то теплопроводность у него почти в 2 раза ниже. Но для радиаторов пади его не должны использовать.
igorka
На дюралюмин icon_biggrin.gif icon_biggrin.gif больше похоже!
VOVA 555
dikobraz Приобрел тоже такие, можно ли их использовать? Они вроде как из силумина, у которого теплопроводимость похуже, возможно медную прокладку надо будет использовать..?
Силумин его на прозводстве называют дюраль - алюминий при обработке стружка при сверловке крышится если он плохого качества то он может быть пористый . А алюминий нормальный вязкий и без смазки очень сильно залипает ( масло или керосин ) стружка тянется . Так что делайте выводы.
Если нормальный алюминий и резать его тяжело если електролобзиком то пилку лучше брать по дереву с крупными зубями на малых оборотах и смазывать маслом .
Эсли кому интересно могу подробно описать методику нарезки резьбы в разных металах и какие диаметра сверл нужны под те или иные резьбы .
владимирон
вот мотнул первичку и вторичку 18и6 соответствено жгут в термоусадке сечение 10ммкв первичка и 35 ммкв вторичка это с неона 201 обмотки смотал и в термоусадку загнал и еще вопрос в неоне стояли диоды 4 штуки по 2 в паралель 80ебу 04 их хватит или еще по одному в плечо добавить такому же только имеется 80ебу 02 подойдут такие
VOVA 555
atX-MAN На производстве обуви наверное...
Откуда вы знаете ? Вроде негде не оговаривался .
Ето последних 7 лет я чиню обувь а до етого 4 года работал слесарем в отделении пресформ .
oleg1ma
Цитата(владимирон @ 22.9.2013, 21:10) *
их хватит
Для тока 160а достаточно 1прямой и 2 обратных.
Павел(Sp)
Вова чинить обувь это вполне приличная работа,мне вон иногда такое дерьмо чинить приходится шо посмотриш и глазам своим не вериш,хотя я по контракту слесарь и сварщик.
Так что если тебя кто сапожником надумает обозвать,плюнь онному в очи и скажи шо ты ремонтник(обуви),ибо нет плохих профессий,есть просто люди которые плохо делают свою работу,вот как депутаты например... beer.gif
владимирон
я так понял хватит прямого на 80а обратного на 2по80а так чтоли
Wasiliy61
Нажмите для просмотра прикрепленного файла Да, типа как здесь, но я бы сделал ровные плечи.
VOVA 555
Павел(Sp) Вы знаете пусть говорят и думают что хотят мне фиолетово . Просто все думают что ет о ремесло просто так вышел погулять .Но когда поработает на моем месте то поймет что да как. Иногда клиенты так протрахают моцк что свет не мил , пытаешся всем угодить да ещо свой самоклеп доделать нада а сил уже нет ..Конечно с постройкой инвертера не сравнить .
Павел(Sp)
Владимир я вам как нибудь в личку скину фотки какого нибудь яркого пациента на реанимацию,до и после.... так шо я иногда для самозащиты моцк дома оставляю..я кстати еще почти в детстве на обувной на конвеере год проработал-творческая работа..
oleg1ma
Правильно поняли.
Павел(Sp)
Олег, вот у меня вопрос,ввязался я в это дело с бармалеем в принципе для общего развития,мож кому и прозвучит обидно,... но начал я с планами на будущее- приделать к нему потом тиг для алюминия,блоки и диски конечно варить несобирался,так что мосща в 250а мне ни к чему,так себе ну типа бляшку приварить,радиатор какой...Но по мере внедрения тсзть в тему,то ли я ничего не понял,то ли бармалей под этодело не катит вообще.
Мож пока я слишком долеко не ушел от начала вернуться и начть снова,но в правильном направлении,или потом его все таки можно будет приспособить?
Да и в гуглях я так толком ничего не нарыл,так только теория на уровне камасутры,а если чего и попадалось то была камасутра на практике.
Существует типа тиг но без наворотов процыков и прочей нараямы?или всех кто прийдет со старой алюминевой кастрюлей за новой сразу посылать?
oleg1ma
Тиг на базе косого моста без проблем, но только постоянным током, можно варить все, для сварки-же алюминия и его сплавов нужен переменный ток и косой(бармалей) для этого не подходит.
Jorg63
У одно чела видел аппарат типа бармалей прямоход,варит алюминий без проблем. какую то приблуду сделали ему кто-то, частота генератора модулируеться частотой 50-100гц,во всяком случае дуга гудит с такой частотой. при мне варил промышленным косариком с приблудой картер автомобиля. шов скажу отлично..Поинтерисовался как чтобы схему приблуды-не дает.
oleg1ma
Приблуда скорее всего DC-AC, с ней конечно без проблем.
Jorg63
уж слишком маленький блочек, скоре всего частотой модуляции управляет генератором микры в сварнике .выход подключаеться к вых клемам сварника,никаких переходных устройств больше нет.банально отключает устройство для сварки аргоном и подключает какбеля и варит уже электродом .отключив блочек.
получаеться пол периода с частотой допустим 100 гц генератор генерит с частотой допусим 40 кгц а пол периода в стопе генератор.вот и получ преривистая сварка.только это могу предположить. процес работы вероятно типа такой
