Страницы: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134, 135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170, 171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206, 207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242, 243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 256, 257, 258, 259, 260, 261, 262, 263, 264, 265, 266, 267, 268, 269, 270, 271, 272, 273, 274, 275, 276, 277, 278, 279, 280, 281, 282, 283, 284, 285, 286, 287, 288, 289, 290, 291, 292, 293, 294, 295, 296, 297, 298, 299, 300, 301, 302, 303, 304, 305, 306, 307, 308, 309, 310, 311, 312, 313, 314, 315, 316, 317, 318, 319, 320, 321, 322, 323, 324, 325, 326, 327, 328, 329, 330, 331, 332, 333, 334, 335, 336, 337, 338, 339, 340, 341, 342, 343, 344, 345, 346, 347, 348, 349, 350, 351, 352, 353, 354, 355, 356, 357, 358, 359, 360, 361, 362, 363, 364, 365, 366, 367, 368, 369, 370, 371, 372, 373, 374, 375, 376, 377, 378, 379, 380, 381, 382, 383, 384, 385, 386, 387, 388, 389, 390, 391, 392, 393, 394, 395, 396, 397, 398, 399, 400, 401, 402, 403, 404, 405, 406, 407, 408, 409, 410, 411, 412, 413, 414, 415, 416, 417, 418, 419, 420, 421, 422, 423, 424, 425, 426, 427, 428, 429, 430, 431, 432, 433, 434, 435, 436, 437, 438, 439, 440, 441, 442, 443, 444, 445, 446, 447, 448, 449, 450, 451, 452, 453, 454, 455, 456, 457, 458, 459, 460
nikon
Цитата(Serg SP @ 23.3.2013, 15:00) *
При наличии истокового резистора как датчика тока будет не просто защита, а поцикловое ограничение тока. Защиту с перезапуском обеспечивает обмотка самопитания на трансформаторе. При козе в нагрузке напряжение на выходе этой обмотки падает ниже порога работы UC3845 и иип "зудит", пытаясь запуститься, пока не будет ликвидирована коза.
Тогда логично предположить что защита по шунту и не нужна, а как же запитка микросхемы от 300 вольт, оно что при козе тоже падает?
Цитата(Серёгин @ 23.3.2013, 17:10) *
Да , интересно было посмотреть .Это та которая на микроконтроллере .А схему можно взглянуть ?
http://www.electrik.org/forum/index.php?showtopic=25898 Вот тут на первой странице есть все схема, печатки, прошивки.
Серёгин
[/quote]
Спасибо .Я эту схему уже видел . А эта схема на PIC кроме горячего старта и регулировки тока , что-то ещё выполняет ?Там вроде ещё какая то функция есть ?
Серёгин
Цитата(nikon @ 23.3.2013, 18:32) *
Это не PIK а ATmel , управляет ветродуем, реле зарядки, антистык, форсаж, отключение при перегреве с индикацией температуры, сбавляет заполнение на ХХ. Почитай, вникни, собери и другого ничего не захочется.
Ну я немного не так выразился , по поводу PIC или AVR , я только начинаю работать с ними .А режимов много , неплохо .По поводу сборки , вряд ли я буду его собирать .
Серёгин
Серёгин я тоже так думал, а вот уже развел плату управы и вытравил. Силу использую ту, что в рабочем аппарате. Правда драйвера хочу попробовать на оптике и для этого сделаю другую дежурку. Если понравится, как будет идти процесс сварки, оставлю ее. В ней больше сервиса, чем в моей теперешней. К хорошему привыкаешь быстро.
[/quote]
Я всё понимаю .Но для хорошего сварщика никакие приблуды не нужны ! Я про то , что когда я первый раз в руки взял держак , я был в возрасте 15 лет ,это был 300 амперный комбайн с регулировкой (все такой знают).
Я конечно тогда ничего не понимал в этом. Но когда я собрал первого Бармалейника ,ничего себя как варит. я подумал , что не надо быть сварщиком , чтобы варить ,я конечно ошибался . icon_biggrin.gif .Но сейчас столько разных схем , собирай на свой вкус и на свои потребности .
Серёгин
Цитата(nikon @ 23.3.2013, 19:07) *
Конечно если собирать в коммерческих целях то отходить от стереотипов накладно, кто же собирает для души тот поймет.
В том то всё дело , я собираю не на продажу а чисто из за интереса к конструктивному исполнению. .
Я же радиолюбитель .
Серёгин
Цитата(nikon @ 23.3.2013, 19:23) *
Тогда скоро будешь собирать эту схему, я год собирался.
Нет , у меня к ней душа не лежит .Я больше склоняюсь к Липину или к баласнику . А может уже больше не буду собирать инверторы .
Vs55
Серёгин, да, вот так и получается, когда ради интереса собираешь только для себя, то собрав один аппарат, уже задумываешься - а зачем мне еще один сварочник, если уже есть и вроде бы все устраивает. Да и домашние могут не понять для чего это нужно. А все равно интерес не ослабевает.
Серёгин
Вот вот .Так и получается .И что дальше делать ? Собирать ещё ? А зачем ? А интерес всё больше и больше !
Wasiliy61
Товарищи подскажите,мой импульсник даёт 13.5в-мне надо бы 15в.На истоке кп707 стоит двух анодный стабилитрон, на вид как кс175,но на нём ни чего не написанно а только 3 чёрных полосы. Кто знает что это за стабилитрон. хотел подобрать его,чтобы получить 15в, или подобрать реристор, через который он идёт на исток.
Серёгин
Для начала найди описание микросхемы .Может в ней есть регулировка .Вроде бы она...
sergey777.68
Ели собираешься делать сварочник то забудь про этот блок питания.Делай как все .Учись на чужих ошибках.
Wasiliy61
Спасибо, что то общее есть. Попробую перед стабилитроном резистор подобрать или подстроичник поставить.
Серёгин
Там есть вроде бы возможность регулировки на 1 ноге.Посмотрите внимательно по схеме и по плате .
Wasiliy61
Я хотел делать, просто не нашёл ТОР, так есть резон этот попробывать довести до ума.
Ной
Это не ленинский путь.
Wasiliy61
В плате нет подстроичного резистора. Стабилитрон так же идёт на 1 ногу,так что регулировку можно попробывать сделать.
Серёгин
Ну да ,это не тот путь .Это как у китайских комсомольцев , сами создаем себе трудности и сами их героически решаем . icon_biggrin.gif
Можно попробовать по 6 ноге .Это питание с сервисной обмотки , питание микросхемы во время работы.
Wasiliy61
Цитата(Серёгин @ 23.3.2013, 23:40) *
Можно попробовать по 6 ноге .Это как раз питание с сервисной обмотки .
В принципе можно 47к убавить, я ещё не знаю какое у меня здесь стоит. А на первой ноге а меня как на схеме 2.2 к.
Серёгин
Мне кажется не надо трогать 47 килоом, это вроде начальный пуск . Надо по 1 ноге пробовать.
Wasiliy61
Тем более по 6 ноге у меня различие со схемой.
Серёгин
ну это же не родная схема .Может вам лучше другой блок питания сделать ?
KT117
Подскажите, люди знающие. Ограничение ХХ ШИМ Кабельщика (поцикловка) кто применяет? Как себя ведет и оправдывает назначение? Как дуга с ней зажигается-тяжелее, легче? (Пытался осилить 3 часть-но здоровья не хватает icon_smile.gif )
ГонZZа
Вечер добрый.Серёгин,меня бы родственники не поняли,если бы все 8 аппаратов я принёс домой и поставил в стенку(в большой комнате).Первый аппарат(в чёрном чемоданчике от дрели),я хотел оставить себе,но когда его увидели на работе,чуть не отобрали силой,сказали,что себе сделаю ещё!После этого и понеслась,обычно заказчик приходит не один,а приводит очередного клиента.Себе я так инвертор и не сделал,в гараже есть самодельный трансформаторный аппарат(в корпусе от монитора).
KT117,я пробовал делать блок от Толяна,там и ХХод глушит и залип,работает ХОРОШО!
Vs55
KT117, поцикловка от Кабельщика предназначена для применения короткого транса, он тогда все описывал и были рекомендации по ее настройке с осциллами. У меня его управа, работает прекрасно.
Wasiliy61, если у Вас схема похожа на ту, что дал Серёгин, то поменяйте стабилитрон по 1 ноге на КС168. Если при этом не будет превышено питание управляющей микросхемы.
Wasiliy61
Благодарю за схему, по 1 ноге добавил подстроичник 1к -регулирует аж до 17 в.
Серёгин
Значит вы на верном пути .Ещё бы измерить при каком токе он нормально стартует и какой
максимальный ток держит.
KT117
Описание и настройку я читал, но не видел широкого применения в сварочниках (косых) , вот и интересуюсь работой. Стоит заморачиваться ( хотя там всего с пяток деталей) или продолжать действовать по принципу-раз работает, то не стоит лишний раз отверткой ковырять ?
Wasiliy61
спасибо за совет. я пробовал 110в не запускается. 150 работает отлично,точно не могу сказать .нет латора. Нашёл дома авто-транс лет 20-30 назад мотал на работе . Он мотан одной обмоткой 0-40-80-110 -150-180-220 а дальше эта-же обмотка идёт на повышение вольт до 300.
Серёгин
Подключите с нагрузкой амперметр ампер на 5-10 и постепенно добавляйте нагрузку и выйдите на максимальный ток.Лучше это измерять на напруге 150-200 вольт , то есть проверить как он держит нагрузку при просадке сети.
Wasiliy61
Да я пробовал при 150 вольтах 2а нагрузкку работает также как и при220в.
Серёгин
А какое падение напряжения на выходе при 2 амперах ? Сначала подключите малую нагрузку , типа вентилятора и вольтметр а потом подключите уже большую нагрузку и увидите падение .
Castiel
Ребята помогите не могу разобраться с трансформаторами.!!!
Из Тр3. 1-18 витков ПЭВ 5х1, 2мм. что это значит?. я думаю так что взять 5 дротиков 1,2мм и сложить вместе и мотать так да? И вторичка 6-витков: ПЭВ 65х0, 6мм. Так же взять 65 жил вместе диаметром провода 0,6мм и намотать 6-вит. то это выходит где-то 16мм2 вторичка???
И транса Тт2 так же мотать как Тт1-го взять 2 шт: к20х10х5 розламать пополам и клеем склеит намотать 100вит. 0,2мм. и одним витком мотнут от первички Тр3-го .Так надо сделает?
Др.1 котором можно дротом мотнут вместо полоси?
Wasiliy61
Да практически не заметно, чуть чуть стрелка качьнётся и всё, а с 1а нагрузкой вообше стрелка не шевелится. Да там сидеть-то будет один шим да реле с задержкой.
KT117
Castiel Дата Сегодня, 22:31
Уменьшено до 83%
561 x 518 (44.85 килобайт)
да, принцип вы поняли правильный. Но провод можно брать любой подходящий. Сечение первички должно быть 4-5кв.мм. , вторички-12-16 кв.мм. Мотают даже медной лентой толщиной 0.2-0.5 мм шириной 32-34мм.
Посмотри рядом ветки-есть про трансформаторы
В кольцо ТТ продевается провод от первички силового транса. (или перемычка из провода 4-5кв.мм. на печатной плате делается и на нее одевается кольцо, зависит от конструктива)
Силовой транс можно мотать на разных сердечниках, особо легко получаются на кольцах R63, посмотри по Липинскому в этой ветке http://www.electrik.org/forum/index.php?sh...44&st=11439
Я дроссель мотаю жилой ПВ3 16кв.мм. очищеной от изоляции и одетой в термоусадку на кольцах или из альсифера или из распыленного железа, можно и на Н-из сердечников от строчников, но там нужно будет с ориентацией в пространстве поиграться, что бы наводок дроссель не давал на управу.
Vs55
KT117, если у Вас сварочник уже собран и нормально работает, то не вижу смысла добавлять в него поцикловку. У меня изначально управа от ув. Кабельщика с поцикловкой, аркфорсом, хотстартом и антистиком. Транс на ЕТД59 не 35/10, а 26/8. Потому поцикловка и имеет смысл.
KT117
Сварочник работает, но транс сделан на каком то левом феррите , продали как Епкос Е65, маркировки нет, на хх греется, да и при работе то же. Свои 120А отрабатывает честно, ПВ 60%. Частота 55000Гц, заполнение 0,42. Просто думаю, что лучше-оставить так и прикрутить поцикловку или заменить транс на кольцо .
mer59
Цитата(KT117 @ 23.3.2013, 22:30) *
Сварочник работает, но на хх греется, да и при работе то же. Свои 120А отрабатывает честно, ПВ 60%. Частота 55000Гц, заполнение 0,42. Просто думаю, что лучше-оставить так и прикрутить поцикловку или заменить транс на кольцо .
У поцикловки есть еще один плюс,кроме короткого транса.Чтобы на холостом ходу не грелся.заводим с выхода обратную связь в схему поцикловки с задержкой несколько секунд через оптрон и ораничиваем выходное напряжение,скажем 12В,соответветственно укорачивается время импульса,ну и ток намагничевания заодно.В дежурном режиме по ключам болтаются импульсы в 200-300мА,все холодное.
Электродом коснуся,обр. связь откинулась,импульс полный сколько позволит схема поцикловки.
and_w
Так можно вобще взять кусок управы от Толяна. там если аппаратом не работают, то он спит, т.е. глушиться Шим и плюс антистик есть... Только отдельных +18В надо от деэжурки. Но, думаю домотать обмотку это не проблема... Сам ее хочу к бармалею привинтить.....
zato4nik
Уважаемые сваркостроители ,подскажите ,как можно уменьшить ток КЗ. По 3 ноге RC уменьшал , компенсацию наклона пробовал - не помогло.Управление бармалея , частота 80кГц ,дроссель 17мкГн (без тока) на распыленке.Регулировка тока работает при нагрузке на балластное сопротивление ,но при КЗ стрелка миллиамперметра на шунте 150А улетает до упора (переживаю как-бы не согнулась icon_biggrin.gif ). Может дроссель великоват?
зы сварочные концы по 2 метра.
nikon
Настраивается нагрузочным резистором ТТ, или витками того самого ТТ
KT117
Сравнил насыщение разных трансформаторов прибором Гумерова-Зуева.
Один трансформатор на кольце R63*32*25 34 витка, надпил на 3/4 и трансформатор на E70 14.5 витков, зазор 0.1мм
Напряжение питания прибора 15В , сигнал снимался с сопротивления 0.2 Ом.
Замерял попарно
Первый замер:
E70
R63
Чуть изменил настройки, второй замер:
E70
R63
Ну и сами подопытные
zato4nik
Пробовал резистор увеличить - уменьшается максимальный ток выставляемый задатчиком , ток КЗ не уменьшился (кз делаю пока на минимальном токе , все равно зашкаливает).
Попробовал дроссель 6мкГн ничего не изменилось.
tranzistor3102
какое сейчас нагрузочное сопротивление тт
Jorg63
конденсатор по 3 ноге какой стоит?Можете его уменьшить.
zato4nik
Как по схеме - 1,6Ом.
tranzistor3102
попробуйте увеличить до 3-4 ом посмотрите разницу если результат не изменится то скорее не исправна цепь ТТ
Vs55
zato4nik, Запитайте силу от ЛАТРа и посмотрите сигнал на 3 ноге UC3845. Если сигнал в норме, может проблема в ней?
nikon
Сигнал на 3 ноге меняется от 0 и до максимума в зависимости от заданного тока. По какому критерию смотреть сигнал, тем более сила запитана от латра. Разве только посмотреть на форму сигнала при подаче нагрузки.
KT117
Ток КЗ может достигать 200А, и превышает максимальный ток. Посмотрите в ветке по Юриному аппарату на Атмеге, там обсуждали это. Какой у вас максимальный ток на балласте?
Для корректного измерения тока возьмите шунт и головку на 200-250А
Серёгин
Суть вопроса не в том как и чем измерить ток .А прочему у него на минимальном токе ток КЗ превышает все рамки . У меня на минимальном токе ток КЗ показывает 30 ампер
