Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
DANTIST
Где же наш Stalker-dass пропал опять?
Меня не будет несколько месяцев. Все вопросы на потом или к Golub у. Он в курсе моих дел.
толян
Цитата(Батарейкин @ 17.11.2011, 12:40) *
Толян подскажите Ктр силового транса Вашей спарки.
Стандартный 3*1. Просто ставлю в один корпус два готовых модуля AVT160. Раньше , на 3845 делал одноплаты и запихивал два в большой корпус. Счас только корпус в два раза ширшее.
STASKIN
Цитата(delivero @ 17.11.2011, 17:05) *
трансформатор силов Е55 первичка 24нав 2 х 1.25мм. вторичка 8нав. 6х1.7мм.
честота 45kHz к.з. 0.43
ресурсные испытания впереди.
delivero
Цитата(STASKIN @ 18.11.2011, 16:38) *
Зазор 0.1мм лист бумага 80грама.
толян
Много, никогда больше кальки -- 0,03 не ставил.
STASKIN
Вы делали на Е55? Можно подробнее?
толян
Делал аппараты на Е65, ETD59, спаренных Е55-21 и по два транса ETD54. Нигде зазор больше указанного не делал. Все рекомендации по увеличению зазора даются применительно , скорей всего, к нашему ферриту. То есть с запасом. А современные ферриты вполне позволяют использовать их по полной, то есть не верить буржуям, озвучивающим параметры сердечников, смысла нет, и перестраховываться с большим запасом тоже.
delivero
моя сотка тест
http://vbox7.com/play:be8fe07134
сварка
http://vbox7.com/play:199d23db89
сварка
http://vbox7.com/play:d624d739e2
TSW
Добрый вечер уважаемые сваркостроители у меня вопрос к oleg1ma на счет его транса на 4комплектах е42 с телеков Сообщение #11222 к какой схеме вы его примастыривали на какой частоте он трудится и какой ток с него можно снять ато уменя их дофига насобиралось а выкинуть жалко.
oleg1ma
Трудится в бармалейнике голом, ведет себя наверное хорошо(назад не приносили) макс ток ограничен на 120А.Собирал аппарат на одноплате от Д713, если будете делать, то для хорошего ПВ должен быть хороший обдув.
TSW
спасибо за ответ! как раз на этой плате и делаю!
TSW
и еще вопрос а какой зазор у е 42???
oleg1ma
Я делал по 0.05мм под боковыми кернами.
oleg.sv
Добрый день уважаемые сваркостроители у меня вопрос к oleg1ma, читая форум узнал что вы "oleg1ma" собирали инвертор AVT-200 и инвертор Липина. Подскажите пожалуйста какой будет проще собрать (проще в настройке)? И с каким будет приятней работать?
Опыт работы с электроникой есть.
UVM
А тема бармалейная....
oleg1ma
Собирай липинский, проще некуда, я здесь до него выложил все и в работе он мне нравится.
oleg.sv
Спасибо за совет. Нашел ваши наработки по липинскому инвертору. Возник вопрос, вы шунт на 100А используете покупной, или самодельный? Если самодельный можно совет по его изготовлению.
oleg1ma
Шунты ставлю покупные, разные, главное что-бы был на 100А.Платы коректирую из ходя из того что достану.В последнем варианте шунт был сделан из заводского шунта на 200А, распилен болгаркой на 2 шунта.
igorka
А что за схема Липина?
Jorg63
Вот по этой ссылке Вы все найдете что надо. http://progcode.narod.ru/ Здесь есть разработки сварочных аппаратов Руслана Липина,а также много еще того что заслуживает внимания.
igorka
Спасибо,занятный сайт.
stalker-dass
Добрый день!
Скажите это норм или нет, вообщем последняя стадия проверки. Фото при хх силы подано 40В осцилогр. нормальная. Но вот подал 120В силы задатчик на минимум, кз на спираль (0.4 Ом) когда задатчик в минимуме и есть кз то сварка пищит, как только задатчиком повышаю ток то писк проподает, примерно после 15А, осциллограмма при этом имеет вид (фото) задатчик на минимум, силы 120В, из сети при этом потребляет около 7-8А, осцил на кол-эмм нижнего ключа, 5мS 20В/дел, + делитель 1-10. Ток повышал до 45А дальше не стал.
Скажите с такой осциллограммой можно повышать напряжения до 220В?????? Все норм или что-то не так????
Зарание спасибо!
lera
dass. Но вот подал 120В силы задатчик на минимум, кз на спираль (0.4 Ом) когда . К.З. это короткое замыкание. Вы гдето прочли что можно варить от 120в? Калькуль лысого --ток намагничивания. Полное напряжение .а уж потом К.З. Успеха. К слову К.З. делают на 40в для проверки схлопывания импульсов .На первом фото импульсы хорошие.
maxon
stalker-dass
простите я наверно не совсем корректно отписался, я провел все проверки и осцилограммы на кол-эмм, и схлопывание имп. при 40В силы, и через лапмочку включал, даже пробовал мерить ток намогничевания, но что-то этот замер у меня не вышел как положено, и силу подымал до 220В вообщем все, вот осталось мерить под нагрузкой(спираль) написано было что начинаем подавать силу с минимума и постепенно повышаем, иногда добавляя ток, в основном слушаем ну и смотрим осцилы на кол-эмм нижнего ключа, вот я и писал что писк есть только когда задатчик в минимальном положении, но он проподает при повороте резистора примерно на 20% дальше сварка ведет себя пока тихо. Осцилограмму вторую я представил когда поднял напряжение до 120В и задатчик повернут был на 40%, вот и спрасил нормальная ли осцилограмма при таком напряжении и задатчике тока. По видемому нормальная и можно напряжения поднять до 220В и ток до мах. если осцилогр. не изменится на ужасную чушь то запаливаю электрод, спалю 3шт. подрят и проверю что больше всего греется от этого и буду решать куда повесить термодатчик и на какую температуру, пока что его нет вообще.
stalker-dass
Вообщем подал штатно 220В при хх писка нет только когда задатчик выкручен полностью в ноль, как только поворачиваешь на 10% то писк при хх проподает, при нагрузке (спираль) писк есть на всем диапазоне задатчика тока, только один нюанс у меня пока что транс не пропитал, просто собран, может частично из-за этого, но я думаю что после пропитки писк полностью не проподет.
Что скажите уважаемые сваркостроители?
пробывал варить задатчик на ток 90А всего вышло 105 пробывал варить старая марка отечественного серого электрода 3мм так она горела не оч, потом взял 4мм но нового образца(зелено-синий) просто ничего другово под рукой не было. вообщем 2-е старые тройки и 2-е новые 4-ки, полили подряд с перевывом в 15сек. сварщик сказал что шов отличный (сваривал 2 пластины 5мм) провар хороший, все говорят что звук сварки тоже хороший а по мне он как -то стронно шипит а не трещит как старые сварки, возможно так и надо я ведь не сварщик и опыта у меня такого не много.
Проверил что больше всего греется после выше описанного вышло: дроссель вообще холодный, он без обдува, радиатор моста холодный он без обдува, радиаторы транзисторов на грани ощущения пальцем нагрелись, но они стоят первые перед кулером, а вот транс на 4-ох ТВС стал тепленький, палец держит свободно сама обмотка теплее, чем феррит но она просто теплая транс стоит вторым после радиаторов транзисторов, вых. диоды стоят на небольшом радиаторе паралельно трансу (т е тоже вторым после радиаторов транзисторов) так вот радиатор вых диодов был теплее транса палец держать можно свабодна не оппекает.
Вопрос мой вот в чем я так понимаю что термодатчик надо поставить на вых диоды но подскажите на какую температуру лучше??????????
АлексейС
Поздравляю,у Вас получилось!Что касается писка на минимуме-немного увеличте сопротивление рез. на делителе регулятора,в Бармалее он 1,3 кОм,поставьте 1,5-1,7.Этот сварочник не шкварчит как трансформаторные,он и должен шипеть.И электроды ему по барабану какие:старые или новые,сухие или мокрые...А вот 4 строчника мне кажется маловато для транса.Это сейчас он теплый,а что будет летом?Вообще больше всех греются вых. диоды и датчик ставится на них.Вы пишете что радиатор на них небольшой,если конструктивно возможно-или замените на бОльший или сделайте доп.обдув.Удачи!
stalker-dass
АлексейС
Сопротивление в делителе стоит и так 1к5 а вот второе не 620, а 680, попробую увеличить до 1к7.
4 ТВС 3000Нм из этого и исходил что 3000, можно и всего 4 шт поставить на 100А в нем обмотки греются хотя первичка 4.5 вторичка 12.5мм2.
вых диоды у меня в виде сборки на 150а400в радиатор под сборкой считал примерно 370см2 знаю что мало, но тяжелова-то поставить туда больший, Скажите если я термодатчик поставлю на вых диоды градусов 70-80 это пойдет или их можно и до 90 греть???????????? обдув радиатора то вроде ниплохой как ни как кулер на 220В 140 литров перекачки. летом будет конечно потяжелее.
Огромное спасибо АлексейС!
АлексейС
Да незачто,я когда собирал своего Бармалея- всех замучил вопросами и,спасибо всем,помогли.Что касается температуры диодов то (моё личное мнение) лучше перебздеть чем недобздеть,тем более в случае отключения по температуре кулер охладит радиатор меньше чем за минуту.Удачи!
Alex_zp
Приветствую всех участников форума!
Продолжаю собирать сварочник SPARK1600. Подскажите, если трансформатор взял с бармалея - Е70 18/6 витков и домотал 1 виток сервисной обмотки на выходе сервисной обмотки получается больше 20 В. Это сильно критично? Надо ли транс перематывать? У меня получилось чуть больше 35В.
Lemm
измеряется температура радиатора , а есть еще тепловое сопротивление кристалл-радиатор (т.е. кристалл-фланец-радиатор-окружающая среда) и это означает то , что когда сработает термодатчик на 90 , кристалл будет работать при 125-150 градусах , где уже стремно . лучше поставить на меньшую температуру .
lera
больше 20 В. Это сильно критично? Надо ли транс перематывать? У меня получилось чуть больше 35В. При 6вит. на вторичке=более 200в. Что-то тут не так. Вы осцилом проверте напругу. dass поздравляю с испытанием.
Alex_zp
35 В это на сервисной обмотке, 1 виток. Забыл уточнить
stalker-dass
Всем участником форума выражаю огромную признательность и говорю огромное спасибо, так как без вашей помощи не смог бы собрать данный девайс.
delivero
Здравствуйте. Может быть заменен HFA15TB60 с
FFAF30U60DN.
oleg1ma
FFAF30U60DN.
Может.
delivero
Меня беспокоит HFA15TB60 - 35nS и FFAF30U60DN - 90nS максимальная так пишет в каталоге.
работна честота сварочник 45kHz.
oleg1ma
Будет работать.
Д713
не путайте наносекунды с нанокулонами.
кабельщик
delivero, при сравнении диодов берите во внимание из даташитов на только указанное там время Trr, но и условия, для которых оно указано (ток и температуру).
Эти два диода по параметру Trr практически идентичны, учитывая снятие параметра у FFAF30U60DN при вдвое большем токе (с мысленным допуском, что FAIRCHILD измерил это при горячем диоде).
PS. Домашнее задание: найти 600-вольтный диод, у которого Trr при токе 15-30А (и температуре 100*-125*) был бы 35ns или меньше. Карбид кремния не предлагать icon_biggrin.gif
oleg.sv
Добрый день!
Подскажите пожалуйста, кто мотал силовой транс на ферритовом кольце, достаточно ли кольца "R58,3х40,8х17,6 N87" на 140 Ампер и какие моточные данные?
Или нужно брать R 63x38х25 N87- какие на него моточные данные?
oleg1ma
Цитата(oleg.sv @ 28.11.2011, 16:43) *
Добрый день!
Подскажите пожалуйста, кто мотал силовой транс на ферритовом кольце, достаточно ли кольца "N87 R58,3х40,8х17,6" на 140 Ампер и какие моточные данные?
Или нужно брать R 63x38х25 - какие на него моточные данные?
У кольца 58.3 х 40.8 х 17.6 вдвое меньше сечение, на 140А нужно 2 такмх кольца.Лучше взять 63 кольцо, я на нем мотаю первичку 32-34 витка, если пилянное или сломанное и вторички 10-11 витков.
delivero
хорошая молния на моя сотка. На баласт термозащита не сработила и БУМММММ!!!!!
эта плата не должна быть использована в косой мост
sarmat
Никто уже не узнает, что там сработало или не сработало. Зачем над малышами балластами издеваться.
maxon
delivero если я правильно понял по вашим фоткам, то транзисторы и размагничивающие диоды были припаяны на плату. А тепло они по вашей задумке скидывали на радиатор через текстолит. Если так, то о какой термозащите вы говорите. Результат закономерен.
delivero
транзисторы и диоды были паяные алюминиевые пластины из ламинированной текстолит. Датчик радиатора тепло составил 75 градусов. алюминиевая пластина не пропускает большой теплоемкостью. транзисторов перегреву и отпаять снабеи и бум! платка алюминия с не достаточно тепла для косы моста. уже опробовал!
Д713
похоже maxon прав,ключам и диодам до радиатора ой как далеко.
yura_
По теплу обычно транзюки умирают тихо, без бахов. тут, скорее всего. не успела сработать защита по току
Dr. Санчес
Жалко видеть , когда испаряется результат долгих трудов .
Похоже что у алюминия ламинированного фольгированным стеклотекстолитом , недостаточная теплопроводность .
При сварке она ещё видимо более или менее , а при нагрузке на балласт , когда динамика тепловыделения на транзисторах сильно возрастает , тонкий слой текстолита не обеспечивает теплопередачу . Тут бы возможно
пригодился бы старый способ - сначала напаять на фольгу толстые медные пластинки , а уж на них - транзисторы .
delivero
Положительный результат не учит ничего. для алюминиевых пластин уже знаете.
Сейчас разработана новая Ver.3 материнской платы. радиатор транзисторов увеличилось на 270 квадратных сантиметров для каждого плечо.
Так что тест еще раз в ближайшее время. Надежность превыше всего. иначе мы будем китайцами.
